[OpenLayers-Commits] r11084 - in sandbox/elemoine/draw-feature:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Thu Feb 10 05:46:18 EST 2011
Author: erilem
Date: 2011-02-10 02:46:17 -0800 (Thu, 10 Feb 2011)
New Revision: 11084
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
sandbox/elemoine/draw-feature/tests/Handler/Path.html
make persist work for the path handler
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:46:08 UTC (rev 11083)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:46:17 UTC (rev 11084)
@@ -91,9 +91,6 @@
this.callback("create", [this.point.geometry, this.getSketch()]);
this.point.geometry.clearBounds();
- if(this.persist) {
- this.destroyFeature();
this.layer.addFeatures([this.line, this.point], {silent: true});
@@ -107,6 +104,17 @@
+ * Method: destroyPersistedFeature
+ * Destroy the persisted feature.
+ destroyPersistedFeature: function() {
+ var layer = this.layer;
+ if(layer && layer.features.length > 2) {
+ this.layer.features[0].destroy();
* Method: removePoint
* Destroy the temporary point.
@@ -274,6 +282,9 @@
this.finalize();
} else {
if(this.lastDown.equals(evt.xy)) {
+ if(this.lastUp == null && this.persist) {
+ this.destroyPersistedFeature();
this.addPoint(evt.xy);
this.lastUp = evt.xy;
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:46:08 UTC (rev 11083)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:46:17 UTC (rev 11084)
@@ -257,6 +257,62 @@
map.destroy();
+ function test_persist(t) {
+ t.plan(3);
+ var map = new OpenLayers.Map("map", {
+ resolutions: [1]
+ var layer = new OpenLayers.Layer.Vector("foo", {
+ maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+ isBaseLayer: true
+ map.addLayer(layer);
+ var control = new OpenLayers.Control({});
+ var handler = new OpenLayers.Handler.Path(control, {});
+ control.handler = handler;
+ map.addControl(control);
+ map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+ handler.activate();
+ handler.persist = false;
+ handler.mousedown(
+ {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+ handler.mouseup(
+ {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+ handler.mousemove(
+ {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+ handler.dblclick(
+ {type: "dblclick", xy: new OpenLayers.Pixel(1, 1)});
+ t.eq(handler.layer.features.length, 2,
+ "feature destroyed on dblclick when persist is false");
+ handler.persist = true;
+ handler.mouseup(
+ handler.dblclick(
+ var feature = handler.layer.features[0];
+ t.eq(handler.layer.features.length, 3,
+ "feature not destroyed on dblclick when persist is true");
+ handler.mouseup(
+ handler.dblclick(
+ t.ok(handler.layer.features[0] !== feature,
+ "persisted feature destroyed on next dblclick");
+ map.destroy();
function test_Handler_Path_destroy(t) {
t.plan(6);
var map = new OpenLayers.Map('map');
More information about the Commits
