[OpenLayers-Commits] r11159 - in trunk/openlayers: examples lib/OpenLayers/Layer tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Feb 21 04:45:23 EST 2011
Author: erilem
Date: 2011-02-21 01:45:22 -0800 (Mon, 21 Feb 2011)
New Revision: 11159
Added:
   trunk/openlayers/examples/fullScreen.js
   trunk/openlayers/examples/fullScreen.html
   trunk/openlayers/lib/OpenLayers/Layer/Grid.js
   trunk/openlayers/tests/Layer/Grid.html
deferred tile loading, i.e. the Google Maps way, p=pgiraud,ahocevar,me, r=ahocevar,me (closes #2998)
Modified: trunk/openlayers/examples/fullScreen.html
--- trunk/openlayers/examples/fullScreen.html	2011-02-21 06:48:33 UTC (rev 11158)
+++ trunk/openlayers/examples/fullScreen.html	2011-02-21 09:45:22 UTC (rev 11159)
@@ -1,4 +1,5 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
+<!DOCTYPE html>
+<html>
     <head>
     <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
     <meta name="apple-mobile-web-app-capable" content="yes" />
@@ -6,10 +7,8 @@
         <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
         <link rel="stylesheet" href="style.css" type="text/css" />
         <style type="text/css">
-            body {
+            html, body, #map {
                 margin: 0;
-            #map {
                 width: 100%;
                 height: 100%;
@@ -25,30 +24,7 @@
         </style>
         <script src="../lib/OpenLayers.js"></script>
-        <script type="text/javascript">
-            var map;
-            function init(){
-                map = new OpenLayers.Map('map');
-            var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-                    "http://vmap0.tiles.osgeo.org/wms/vmap0",
-                    {layers: 'basic'} );
-            var jpl_wms = new OpenLayers.Layer.WMS( "NASA Global Mosaic",
-                "http://t1.hypercube.telascience.org/cgi-bin/landsat7",
-                {layers: "landsat7"});
-                var dm_wms = new OpenLayers.Layer.WMS( "DM Solutions Demo",
-                    "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap",
-                    {layers: "bathymetry,land_fn,park,drain_fn,drainage," +
-                             "prov_bound,fedlimit,rail,road,popplace",
-                     transparent: "true", format: "image/png" });
-                map.addLayers([ol_wms, jpl_wms, dm_wms]);
-                map.addControl(new OpenLayers.Control.LayerSwitcher());
-                map.setCenter(new OpenLayers.LonLat(0, 0), 6);
-                //map.zoomToMaxExtent();
-        </script>
+        <script src="fullScreen.js"></script>
     </head>
     <body onload="init()">
         <div id="map"></div>
@@ -65,8 +41,11 @@
             </p>
             <div id="docs">
-                This example uses CSS to define the dimensions of the map element in order to fill the screen.
-                When the user resizes the window, the map size changes correspondingly. No scroll bars!
+                <p>This example uses CSS to define the dimensions of the map element in order to fill the screen.
+                When the user resizes the window, the map size changes correspondingly. No scroll bars!</p>
+                <p>See the
+                <a href="fullScreen.js" target="_blank">fullScreen.js source</a>
+                to see how this is done.</p>
             </div>
         </div>
     </body>
Added: trunk/openlayers/examples/fullScreen.js
--- trunk/openlayers/examples/fullScreen.js	                        (rev 0)
+++ trunk/openlayers/examples/fullScreen.js	2011-02-21 09:45:22 UTC (rev 11159)
@@ -0,0 +1,30 @@
+var map;
+function init(){
+    map = new OpenLayers.Map('map');
+    var ol_wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
+        "http://vmap0.tiles.osgeo.org/wms/vmap0",
+        {layers: 'basic'} );
+        var ol_wms_nobuffer = new OpenLayers.Layer.WMS( "OpenLayers WMS (no tile buffer)",
+        {layers: 'basic'}, {buffer: 0});
+    map.addLayers([ol_wms, ol_wms_nobuffer]);
+    map.addControl(new OpenLayers.Control.LayerSwitcher());
+    map.setCenter(new OpenLayers.LonLat(0, 0), 6);
+var map;
+function init(){
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-21 06:48:33 UTC (rev 11158)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-21 09:45:22 UTC (rev 11159)
@@ -88,6 +88,19 @@
     numLoadingTiles: 0,
+     * APIProperty: tileLoadingDelay
+     * {Integer} - Number of milliseconds before we shift and load
+     *     tiles. Default is 100.
+    tileLoadingDelay: 100,
+     * Property: timerId
+     * {Number} - The id of the tileLoadingDelay timer.
