[OpenLayers-Commits] r11367 -
sandbox/jennier/openlayers/lib/OpenLayers/Layer
commits-20090109 at openlayers.org
Wed Feb 23 13:17:13 EST 2011
Author: jennier
Date: 2011-02-23 10:17:13 -0800 (Wed, 23 Feb 2011)
New Revision: 11367
sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMapCache.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js
sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js
In order to use the stored tile we need a small modification to the getURL function of the layers that extend Grid.js. This will call the Grid.js GetURL function that will allow the image to be proxied if needed and will replace the URL with the data URI from the store if the tile has been stored.
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcGIS93Rest.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -172,8 +172,10 @@
newParams['LAYERDEFS'] = layerDefStrList.join("");
- var requestString = this.getFullRequestString(newParams);
- return requestString;
+ var url = this.getFullRequestString(newParams);
+ // Check to see if the Image has been stored locally
+ return OpenLayers.Layer.Grid.prototype.getURL.apply(this, [url]);
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/ArcIMS.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -205,7 +205,8 @@
url = this.getUrlOrImage(arcxml.image.output);
- return url;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMap.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -87,11 +87,14 @@
var scale = Math.round((this.map.getScale() * 10000)) / 10000;
var pX = Math.round(bounds.left / mapRes);
var pY = -Math.round(bounds.top / mapRes);
- return this.getFullRequestString(
{ t: pY,
l: pX,
s: scale
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMapCache.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMapCache.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/KaMapCache.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -141,7 +141,10 @@
this.extension
- return components.join("");
+ url = components.join("");
CLASS_NAME: "OpenLayers.Layer.KaMapCache"
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapGuide.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -320,7 +320,10 @@
- return url;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/MapServer.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -123,7 +123,8 @@
imgxy: [imageSize.w, imageSize.h]
- return url;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/TMS.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -128,7 +128,10 @@
if (url instanceof Array) {
url = this.selectUrl(path, url);
- return url + path;
+ url = url + path;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/TileCache.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -142,7 +142,10 @@
url = (url.charAt(url.length - 1) == '/') ? url : url + '/';
+ url = url + path;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/WMTS.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -437,7 +437,9 @@
- return url;
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/WorldWind.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -103,17 +103,20 @@
var deg = this.lzd/Math.pow(2,this.getZoom());
var x = Math.floor((bounds.left - extent.left)/deg);
var y = Math.floor((bounds.bottom - extent.bottom)/deg);
+ var url;
if (this.map.getResolution() <= (this.lzd/512)
&& this.getZoom() <= this.zoomLevels) {
+ url = this.getFullRequestString(
{ L: zoom,
X: x,
Y: y
} else {
- return OpenLayers.Util.getImagesLocation() + "blank.gif";
+ url = OpenLayers.Util.getImagesLocation() + "blank.gif";
CLASS_NAME: "OpenLayers.Layer.WorldWind"
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/XYZ.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -125,7 +125,10 @@
url = this.selectUrl(s, url);
- return OpenLayers.String.format(url, xyz);
+ url = OpenLayers.String.format(url, xyz);
Modified: sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js
--- sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js 2011-02-23 18:04:13 UTC (rev 11366)
+++ sandbox/jennier/openlayers/lib/OpenLayers/Layer/Zoomify.js 2011-02-23 18:17:13 UTC (rev 11367)
@@ -208,7 +208,10 @@
+ url = url + path;
More information about the Commits
