[OpenLayers-Commits] r11136 - in trunk/openlayers: lib tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 17 14:54:11 EST 2011
Author: erilem
Date: 2011-02-17 11:54:11 -0800 (Thu, 17 Feb 2011)
New Revision: 11136
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/tests/Util.html
   trunk/openlayers/tests/list-tests.html
allow custom jsfiles array, r=tschaub (closes #2947)
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-02-17 15:25:28 UTC (rev 11135)
+++ trunk/openlayers/lib/OpenLayers.js	2011-02-17 19:54:11 UTC (rev 11136)
@@ -29,7 +29,28 @@
      * Relative path of this script.
     var scriptName = (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js";
+     * If window.OpenLayers isn't set when this script (OpenLayers.js) is
+     * evaluated (and if singleFile is false) then this script will load
+     * *all* OpenLayers scripts. If window.OpenLayers is set to an array
+     * then this script will attempt to load scripts for each string of
+     * the array, using the string as the src of the script.
+     * Example:
+     * (code)
+     *     <script type="text/javascript">
+     *         window.OpenLayers = [
+     *             "OpenLayers/Util.js",
+     *             "OpenLayers/BaseTypes.js"
+     *     </script>
+     *     <script type="text/javascript" src="../lib/OpenLayers.js"></script>
+     * (end)
+     * In this example OpenLayers.js will load Util.js and BaseTypes.js only.
+    var jsFiles = window.OpenLayers;
      * Namespace: OpenLayers
      * The OpenLayers object provides a namespace for all things OpenLayers
@@ -60,6 +81,7 @@
             return (function() { return l; });
      * OpenLayers.singleFile is a flag indicating this file is being included
      * in a Single File Library build of the OpenLayers Library.
@@ -71,260 +93,264 @@
      * OpenLayers library code as it will be appended at the end of this file.
     if(!singleFile) {
-        var jsfiles = new Array(
-            "OpenLayers/BaseTypes/Class.js",
-            "OpenLayers/Util.js",
-            "OpenLayers/BaseTypes.js",
-            "OpenLayers/BaseTypes/Bounds.js",
-            "OpenLayers/BaseTypes/Element.js",
-            "OpenLayers/BaseTypes/LonLat.js",
-            "OpenLayers/BaseTypes/Pixel.js",
-            "OpenLayers/BaseTypes/Size.js",
-            "OpenLayers/Console.js",
-            "OpenLayers/Tween.js",
-            "Rico/Corner.js",
-            "Rico/Color.js",
-            "OpenLayers/Ajax.js",
-            "OpenLayers/Events.js",
-            "OpenLayers/Request.js",
-            "OpenLayers/Request/XMLHttpRequest.js",
-            "OpenLayers/Projection.js",
-            "OpenLayers/Map.js",
-            "OpenLayers/Layer.js",
-            "OpenLayers/Icon.js",
-            "OpenLayers/Marker.js",
-            "OpenLayers/Marker/Box.js",
-            "OpenLayers/Popup.js",
-            "OpenLayers/Tile.js",
-            "OpenLayers/Tile/Image.js",
-            "OpenLayers/Tile/Image/IFrame.js",
-            "OpenLayers/Tile/WFS.js",
-            "OpenLayers/Layer/Image.js",
-            "OpenLayers/Layer/SphericalMercator.js",
-            "OpenLayers/Layer/EventPane.js",
-            "OpenLayers/Layer/FixedZoomLevels.js",
-            "OpenLayers/Layer/Google.js",
-            "OpenLayers/Layer/Google/v3.js",
