[OpenLayers-Commits] r11331 - in sandbox/igorti/openlayers:
examples lib/OpenLayers/Control
commits-20090109 at openlayers.org
Wed Feb 23 09:59:41 EST 2011
Author: igorti
Date: 2011-02-23 06:59:40 -0800 (Wed, 23 Feb 2011)
New Revision: 11331
Removed:
sandbox/igorti/openlayers/examples/mobile-layerswitcher.html
sandbox/igorti/openlayers/lib/OpenLayers/Control/MobileLayerSwitcher.js
Remove two files
Deleted: sandbox/igorti/openlayers/examples/mobile-layerswitcher.html
--- sandbox/igorti/openlayers/examples/mobile-layerswitcher.html 2011-02-23 14:53:13 UTC (rev 11330)
+++ sandbox/igorti/openlayers/examples/mobile-layerswitcher.html 2011-02-23 14:59:40 UTC (rev 11331)
@@ -1,60 +0,0 @@
-<html xmlns="http://www.w3.org/1999/xhtml">
- <head>
- <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;" />
- <meta name="apple-mobile-web-app-capable" content="yes" />
- <title>OpenLayers Mobile Layer Switcher Example</title>
- <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
- <link rel="stylesheet" href="style.css" type="text/css" />
- <style type="text/css">
- html, body, #map{
- width:100%;
- height:100%;
- margin:0px;
- </style>
- <script src="http://maps.google.com/maps/api/js?v=3.3&sensor=false"></script>
- <script src="../lib/OpenLayers.js"></script>
- <script type="text/javascript">
- var map;
- function init(){
- map = new OpenLayers.Map('map', { controls: [] });
- map.addControl(new OpenLayers.Control.Navigation());
- map.addControl(new OpenLayers.Control.MobileLayerSwitcher());
- var osm = new OpenLayers.Layer.OSM();
- var gmap = new OpenLayers.Layer.Google("Google Streets");
- var vectorLayer1 = new OpenLayers.Layer.Vector("Vector Layer 1");
- var point1 = new OpenLayers.Geometry.Point(1526200, 7572700);
- var pointFeature1 = new OpenLayers.Feature.Vector(point1,null,null);
- var point2 = new OpenLayers.Geometry.Point(4782500, 5679500);
- var pointFeature2 = new OpenLayers.Feature.Vector(point2,null,null);
- var point3 = new OpenLayers.Geometry.Point(-8883800, 4461400);
- var pointFeature3 = new OpenLayers.Feature.Vector(point3,null,null);
- vectorLayer1.addFeatures([pointFeature1,pointFeature2,pointFeature3]);
- var vectorLayer2 = new OpenLayers.Layer.Vector("Vector Layer 2");
- var point4 = new OpenLayers.Geometry.Point(1406200, 6002700);
- var pointFeature4 = new OpenLayers.Feature.Vector(point4,null,null);
- var point5 = new OpenLayers.Geometry.Point(4502500, 4009500);
- var pointFeature5 = new OpenLayers.Feature.Vector(point5,null,null);
- var point6 = new OpenLayers.Geometry.Point(-7003800, 3001400);
- var pointFeature6 = new OpenLayers.Feature.Vector(point6,null,null);
- vectorLayer2.addFeatures([pointFeature4,pointFeature5,pointFeature6]);
- map.addLayers([osm, gmap, vectorLayer1,vectorLayer2]);
- if (!map.getCenter())
- map.zoomToMaxExtent();
- </script>
- </head>
- <body onload="init()">
- <div id="map"></div>
- </body>
-</html>
Deleted: sandbox/igorti/openlayers/lib/OpenLayers/Control/MobileLayerSwitcher.js
--- sandbox/igorti/openlayers/lib/OpenLayers/Control/MobileLayerSwitcher.js 2011-02-23 14:53:13 UTC (rev 11330)
+++ sandbox/igorti/openlayers/lib/OpenLayers/Control/MobileLayerSwitcher.js 2011-02-23 14:59:40 UTC (rev 11331)
@@ -1,482 +0,0 @@
-/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
- * full list of contributors). Published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Control.js
- * @requires OpenLayers/Lang.js
- * @requires Rico/Corner.js
- * Class: OpenLayers.Control.LayerSwitcher
- * The LayerSwitcher control displays a table of contents for the map. This
- * allows the user interface to switch between BaseLasyers and to show or hide
- * Overlays. By default the switcher is shown minimized on the right edge of
- * the map, the user may expand it by clicking on the handle.
