[OpenLayers-Commits] r11328 - in sandbox/igorti/openlayers: .
examples lib/OpenLayers lib/OpenLayers/Control tests/Control
tests/Layer
commits-20090109 at openlayers.org
Wed Feb 23 09:42:54 EST 2011
Author: igorti
Date: 2011-02-23 06:42:54 -0800 (Wed, 23 Feb 2011)
New Revision: 11328
sandbox/igorti/openlayers/
sandbox/igorti/openlayers/examples/geolocation.html
sandbox/igorti/openlayers/examples/geolocation.js
sandbox/igorti/openlayers/examples/mobile-navigation.html
sandbox/igorti/openlayers/lib/OpenLayers/Control/Geolocate.js
sandbox/igorti/openlayers/lib/OpenLayers/Kinetic.js
sandbox/igorti/openlayers/tests/Control/Geolocate.html
sandbox/igorti/openlayers/tests/Layer/EventPane.html
merge with trunk
Property changes on: sandbox/igorti/openlayers
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11298-11327
Modified: sandbox/igorti/openlayers/examples/geolocation.html
--- sandbox/igorti/openlayers/examples/geolocation.html 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/examples/geolocation.html 2011-02-23 14:42:54 UTC (rev 11328)
@@ -13,7 +13,7 @@
</style>
</head>
- <body onload="init()">
+ <body>
<h1 id="title">Geolocation Example</h1>
<div id="tags">
Modified: sandbox/igorti/openlayers/examples/geolocation.js
--- sandbox/igorti/openlayers/examples/geolocation.js 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/examples/geolocation.js 2011-02-23 14:42:54 UTC (rev 11328)
@@ -1,8 +1,7 @@
var style = {
+ fillColor: '#000',
fillOpacity: 0.1,
- fillColor: '#000',
- strokeColor: '#f00',
- strokeOpacity: 0.6
+ strokeWidth: 0
var map = new OpenLayers.Map('map');
@@ -17,6 +16,34 @@
), 12
+var pulsate = function(feature) {
+ var point = feature.geometry.getCentroid(),
+ bounds = feature.geometry.getBounds(),
+ radius = Math.abs((bounds.right - bounds.left)/2),
+ count = 0,
+ grow = 'up';
+ var resize = function(){
+ if (count>16) clearInterval(window.resizeInterval);
+ var interval = radius * 0.03;
+ var ratio = interval/radius;
+ switch(count) {
+ case 4:
+ case 12:
+ grow = 'down'; break;
+ case 8:
+ grow = 'up'; break;
+ if (grow!=='up') {
+ ratio = - Math.abs(ratio);
+ feature.geometry.resize(1+ratio, point);
+ vector.drawFeature(feature);
+ count++;
+ window.resizeInterval = window.setInterval(resize, 50, point, radius);
var geolocate = new OpenLayers.Control.Geolocate({
geolocationOptions: {
enableHighAccuracy: false,
@@ -27,6 +54,16 @@
map.addControl(geolocate);
geolocate.events.register("locationupdated",this,function(e) {
vector.removeAllFeatures();
+ var circle = new OpenLayers.Feature.Vector(
+ OpenLayers.Geometry.Polygon.createRegularPolygon(
+ new OpenLayers.Geometry.Point(e.point.x, e.point.y),
+ e.position.coords.accuracy/2,
+ 40,
+ 0
+ style
vector.addFeatures([
e.point,
@@ -39,34 +76,28 @@
pointRadius: 10
- new OpenLayers.Feature.Vector(
- OpenLayers.Geometry.Polygon.createRegularPolygon(
- new OpenLayers.Geometry.Point(e.point.x, e.point.y),
- e.position.coords.accuracy/2,
- 50,
- 0
- style
+ circle
map.zoomToExtent(vector.getDataExtent());
+ pulsate(circle);
geolocate.events.register("locationfailed",this,function() {
OpenLayers.Console.log('Location detection failed');
$('locate').onclick = function() {
+ vector.removeAllFeatures();
geolocate.deactivate();
$('track').checked = false;
geolocate.watch = false;
geolocate.activate();
$('track').onclick = function() {
if (this.checked) {
geolocate.watch = true;
-$('track').checked = false;
\ No newline at end of file
+$('track').checked = false;
Modified: sandbox/igorti/openlayers/examples/mobile-navigation.html
--- sandbox/igorti/openlayers/examples/mobile-navigation.html 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/examples/mobile-navigation.html 2011-02-23 14:42:54 UTC (rev 11328)
@@ -3,7 +3,7 @@
<head>
<meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
<meta name="apple-mobile-web-app-capable" content="yes" />
- <title>OpenLayers TouchNavigation Control</title>
+ <title>Mobile Navigation Example</title>
<link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
<link rel="stylesheet" href="style.mobile.css" type="text/css" />
<link rel="stylesheet" href="style.css" type="text/css" />
Modified: sandbox/igorti/openlayers/lib/OpenLayers/Control/Geolocate.js
--- sandbox/igorti/openlayers/lib/OpenLayers/Control/Geolocate.js 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/lib/OpenLayers/Control/Geolocate.js 2011-02-23 14:42:54 UTC (rev 11328)
@@ -85,7 +85,7 @@
this.events.triggerEvent("locationuncapable");
return false;
- if (!this.active) {
+ if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
if (this.watch) {
this.watchId = this.geolocation.watchPosition(
OpenLayers.Function.bind(this.geolocate, this),
@@ -93,16 +93,11 @@
this.geolocationOptions
} else {
- this.geolocation.getCurrentPosition(
- OpenLayers.Function.bind(this.geolocate, this),
- OpenLayers.Function.bind(this.failure, this),
- this.geolocationOptions
+ this.getCurrentLocation();
+ return true;
- return OpenLayers.Control.prototype.activate.apply(
- this, arguments
+ return false;
@@ -146,6 +141,25 @@
+ * APIMethod: getCurrentLocation
+ * Returns:
+ * {Boolean} Returns true if a event will be fired (successfull
+ * registration)
+ getCurrentLocation: function() {
+ if (!this.active || this.watch) {
+ return false;
+ this.geolocation.getCurrentPosition(
+ OpenLayers.Function.bind(this.geolocate, this),
+ OpenLayers.Function.bind(this.failure, this),
+ this.geolocationOptions
+ return true;
* Method: failure
* method called on browser's geolocation failure
Modified: sandbox/igorti/openlayers/lib/OpenLayers/Kinetic.js
--- sandbox/igorti/openlayers/lib/OpenLayers/Kinetic.js 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/lib/OpenLayers/Kinetic.js 2011-02-23 14:42:54 UTC (rev 11328)
@@ -63,7 +63,6 @@
* Method: begin
* Begins the dragging.
