[OpenLayers-Commits] r11087 - in sandbox/elemoine/draw-feature:
lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org
Thu Feb 10 05:46:40 EST 2011
Author: erilem
Date: 2011-02-10 02:46:40 -0800 (Thu, 10 Feb 2011)
New Revision: 11087
sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
sandbox/elemoine/draw-feature/tests/Handler/Path.html
path handler - do not call modifyFeature on mousedown
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:46:31 UTC (rev 11086)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js 2011-02-10 10:46:40 UTC (rev 11087)
@@ -231,7 +231,6 @@
this.mouseDown = true;
this.lastDown = evt.xy;
- this.modifyFeature(evt.xy);
if (this.freehandMode(evt)) {
return false;
} else {
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:46:31 UTC (rev 11086)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html 2011-02-10 10:46:40 UTC (rev 11087)
@@ -93,6 +93,7 @@
var activated = handler.activate();
var evt = {xy: new OpenLayers.Pixel(150, 75), which: 1};
+ handler.mousemove(evt);
handler.mousedown(evt);
handler.mouseup(evt);
var evt = {xy: new OpenLayers.Pixel(175, 100), which: 1};
@@ -115,7 +116,7 @@
function test_callbacks(t) {
- t.plan(36);
+ t.plan(37);
var map = new OpenLayers.Map("map", {
resolutions: [1]
@@ -156,16 +157,20 @@
"[activate] correct point");
t.ok(log.args[1] == handler.line,
"[activate] correct feature");
+ // mouse move
+ {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+ t.eq(logs.length, 1, "[mousemove] called back");
+ log = logs.shift();
+ t.eq(log.type, "modify", "[mousemove] modify called");
+ t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75),
+ "[mousemove] correct point");
+ t.ok(log.args[1] === handler.line,
+ "[mousemove] correct feature");
// mouse down
handler.mousedown(
- t.eq(logs.length, 1, "[mousedown] called back");
- log = logs.shift();
- t.eq(log.type, "modify", "[mousedown] modify called");
- t.geom_eq(log.args[0], new OpenLayers.Geometry.Point(-150, 75),
- "[mousedown] correct point");
- t.ok(log.args[1] == handler.line,
- "[mousedown] correct feature");
+ t.eq(logs.length, 0, "[mousedown] not called back");
// mouse up
handler.mouseup({type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
t.eq(logs.length, 2, "[mouseup] called back twice");
@@ -204,18 +209,17 @@
- // mouse down ("modify")
+ // mouse down
handler.mousedown({type: "mousedown",
xy: new OpenLayers.Pixel(10, 10)});
// mouse up ("point", "modify")
log = logs.shift();
log = logs.shift();
+ // mouse down
More information about the Commits