- * To create the LayerSwitcher outside of the map, pass the Id of a html div
- * as the first argument to the constructor.
- * Inherits from:
- * - <OpenLayers.Control>
-OpenLayers.Control.MobileLayerSwitcher =
- OpenLayers.Class(OpenLayers.Control, {
- * Property: layerStates
- * {Array(Object)} Basically a copy of the "state" of the map's layers
- * the last time the control was drawn. We have this in order to avoid
- * unnecessarily redrawing the control.
- layerStates: null,
- * Property: triggerBtn
- * {DOMElement}
- triggerBtn: null,
- * Property: dataLbl
- * {DOMElement}
- dataLbl: null,
- * Property: dataLayersUl
- * {DOMElement}
- dataLayersUl: null,
- * Property: baseLbl
- * {DOMElement}
- baseLbl: null,
- * Property: baseLayersUl
- * {DOMElement}
- baseLayersUl: null,
- * Property: closeNtn
- * {DOMElement}
- closeBtn: null,
- * {Array(<OpenLayers.Layer>)}
- baseLayers: null,
- dataLayers: null,
- * APIProperty: ascending
- * {Boolean}
- ascending: true,
- * Constructor: OpenLayers.Control.LayerSwitcher
- * Parameters:
- * options - {Object}
- initialize: function(options) {
- OpenLayers.Control.prototype.initialize.apply(this, arguments);
- this.layerStates = [];
- * APIMethod: destroy
- destroy: function() {
- OpenLayers.Event.stopObservingElement(this.div);
- //OpenLayers.Event.stopObservingElement(this.minimizeDiv);
- //OpenLayers.Event.stopObservingElement(this.maximizeDiv);
- //clear out layers info and unregister their events
- this.clearLayersArray("base");
- this.clearLayersArray("data");
- this.map.events.un({
- "addlayer": this.redraw,
- "changelayer": this.redraw,
- "removelayer": this.redraw,
- "changebaselayer": this.redraw,
- scope: this
- OpenLayers.Control.prototype.destroy.apply(this, arguments);
- * Method: setMap
- * Properties:
- * map - {<OpenLayers.Map>}
- setMap: function(map) {
- OpenLayers.Control.prototype.setMap.apply(this, arguments);
- this.map.events.on({
- scope: this
- * Method: draw
- * Returns:
- * {DOMElement} A reference to the DIV DOMElement containing the
- * switcher tabs.
- draw: function() {
- OpenLayers.Control.prototype.draw.apply(this);
- // create layout divs
- this.loadContents();
- // set mode to minimize
- if(!this.outsideViewport) {
- this.minimizeControl();
- // populate div with current info
- this.redraw();
- this.events = new OpenLayers.Events(this, this.div);
- //prevent all kinds of map events when layerswitcher is opened
- for(var i = 0; i < this.events.BROWSER_EVENTS.length; i++){
- this.events.registerPriority(this.events.BROWSER_EVENTS[i], this, function(){ return false;});
- return this.div;
- * Method: clearLayersArray
- * User specifies either "base" or "data". we then clear all the
- * corresponding listeners, the div, and reinitialize a new array.
