[OpenLayers-Commits] r11258 - in trunk/openlayers: examples lib
lib/OpenLayers/Control tests tests/Control
commits-20090109 at openlayers.org
Tue Feb 22 11:48:05 EST 2011
Author: erilem
Date: 2011-02-22 08:48:05 -0800 (Tue, 22 Feb 2011)
New Revision: 11258
Added:
trunk/openlayers/examples/geolocation.html
trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
trunk/openlayers/tests/Control/Geolocate.html
trunk/openlayers/lib/OpenLayers.js
trunk/openlayers/tests/list-tests.html
add a Geolocate control, p=cmoullet,aabt, r=me (closes #1885)
Added: trunk/openlayers/examples/geolocation.html
--- trunk/openlayers/examples/geolocation.html (rev 0)
+++ trunk/openlayers/examples/geolocation.html 2011-02-22 16:48:05 UTC (rev 11258)
@@ -0,0 +1,109 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+ <head>
+ <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
+ <meta name="apple-mobile-web-app-capable" content="yes" />
+ <title>OpenLayers Geolocation</title>
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
+ <link rel="stylesheet" href="style.css" type="text/css" />
+ <script src="../lib/OpenLayers.js"></script>
+ <script type="text/javascript">
+ var map, layer, vector, watchId;
+ function init(){
+ var style = {
+ fillOpacity: 0.1,
+ fillColor: '#000',
+ strokeColor: '#f00',
+ strokeOpacity: 0.6
+ map = new OpenLayers.Map('map');
+ layer = new OpenLayers.Layer.OSM( "Simple OSM Map");
+ vector = new OpenLayers.Layer.Vector('vector');
+ map.addLayers([layer, vector]);
+ map.setCenter(
+ new OpenLayers.LonLat(-71.147, 42.472).transform(
+ new OpenLayers.Projection("EPSG:4326"),
+ map.getProjectionObject()
+ ), 12
+ var geolocate = new OpenLayers.Control.Geolocate({
+ geolocationOptions: {
+ enableHighAccuracy: false,
+ maximumAge: 0,
+ timeout: 7000
+ map.addControl(geolocate);
+ geolocate.events.register("locationupdated",this,function(e) {
+ vector.removeAllFeatures();
+ vector.addFeatures([
+ new OpenLayers.Feature.Vector(
+ e.point,
+ graphicName: 'cross',
+ strokeWidth: 2,
+ fillOpacity: 0,
+ pointRadius: 10
+ OpenLayers.Geometry.Polygon.createRegularPolygon(
+ new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+ e.position.coords.accuracy/2,
+ 50,
+ 0
+ style
+ map.zoomToExtent(vector.getDataExtent());
+ geolocate.events.register("locationfailed",this,function() {
+ console.log('Location detection failed');
+ window.geolocate = geolocate;
+ $('locate').onclick = function() {
+ geolocate.deactivate();
+ $('track').checked = false;
+ geolocate.watch = false;
+ geolocate.activate();
+ $('track').onclick = function() {
+ if (this.checked) {
+ geolocate.watch = true;
+ </script>
+ </head>
+ <body onload="init()">
+ <h1 id="title">Geolocation Example</h1>
+ <div id="tags">
+ geolocation, geolocate, mobile
+ </div>
+ <p id="shortdesc">
+ Track current position and display it with its accuracy.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <div id="docs">
+ <button id="locate">Locate me!</button>
+ <label>
+ <input type="checkbox" name="track" id="track" />
+ Track my position
+ </label>
+ </div>
+ </body>
+</html>
Added: trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
--- trunk/openlayers/lib/OpenLayers/Control/Geolocate.js (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Control/Geolocate.js 2011-02-22 16:48:05 UTC (rev 11258)
@@ -0,0 +1,158 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Control.js
+ * @requires OpenLayers/Geometry/Point.js
+ * @requires OpenLayers/Projection.js
+ * Class: OpenLayers.Control.Geolocate
+ * The Geolocate control wraps w3c geolocation API into control that can be
+ * bound to a map, and generate events on location update
+ * To use this control requires to load the proj4js library if the projection
+ * of the map is not EPSG:4326 or EPSG:900913.
+ * Inherits from:
+ * - <OpenLayers.Control>
+OpenLayers.Control.Geolocate = OpenLayers.Class(OpenLayers.Control, {
+ * Constant: EVENT_TYPES
+ * Supported event types:
+ * - *locationupdated* Triggered when browser return a new position
+ * - *locationfailed* Triggered when geolocation has failed
+ * - *locationuncapable* Triggered when control is activated on a browser
+ * which doesn't support geolocation
+ EVENT_TYPES: ["locationupdated", "locationfailed", "locationuncapable"],
+ * Property: geolocation
+ * {Object} The geolocation engine, as a property to be possibly mocked.
+ geolocation: navigator.geolocation,
+ * APIProperty: bind
+ * {Boolean} If true, map center will be set on location update.
+ bind: true,
+ * APIProperty: watch
+ * {Boolean} If true, position will be update regularly.
+ watch: false,
+ * APIProperty: geolocationOptions
+ * {Object} Options to pass to the navigator's geolocation API. See
+ * <http://dev.w3.org/geo/api/spec-source.html>. No specific
+ * option is passed to the geolocation API by default.
+ geolocationOptions: null,
+ * Constructor: OpenLayers.Control.Geolocate
+ * Create a new control to deal with browser geolocation API
+ initialize: function(options) {
+ // concatenate events specific to this control with those from the base
+ this.EVENT_TYPES =
+ OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(
+ OpenLayers.Control.prototype.EVENT_TYPES
+ this.geolocationOptions = {};
+ OpenLayers.Control.prototype.initialize.apply(this, [options]);
+ * Method: activate
+ * Activates the control.