-            "OpenLayers/Layer/VirtualEarth.js",
-            "OpenLayers/Layer/Yahoo.js",
-            "OpenLayers/Layer/HTTPRequest.js",
-            "OpenLayers/Layer/Grid.js",
-            "OpenLayers/Layer/MapGuide.js",
-            "OpenLayers/Layer/MapServer.js",
-            "OpenLayers/Layer/MapServer/Untiled.js",
-            "OpenLayers/Layer/KaMap.js",
-            "OpenLayers/Layer/KaMapCache.js",
-            "OpenLayers/Layer/MultiMap.js",
-            "OpenLayers/Layer/Markers.js",
-            "OpenLayers/Layer/Text.js",
-            "OpenLayers/Layer/WorldWind.js",
-            "OpenLayers/Layer/ArcGIS93Rest.js",
-            "OpenLayers/Layer/WMS.js",
-            "OpenLayers/Layer/WMS/Untiled.js",
-            "OpenLayers/Layer/WMS/Post.js",
-            "OpenLayers/Layer/WMTS.js",
-            "OpenLayers/Layer/ArcIMS.js",
-            "OpenLayers/Layer/GeoRSS.js",
-            "OpenLayers/Layer/Boxes.js",
-            "OpenLayers/Layer/XYZ.js",
-            "OpenLayers/Layer/Bing.js",
-            "OpenLayers/Layer/TMS.js",
-            "OpenLayers/Layer/TileCache.js",
-            "OpenLayers/Layer/Zoomify.js",
-            "OpenLayers/Popup/Anchored.js",
-            "OpenLayers/Popup/AnchoredBubble.js",
-            "OpenLayers/Popup/Framed.js",
-            "OpenLayers/Popup/FramedCloud.js",
-            "OpenLayers/Feature.js",
-            "OpenLayers/Feature/Vector.js",
-            "OpenLayers/Feature/WFS.js",
-            "OpenLayers/Handler.js",
-            "OpenLayers/Handler/Click.js",
-            "OpenLayers/Handler/Hover.js",
-            "OpenLayers/Handler/Point.js",
-            "OpenLayers/Handler/Path.js",
-            "OpenLayers/Handler/Polygon.js",
-            "OpenLayers/Handler/Feature.js",
-            "OpenLayers/Handler/Drag.js",
-            "OpenLayers/Handler/RegularPolygon.js",
-            "OpenLayers/Handler/Box.js",
-            "OpenLayers/Handler/MouseWheel.js",
-            "OpenLayers/Handler/Keyboard.js",
-            "OpenLayers/Control.js",
-            "OpenLayers/Control/Attribution.js",
-            "OpenLayers/Control/Button.js",
-            "OpenLayers/Control/ZoomBox.js",
-            "OpenLayers/Control/ZoomToMaxExtent.js",
-            "OpenLayers/Control/DragPan.js",
-            "OpenLayers/Control/Navigation.js",
-            "OpenLayers/Control/MouseDefaults.js",
-            "OpenLayers/Control/MousePosition.js",
-            "OpenLayers/Control/OverviewMap.js",
-            "OpenLayers/Control/KeyboardDefaults.js",
-            "OpenLayers/Control/PanZoom.js",
-            "OpenLayers/Control/PanZoomBar.js",
-            "OpenLayers/Control/ArgParser.js",
-            "OpenLayers/Control/Permalink.js",
-            "OpenLayers/Control/Scale.js",
-            "OpenLayers/Control/ScaleLine.js",
-            "OpenLayers/Control/Snapping.js",
-            "OpenLayers/Control/Split.js",
-            "OpenLayers/Control/LayerSwitcher.js",
-            "OpenLayers/Control/DrawFeature.js",
-            "OpenLayers/Control/DragFeature.js",
-            "OpenLayers/Control/ModifyFeature.js",
-            "OpenLayers/Control/Panel.js",
-            "OpenLayers/Control/SelectFeature.js",
-            "OpenLayers/Control/NavigationHistory.js",
-            "OpenLayers/Control/Measure.js",
