[OpenLayers-Commits] r11185 - in trunk/openlayers/lib/OpenLayers: .
Control Format/CSWGetDomain Format/WFST Layer Renderer Tile/Image
commits-20090109 at openlayers.org
Mon Feb 21 09:55:01 EST 2011
Author: fredj
Date: 2011-02-21 06:55:01 -0800 (Mon, 21 Feb 2011)
New Revision: 11185
trunk/openlayers/lib/OpenLayers/Control/LayerSwitcher.js
trunk/openlayers/lib/OpenLayers/Format/CSWGetDomain/v2_0_2.js
trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
trunk/openlayers/lib/OpenLayers/Layer/Bing.js
trunk/openlayers/lib/OpenLayers/Layer/Vector.js
trunk/openlayers/lib/OpenLayers/Layer/WMS.js
trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js
trunk/openlayers/lib/OpenLayers/Map.js
trunk/openlayers/lib/OpenLayers/Renderer/VML.js
trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
trunk/openlayers/lib/OpenLayers/Util.js
Add missing semicolon. Non functional change.
Modified: trunk/openlayers/lib/OpenLayers/Control/LayerSwitcher.js
--- trunk/openlayers/lib/OpenLayers/Control/LayerSwitcher.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Control/LayerSwitcher.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -316,7 +316,7 @@
// create span
var labelSpan = document.createElement("span");
- OpenLayers.Element.addClass(labelSpan, "labelSpan")
+ OpenLayers.Element.addClass(labelSpan, "labelSpan");
if (!baseLayer && !layer.inRange) {
labelSpan.style.color = "gray";
Modified: trunk/openlayers/lib/OpenLayers/Format/CSWGetDomain/v2_0_2.js
--- trunk/openlayers/lib/OpenLayers/Format/CSWGetDomain/v2_0_2.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Format/CSWGetDomain/v2_0_2.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -133,7 +133,7 @@
"Value": function(node, obj) {
var attrs = node.attributes;
- var value = {}
+ var value = {};
for(var i=0, len=attrs.length; i<len; ++i) {
value[attrs[i].name] = attrs[i].nodeValue;
@@ -159,7 +159,7 @@
"MinValue": function(node, obj) {
- var value = {}
+ var value = {};
@@ -168,7 +168,7 @@
"MaxValue": function(node, obj) {
- var value = {}
+ var value = {};
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -182,7 +182,7 @@
if(value) {
this.setAttributeNS(
node, this.namespaces["xsi"], "xsi:schemaLocation", value
return OpenLayers.Format.XML.prototype.write.apply(this, [node]);
Modified: trunk/openlayers/lib/OpenLayers/Layer/Bing.js
--- trunk/openlayers/lib/OpenLayers/Layer/Bing.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Layer/Bing.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -79,7 +79,7 @@
options = OpenLayers.Util.applyDefaults({
restrictedMinZoom: 1,
sphericalMercator: true
- }, options)
+ }, options);
var name = options.name || "Bing " + (options.type || this.type);
var newArgs = [name, null, options];
Modified: trunk/openlayers/lib/OpenLayers/Layer/Vector.js
--- trunk/openlayers/lib/OpenLayers/Layer/Vector.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Layer/Vector.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -779,7 +779,7 @@
// don't try to draw the feature with the renderer if the layer is not
// drawn itself
if (!this.drawn) {
- return
+ return;
if (typeof style != "object") {
if(!style && feature.state === OpenLayers.State.DELETE) {
Modified: trunk/openlayers/lib/OpenLayers/Layer/WMS.js
--- trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Layer/WMS.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -256,7 +256,7 @@
var projectionCode = this.projection.equals(mapProjection) ?
this.projection.getCode() :
mapProjection.getCode();
- var value = (projectionCode == "none") ? null : projectionCode
+ var value = (projectionCode == "none") ? null : projectionCode;
if (parseFloat(this.params.VERSION) >= 1.3) {
this.params.CRS = value;
} else {
Modified: trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js
--- trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Layer/Zoomify.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -105,7 +105,7 @@
initializeZoomify: function( size ) {
- var imageSize = size.clone()
+ var imageSize = size.clone();
var tiles = new OpenLayers.Size(
Math.ceil( imageSize.w / this.standardTileSize ),
Math.ceil( imageSize.h / this.standardTileSize )
@@ -151,9 +151,9 @@
OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
// Remove from memory the Zoomify pyramid - is that enough?
- this.tileCountUpToTier.length = 0
- this.tierSizeInTiles.length = 0
- this.tierImageSize.length = 0
+ this.tileCountUpToTier.length = 0;
+ this.tierSizeInTiles.length = 0;
+ this.tierImageSize.length = 0;
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -1018,7 +1018,7 @@
this.resetLayersZIndex();
this.events.triggerEvent("removelayer", {layer: layer});
- layer.events.triggerEvent("removed", {map: this, layer: layer})
+ layer.events.triggerEvent("removed", {map: this, layer: layer});
Modified: trunk/openlayers/lib/OpenLayers/Renderer/VML.js
--- trunk/openlayers/lib/OpenLayers/Renderer/VML.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Renderer/VML.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -765,7 +765,7 @@
x = (comp.x / resolution - this.offset.x) | 0;
y = (comp.y / resolution - this.offset.y) | 0;
pathComp = " " + x + "," + y;
- path.push(pathComp)
+ path.push(pathComp);
if (i==0) {
path.push(" l");
Modified: trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js
--- trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Tile/Image/IFrame.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -42,7 +42,7 @@
delete iFrame;
} else {
- OpenLayers.Tile.Image.prototype.clear.apply(this, arguments)
+ OpenLayers.Tile.Image.prototype.clear.apply(this, arguments);
@@ -221,4 +221,5 @@
return form;
Modified: trunk/openlayers/lib/OpenLayers/Util.js
--- trunk/openlayers/lib/OpenLayers/Util.js 2011-02-21 14:54:25 UTC (rev 11184)
+++ trunk/openlayers/lib/OpenLayers/Util.js 2011-02-21 14:55:01 UTC (rev 11185)
@@ -1038,7 +1038,7 @@
// follow OGC convention of comma delimited values
- value = value.split(",")
+ value = value.split(",");
//if there's only one value, do not return as array
if (value.length == 1) {
@@ -1839,7 +1839,7 @@
if (!dmsOption) {
dmsOption = 'dms'; //default to show degree, minutes, seconds
- var abscoordinate = Math.abs(coordinate)
+ var abscoordinate = Math.abs(coordinate);
var coordinatedegrees = Math.floor(abscoordinate);
var coordinateminutes = (abscoordinate - coordinatedegrees)/(1/60);
More information about the Commits
