[OpenLayers-Commits] r11229 - in trunk/openlayers:
lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org
Tue Feb 22 07:06:12 EST 2011
Author: bartvde
Date: 2011-02-22 04:06:12 -0800 (Tue, 22 Feb 2011)
New Revision: 11229
trunk/openlayers/lib/OpenLayers/Control/PanZoomBar.js
trunk/openlayers/tests/Control/PanZoomBar.html
PanZoomBar doesn't handle forceFixedZoomLevel correct, p=patzi,marcjansen r=me (closes #2725)
Modified: trunk/openlayers/lib/OpenLayers/Control/PanZoomBar.js
--- trunk/openlayers/lib/OpenLayers/Control/PanZoomBar.js 2011-02-22 12:03:55 UTC (rev 11228)
+++ trunk/openlayers/lib/OpenLayers/Control/PanZoomBar.js 2011-02-22 12:06:12 UTC (rev 11229)
@@ -386,7 +386,8 @@
zoomLevel = Math.min(Math.max(zoomLevel, 0),
this.map.getNumZoomLevels() - 1);
} else {
- zoomLevel += Math.round(this.deltaY/this.zoomStopHeight);
+ zoomLevel += this.deltaY/this.zoomStopHeight;
+ zoomLevel = Math.max(Math.round(zoomLevel), 0);
this.map.zoomTo(zoomLevel);
this.mouseDragStart = null;
Modified: trunk/openlayers/tests/Control/PanZoomBar.html
--- trunk/openlayers/tests/Control/PanZoomBar.html 2011-02-22 12:03:55 UTC (rev 11228)
+++ trunk/openlayers/tests/Control/PanZoomBar.html 2011-02-22 12:06:12 UTC (rev 11229)
@@ -67,20 +67,104 @@
- function test_Control_PanZoomBar_forceFixedZoomLevel_divClick (t) {
+ function test_Control_PanZoomBar_forceFixedZoomLevel_divClick(t){
t.plan(1);
- map = new OpenLayers.Map('map', {controls:[], fractionalZoom: true});
- var layer = new OpenLayers.Layer.WMS("Test Layer",
- "http://octo.metacarta.com/cgi-bin/mapserv?",
- {map: "/mapdata/vmap_wms.map", layers: "basic"});
+ map = new OpenLayers.Map('map', {
+ controls: [],
+ fractionalZoom: true
+ var layer = new OpenLayers.Layer.WMS("Test Layer", "http://octo.metacarta.com/cgi-bin/mapserv?", {
+ map: "/mapdata/vmap_wms.map",
+ layers: "basic"
map.addLayer(layer);
- control = new OpenLayers.Control.PanZoomBar({forceFixedZoomLevel: true});
+ control = new OpenLayers.Control.PanZoomBar({
+ forceFixedZoomLevel: true
map.addControl(control);
- control.divClick({'xy': {'x': 0, 'y': 49}, which: 1});
- t.eq(map.zoom, 11, "forceFixedZoomLevel makes sure only fixed zoom levels are used even if the map has fractionalZoom");
+ control.divClick({
+ 'xy': {
+ 'x': 0,
+ 'y': 49
+ which: 1
+ t.eq(map.zoom, 11, "forceFixedZoomLevel makes sure that after a div click only fixed zoom levels are used even if the map has fractionalZoom");
+ function test_Control_PanZoomBar_forceFixedZoomLevel_zoomBarUp (t) {
+ var numRandomDrags = 25;
+ // plan one static recorded test and two for every random drag
+ t.plan(1 + (numRandomDrags * 2));
+ var map = new OpenLayers.Map('map', {
+ controls: [],
+ layers: "basic"
+ map.addLayer(layer);
+ // zoom to a fractional ZoomLevel initially:
+ map.setCenter(new OpenLayers.LonLat(0, 0), 9.545);
+ map.addControl(control);
+ // The y values come from manually recording real values in an example
+ var evt = {
+ 'xy': {
+ 'x': 0,
+ 'y': -10.633
+ which: 1
+ control.zoomStart = {
+ 'x': 0,
+ 'y': 5.366
+ control.mouseDragStart = {
+ 'x': 0,
+ 'y': -10.633
+ control.deltaY = control.zoomStart.y - evt.xy.y
+ control.zoomBarUp(evt);
+ t.eq(map.zoom, 11, "forceFixedZoomLevel makes sure that after dragging of the handle only fixed zoom levels are used even if the map has fractionalZoom");
+ // randomly drag the handle around
+ // we should never get a zoom < 0 or a non-integer zoom, regardless of
+ // captured random values for start and end of the drag.
+ for (var i = 0; i < numRandomDrags; i++) {
+ var randStartY = Math.random() * 10 * ((i % 2 === 0) ? -1 : 1);
+ var randStopY = Math.random() * 160 * ((i % 2 === 1) ? -1 : 1);
+ var evt = {
+ 'xy': {
+ 'x': 0,
+ 'y': randStopY
+ which: 1
+ 'x': 0,
+ 'y': randStartY
+ 'x': 0,
+ 'y': randStopY
+ t.eq(Math.floor(map.zoom), Math.ceil(map.zoom), 'Only integer zooms after random handle drag with forceFixedZoomLevel=true and fractionalZoom=true (current zoom was ' + map.zoom + ')');
+ t.ok(map.zoom >= 0, 'map.zoom is never < 0 after random handle drag with forceFixedZoomLevel=true and fractionalZoom=true');
</script>
</head>
<body>
More information about the Commits
