[OpenLayers-Commits] r11118 - in trunk/openlayers:
lib/OpenLayers/Layer lib/OpenLayers/Layer/Google tests/Layer/Google
commits-20090109 at openlayers.org
Mon Feb 14 08:10:39 EST 2011
Author: ahocevar
Date: 2011-02-14 05:10:39 -0800 (Mon, 14 Feb 2011)
New Revision: 11118
trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
trunk/openlayers/lib/OpenLayers/Layer/SphericalMercator.js
trunk/openlayers/lib/OpenLayers/Layer/XYZ.js
trunk/openlayers/tests/Layer/Google/v3.html
use the correct maxResolution of 156543.03390625. r=bartvde (closes #3058)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
--- trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-02-14 12:07:02 UTC (rev 11117)
+++ trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-02-14 13:10:39 UTC (rev 11118)
@@ -26,13 +26,13 @@
* (code)
* maxExtent: new OpenLayers.Bounds(
- * -128 * 156543.0339,
- * 128 * 156543.0339,
+ * -128 * 156543.03390625,
+ * 128 * 156543.03390625,
* sphericalMercator: true,
- * maxResolution: 156543.0339,
+ * maxResolution: 156543.03390625,
* units: "m",
* projection: "EPSG:900913"
@@ -40,13 +40,13 @@
DEFAULTS: {
- -128 * 156543.0339,
- 128 * 156543.0339,
- 128 * 156543.0339
+ -128 * 156543.03390625,
+ 128 * 156543.03390625,
- maxResolution: 156543.0339,
+ maxResolution: 156543.03390625,
units: "m",
Modified: trunk/openlayers/lib/OpenLayers/Layer/SphericalMercator.js
--- trunk/openlayers/lib/OpenLayers/Layer/SphericalMercator.js 2011-02-14 12:07:02 UTC (rev 11117)
+++ trunk/openlayers/lib/OpenLayers/Layer/SphericalMercator.js 2011-02-14 13:10:39 UTC (rev 11118)
@@ -95,7 +95,7 @@
initMercatorParameters: function() {
// set up properties for Mercator - assume EPSG:900913
this.RESOLUTIONS = [];
- var maxResolution = 156543.0339;
+ var maxResolution = 156543.03390625;
for(var zoom=0; zoom<=this.MAX_ZOOM_LEVEL; ++zoom) {
this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
Modified: trunk/openlayers/lib/OpenLayers/Layer/XYZ.js
--- trunk/openlayers/lib/OpenLayers/Layer/XYZ.js 2011-02-14 12:07:02 UTC (rev 11117)
+++ trunk/openlayers/lib/OpenLayers/Layer/XYZ.js 2011-02-14 13:10:39 UTC (rev 11118)
@@ -65,12 +65,12 @@
if (options && options.sphericalMercator || this.sphericalMercator) {
options = OpenLayers.Util.extend({
- 128 * 156543.0339
numZoomLevels: 19,
units: "m",
Modified: trunk/openlayers/tests/Layer/Google/v3.html
--- trunk/openlayers/tests/Layer/Google/v3.html 2011-02-14 12:07:02 UTC (rev 11117)
+++ trunk/openlayers/tests/Layer/Google/v3.html 2011-02-14 13:10:39 UTC (rev 11118)
@@ -3,6 +3,7 @@
<script src="http://maps.google.com/maps/api/js?sensor=false"></script>
<script src="../../../lib/OpenLayers.js"></script>
<script type="text/javascript">
var layer;
function test_Layer_Google_constructor (t) {
@@ -265,6 +266,12 @@
t.plan(8);
+ var origPrecision = OpenLayers.Util.DEFAULT_PRECISION;
+ // GMaps v3 seems to use a default precision of 13, which is lower
+ // than what we use in OpenLayers.
+ // See http://trac.osgeo.org/openlayers/ticket/3059
+ OpenLayers.Util.DEFAULT_PRECISION = 13;
var map = new OpenLayers.Map('map', {allOverlays: true});
var gmap = new OpenLayers.Layer.Google("Google Streets");
@@ -275,16 +282,18 @@
map.setCenter(origin, 4);
var resolution = map.getResolution();
- var dx, dy, center, expectedX, expectedY;
+ var dx, dy, center, expected;
// confirm that panning works with Google visible
dx = 100, dy = -100;
map.pan(dx, dy, {animate: false});
center = map.getCenter();
- expectedX = origin.lon + (resolution * dx);
- expectedY = origin.lat - (resolution * dy);
- t.eq(center.lon, expectedX, "x panning with Google visible " + dx + ", " + dy);
- t.eq(center.lat, expectedY, "y panning with Google visible " + dx + ", " + dy);
+ expected = new OpenLayers.LonLat(
+ origin.lon + (resolution * dx),
+ origin.lat - (resolution * dy)
+ t.eq(center.lon, expected.lon, "x panning with Google visible " + dx + ", " + dy);
+ t.eq(center.lat, expected.lat, "y panning with Google visible " + dx + ", " + dy);
map.pan(-dx, -dy, {animate: false});
t.eq(center.lon, origin.lon, "x panning with Google visible " + (-dx) + ", " + (-dy));
@@ -295,22 +304,30 @@
- t.eq(center.lon, expectedX, "x panning with Google invisible " + dx + ", " + dy);
- t.eq(center.lat, expectedY, "y panning with Google invisible " + dx + ", " + dy);
+ t.eq(center.lon, expected.lon, "x panning with Google invisible " + dx + ", " + dy);
+ t.eq(center.lat, expected.lat, "y panning with Google invisible " + dx + ", " + dy);
t.eq(center.lon, origin.lon, "x panning with Google invisible " + (-dx) + ", " + (-dy));
t.eq(center.lat, origin.lat, "y panning with Google invisible " + (-dx) + ", " + (-dy));
map.destroy();
+ OpenLayers.Util.DEFAULT_PRECISION = origPrecision;
function test_wrapDateLine(t) {
t.plan(2);
var map = new OpenLayers.Map("map");
@@ -322,14 +339,15 @@
// pan to the edge of the world
map.pan(256, 0, {animate: false});
- t.eq(center.lon, 20037508.3392, "edge of the world");
+ t.eq(center.lon, 20037508.34, "edge of the world");
// pan off the edge of the world
map.pan(100, 0, {animate: false});
- t.eq(center.lon, -12210356.6442, "magically back in the western hemisphere");
+ var expect = OpenLayers.Util.toFloat(100 * map.getResolution() - 20037508.34);
+ t.eq(center.lon, expect, "magically back in the western hemisphere");
map.destroy();
function test_respectDateLine(t) {
@@ -346,16 +364,16 @@
- t.eq(center.lon, 20037508.3392, "whew, still on the edge");
+ t.eq(center.lon, 20037508.34, "whew, still on the edge");
map.destroy();
</script>
</head>
<body>
More information about the Commits
