[OpenLayers-Commits] r11215 - in trunk/openlayers: lib/OpenLayers/Layer tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 04:06:50 EST 2011
Author: ahocevar
Date: 2011-02-22 01:06:50 -0800 (Tue, 22 Feb 2011)
New Revision: 11215
   trunk/openlayers/lib/OpenLayers/Layer/Grid.js
   trunk/openlayers/tests/Layer/Grid.html
removing unused _bounds member variable. non-functinal change.
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-22 09:06:03 UTC (rev 11214)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-22 09:06:50 UTC (rev 11215)
@@ -239,7 +239,6 @@
                     if (this.timerId != null) {
                         window.clearTimeout(this.timerId);
-                    this._bounds = bounds;
                     this.timerId = window.setTimeout(
                         this._moveGriddedTiles,
                         this.tileLoadingDelay
@@ -663,7 +662,6 @@
      * Method: moveGriddedTiles
     moveGriddedTiles: function() {
-        var bounds = this._bounds;
         var shifted = true;
         var buffer = this.buffer || 1;
         var tlLayer = this.grid[0][0].position;
@@ -678,7 +676,6 @@
             this.shiftRow(false);
         } else {
             shifted = false;
-            delete this._bounds;
         if (shifted) {
             // we may have other row or columns to shift, schedule it
Modified: trunk/openlayers/tests/Layer/Grid.html
--- trunk/openlayers/tests/Layer/Grid.html	2011-02-22 09:06:03 UTC (rev 11214)
+++ trunk/openlayers/tests/Layer/Grid.html	2011-02-22 09:06:50 UTC (rev 11215)
@@ -195,7 +195,7 @@
         layer._moveGriddedTiles = function() {
             g_WhichFunc = "MoveGridded";
-            g_Bounds = layer._bounds;
+            g_Bounds = layer.map.getExtent();
         var clearTestBounds = function() {
             g_WhichFunc = null;
More information about the Commits mailing list
