[OpenLayers-Commits] r11227 - trunk/openlayers/tests
commits-20090109 at openlayers.org
Tue Feb 22 06:44:36 EST 2011
Author: erilem
Date: 2011-02-22 03:44:36 -0800 (Tue, 22 Feb 2011)
New Revision: 11227
trunk/openlayers/tests/Events.html
test that we set clientX and clientY in the event, test-only patch
Modified: trunk/openlayers/tests/Events.html
--- trunk/openlayers/tests/Events.html 2011-02-22 11:21:20 UTC (rev 11226)
+++ trunk/openlayers/tests/Events.html 2011-02-22 11:44:36 UTC (rev 11227)
@@ -305,9 +305,23 @@
events.unregister("something", instance, listener1);
events.unregister("something", instance, listener2);
events.unregister("something", instance, listener3);
+ function test_Events_handleBrowserEvent(t) {
+ t.plan(2);
+ var events = new OpenLayers.Events({}, null, ['sometouchevent']);
+ events.on({'sometouchevent': function() {}});
+ // this test verifies that when handling a touch event we correctly
+ // set clientX and clientY in the event object
+ var evt = {type: 'sometouchevent',
+ touches: [{clientX: 1, clientY: 1}, {clientX: 2, clientY: 2}]
+ events.handleBrowserEvent(evt);
+ t.eq(evt.clientX, 1, "evt.clientX value is correct");
+ t.eq(evt.clientY, 1, "evt.clientY value is correct");
function test_Events_destroy (t) {
t.plan(2);
More information about the Commits