-            "OpenLayers/Control/WMSGetFeatureInfo.js",
-            "OpenLayers/Control/WMTSGetFeatureInfo.js",
-            "OpenLayers/Control/Graticule.js",
-            "OpenLayers/Control/TransformFeature.js",
-            "OpenLayers/Control/SLDSelect.js",
-            "OpenLayers/Geometry.js",
-            "OpenLayers/Geometry/Rectangle.js",
-            "OpenLayers/Geometry/Collection.js",
-            "OpenLayers/Geometry/Point.js",
-            "OpenLayers/Geometry/MultiPoint.js",
-            "OpenLayers/Geometry/Curve.js",
-            "OpenLayers/Geometry/LineString.js",
-            "OpenLayers/Geometry/LinearRing.js",
-            "OpenLayers/Geometry/Polygon.js",
-            "OpenLayers/Geometry/MultiLineString.js",
-            "OpenLayers/Geometry/MultiPolygon.js",
-            "OpenLayers/Geometry/Surface.js",
-            "OpenLayers/Renderer.js",
-            "OpenLayers/Renderer/Elements.js",
-            "OpenLayers/Renderer/SVG.js",
-            "OpenLayers/Renderer/Canvas.js",
-            "OpenLayers/Renderer/VML.js",
-            "OpenLayers/Layer/Vector.js",
-            "OpenLayers/Layer/Vector/RootContainer.js",
-            "OpenLayers/Strategy.js",
-            "OpenLayers/Strategy/Filter.js",
-            "OpenLayers/Strategy/Fixed.js",
-            "OpenLayers/Strategy/Cluster.js",
-            "OpenLayers/Strategy/Paging.js",
-            "OpenLayers/Strategy/BBOX.js",
-            "OpenLayers/Strategy/Save.js",
-            "OpenLayers/Strategy/Refresh.js",
-            "OpenLayers/Filter.js",
-            "OpenLayers/Filter/FeatureId.js",
-            "OpenLayers/Filter/Logical.js",
-            "OpenLayers/Filter/Comparison.js",
-            "OpenLayers/Filter/Spatial.js",
-            "OpenLayers/Protocol.js",
-            "OpenLayers/Protocol/HTTP.js",
-            "OpenLayers/Protocol/SQL.js",
-            "OpenLayers/Protocol/SQL/Gears.js",
-            "OpenLayers/Protocol/WFS.js",
-            "OpenLayers/Protocol/WFS/v1.js",
-            "OpenLayers/Protocol/WFS/v1_0_0.js",
-            "OpenLayers/Protocol/WFS/v1_1_0.js",
-            "OpenLayers/Protocol/SOS.js",
-            "OpenLayers/Protocol/SOS/v1_0_0.js",
-            "OpenLayers/Layer/PointTrack.js",
-            "OpenLayers/Layer/GML.js",
-            "OpenLayers/Style.js",
-            "OpenLayers/Style2.js",
-            "OpenLayers/StyleMap.js",
-            "OpenLayers/Rule.js",
-            "OpenLayers/Format.js",
-            "OpenLayers/Format/XML.js",
-            "OpenLayers/Format/Context.js",
-            "OpenLayers/Format/ArcXML.js",
-            "OpenLayers/Format/ArcXML/Features.js",
-            "OpenLayers/Format/GML.js",
-            "OpenLayers/Format/GML/Base.js",
-            "OpenLayers/Format/GML/v2.js",
-            "OpenLayers/Format/GML/v3.js",
-            "OpenLayers/Format/Atom.js",
-            "OpenLayers/Format/KML.js",
-            "OpenLayers/Format/GeoRSS.js",
-            "OpenLayers/Format/WFS.js",
-            "OpenLayers/Format/WFSCapabilities.js",
-            "OpenLayers/Format/WFSCapabilities/v1.js",
-            "OpenLayers/Format/WFSCapabilities/v1_0_0.js",
-            "OpenLayers/Format/WFSCapabilities/v1_1_0.js",
-            "OpenLayers/Format/WFSDescribeFeatureType.js",