+ * Returns:
+ * {Boolean} The control was effectively activated.
+ activate: function () {
+ if (!this.geolocation) {
+ this.events.triggerEvent("locationuncapable");
+ return false;
+ if (!this.active) {
+ if (this.watch) {
+ this.watchId = this.geolocation.watchPosition(
+ OpenLayers.Function.bind(this.geolocate, this),
+ OpenLayers.Function.bind(this.failure, this),
+ } else {
+ this.geolocation.getCurrentPosition(
+ return OpenLayers.Control.prototype.activate.apply(
+ this, arguments
+ * Method: deactivate
+ * Deactivates the control.
+ * Returns:
+ * {Boolean} The control was effectively deactivated.
+ deactivate: function () {
+ if (this.active && this.watchId !== null) {
+ this.geolocation.clearWatch(this.watchId);
+ return OpenLayers.Control.prototype.deactivate.apply(
+ this, arguments
+ * Method: geolocate
+ geolocate: function (position) {
+ var center = new OpenLayers.LonLat(
+ position.coords.longitude,
+ position.coords.latitude
+ ).transform(
+ this.map.getProjectionObject()
+ if (this.bind) {
+ this.map.setCenter(center);
+ this.events.triggerEvent("locationupdated", {
+ position: position,
+ point: new OpenLayers.Geometry.Point(
+ center.lon, center.lat
+ * Method: failure
+ * method called on browser's geolocation failure
+ failure: function (error) {
+ this.events.triggerEvent("locationfailed", {error: error});
+ CLASS_NAME: "OpenLayers.Control.Geolocate"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js 2011-02-22 16:42:30 UTC (rev 11257)
+++ trunk/openlayers/lib/OpenLayers.js 2011-02-22 16:48:05 UTC (rev 11258)
@@ -331,6 +331,7 @@
"OpenLayers/Control/ZoomOut.js",
"OpenLayers/Control/ZoomPanel.js",
"OpenLayers/Control/EditingToolbar.js",
+ "OpenLayers/Control/Geolocate.js",
"OpenLayers/Symbolizer.js",
"OpenLayers/Symbolizer/Point.js",
"OpenLayers/Symbolizer/Line.js",
Added: trunk/openlayers/tests/Control/Geolocate.html
--- trunk/openlayers/tests/Control/Geolocate.html (rev 0)
+++ trunk/openlayers/tests/Control/Geolocate.html 2011-02-22 16:48:05 UTC (rev 11258)
@@ -0,0 +1,105 @@
+<html>
+<head>
+ <script src="../../lib/OpenLayers.js"></script>
+ var map, control, centerLL
+ watch = null,
+ geolocation= {
+ getCurrentPosition: function(f) {
+ f({
+ coords: { latitude: 10, longitude: 10 }
+ watchPosition: function(f) {
+ watch = true;
+ clearWatch: function() {
+ watch = null;
+ function test_initialize(t) {
+ t.plan(3);
+ control = new OpenLayers.Control.Geolocate({geolocationOptions: {foo: 'bar'}});
+ t.ok(control instanceof OpenLayers.Control.Geolocate,
+ "new OpenLayers.Control returns object" );
+ t.eq(control.displayClass, "olControlGeolocate", "displayClass is correct" );
+ t.eq(control.geolocationOptions.foo, 'bar',
+ 'provided geolocation options are set in the geolocationOptions prop');
+ function test_bind(t) {
+ t.plan(3);
+ var control = new OpenLayers.Control.Geolocate({
+ geolocation: geolocation
+ control.events.register('locationupdated', null, function() {
+ t.ok(true, 'locationupdated event is fired when bound');
+ map.addControl(control);
+ control.activate();
+ var center = map.getCenter();
+ t.eq(center.lon, 10, 'bound control sets the map lon');
+ t.eq(center.lat, 10, 'bound control sets the map lat');
+ control.deactivate();
+ map.removeControl(control);
+ map.setCenter(centerLL);
+ function test_unbind(t) {
+ t.plan(3);
+ geolocation: geolocation,
+ bind: false
+ t.ok(true, 'locationupdated event is fired when unbound');
+ t.eq(center.lon, 0, 'unbound control doesnt sets the map lon');
+ t.eq(center.lat, 0, 'unbound control doesnt sets the map lat');
+ function test_watch(t) {
+ t.plan(2);
+ watch: true
+ t.eq(watch, true, 'watch option makes calls to watchPosition');
+ t.eq(watch, null, 'deactivate control calls the clearwatch');
+ function test_uncapable(t) {
+ t.plan(1);
+ geolocation: null,
+ bind: false
+ control.events.register('locationuncapable', null, function() {
+ t.ok(true,'uncapable browser fired locationuncapable event');
+ function loader() {
+ var layer = new OpenLayers.Layer.WMS("Test Layer",
+ "http://labs.metacarta.com/wms-c/Basic.py?",
+ {layers: "basic"});
+ map.addLayer(layer);
+ centerLL = new OpenLayers.LonLat(0,0);
+ map.setCenter(centerLL, 5);
+ </script>
+</head>
+<body onload="loader()">
+ <div id="map" style="width: 256px; height: 256px;"/>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2011-02-22 16:42:30 UTC (rev 11257)
+++ trunk/openlayers/tests/list-tests.html 2011-02-22 16:48:05 UTC (rev 11258)
@@ -15,6 +15,7 @@
<li>Control/DragFeature.html</li>
<li>Control/DragPan.html</li>
<li>Control/DrawFeature.html</li>
+ <li>Control/Geolocate.html</li>
<li>Control/GetFeature.html</li>
<li>Control/Graticule.html</li>
<li>Control/KeyboardDefaults.html</li>
More information about the Commits
