[OpenLayers-Commits] r11221 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Feb 22 05:00:43 EST 2011
Author: erilem
Date: 2011-02-22 02:00:42 -0800 (Tue, 22 Feb 2011)
New Revision: 11221
   trunk/openlayers/lib/OpenLayers/Kinetic.js
remove trailing whitespaces, no functional change
Modified: trunk/openlayers/lib/OpenLayers/Kinetic.js
--- trunk/openlayers/lib/OpenLayers/Kinetic.js	2011-02-22 09:59:21 UTC (rev 11220)
+++ trunk/openlayers/lib/OpenLayers/Kinetic.js	2011-02-22 10:00:42 UTC (rev 11221)
@@ -33,7 +33,7 @@
      * In ms, default to 200.
     delay: 200,
      * Property: points
      * List of points use to calculate the kinetic initial values.
@@ -58,7 +58,7 @@
      * Method: begin
      * Begins the dragging.
     begin: function() {
@@ -69,7 +69,7 @@
      * Method: update
      * Updates during the dragging.
     update: function(xy) {
@@ -81,7 +81,7 @@
      * Method: end
      * Ends the dragging, start the kinetic.
     end: function(xy) {
@@ -112,7 +112,7 @@
      * Method: move
      * Launch the kinetic move pan.
      * Parameters:
More information about the Commits mailing list