- * Parameters:
- * layersType - {String}
- clearLayersArray: function(layersType) {
- var layers = this[layersType + "Layers"];
- if (layers) {
- for(var i=0, len=layers.length; i<len ; i++) {
- var layer = layers[i];
- OpenLayers.Event.stopObservingElement(layer.inputElem);
- OpenLayers.Event.stopObservingElement(layer.labelSpan);
- this[layersType + "LayersUl"].innerHTML = "";
- this[layersType + "Layers"] = [];
- * Method: checkRedraw
- * Checks if the layer state has changed since the last redraw() call.
- * Returns:
- * {Boolean} The layer state changed since the last redraw() call.
- checkRedraw: function() {
- var redraw = false;
- if ( !this.layerStates.length ||
- (this.map.layers.length != this.layerStates.length) ) {
- redraw = true;
- } else {
- for (var i=0, len=this.layerStates.length; i<len; i++) {
- var layerState = this.layerStates[i];
- var layer = this.map.layers[i];
- if ( (layerState.name != layer.name) ||
- (layerState.inRange != layer.inRange) ||
- (layerState.id != layer.id) ||
- (layerState.visibility != layer.visibility) ) {
- redraw = true;
- break;
- return redraw;
- * Method: redraw
- * Goes through and takes the current state of the Map and rebuilds the
- * control to display that state. Groups base layers into a
- * radio-button group and lists each data layer with a checkbox.
- * Returns:
- * {DOMElement} A reference to the DIV DOMElement containing the control
- redraw: function() {
- //if the state hasn't changed since last redraw, no need
- // to do anything. Just return the existing div.
- if (!this.checkRedraw()) {
- return this.div;
- if(this.div.style.zIndex)
- this.triggerBtn.style.zIndex = this.div.style.zIndex-1;
- //clear out previous layers
- var containsOverlays = false;
- var containsBaseLayers = false;
- // Save state -- for checking layer if the map state changed.
- // We save this before redrawing, because in the process of redrawing
- // we will trigger more visibility changes, and we want to not redraw
- // and enter an infinite loop.
- var len = this.map.layers.length;
- this.layerStates = new Array(len);
- for (var i=0; i <len; i++) {
- this.layerStates[i] = {
- 'name': layer.name,
- 'visibility': layer.visibility,
- 'inRange': layer.inRange,
- 'id': layer.id
- var layers = this.map.layers.slice();
- if (!this.ascending)
- layers.reverse();
- for(var i=0, len=layers.length; i<len; i++) {
- var baseLayer = layer.isBaseLayer;
- if (layer.displayInLayerSwitcher) {
- if (baseLayer) {
- containsBaseLayers = true;
- } else {
- containsOverlays = true;
- // only check a baselayer if it is *the* baselayer, check data
- // layers if they are visible
- var checked = (baseLayer) ? (layer == this.map.baseLayer)
- : layer.getVisibility();
- // create input element
- var inputElem = document.createElement("input");
- inputElem.id = this.id + "_input_" + layer.name;
- inputElem.name = (baseLayer) ? this.id + "_baseLayers" : layer.name;
- inputElem.type = (baseLayer) ? "radio" : "checkbox";
- inputElem.value = layer.name;
- inputElem.checked = checked;
- inputElem.defaultChecked = checked;
- if (!baseLayer && !layer.inRange) {
- inputElem.disabled = true;
- var context = {
- 'inputElem': inputElem,
- 'layer': layer,
- 'layerSwitcher': this
- OpenLayers.Event.observe(inputElem, "mouseup",
- OpenLayers.Function.bindAsEventListener(this.onInputClick,
- context)
- // create span
- var label = document.createElement("label");
- label.style.color = "gray";
- var textNode = document.createTextNode(layer.name);
- label.appendChild(inputElem);
- label.appendChild(textNode);