-            "OpenLayers/Format/WMSDescribeLayer.js",
-            "OpenLayers/Format/WMSDescribeLayer/v1_1.js",
-            "OpenLayers/Format/WKT.js",
-            "OpenLayers/Format/CQL.js",
-            "OpenLayers/Format/OSM.js",
-            "OpenLayers/Format/GPX.js",
-            "OpenLayers/Format/Filter.js",
-            "OpenLayers/Format/Filter/v1.js",
-            "OpenLayers/Format/Filter/v1_0_0.js",
-            "OpenLayers/Format/Filter/v1_1_0.js",
-            "OpenLayers/Format/SLD.js",
-            "OpenLayers/Format/SLD/v1.js",
-            "OpenLayers/Format/SLD/v1_0_0.js",
-            "OpenLayers/Format/OWSCommon/v1.js",
-            "OpenLayers/Format/OWSCommon/v1_0_0.js",
-            "OpenLayers/Format/OWSCommon/v1_1_0.js",
-            "OpenLayers/Format/CSWGetDomain.js",
-            "OpenLayers/Format/CSWGetDomain/v2_0_2.js",
-            "OpenLayers/Format/CSWGetRecords.js",
-            "OpenLayers/Format/CSWGetRecords/v2_0_2.js",
-            "OpenLayers/Format/WFST.js",
-            "OpenLayers/Format/WFST/v1.js",
-            "OpenLayers/Format/WFST/v1_0_0.js",
-            "OpenLayers/Format/WFST/v1_1_0.js",
-            "OpenLayers/Format/Text.js",
-            "OpenLayers/Format/JSON.js",
-            "OpenLayers/Format/GeoJSON.js",
-            "OpenLayers/Format/WMC.js",
-            "OpenLayers/Format/WMC/v1.js",
-            "OpenLayers/Format/WMC/v1_0_0.js",
-            "OpenLayers/Format/WMC/v1_1_0.js",
-            "OpenLayers/Format/WMSCapabilities.js",
-            "OpenLayers/Format/WMSCapabilities/v1.js",
-            "OpenLayers/Format/WMSCapabilities/v1_1.js",
-            "OpenLayers/Format/WMSCapabilities/v1_1_0.js",
-            "OpenLayers/Format/WMSCapabilities/v1_1_1.js",
-            "OpenLayers/Format/WMSCapabilities/v1_3.js",
-            "OpenLayers/Format/WMSCapabilities/v1_3_0.js",
-            "OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js",
-            "OpenLayers/Format/WMSGetFeatureInfo.js",
-            "OpenLayers/Format/SOSCapabilities.js",
-            "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
-            "OpenLayers/Format/SOSGetFeatureOfInterest.js",
-            "OpenLayers/Format/SOSGetObservation.js",
-            "OpenLayers/Format/OWSContext.js",
-            "OpenLayers/Format/OWSContext/v0_3_1.js",
-            "OpenLayers/Format/WMTSCapabilities.js",
-            "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
-            "OpenLayers/Layer/WFS.js",
-            "OpenLayers/Control/GetFeature.js",
-            "OpenLayers/Control/MouseToolbar.js",
-            "OpenLayers/Control/NavToolbar.js",
-            "OpenLayers/Control/PanPanel.js",
-            "OpenLayers/Control/Pan.js",
-            "OpenLayers/Control/ZoomIn.js",
-            "OpenLayers/Control/ZoomOut.js",
-            "OpenLayers/Control/ZoomPanel.js",
-            "OpenLayers/Control/EditingToolbar.js",
-            "OpenLayers/Symbolizer.js",
-            "OpenLayers/Symbolizer/Point.js",
-            "OpenLayers/Symbolizer/Line.js",
-            "OpenLayers/Symbolizer/Polygon.js",
-            "OpenLayers/Symbolizer/Text.js",
-            "OpenLayers/Symbolizer/Raster.js",
-            "OpenLayers/Lang.js",
-            "OpenLayers/Lang/en.js"
-        ); // etc.
