[OpenLayers-Commits] r11266 - in sandbox/ahocevar/layercontainer:
lib/OpenLayers lib/OpenLayers/Layer tests tests/Layer/Google
commits-20090109 at openlayers.org
Tue Feb 22 18:48:01 EST 2011
Author: ahocevar
Date: 2011-02-22 15:48:01 -0800 (Tue, 22 Feb 2011)
New Revision: 11266
sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js
sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html
sandbox/ahocevar/layercontainer/tests/Map.html
applied openlayers-3062.2.patch from #3062
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js 2011-02-22 23:45:35 UTC (rev 11265)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer/Grid.js 2011-02-22 23:48:01 UTC (rev 11266)
@@ -665,7 +665,9 @@
var shifted = true;
var buffer = this.buffer || 1;
var tlLayer = this.grid[0][0].position;
- var tlViewPort = this.map.getViewPortPxFromLayerPx(tlLayer);
+ var offsetX = parseInt(this.map.layerContainerDiv.style.left);
+ var offsetY = parseInt(this.map.layerContainerDiv.style.top);
+ tlViewPort = tlLayer.add(offsetX, offsetY);
if (tlViewPort.x > -this.tileSize.w * (buffer - 1)) {
this.shiftColumn(true);
} else if (tlViewPort.x < -this.tileSize.w * buffer) {
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-22 23:45:35 UTC (rev 11265)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-22 23:48:01 UTC (rev 11266)
@@ -1234,12 +1234,15 @@
getViewPortPxFromLonLat: function (lonlat) {
var px = null;
if (lonlat != null) {
- var resolution = this.map.getResolution();
- var extent = this.map.getExtent();
- px = new OpenLayers.Pixel(
- (1/resolution * (lonlat.lon - extent.left)),
- (1/resolution * (extent.top - lonlat.lat))
+ var res = this.map.resolution;
+ var center = this.map.extent.getCenterLonLat();
+ var lonDelta = lonlat.lon - center.lon;
+ var latDelta = center.lat - lonlat.lat;
+ var halfViewPortWidth = this.map.size.w / 2;
+ var halfViewPortHeight = this.map.size.h / 2;
+ var left = halfViewPortWidth + lonDelta / res;
+ var top = halfViewPortHeight + latDelta / res;
+ px = new OpenLayers.Pixel(left, top);
return px;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-22 23:45:35 UTC (rev 11265)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-22 23:48:01 UTC (rev 11266)
@@ -166,19 +166,18 @@
+ * Property: extent
+ * {<OpenLayers.Bounds>} Cached extent.
+ extent: null,
* Property: viewPortDiv
* {HTMLDivElement} The element that represents the map viewport
viewPortDiv: null,
- * Property: layerContainerOrigin
- * {<OpenLayers.LonLat>} The lonlat at which the later container was
- * re-initialized (on-zoom)
- layerContainerOrigin: null,
* Property: layerContainerDiv
* {HTMLDivElement} The element that contains the layers.
@@ -233,7 +232,7 @@
* {Integer} The current zoom level of the map
zoom: 0,
* Property: panRatio
* {Float} The ratio of the current extent within
@@ -1115,7 +1114,7 @@
if (OpenLayers.Util.indexOf(this.layers, newBaseLayer) != -1) {
// preserve center and scale when changing base layers
- var center = this.getCenter();
+ var center = this.center;
var newResolution = OpenLayers.Util.getResolutionFromScale(
this.getScale(), newBaseLayer.units
@@ -1363,7 +1362,7 @@
var newSize = this.getCurrentSize();
if (newSize && !isNaN(newSize.h) && !isNaN(newSize.w)) {
this.events.clearMouseCache();
- var oldSize = this.getSize();
+ var oldSize = this.size;
if (oldSize == null) {
this.size = oldSize = newSize;
@@ -1377,10 +1376,10 @@
this.layers[i].onMapResize();
if (this.baseLayer != null && center != null) {
- var zoom = this.getZoom();
+ var zoom = this.zoom;
this.zoom = null;
this.setCenter(center, zoom);
@@ -1428,15 +1427,15 @@
var extent = null;
if (center == null) {
- center = this.getCenter();
+ center = this.center;
if (resolution == null) {
- resolution = this.getResolution();
+ resolution = this.resolution;
if ((center != null) && (resolution != null)) {
- var size = this.getSize();
+ var size = this.size;
var w_deg = size.w * resolution;
var h_deg = size.h * resolution;
@@ -1502,6 +1501,7 @@
animate: true,
dragging: false
// getCenter
var centerPx = this.getViewPortPxFromLonLat(this.getCenter());
@@ -1529,11 +1529,11 @@
* lonlat - {<OpenLayers.Lonlat>}
panTo: function(lonlat) {
- if (this.panMethod && this.getExtent().scale(this.panRatio).containsLonLat(lonlat)) {
+ if (this.panMethod && this.extent.scale(this.panRatio).containsLonLat(lonlat)) {
if (!this.panTween) {
this.panTween = new OpenLayers.Tween(this.panMethod);
// center will not change, don't do nothing
if (lonlat.lon == center.lon &&
@@ -1609,105 +1609,96 @@
if (!options) {
options = {};
- if (zoom != null) {
- zoom = parseFloat(zoom);
- if (!this.fractionalZoom) {
- zoom = Math.round(zoom);
// dragging is false by default
var dragging = options.dragging;
// forceZoomChange is false by default
var forceZoomChange = options.forceZoomChange;
// noEvent is false by default
var noEvent = options.noEvent;
if (this.panTween && options.caller == "setCenter") {
this.panTween.stop();
- if (!this.center && !this.isValidLonLat(lonlat)) {
- lonlat = this.maxExtent.getCenterLonLat();
- if(this.restrictedExtent != null) {
- // In 3.0, decide if we want to change interpretation of maxExtent.