- OpenLayers.Event.observe(label, "click",
- context)
- var groupArray = (baseLayer) ? this.baseLayers
- : this.dataLayers;
- groupArray.push({
- 'layer': layer,
- 'labelSpan': label
- var li = document.createElement("li");
- li.appendChild(label);
- if(baseLayer)
- this.baseLayersUl.appendChild(li);
- else
- this.dataLayersUl.appendChild(li);
- if(!containsBaseLayers)
- this.baseLbl.style.display = "none";
- else
- this.baseLbl.style.display = "";
- if(!containsOverlays)
- this.dataLbl.style.display = "none";
- else
- this.dataLbl.style.display = "";
- return this.div;
- * Method:
- * A label has been clicked, check or uncheck its corresponding input
- * Parameters:
- * e - {Event}
- * Context:
- * - {DOMElement} inputElem
- * - {<OpenLayers.Control.LayerSwitcher>} layerSwitcher
- * - {<OpenLayers.Layer>} layer
- onInputClick: function(e) {
- if (!this.inputElem.disabled) {
- if (this.inputElem.type == "radio") {
- this.inputElem.checked = true;
- this.layer.map.setBaseLayer(this.layer);
- } else {
- this.inputElem.checked = !this.inputElem.checked;
- this.layerSwitcher.updateMap();
- OpenLayers.Event.stop(e);
- * Method: updateMap
- * Cycles through the loaded data and base layer input arrays and makes
- * the necessary calls to the Map object such that that the map's
- * visual state corresponds to what the user has selected in
- * the control.
- updateMap: function() {
- // set the newly selected base layer
- for(var i=0, len=this.baseLayers.length; i<len; i++) {
- var layerEntry = this.baseLayers[i];
- if (layerEntry.inputElem.checked) {
- this.map.setBaseLayer(layerEntry.layer, false);
- // set the correct visibilities for the overlays
- for(var i=0, len=this.dataLayers.length; i<len; i++) {
- var layerEntry = this.dataLayers[i];
- layerEntry.layer.setVisibility(layerEntry.inputElem.checked);
- * Method: maximizeControl
- * Set up the labels and divs for the control
- * Parameters:
- * e - {Event}
- maximizeControl: function(e) {
- this.div.style.display = "block";
- if (e != null) {
- * Method: minimizeControl
- * Hide all the contents of the control, shrink the size,
- * add the maximize icon
- * Parameters:
- * e - {Event}
- minimizeControl: function(e) {
- this.div.style.display = "none";
- if (e != null) {
- * Method: loadContents
- loadContents: function() {
- this.triggerBtn = document.createElement("div");
- this.triggerBtn.innerHTML = "Layers";
- OpenLayers.Element.addClass(this.triggerBtn, "olControlMobileLayerSwitcherTrigger");
- OpenLayers.Event.observe(this.triggerBtn, "click",
- OpenLayers.Function.bindAsEventListener(this.maximizeControl, this)
- this.closeBtn = document.createElement("a");
- this.closeBtn.href = "#";
- this.closeBtn.innerHTML = "Close";
- OpenLayers.Element.addClass(this.closeBtn, "btnClose");
- OpenLayers.Event.observe(this.closeBtn, "click",
- OpenLayers.Function.bindAsEventListener(this.minimizeControl, this)
- this.baseLbl = document.createElement("span");
- this.baseLbl.innerHTML = OpenLayers.i18n("baseLayer");
- this.baseLayersUl = document.createElement("ul");
- this.dataLbl = document.createElement("span");
- this.dataLbl.innerHTML = OpenLayers.i18n("overlays");
- this.dataLayersUl = document.createElement("ul");
- this.div.appendChild(this.closeBtn);
- this.div.appendChild(this.baseLbl);
- this.div.appendChild(this.baseLayersUl);
- this.div.appendChild(this.dataLbl);
- this.div.appendChild(this.dataLayersUl);
- this.map.div.appendChild(this.triggerBtn);
- CLASS_NAME: "OpenLayers.Control.MobileLayerSwitcher"
More information about the Commits