+        if (!jsFiles) {
+            jsFiles = [
+                "OpenLayers/BaseTypes/Class.js",
+                "OpenLayers/Util.js",
+                "OpenLayers/BaseTypes.js",
+                "OpenLayers/BaseTypes/Bounds.js",
+                "OpenLayers/BaseTypes/Element.js",
+                "OpenLayers/BaseTypes/LonLat.js",
+                "OpenLayers/BaseTypes/Pixel.js",
+                "OpenLayers/BaseTypes/Size.js",
+                "OpenLayers/Console.js",
+                "OpenLayers/Tween.js",
+                "Rico/Corner.js",
+                "Rico/Color.js",
+                "OpenLayers/Ajax.js",
+                "OpenLayers/Events.js",
+                "OpenLayers/Request.js",
+                "OpenLayers/Request/XMLHttpRequest.js",
+                "OpenLayers/Projection.js",
+                "OpenLayers/Map.js",
+                "OpenLayers/Layer.js",
+                "OpenLayers/Icon.js",
+                "OpenLayers/Marker.js",
+                "OpenLayers/Marker/Box.js",
+                "OpenLayers/Popup.js",
+                "OpenLayers/Tile.js",
+                "OpenLayers/Tile/Image.js",
+                "OpenLayers/Tile/Image/IFrame.js",
+                "OpenLayers/Tile/WFS.js",
+                "OpenLayers/Layer/Image.js",
+                "OpenLayers/Layer/SphericalMercator.js",
+                "OpenLayers/Layer/EventPane.js",
+                "OpenLayers/Layer/FixedZoomLevels.js",
+                "OpenLayers/Layer/Google.js",
+                "OpenLayers/Layer/Google/v3.js",
+                "OpenLayers/Layer/VirtualEarth.js",
+                "OpenLayers/Layer/Yahoo.js",
+                "OpenLayers/Layer/HTTPRequest.js",
+                "OpenLayers/Layer/Grid.js",
+                "OpenLayers/Layer/MapGuide.js",
+                "OpenLayers/Layer/MapServer.js",
+                "OpenLayers/Layer/MapServer/Untiled.js",
+                "OpenLayers/Layer/KaMap.js",
+                "OpenLayers/Layer/KaMapCache.js",
+                "OpenLayers/Layer/MultiMap.js",
+                "OpenLayers/Layer/Markers.js",
+                "OpenLayers/Layer/Text.js",
+                "OpenLayers/Layer/WorldWind.js",
+                "OpenLayers/Layer/ArcGIS93Rest.js",
+                "OpenLayers/Layer/WMS.js",
+                "OpenLayers/Layer/WMS/Untiled.js",
+                "OpenLayers/Layer/WMS/Post.js",
+                "OpenLayers/Layer/WMTS.js",
+                "OpenLayers/Layer/ArcIMS.js",
+                "OpenLayers/Layer/GeoRSS.js",
+                "OpenLayers/Layer/Boxes.js",
+                "OpenLayers/Layer/XYZ.js",
+                "OpenLayers/Layer/Bing.js",
+                "OpenLayers/Layer/TMS.js",
+                "OpenLayers/Layer/TileCache.js",
+                "OpenLayers/Layer/Zoomify.js",
+                "OpenLayers/Popup/Anchored.js",
+                "OpenLayers/Popup/AnchoredBubble.js",
+                "OpenLayers/Popup/Framed.js",
+                "OpenLayers/Popup/FramedCloud.js",
+                "OpenLayers/Feature.js",
+                "OpenLayers/Feature/Vector.js",
+                "OpenLayers/Feature/WFS.js",
+                "OpenLayers/Handler.js",
+                "OpenLayers/Handler/Click.js",
+                "OpenLayers/Handler/Hover.js",
+                "OpenLayers/Handler/Point.js",
+                "OpenLayers/Handler/Path.js",
+                "OpenLayers/Handler/Polygon.js",
+                "OpenLayers/Handler/Feature.js",
+                "OpenLayers/Handler/Drag.js",
+                "OpenLayers/Handler/RegularPolygon.js",
+                "OpenLayers/Handler/Box.js",
