[OpenLayers-Commits] r11203 - in sandbox/bartvde/sencha/openlayers:
. examples/map lib/OpenLayers/Handler tests tests/Handler
commits-20090109 at openlayers.org
Mon Feb 21 11:08:29 EST 2011
Author: bartvde
Date: 2011-02-21 08:08:29 -0800 (Mon, 21 Feb 2011)
New Revision: 11203
sandbox/bartvde/sencha/openlayers/
sandbox/bartvde/sencha/openlayers/examples/map/index.js
sandbox/bartvde/sencha/openlayers/lib/OpenLayers/Handler/Click.js
sandbox/bartvde/sencha/openlayers/tests/Handler/Click.html
sandbox/bartvde/sencha/openlayers/tests/OLLoader.js
merge sandbox with trunk
Property changes on: sandbox/bartvde/sencha/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11179-11190
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11179-11202
Modified: sandbox/bartvde/sencha/openlayers/examples/map/index.js
--- sandbox/bartvde/sencha/openlayers/examples/map/index.js 2011-02-21 16:07:07 UTC (rev 11202)
+++ sandbox/bartvde/sencha/openlayers/examples/map/index.js 2011-02-21 16:08:29 UTC (rev 11203)
@@ -17,6 +17,7 @@
items : [
+ /* iconCls: 'add' */
text: 'Zoom In',
handler: function() {
mapdemo.map.zoomIn();
Modified: sandbox/bartvde/sencha/openlayers/lib/OpenLayers/Handler/Click.js
--- sandbox/bartvde/sencha/openlayers/lib/OpenLayers/Handler/Click.js 2011-02-21 16:07:07 UTC (rev 11202)
+++ sandbox/bartvde/sencha/openlayers/lib/OpenLayers/Handler/Click.js 2011-02-21 16:08:29 UTC (rev 11203)
@@ -22,7 +22,6 @@
* - <OpenLayers.Handler>
OpenLayers.Handler.Click = OpenLayers.Class(OpenLayers.Handler, {
* APIProperty: delay
* {Number} Number of milliseconds between clicks before the event is
@@ -89,7 +88,14 @@
* {<OpenLayers.Pixel>} The pixel location of the last mousedown.
down: null,
+ * Property: last
+ * {<OpenLayers.Pixel>} The pixel for the last touchmove. This is
+ * used to
+ last: null,
* Property: rightclickTimerId
* {Number} The id of the right mouse timeout waiting to clear the
@@ -118,7 +124,7 @@
// optionally register for mouseup and mousedown
if(this.pixelTolerance != null) {
this.mousedown = function(evt) {
- this.down = evt.xy;
+ this.down = evt;
return true;
@@ -135,22 +141,35 @@
mousedown: null,
+ * Method: touchstart
+ * Handle touchstart.
+ * Returns:
+ * {Boolean} Continue propagating this event.
+ touchstart: function(evt) {
+ this.down = evt;
+ this.last = null;
+ return true;
* Method: mouseup
* Handle mouseup. Installed to support collection of right mouse events.
* Returns:
- mouseup: function (evt) {
+ mouseup: function (evt) {
var propagate = true;
// Collect right mouse clicks from the mouseup
// IE - ignores the second right click in mousedown so using
// mouseup instead
- if (this.checkModifiers(evt) &&
- this.control.handleRightClicks &&
- OpenLayers.Event.isRightClick(evt)) {
- propagate = this.rightclick(evt);
+ if(this.checkModifiers(evt) &&
+ this.control.handleRightClicks &&
+ OpenLayers.Event.isRightClick(evt)) {
+ propagate = this.rightclick(evt);
return propagate;
@@ -216,7 +235,10 @@
dblclick: function(evt) {
- if(this.passesTolerance(evt)) {
+ // for touch devices trigger dblclick only for
+ // "one finger" touch
+ if(this.passesTolerance(evt) &&
+ (!evt.lastTouches || evt.lastTouches.length == 1)) {
if(this["double"]) {
this.callback('dblclick', [evt]);
@@ -226,6 +248,30 @@
+ * Method: touchmove
+ * Store position of last move, because touchend event can have
+ * an empty "touches" property.
+ touchmove: function(evt) {
+ this.last = evt;
+ * Method: touchend
+ * Correctly set event xy property, and add lastTouches to have
+ * touches property from last touchstart or touchmove
+ touchend: function(evt) {
+ if(!evt) {
+ return false;
+ var last = this.last || this.down;
+ evt.xy = last.xy;
+ evt.lastTouches = last.touches;
+ return evt.xy ? this.click(evt) : false;
* Method: click
* Handle click.
