[OpenLayers-Commits] r11323 - in sandbox/sbrunner/openlayers:
examples lib/OpenLayers/Control
commits-20090109 at openlayers.org
Wed Feb 23 09:13:37 EST 2011
Author: fredj
Date: 2011-02-23 06:13:37 -0800 (Wed, 23 Feb 2011)
New Revision: 11323
sandbox/sbrunner/openlayers/examples/orientation.html
sandbox/sbrunner/openlayers/lib/OpenLayers/Control/DeviceOrientation.js
only activate if supported
Modified: sandbox/sbrunner/openlayers/examples/orientation.html
--- sandbox/sbrunner/openlayers/examples/orientation.html 2011-02-23 14:10:39 UTC (rev 11322)
+++ sandbox/sbrunner/openlayers/examples/orientation.html 2011-02-23 14:13:37 UTC (rev 11323)
@@ -20,12 +20,12 @@
orientation = new OpenLayers.Control.DeviceOrientation();
if (orientation.supported()) {
orientation.events.register("orientationchange", this, function(event) {
+ logs.innerHTML = "rotation: " + event.orientation;
var img = document.getElementById("orientation");
var value = "rotate(" + event.orientation + "deg)";
img.style.transform = value;
img.style.webkitTransform = value;
- logs.innerHTML = "rotation: " + event.orientation;
orientation.activate();
} else {
Modified: sandbox/sbrunner/openlayers/lib/OpenLayers/Control/DeviceOrientation.js
--- sandbox/sbrunner/openlayers/lib/OpenLayers/Control/DeviceOrientation.js 2011-02-23 14:10:39 UTC (rev 11322)
+++ sandbox/sbrunner/openlayers/lib/OpenLayers/Control/DeviceOrientation.js 2011-02-23 14:13:37 UTC (rev 11323)
@@ -55,7 +55,7 @@
* {Boolean} The control was effectively activated.
activate: function() {
- if (!this.active) {
+ if (!this.active && this.supported()) {
window.addEventListener("deviceorientation",
OpenLayers.Function.bind(this.onOrientation, this), true);
More information about the Commits