+                "OpenLayers/Handler/MouseWheel.js",
+                "OpenLayers/Handler/Keyboard.js",
+                "OpenLayers/Control.js",
+                "OpenLayers/Control/Attribution.js",
+                "OpenLayers/Control/Button.js",
+                "OpenLayers/Control/ZoomBox.js",
+                "OpenLayers/Control/ZoomToMaxExtent.js",
+                "OpenLayers/Control/DragPan.js",
+                "OpenLayers/Control/Navigation.js",
+                "OpenLayers/Control/MouseDefaults.js",
+                "OpenLayers/Control/MousePosition.js",
+                "OpenLayers/Control/OverviewMap.js",
+                "OpenLayers/Control/KeyboardDefaults.js",
+                "OpenLayers/Control/PanZoom.js",
+                "OpenLayers/Control/PanZoomBar.js",
+                "OpenLayers/Control/ArgParser.js",
+                "OpenLayers/Control/Permalink.js",
+                "OpenLayers/Control/Scale.js",
+                "OpenLayers/Control/ScaleLine.js",
+                "OpenLayers/Control/Snapping.js",
+                "OpenLayers/Control/Split.js",
+                "OpenLayers/Control/LayerSwitcher.js",
+                "OpenLayers/Control/DrawFeature.js",
+                "OpenLayers/Control/DragFeature.js",
+                "OpenLayers/Control/ModifyFeature.js",
+                "OpenLayers/Control/Panel.js",
+                "OpenLayers/Control/SelectFeature.js",
+                "OpenLayers/Control/NavigationHistory.js",
+                "OpenLayers/Control/Measure.js",
+                "OpenLayers/Control/WMSGetFeatureInfo.js",
+                "OpenLayers/Control/WMTSGetFeatureInfo.js",
+                "OpenLayers/Control/Graticule.js",
+                "OpenLayers/Control/TransformFeature.js",
+                "OpenLayers/Control/SLDSelect.js",
+                "OpenLayers/Geometry.js",
+                "OpenLayers/Geometry/Rectangle.js",
+                "OpenLayers/Geometry/Collection.js",
+                "OpenLayers/Geometry/Point.js",
+                "OpenLayers/Geometry/MultiPoint.js",
+                "OpenLayers/Geometry/Curve.js",
+                "OpenLayers/Geometry/LineString.js",
+                "OpenLayers/Geometry/LinearRing.js",
+                "OpenLayers/Geometry/Polygon.js",
+                "OpenLayers/Geometry/MultiLineString.js",
+                "OpenLayers/Geometry/MultiPolygon.js",
+                "OpenLayers/Geometry/Surface.js",
+                "OpenLayers/Renderer.js",
+                "OpenLayers/Renderer/Elements.js",
+                "OpenLayers/Renderer/SVG.js",
+                "OpenLayers/Renderer/Canvas.js",
+                "OpenLayers/Renderer/VML.js",
+                "OpenLayers/Layer/Vector.js",
+                "OpenLayers/Layer/Vector/RootContainer.js",
+                "OpenLayers/Strategy.js",
+                "OpenLayers/Strategy/Filter.js",
+                "OpenLayers/Strategy/Fixed.js",
+                "OpenLayers/Strategy/Cluster.js",
+                "OpenLayers/Strategy/Paging.js",
+                "OpenLayers/Strategy/BBOX.js",
+                "OpenLayers/Strategy/Save.js",
+                "OpenLayers/Strategy/Refresh.js",
+                "OpenLayers/Filter.js",
+                "OpenLayers/Filter/FeatureId.js",
+                "OpenLayers/Filter/Logical.js",
+                "OpenLayers/Filter/Comparison.js",
+                "OpenLayers/Filter/Spatial.js",
+                "OpenLayers/Protocol.js",
+                "OpenLayers/Protocol/HTTP.js",
+                "OpenLayers/Protocol/SQL.js",
+                "OpenLayers/Protocol/SQL/Gears.js",
+                "OpenLayers/Protocol/WFS.js",