- if(lonlat == null) {
- lonlat = this.getCenter();
+ var zoomChanged = forceZoomChange;
+ if (zoom != null) {
+ if (typeof zoom != "number") {
+ zoom = parseFloat(zoom);
- if(zoom == null) {
- zoom = this.getZoom();
+ if (!this.fractionalZoom) {
+ zoom = Math.round(zoom);
- var resolution = this.getResolutionForZoom(zoom);
- var extent = this.calculateBounds(lonlat, resolution);
- if(!this.restrictedExtent.containsBounds(extent)) {
- var maxCenter = this.restrictedExtent.getCenterLonLat();
- if(extent.getWidth() > this.restrictedExtent.getWidth()) {
- lonlat = new OpenLayers.LonLat(maxCenter.lon, lonlat.lat);
- } else if(extent.left < this.restrictedExtent.left) {
- lonlat = lonlat.add(this.restrictedExtent.left -
- extent.left, 0);
- } else if(extent.right > this.restrictedExtent.right) {
- lonlat = lonlat.add(this.restrictedExtent.right -
- extent.right, 0);
- if(extent.getHeight() > this.restrictedExtent.getHeight()) {
- lonlat = new OpenLayers.LonLat(lonlat.lon, maxCenter.lat);
- } else if(extent.bottom < this.restrictedExtent.bottom) {
- lonlat = lonlat.add(0, this.restrictedExtent.bottom -
- extent.bottom);
- else if(extent.top > this.restrictedExtent.top) {
- lonlat = lonlat.add(0, this.restrictedExtent.top -
- extent.top);
+ zoomChanged = zoomChanged ||
+ zoom != this.zoom && this.isValidZoomLevel(zoom);
+ var res;
+ if (zoomChanged) {
+ res = this.resolution = this.getResolutionForZoom(zoom);
+ } else {
+ res = this.resolution = this.getResolution();
- var zoomChanged = forceZoomChange || (
- (this.isValidZoomLevel(zoom)) &&
- (zoom != this.getZoom()) );
+ if (lonlat) {
+ if (this.restrictedExtent) {
+ var extent = this.calculateBounds(lonlat, res);
+ if (!this.restrictedExtent.containsBounds(extent)) {
+ var maxCenter = this.restrictedExtent.getCenterLonLat();
+ if (extent.getWidth() > this.restrictedExtent.getWidth()) {
+ lonlat = new OpenLayers.LonLat(maxCenter.lon, lonlat.lat);
+ } else if (extent.left < this.restrictedExtent.left) {
+ lonlat = lonlat.add(this.restrictedExtent.left -
+ extent.left, 0);
+ } else if (extent.right > this.restrictedExtent.right) {
+ lonlat = lonlat.add(this.restrictedExtent.right -
+ extent.right, 0);
+ if (extent.getHeight() > this.restrictedExtent.getHeight()) {
+ lonlat = new OpenLayers.LonLat(lonlat.lon, maxCenter.lat);
+ } else if (extent.bottom < this.restrictedExtent.bottom) {
+ lonlat = lonlat.add(0, this.restrictedExtent.bottom -
+ extent.bottom);
+ else if (extent.top > this.restrictedExtent.top) {
+ lonlat = lonlat.add(0, this.restrictedExtent.top -
+ extent.top);
- var centerChanged = (this.isValidLonLat(lonlat)) &&
- (!lonlat.equals(this.center));
+ var maxExtent = this.getMaxExtent();
+ this.layerContainerDiv.style.width =
+ Math.round(maxExtent.getWidth() / res) + "px";
+ this.layerContainerDiv.style.height =
+ Math.round(maxExtent.getHeight() / res) + "px";
+ this.zoom = zoom;
+ // zoom level has changed, increment viewRequestID.
