[OpenLayers-Commits] r11106 - in sandbox/elemoine/draw-feature:
	lib/OpenLayers/Handler tests/Handler
    commits-20090109 at openlayers.org
    Fri Feb 11 15:53:55 EST 2011
Author: erilem
Date: 2011-02-11 12:53:55 -0800 (Fri, 11 Feb 2011)
New Revision: 11106
   sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
   sandbox/elemoine/draw-feature/tests/Handler/Path.html
path handler - make freehand and persist play well together, thanks jorix for catching the problem
Modified: sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js
--- sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-11 15:40:39 UTC (rev 11105)
+++ sandbox/elemoine/draw-feature/lib/OpenLayers/Handler/Path.js	2011-02-11 20:53:55 UTC (rev 11106)
@@ -233,6 +233,10 @@
         this.mouseDown = true;
         this.lastDown = evt.xy;
         if (this.freehandMode(evt)) {
+            if(this.persist) {
+                this.destroyPersistedFeature();
+            this.addPoint(evt.xy);
             return false;
         } else {
             return !this.stopDown;
Modified: sandbox/elemoine/draw-feature/tests/Handler/Path.html
--- sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-11 15:40:39 UTC (rev 11105)
+++ sandbox/elemoine/draw-feature/tests/Handler/Path.html	2011-02-11 20:53:55 UTC (rev 11106)
@@ -327,6 +327,68 @@
         map.destroy();
+    function test_persist_freehand(t) {
+        t.plan(3);
+        var map = new OpenLayers.Map("map", {
+            resolutions: [1]
+        var layer = new OpenLayers.Layer.Vector("foo", {
+            maxExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+            isBaseLayer: true
+        map.addLayer(layer);
+        var control = new OpenLayers.Control({});
+        var handler = new OpenLayers.Handler.Path(control, {}, {freehand: true});
+        control.handler = handler;
+        map.addControl(control);
+        map.setCenter(new OpenLayers.LonLat(0, 0), 0);
+        handler.activate();
+        handler.persist = false;
+        handler.mousemove(
+            {type: "mousemove", xy: new OpenLayers.Pixel(0, 0)});
+        handler.mousedown(
+            {type: "mousedown", xy: new OpenLayers.Pixel(0, 0)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(1, 1)});
+            {type: "mousemove", xy: new OpenLayers.Pixel(2, 2)});
+        handler.mouseup(
+            {type: "mouseup", xy: new OpenLayers.Pixel(0, 0)});
+        t.eq(handler.layer.features.length, 2,
+             "feature destroyed on mouseup when persist is false");
+        handler.persist = true;
+        handler.mouseup(
+        var feature = handler.layer.features[0];
+        t.eq(handler.layer.features.length, 3,
+             "feature not destroyed on mouseup when persist is true");
+        handler.mouseup(
+        t.ok(handler.layer.features[0] !== feature,
+             "persisted feature destroyed on next mouseup");
+        map.destroy();
     function test_Handler_Path_destroy(t) {
         t.plan(6);
         var map = new OpenLayers.Map('map');
More information about the Commits
