[OpenLayers-Commits] r11145 - in trunk/openlayers:
lib/OpenLayers/Handler tests tests/Handler
commits-20090109 at openlayers.org
Fri Feb 18 10:22:13 EST 2011
Author: ahocevar
Date: 2011-02-18 07:22:12 -0800 (Fri, 18 Feb 2011)
New Revision: 11145
Added:
trunk/openlayers/tests/Handler/Box.html
trunk/openlayers/lib/OpenLayers/Handler/Box.js
trunk/openlayers/tests/list-tests.html
fixing error when closing page in IE. Thanks bartvde for the testcase. r=bartvde (closes #3003)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Box.js
--- trunk/openlayers/lib/OpenLayers/Handler/Box.js 2011-02-18 13:20:07 UTC (rev 11144)
+++ trunk/openlayers/lib/OpenLayers/Handler/Box.js 2011-02-18 15:22:12 UTC (rev 11145)
@@ -68,11 +68,11 @@
* Method: destroy
destroy: function() {
+ OpenLayers.Handler.prototype.destroy.apply(this, arguments);
if (this.dragHandler) {
this.dragHandler.destroy();
this.dragHandler = null;
- OpenLayers.Handler.prototype.destroy.apply(this, arguments);
Added: trunk/openlayers/tests/Handler/Box.html
--- trunk/openlayers/tests/Handler/Box.html (rev 0)
+++ trunk/openlayers/tests/Handler/Box.html 2011-02-18 15:22:12 UTC (rev 11145)
@@ -0,0 +1,26 @@
+<html>
+<head>
+ <script src="../../lib/OpenLayers.js"></script>
+ <script type="text/javascript">
+ function test_Handler_Box_destroy(t) {
+ t.plan(1);
+ var map = new OpenLayers.Map('map');
+ var control = new OpenLayers.Control();
+ map.addControl(control);
+ var handler = new OpenLayers.Handler.Box(control);
+ handler.activate();
+ try {
+ handler.destroy();
+ t.ok(true, "destroying the box handler should not raise any error");
+ } catch(err) {
+ t.fail("destroying the box handler causes trouble: " + err);
+ map.destroy();
+ </script>
+</head>
+<body>
+ <div id="map" style="width: 300px; height: 150px;"/>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2011-02-18 13:20:07 UTC (rev 11144)
+++ trunk/openlayers/tests/list-tests.html 2011-02-18 15:22:12 UTC (rev 11145)
@@ -112,6 +112,7 @@
<li>Geometry/Rectangle.html</li>
<li>Geometry/Surface.html</li>
<li>Handler.html</li>
+ <li>Handler/Box.html</li>
<li>Handler/Click.html</li>
<li>Handler/Drag.html</li>
<li>Handler/Feature.html</li>
More information about the Commits