+ this.viewRequestID++;
+ var centerChanged =
+ this.isValidLonLat(lonlat) && !lonlat.equals(this.center);
+ if (centerChanged || !this.center) {
+ if (!this.center && !this.isValidLonLat(lonlat)) {
+ lonlat = this.maxExtent.getCenterLonLat();
+ this.centerLayerContainer(lonlat);
+ this.center = lonlat;
// if neither center nor zoom will change, no need to do anything
if (zoomChanged || centerChanged || !dragging) {
if (!this.dragging && !noEvent) {
this.events.triggerEvent("movestart");
- if (centerChanged) {
- if ((!zoomChanged) && (this.center)) {
- // if zoom hasnt changed, just slide layerContainer
- // (must be done before setting this.center to new value)
- this.centerLayerContainer(lonlat);
- this.center = lonlat.clone();
- // (re)set the layerContainerDiv's location
- if ((zoomChanged) || (this.layerContainerOrigin == null)) {
- this.layerContainerOrigin = this.center.clone();
- this.layerContainerDiv.style.left = "0px";
- this.layerContainerDiv.style.top = "0px";
- if (zoomChanged) {
- this.zoom = zoom;
- this.resolution = this.getResolutionForZoom(zoom);
- // zoom level has changed, increment viewRequestID.
- this.viewRequestID++;
- var bounds = this.getExtent();
+ this.extent = this.baseLayer.getExtent();
//send the move call to the baselayer and all the overlays
if(this.baseLayer.visibility) {
- this.baseLayer.moveTo(bounds, zoomChanged, dragging);
+ this.baseLayer.moveTo(this.extent, zoomChanged, dragging);
if(dragging) {
this.baseLayer.events.triggerEvent("move");
} else {
@@ -1716,9 +1707,7 @@
- bounds = this.baseLayer.getExtent();
for (var i=0, len=this.layers.length; i<len; i++) {
var layer = this.layers[i];
if (layer !== this.baseLayer && !layer.isBaseLayer) {
@@ -1737,7 +1726,7 @@
if (inRange && layer.visibility) {
- layer.moveTo(bounds, zoomChanged, dragging);
+ layer.moveTo(this.extent, zoomChanged, dragging);
if(dragging) {
layer.events.triggerEvent("move");
} else {
@@ -1779,14 +1768,18 @@
* lonlat - {<OpenLayers.LonLat>}
centerLayerContainer: function (lonlat) {
- var originPx = this.getViewPortPxFromLonLat(this.layerContainerOrigin);
- var newPx = this.getViewPortPxFromLonLat(lonlat);
- if ((originPx != null) && (newPx != null)) {
- this.layerContainerDiv.style.left = Math.round(originPx.x - newPx.x) + "px";
- this.layerContainerDiv.style.top = Math.round(originPx.y - newPx.y) + "px";
+ var res = this.resolution;
+ var center = this.getMaxExtent().getCenterLonLat();
+ var halfExtentWidth = parseInt(this.layerContainerDiv.style.width) / 2;
+ var halfExtentHeight = parseInt(this.layerContainerDiv.style.height) / 2;
+ var halfViewPortWidth = this.size.w / 2;
+ var halfViewPortHeight = this.size.h / 2;
+ var left = halfViewPortWidth - halfExtentWidth - lonDelta / res;
+ var top = halfViewPortHeight - halfExtentHeight - latDelta / res;
+ this.layerContainerDiv.style.left = Math.round(left) + "px";
+ this.layerContainerDiv.style.top = Math.round(top) + "px";
@@ -1955,8 +1948,8 @@
getExtent: function () {
var extent = null;
- if (this.baseLayer != null) {
- extent = this.baseLayer.getExtent();
+ if (this.extent != null) {
+ extent = this.extent.clone();
return extent;
@@ -2109,7 +2102,7 @@
* zoom - {int}
zoomIn: function() {
- this.zoomTo(this.getZoom() + 1);
+ this.zoomTo(this.zoom + 1);
@@ -2119,7 +2112,7 @@
* zoom - {int}
zoomOut: function() {
- this.zoomTo(this.getZoom() - 1);
+ this.zoomTo(this.zoom - 1);
@@ -2197,10 +2190,10 @@
zoomToScale: function(scale, closest) {
var res = OpenLayers.Util.getResolutionFromScale(scale,
this.baseLayer.units);
var w_deg = size.w * res;
var h_deg = size.h * res;
var extent = new OpenLayers.Bounds(center.lon - w_deg / 2,
center.lat - h_deg / 2,
@@ -2312,7 +2305,7 @@
* {<OpenLayers.Size>} The geodesic size of the pixel in kilometers.