@@ -236,7 +282,12 @@
if(this.timerId != null) {
// already received a click
- this.clearTimer();
+ if(evt.lastTouches) {
+ // touch device - we may trigger dblclick
+ this.dblclick(evt);
+ } else {
+ this.clearTimer();
} else {
// set the timer, send evt only if single is true
//use a clone of the event object because it will no longer
@@ -246,7 +297,7 @@
this.timerId = window.setTimeout(
OpenLayers.Function.bind(this.delayedCall, this, clickEvent),
this.delay
return !this.stopSingle;
@@ -265,10 +316,10 @@
passesTolerance: function(evt) {
var passes = true;
- if(this.pixelTolerance != null && this.down) {
+ if(this.pixelTolerance != null && this.down && this.down.xy) {
var dpx = Math.sqrt(
- Math.pow(this.down.x - evt.xy.x, 2) +
- Math.pow(this.down.y - evt.xy.y, 2)
+ Math.pow(this.down.xy.x - evt.xy.x, 2) +
+ Math.pow(this.down.xy.y - evt.xy.y, 2)
if(dpx > this.pixelTolerance) {
passes = false;
@@ -316,6 +367,7 @@
if(OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
this.clearTimer();
this.down = null;
+ this.last = null;
deactivated = true;
return deactivated;
Modified: sandbox/bartvde/sencha/openlayers/tests/Handler/Click.html
--- sandbox/bartvde/sencha/openlayers/tests/Handler/Click.html 2011-02-21 16:07:07 UTC (rev 11202)
+++ sandbox/bartvde/sencha/openlayers/tests/Handler/Click.html 2011-02-21 16:08:29 UTC (rev 11203)
@@ -43,7 +43,7 @@
function test_Handler_Click_events(t) {
- t.plan(50);
+ t.plan(80);
var map = new OpenLayers.Map('map');
var control = {
@@ -72,7 +72,7 @@
// list below events that should be handled (events) and those
// that should not be handled (nonevents) by the handler
- var events = ["click", "dblclick", "mousedown", "mouseup", "rightclick"];
+ var events = ["click", "dblclick", "mousedown", "mouseup", "rightclick", "touchstart", "touchmove", "touchend"];
var nonevents = ["mousemove", "resize", "focus", "blur"];
var handler = new OpenLayers.Handler.Click(control);
// set browser event like properties on the handler
@@ -82,7 +82,7 @@
handler.activate();
// different listeners registered for pixelTolerance option
var handler = new OpenLayers.Handler.Click(control, {}, {
pixelTolerance: 2
@@ -290,7 +290,90 @@
OpenLayers.Event.isRightClick = temp;
+ function test_touch_click(t) {
+ t.plan(4);
+ // set up
+ var log;
+ var map = new OpenLayers.Map('map');
+ var control = {map: map};
+ var callbacks = {
+ 'click': function(e) {
+ log = {x: e.xy.x, y: e.xy.y,
+ lastTouches: e.lastTouches};
+ var handler = new OpenLayers.Handler.Click(
+ control, callbacks,
+ {'single': true, pixelTolerance: null});
+ // test
+ log = null;
+ handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
+ handler.touchend({});
+ t.delay_call(1, function() {
+ t.ok(log != null, "click callback called");
+ if(log != null) {
+ t.eq(log.x, 1, "evt.xy.x as expected");
+ t.eq(log.y, 1, "evt.xy.y as expected");
+ t.eq(log.lastTouches, ["foo"], "evt.lastTouches as expected");
+ // tear down
+ map.destroy();
+ function test_touch_dblclick(t) {
+ t.plan(5);
+ // set up
+ var log;
+ var callbacks = {
+ log.click = {x: e.xy.x, y: e.xy.y,
+ 'dblclick': function(e) {
+ log.dblclick = {x: e.xy.x, y: e.xy.y,
+ {'double': true, pixelTolerance: null});
+ // test
+ log = {};
+ t.eq(log.click, undefined, "click callback not called");
+ t.ok(log.dblclick != undefined, "dblclick callback called");
+ if(log.dblclick != undefined) {
+ t.eq(log.dblclick.x, 1, "evt.xy.x as expected");
+ t.eq(log.dblclick.y, 1, "evt.xy.y as expected");
+ t.eq(log.dblclick.lastTouches, ["foo"], "evt.lastTouches as expected");
+ // tear down
+ map.destroy();
</script>
</head>
<body>
Modified: sandbox/bartvde/sencha/openlayers/tests/OLLoader.js
--- sandbox/bartvde/sencha/openlayers/tests/OLLoader.js 2011-02-21 16:07:07 UTC (rev 11202)
+++ sandbox/bartvde/sencha/openlayers/tests/OLLoader.js 2011-02-21 16:08:29 UTC (rev 11203)
@@ -1,25 +1,26 @@
// Adding a mode parameter with "build" as value in the run-tests.html will
// make usage of the build version of the library.
// get the OLLoader.js script location
-var r = new RegExp("(^|(.*?\\/))(" + "OLLoader.js" + ")(\\?|$)"),
- s = document.getElementsByTagName('script'),
- src, m, l = "";
-for(var i=0, len=s.length; i<len; i++) {
- src = s[i].getAttribute('src');
- if(src) {
- var m = src.match(r);
- if(m) {
- l = m[1];
- break;
+(function() {
+ var r = new RegExp("(^|(.*?\\/))(" + "OLLoader.js" + ")(\\?|$)"),
+ s = document.getElementsByTagName('script'),
+ src, m, l = "";
+ for(var i=0, len=s.length; i<len; i++) {
+ src = s[i].getAttribute('src');
+ if(src) {
+ var m = src.match(r);
+ if(m) {
+ l = m[1];
+ break;
-var regex = new RegExp( "[\\?&]mode=([^&#]*)" );
-var href = window.parent.location.href;
-var results = regex.exec( href );
-l += (results && results[1] == 'build') ?
- "../build/OpenLayers.js" : "../lib/OpenLayers.js";
-scriptTag = "<script src='" + l + "'></script>";
-document.write(scriptTag);
+ var regex = new RegExp( "[\\?&]mode=([^&#]*)" );
+ var href = window.parent.location.href;
+ var results = regex.exec( href );
+ l += (results && results[1] == 'build') ?
+ "../build/OpenLayers.js" : "../lib/OpenLayers.js";
+ scriptTag = "<script src='" + l + "'></script>";
+ document.write(scriptTag);
More information about the Commits