+                "OpenLayers/Protocol/WFS/v1.js",
+                "OpenLayers/Protocol/WFS/v1_0_0.js",
+                "OpenLayers/Protocol/WFS/v1_1_0.js",
+                "OpenLayers/Protocol/SOS.js",
+                "OpenLayers/Protocol/SOS/v1_0_0.js",
+                "OpenLayers/Layer/PointTrack.js",
+                "OpenLayers/Layer/GML.js",
+                "OpenLayers/Style.js",
+                "OpenLayers/Style2.js",
+                "OpenLayers/StyleMap.js",
+                "OpenLayers/Rule.js",
+                "OpenLayers/Format.js",
+                "OpenLayers/Format/XML.js",
+                "OpenLayers/Format/Context.js",
+                "OpenLayers/Format/ArcXML.js",
+                "OpenLayers/Format/ArcXML/Features.js",
+                "OpenLayers/Format/GML.js",
+                "OpenLayers/Format/GML/Base.js",
+                "OpenLayers/Format/GML/v2.js",
+                "OpenLayers/Format/GML/v3.js",
+                "OpenLayers/Format/Atom.js",
+                "OpenLayers/Format/KML.js",
+                "OpenLayers/Format/GeoRSS.js",
+                "OpenLayers/Format/WFS.js",
+                "OpenLayers/Format/WFSCapabilities.js",
+                "OpenLayers/Format/WFSCapabilities/v1.js",
+                "OpenLayers/Format/WFSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/WFSCapabilities/v1_1_0.js",
+                "OpenLayers/Format/WFSDescribeFeatureType.js",
+                "OpenLayers/Format/WMSDescribeLayer.js",
+                "OpenLayers/Format/WMSDescribeLayer/v1_1.js",
+                "OpenLayers/Format/WKT.js",
+                "OpenLayers/Format/CQL.js",
+                "OpenLayers/Format/OSM.js",
+                "OpenLayers/Format/GPX.js",
+                "OpenLayers/Format/Filter.js",
+                "OpenLayers/Format/Filter/v1.js",
+                "OpenLayers/Format/Filter/v1_0_0.js",
+                "OpenLayers/Format/Filter/v1_1_0.js",
+                "OpenLayers/Format/SLD.js",
+                "OpenLayers/Format/SLD/v1.js",
+                "OpenLayers/Format/SLD/v1_0_0.js",
+                "OpenLayers/Format/OWSCommon/v1.js",
+                "OpenLayers/Format/OWSCommon/v1_0_0.js",
+                "OpenLayers/Format/OWSCommon/v1_1_0.js",
+                "OpenLayers/Format/CSWGetDomain.js",
+                "OpenLayers/Format/CSWGetDomain/v2_0_2.js",
+                "OpenLayers/Format/CSWGetRecords.js",
+                "OpenLayers/Format/CSWGetRecords/v2_0_2.js",
+                "OpenLayers/Format/WFST.js",
+                "OpenLayers/Format/WFST/v1.js",
+                "OpenLayers/Format/WFST/v1_0_0.js",
+                "OpenLayers/Format/WFST/v1_1_0.js",
+                "OpenLayers/Format/Text.js",
+                "OpenLayers/Format/JSON.js",
+                "OpenLayers/Format/GeoJSON.js",
+                "OpenLayers/Format/WMC.js",
+                "OpenLayers/Format/WMC/v1.js",
+                "OpenLayers/Format/WMC/v1_0_0.js",
+                "OpenLayers/Format/WMC/v1_1_0.js",
+                "OpenLayers/Format/WMSCapabilities.js",
+                "OpenLayers/Format/WMSCapabilities/v1.js",
+                "OpenLayers/Format/WMSCapabilities/v1_1.js",
+                "OpenLayers/Format/WMSCapabilities/v1_1_0.js",
+                "OpenLayers/Format/WMSCapabilities/v1_1_1.js",
+                "OpenLayers/Format/WMSCapabilities/v1_3.js",
+                "OpenLayers/Format/WMSCapabilities/v1_3_0.js",
+                "OpenLayers/Format/WMSCapabilities/v1_1_1_WMSC.js",
+                "OpenLayers/Format/WMSGetFeatureInfo.js",