begin: function() {
@@ -74,8 +73,10 @@
* Method: update
+ * Updates during the dragging.
- * Updates during the dragging.
+ * Parameters:
+ * xy - {<OpenLayers.Pixel>} The new position.
update: function(xy) {
this.points.unshift({xy: xy, tick: new Date().getTime()});
@@ -86,8 +87,15 @@
* Method: end
+ * Ends the dragging, start the kinetic.
- * Ends the dragging, start the kinetic.
+ * Parameters:
+ * xy - {<OpenLayers.Pixel>} The last position.
+ * Returns:
+ * {Object} An object with two properties: "speed", and "theta". The
+ * "speed" and "theta" values are to be passed to the move
+ * function when starting the animation.
end: function(xy) {
var last, now = new Date().getTime();
@@ -117,12 +125,13 @@
* Method: move
* Launch the kinetic move pan.
* Parameters:
- * info - {Object}
- * callback - arguments x, y (values to pan), end (is the last point)
+ * info - {Object} An object with two properties, "speed", and "theta".
+ * These values are those returned from the "end" call.
+ * callback - {Function} Function called on every step of the animation,
+ * receives x, y (values to pan), end (is the last point).
move: function(info, callback) {
var v0 = info.speed;
Modified: sandbox/igorti/openlayers/tests/Control/Geolocate.html
--- sandbox/igorti/openlayers/tests/Control/Geolocate.html 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/tests/Control/Geolocate.html 2011-02-23 14:42:54 UTC (rev 11328)
@@ -62,6 +62,31 @@
map.removeControl(control);
map.setCenter(centerLL);
+ function test_getCurrentLocation(t) {
+ t.plan(5);
+ var control = new OpenLayers.Control.Geolocate({
+ geolocation: geolocation
+ map.addControl(control);
+ t.eq(control.getCurrentLocation(), false, 'getCurrentLocation return false if control hasnt been activated');
+ control.activate();
+ map.setCenter(centerLL);
+ t.eq(control.getCurrentLocation(), true, 'getCurrentLocation return true if control has been activated');
+ var center = map.getCenter();
+ t.eq(center.lon, 10, 'bound control sets the map lon when calling getCurrentLocation');
+ t.eq(center.lat, 10, 'bound control sets the map lat when calling getCurrentLocation');
+ control.deactivate();
+ map.removeControl(control);
+ var control2 = new OpenLayers.Control.Geolocate({
+ map.addControl(control2);
+ t.eq(control2.getCurrentLocation(), false, 'getCurrentLocation return false if control is in watch mode');
+ control2.deactivate();
+ map.removeControl(control2);
function test_watch(t) {
t.plan(2);
Modified: sandbox/igorti/openlayers/tests/Layer/EventPane.html
--- sandbox/igorti/openlayers/tests/Layer/EventPane.html 2011-02-23 14:31:55 UTC (rev 11327)
+++ sandbox/igorti/openlayers/tests/Layer/EventPane.html 2011-02-23 14:42:54 UTC (rev 11328)
@@ -58,11 +58,11 @@
// t.plan( 2 );
if (OpenLayers.BROWSER_NAME != "firefox" && OpenLayers.BROWSER_NAME != "mozilla") {
- t.plan(4);
+ t.plan(4);
} else {
- t.plan(0);
- t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
- return;
+ t.plan(0);
+ t.debug_print("Firefox gives different results for different browsers on setMap on EventPane, so just don't run it for now.")
+ return;
@@ -84,19 +84,23 @@
layer2.getWarningHTML = function() { this.warning = true; return ""; }
map.addLayer(layer2);
- t.ok( !layer2.warning, "warning not registered on mapObject load" );
+ t.ok(!layer2.warning, "warning not registered on mapObject load");
- map.events.register("mousemove", map, function () {
- t.ok(true, "got mouse move");
+ var log = [];
+ map.events.register("mousemove", map, function(event) {
+ log.push(event);
- if( document.createEvent ) { // Mozilla
- var evObj = document.createEvent('MouseEvents');
- evObj.initEvent( 'mousemove', true, false );
- layer.pane.dispatchEvent(evObj);
- } else if( document.createEventObject ) { // IE
- layer.pane.fireEvent('onmousemove');
+ if (document.createEvent) { // Mozilla
+ var evObj = document.createEvent('MouseEvents');
+ evObj.initEvent('mousemove', true, false);
+ layer.pane.dispatchEvent(evObj);
+ } else if(document.createEventObject) { // IE
+ layer.pane.fireEvent('onmousemove');
+ t.eq(log.length, 1, "got one event");
function test_Layer_EventPane_setVisibility (t) {
More information about the Commits
