[OpenLayers-Commits] r11281 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 04:32:36 EST 2011
Author: tschaub
Date: 2011-02-23 01:32:36 -0800 (Wed, 23 Feb 2011)
New Revision: 11281
   trunk/openlayers/lib/OpenLayers/BaseTypes.js
Getting consistent datestring parsing in Chrome and Firefox. r=crschmidt (closes #2994)
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-02-23 09:29:00 UTC (rev 11280)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-02-23 09:32:36 UTC (rev 11281)
@@ -632,9 +632,11 @@
      * APIMethod: parse
      * Generate a date object from a string.  The format for the string follows
      *     the profile of ISO 8601 for date and time on the Internet (see
-     *     http://tools.ietf.org/html/rfc3339).  If the parse method on
-     *     the Date constructor returns a valid date for the given string,
-     *     that method is used.
+     *     http://tools.ietf.org/html/rfc3339).  We don't call the native
+     *     Date.parse because of inconsistency between implmentations.  In
+     *     Chrome, calling Date.parse with a string that doesn't contain any
+     *     indication of the timezone (e.g. "2011"), the date is interpreted
+     *     in local time.  On Firefox, the assumption is UTC.
      * Parameters:
      * str - {String} A string representing the date (e.g.
@@ -647,37 +649,31 @@
     parse: function(str) {
         var date;
-        // first check if the native parse method can parse it
-        var elapsed = Date.parse(str);
-        if (!isNaN(elapsed)) {
-            date = new Date(elapsed);
-        } else {
-            var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
-            if (match && (match[1] || match[7])) { // must have at least year or time
-                var year = parseInt(match[1], 10) || 0;
-                var month = (parseInt(match[2], 10) - 1) || 0;
-                var day = parseInt(match[3], 10) || 1;
-                date = new Date(Date.UTC(year, month, day));
-                // optional time
-                var type = match[7];
-                if (type) {
-                    var hours = parseInt(match[4], 10);
-                    var minutes = parseInt(match[5], 10);
-                    var secFrac = parseFloat(match[6]);
-                    var seconds = secFrac | 0;
-                    var milliseconds = Math.round(1000 * (secFrac - seconds));
-                    date.setUTCHours(hours, minutes, seconds, milliseconds);
-                    // check offset
-                    if (type !== "Z") {
-                        var hoursOffset = parseInt(type, 10);
-                        var minutesOffset = parseInt(match[8], 10) || 0;
-                        var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
-                        date = new Date(date.getTime() + offset);
+        var match = str.match(/^(?:(\d{4})(?:-(\d{2})(?:-(\d{2}))?)?)?(?:T(\d{1,2}):(\d{2}):(\d{2}(?:\.\d+)?)(Z|(?:[+-]\d{1,2}(?::(\d{2}))?)))?$/);
+        if (match && (match[1] || match[7])) { // must have at least year or time
+            var year = parseInt(match[1], 10) || 0;
+            var month = (parseInt(match[2], 10) - 1) || 0;
+            var day = parseInt(match[3], 10) || 1;
+            date = new Date(Date.UTC(year, month, day));
+            // optional time
+            var type = match[7];
+            if (type) {
+                var hours = parseInt(match[4], 10);
+                var minutes = parseInt(match[5], 10);
+                var secFrac = parseFloat(match[6]);
+                var seconds = secFrac | 0;
+                var milliseconds = Math.round(1000 * (secFrac - seconds));
+                date.setUTCHours(hours, minutes, seconds, milliseconds);
+                // check offset
+                if (type !== "Z") {
+                    var hoursOffset = parseInt(type, 10);
+                    var minutesOffset = parseInt(match[8], 10) || 0;
+                    var offset = -1000 * (60 * (hoursOffset * 60) + minutesOffset * 60);
+                    date = new Date(date.getTime() + offset);
-            } else {
-                date = new Date("invalid");
+        } else {
+            date = new Date("invalid");
         return date;
More information about the Commits mailing list