getGeodesicPixelSize: function(px) {
- var lonlat = px ? this.getLonLatFromPixel(px) : (this.getCenter() ||
+ var lonlat = px ? this.getLonLatFromPixel(px) : (this.center ||
new OpenLayers.LonLat(0, 0));
var res = this.getResolution();
var left = lonlat.add(-res / 2, 0);
@@ -2353,9 +2346,11 @@
getViewPortPxFromLayerPx:function(layerPx) {
var viewPortPx = null;
if (layerPx != null) {
- var dX = parseInt(this.layerContainerDiv.style.left);
- var dY = parseInt(this.layerContainerDiv.style.top);
- viewPortPx = layerPx.add(dX, dY);
+ var deltaX = Math.round(center.lon / res - this.center.lon / res);
+ var deltaY = Math.round(this.center.lat / res - center.lat / res);
+ viewPortPx = layerPx.add(deltaX, deltaY);
return viewPortPx;
@@ -2373,12 +2368,11 @@
getLayerPxFromViewPortPx:function(viewPortPx) {
var layerPx = null;
if (viewPortPx != null) {
- var dX = -parseInt(this.layerContainerDiv.style.left);
- var dY = -parseInt(this.layerContainerDiv.style.top);
- layerPx = viewPortPx.add(dX, dY);
- if (isNaN(layerPx.x) || isNaN(layerPx.y)) {
- layerPx = null;
+ var deltaX = Math.round(this.center.lon / res - center.lon / res);
+ var deltaY = Math.round(center.lat / res - this.center.lat / res);
+ layerPx = viewPortPx.add(deltaX, deltaY);
return layerPx;
Modified: sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html
--- sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html 2011-02-22 23:45:35 UTC (rev 11265)
+++ sandbox/ahocevar/layercontainer/tests/Layer/Google/v3.html 2011-02-22 23:48:01 UTC (rev 11266)
@@ -266,12 +266,6 @@
t.plan(8);
- var origPrecision = OpenLayers.Util.DEFAULT_PRECISION;
- // GMaps v3 seems to use a default precision of 13, which is lower
- // than what we use in OpenLayers.
- // See http://trac.osgeo.org/openlayers/ticket/3059
- OpenLayers.Util.DEFAULT_PRECISION = 13;
var map = new OpenLayers.Map('map', {allOverlays: true});
var gmap = new OpenLayers.Layer.Google("Google Streets");
@@ -316,7 +310,6 @@
t.eq(center.lat, origin.lat, "y panning with Google invisible " + (-dx) + ", " + (-dy));
map.destroy();
- OpenLayers.Util.DEFAULT_PRECISION = origPrecision;
function test_wrapDateLine(t) {
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-22 23:45:35 UTC (rev 11265)
+++ sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-22 23:48:01 UTC (rev 11266)
@@ -797,23 +797,20 @@
map.destroy();
- function test_Map_setBaseLayer_after_pan (t) {
- t.plan(1);
+ function test_Map_setBaseLayer_containerdiv (t) {
+ t.plan(4);
map = new OpenLayers.Map('map');
- var wmsLayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
- "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
- var tmsLayer = new OpenLayers.Layer.TMS("TMS",
- "http://labs.metacarta.com/wms-c/Basic.py/",
- {'layername':'basic', 'type':'png'});
- map.addLayers([wmsLayer,tmsLayer]);
- map.setBaseLayer(wmsLayer);
+ map.addLayer(new OpenLayers.Layer(null, {isBaseLayer: true}));
map.zoomToMaxExtent();
- map.setBaseLayer(tmsLayer);
+ var res = map.getResolution();
+ t.eq(map.layerContainerDiv.style.top, (150-90/res)+"px", "layerContainer.style.top is correct");
+ t.eq(map.layerContainerDiv.style.left, (300-180/res)+"px", "layerContainer.style.left is correct");
map.zoomIn();
- map.pan(0, -200, {animate:false});
- t.eq(map.layerContainerDiv.style.top, "0px", "layerContainer is recentered after setBaseLayer");
+ map.pan(50, -200, {animate:false});
+ t.eq(map.layerContainerDiv.style.top, (350-90/res)+"px", "layerContainer.style.top is correct");
+ t.eq(map.layerContainerDiv.style.left, (250-180/res)+"px", "layerContainer.style.left is correct");
map.destroy();
@@ -1318,8 +1315,8 @@
var m = {
'baseLayer': { 'units': {} },
- 'getSize': function() { return {'w': 10, 'h': 15}; },
- 'getCenter': function() { return {'lon': -5, 'lat': -25}; },
+ 'size': {'w': 10, 'h': 15},
+ 'center': {'lon': -5, 'lat': -25},
'zoomToExtent': function(extent, closest) {
t.ok(extent.equals(g_ExpectedExtent), "extent correctly calculated for zoomToExtent()");
t.ok(closest == g_Closest, "closest correctly passed on to zoomToExtent()");
More information about the Commits
