[OpenLayers-Commits] r11315 - in trunk/openlayers: lib/OpenLayers/Control tests/Control
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Feb 23 08:33:14 EST 2011
Author: pgiraud
Date: 2011-02-23 05:33:14 -0800 (Wed, 23 Feb 2011)
New Revision: 11315
   trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
   trunk/openlayers/tests/Control/Geolocate.html
Adding getCurrentLocation API method so that application can get the location anytime, p=aabt, r=elemoine, (Closes #3090)
Modified: trunk/openlayers/lib/OpenLayers/Control/Geolocate.js
--- trunk/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-02-23 13:24:27 UTC (rev 11314)
+++ trunk/openlayers/lib/OpenLayers/Control/Geolocate.js	2011-02-23 13:33:14 UTC (rev 11315)
@@ -85,7 +85,7 @@
             this.events.triggerEvent("locationuncapable");
             return false;
-        if (!this.active) {
+        if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
             if (this.watch) {
                 this.watchId = this.geolocation.watchPosition(
                     OpenLayers.Function.bind(this.geolocate, this),
@@ -93,16 +93,11 @@
                     this.geolocationOptions
             } else {
-                this.geolocation.getCurrentPosition(
-                    OpenLayers.Function.bind(this.geolocate, this),
-                    OpenLayers.Function.bind(this.failure, this),
-                    this.geolocationOptions
+                this.getCurrentLocation();
+            return true;
-        return OpenLayers.Control.prototype.activate.apply(
-            this, arguments
+        return false;
@@ -146,6 +141,25 @@
+     * APIMethod: getCurrentLocation
+     * Returns:
+     * {Boolean} Returns true if a event will be fired (successfull
+     * registration)
+    getCurrentLocation: function() {
+        if (!this.active || this.watch) {
+            return false;
+        this.geolocation.getCurrentPosition(
+            OpenLayers.Function.bind(this.geolocate, this),
+            OpenLayers.Function.bind(this.failure, this),
+            this.geolocationOptions
+        return true;
      * Method: failure
      * method called on browser's geolocation failure
Modified: trunk/openlayers/tests/Control/Geolocate.html
--- trunk/openlayers/tests/Control/Geolocate.html	2011-02-23 13:24:27 UTC (rev 11314)
+++ trunk/openlayers/tests/Control/Geolocate.html	2011-02-23 13:33:14 UTC (rev 11315)
@@ -62,6 +62,31 @@
         map.removeControl(control);
         map.setCenter(centerLL);
+    function test_getCurrentLocation(t) {
+        t.plan(5);
+        var control = new OpenLayers.Control.Geolocate({
+            geolocation: geolocation
+        map.addControl(control);
+        t.eq(control.getCurrentLocation(), false, 'getCurrentLocation return false if control hasnt been activated');
+        control.activate();
+        map.setCenter(centerLL);
+        t.eq(control.getCurrentLocation(), true, 'getCurrentLocation return true if control has been activated');
+        var center = map.getCenter();
+        t.eq(center.lon, 10, 'bound control sets the map lon when calling getCurrentLocation');
+        t.eq(center.lat, 10, 'bound control sets the map lat when calling getCurrentLocation');
+        control.deactivate();
+        map.removeControl(control);
+        var control2 = new OpenLayers.Control.Geolocate({
+        map.addControl(control2);
+        t.eq(control2.getCurrentLocation(), false, 'getCurrentLocation return false if control is in watch mode');
+        control2.deactivate();
+        map.removeControl(control2);
     function test_watch(t) {
         t.plan(2);
More information about the Commits mailing list
