[OpenLayers-Commits] r11177 - trunk/openlayers/tests
commits-20090109 at openlayers.org
Mon Feb 21 08:02:11 EST 2011
Author: pgiraud
Date: 2011-02-21 05:02:11 -0800 (Mon, 21 Feb 2011)
New Revision: 11177
trunk/openlayers/tests/OpenLayers1.html
trunk/openlayers/tests/OpenLayers2.html
trunk/openlayers/tests/OpenLayers3.html
trunk/openlayers/tests/OpenLayers4.html
trunk/openlayers/tests/OpenLayersJsFiles.html
The OpenLayersXXXX.html tests shouldn't use the built file
Modified: trunk/openlayers/tests/OpenLayers1.html
--- trunk/openlayers/tests/OpenLayers1.html 2011-02-21 12:51:13 UTC (rev 11176)
+++ trunk/openlayers/tests/OpenLayers1.html 2011-02-21 13:02:11 UTC (rev 11177)
@@ -1,6 +1,6 @@
<html>
<head>
- <script src="OLLoader.js"></script>
+ <script src="../lib/OpenLayers.js"></script>
<script type="text/javascript">
function test_OpenLayers(t) {
t.plan(1);
Modified: trunk/openlayers/tests/OpenLayers2.html
--- trunk/openlayers/tests/OpenLayers2.html 2011-02-21 12:51:13 UTC (rev 11176)
+++ trunk/openlayers/tests/OpenLayers2.html 2011-02-21 13:02:11 UTC (rev 11177)
@@ -2,7 +2,7 @@
<head>
<script src="bogus/1/OpenLayers.js-foo"></script>
<script src="bogus/2/foo-OpenLayers.js"></script>
- <script src="OLLoader.js?foo"></script>
+ <script src="../lib/OpenLayers.js?foo"></script>
<script src="bogus/3/after-OpenLayers.js"></script>
Modified: trunk/openlayers/tests/OpenLayers3.html
--- trunk/openlayers/tests/OpenLayers3.html 2011-02-21 12:51:13 UTC (rev 11176)
+++ trunk/openlayers/tests/OpenLayers3.html 2011-02-21 13:02:11 UTC (rev 11177)
@@ -3,7 +3,7 @@
<script>
var OpenLayers = {singleFile: true};
</script>
t.plan(1);
Modified: trunk/openlayers/tests/OpenLayers4.html
--- trunk/openlayers/tests/OpenLayers4.html 2011-02-21 12:51:13 UTC (rev 11176)
+++ trunk/openlayers/tests/OpenLayers4.html 2011-02-21 13:02:11 UTC (rev 11177)
@@ -1,8 +1,8 @@
<html>
<head>
- OpenLayers = {singleFile: true}; // just to make the test run faster
- document.write('<scr'+'ipt src="OLLoader.js"></scr'+'ipt>');
+ OpenLayers = {singleFile: true}; // just to make the test run faster
+ document.write('<scr'+'ipt src="../lib/OpenLayers.js"></scr'+'ipt>');
document.write('<scr'+'ipt src="bogus/foo-/OpenLayers.js"></scr'+'ipt>');
</script>
Modified: trunk/openlayers/tests/OpenLayersJsFiles.html
--- trunk/openlayers/tests/OpenLayersJsFiles.html 2011-02-21 12:51:13 UTC (rev 11176)
+++ trunk/openlayers/tests/OpenLayersJsFiles.html 2011-02-21 13:02:11 UTC (rev 11177)
@@ -6,7 +6,7 @@
"OpenLayers/BaseTypes.js"
</script>
t.plan(1);
More information about the Commits