+    timerId: null,
      * Constructor: OpenLayers.Layer.Grid
      * Create a new grid layer
@@ -109,6 +122,10 @@
         this.events.addEventType("tileloaded");
         this.grid = [];
+        this._moveGriddedTiles = OpenLayers.Function.bind(
+            this.moveGriddedTiles, this
@@ -217,8 +234,16 @@
                 if (forceReTile || !tilesBounds.containsBounds(bounds, true)) {
                     this.initGriddedTiles(bounds);
                 } else {
-                    //we might have to shift our buffer tiles
-                    this.moveGriddedTiles(bounds);
+                    // we might have to shift our buffer tiles, schedule
+                    // that
+                    if (this.timerId != null) {
+                        window.clearTimeout(this.timerId);
+                    this._bounds = bounds;
+                    this.timerId = window.setTimeout(
+                        this._moveGriddedTiles,
+                        this.tileLoadingDelay
@@ -636,28 +661,31 @@
      * Method: moveGriddedTiles
-     * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
-    moveGriddedTiles: function(bounds) {
+    moveGriddedTiles: function() {
+        var bounds = this._bounds;
+        var shifted = true;
         var buffer = this.buffer || 1;
-        while (true) {
-            var tlLayer = this.grid[0][0].position;
-            var tlViewPort =
-                this.map.getViewPortPxFromLayerPx(tlLayer);
-            if (tlViewPort.x > -this.tileSize.w * (buffer - 1)) {
-                this.shiftColumn(true);
-            } else if (tlViewPort.x < -this.tileSize.w * buffer) {
-                this.shiftColumn(false);
-            } else if (tlViewPort.y > -this.tileSize.h * (buffer - 1)) {
-                this.shiftRow(true);
-            } else if (tlViewPort.y < -this.tileSize.h * buffer) {
-                this.shiftRow(false);
-            } else {
-                break;
+        var tlLayer = this.grid[0][0].position;
+        var tlViewPort = this.map.getViewPortPxFromLayerPx(tlLayer);
+        if (tlViewPort.x > -this.tileSize.w * (buffer - 1)) {
+            this.shiftColumn(true);
+        } else if (tlViewPort.x < -this.tileSize.w * buffer) {
+            this.shiftColumn(false);
+        } else if (tlViewPort.y > -this.tileSize.h * (buffer - 1)) {
+            this.shiftRow(true);
+        } else if (tlViewPort.y < -this.tileSize.h * buffer) {
+            this.shiftRow(false);
+        } else {
+            shifted = false;
+            delete this._bounds;
+        if (shifted) {
+            // we may have other row or columns to shift, schedule it
+            // with a setTimeout, to give the user a chance to sneak
+            // in moveTo's
+            this.timerId = window.setTimeout(this._moveGriddedTiles, 0);
Modified: trunk/openlayers/tests/Layer/Grid.html
--- trunk/openlayers/tests/Layer/Grid.html	2011-02-21 06:48:33 UTC (rev 11158)
+++ trunk/openlayers/tests/Layer/Grid.html	2011-02-21 09:45:22 UTC (rev 11159)
@@ -169,7 +169,7 @@
     function test_Layer_Grid_moveTo(t) {
-    t.plan(13);
+    t.plan(14);
         var map = new OpenLayers.Map('map');
         layer = new OpenLayers.Layer.WMS(name, url, params);
@@ -193,9 +193,9 @@
             g_WhichFunc = "InitGridded";
             g_Bounds = bounds;
-        layer.moveGriddedTiles = function(bounds) {
+        layer._moveGriddedTiles = function() {
             g_WhichFunc = "MoveGridded";
-            g_Bounds = bounds;
+            g_Bounds = layer._bounds;
         var clearTestBounds = function() {
             g_WhichFunc = null;
@@ -243,14 +243,8 @@
         clearTestBounds();
         layer.singleTile = true;
         layer.moveTo(null, zoomChanged);
-        t.ok(g_Bounds.equals(b), "if layer has grid but zoomChanged is called, initSingleTile called");
-        layer.getTilesBounds = function() {
-            return tilesBounds;
+        t.ok(g_Bounds.equals(b), "if layer has grid but zoomChanged is called, initSingleTile called");
 //NO FORCE
         zoomChanged = false;
@@ -305,9 +299,13 @@
         //regular move
         clearTestBounds();
         tilesBounds = new OpenLayers.Bounds(10,10,120,120);
+        g_WhichFunc = null;
-        t.ok(g_WhichFunc == "MoveGridded", "if tiles not drastically out of bounds, we call moveGriddedTile()");
-        t.ok(g_Bounds.equals(b), "if tiles not drastically out of bounds, we call moveGriddedTile() with correct bounds");
+        t.eq(g_WhichFunc, null, "moveGriddedTiles is delayed - not called yet");
+        t.delay_call(0.2, function() {
+            t.ok(g_WhichFunc == "MoveGridded", "if tiles not drastically out of bounds, we call moveGriddedTile()");
+            t.ok(g_Bounds.equals(b), "if tiles not drastically out of bounds, we call moveGriddedTile() with correct bounds");
     /** THIS WOULD BE WHERE THE TESTS WOULD GO FOR
More information about the Commits mailing list