+                "OpenLayers/Format/SOSCapabilities.js",
+                "OpenLayers/Format/SOSCapabilities/v1_0_0.js",
+                "OpenLayers/Format/SOSGetFeatureOfInterest.js",
+                "OpenLayers/Format/SOSGetObservation.js",
+                "OpenLayers/Format/OWSContext.js",
+                "OpenLayers/Format/OWSContext/v0_3_1.js",
+                "OpenLayers/Format/WMTSCapabilities.js",
+                "OpenLayers/Format/WMTSCapabilities/v1_0_0.js",
+                "OpenLayers/Layer/WFS.js",
+                "OpenLayers/Control/GetFeature.js",
+                "OpenLayers/Control/MouseToolbar.js",
+                "OpenLayers/Control/NavToolbar.js",
+                "OpenLayers/Control/PanPanel.js",
+                "OpenLayers/Control/Pan.js",
+                "OpenLayers/Control/ZoomIn.js",
+                "OpenLayers/Control/ZoomOut.js",
+                "OpenLayers/Control/ZoomPanel.js",
+                "OpenLayers/Control/EditingToolbar.js",
+                "OpenLayers/Symbolizer.js",
+                "OpenLayers/Symbolizer/Point.js",
+                "OpenLayers/Symbolizer/Line.js",
+                "OpenLayers/Symbolizer/Polygon.js",
+                "OpenLayers/Symbolizer/Text.js",
+                "OpenLayers/Symbolizer/Raster.js",
+                "OpenLayers/Lang.js",
+                "OpenLayers/Lang/en.js"
+            ]; // etc.
         // use "parser-inserted scripts" for guaranteed execution order
         // http://hsivonen.iki.fi/script-execution/
-        var allScriptTags = new Array(jsfiles.length);
-        var host = OpenLayers._getScriptLocation() + "lib/";
-        for (var i=0, len=jsfiles.length; i<len; i++) {
-            allScriptTags[i] = "<script src='" + host + jsfiles[i] +
+        var scriptTags = new Array(jsFiles.length);
+        var host = OpenLayers._getScriptLocation() + "lib/";
+        for (var i=0, len=jsFiles.length; i<len; i++) {
+            scriptTags[i] = "<script src='" + host + jsFiles[i] +
                                    "'></script>";
-        document.write(allScriptTags.join(""));
+        if (scriptTags.length > 0) {
+            document.write(scriptTags.join(""));
Modified: trunk/openlayers/tests/Util.html
--- trunk/openlayers/tests/Util.html	2011-02-17 15:25:28 UTC (rev 11135)
+++ trunk/openlayers/tests/Util.html	2011-02-17 19:54:11 UTC (rev 11136)
@@ -5,16 +5,20 @@
     var custom$ = function() {};
     window.$ = custom$;
   </script>
-  <script src="../lib/OpenLayers/SingleFile.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes/Class.js"></script>
-  <script src="../lib/OpenLayers/Util.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes/Element.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes/LonLat.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes/Pixel.js"></script>
-  <script src="../lib/OpenLayers/BaseTypes/Size.js"></script>
-  <script src="../lib/OpenLayers/Lang.js"></script>
-  <script src="../lib/OpenLayers/Console.js"></script>
+  <script>
+    var OpenLayers = [
+  </script>
+  <script src="../lib/OpenLayers.js"></script>
     var isMozilla = (navigator.userAgent.indexOf("compatible") == -1);
     var map;
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-02-17 15:25:28 UTC (rev 11135)
+++ trunk/openlayers/tests/list-tests.html	2011-02-17 19:54:11 UTC (rev 11136)
@@ -163,6 +163,7 @@
     <li>OpenLayers2.html</li>
     <li>OpenLayers3.html</li>
     <li>OpenLayers4.html</li>
+    <li>OpenLayersJsFiles.html</li>
     <li>Popup.html</li>
     <li>Popup/Anchored.html</li>
     <li>Popup/AnchoredBubble.html</li>
More information about the Commits mailing list
