[OpenLayers-Commits] r11382 - trunk/openlayers/build
commits-20090109 at openlayers.org
Thu Feb 24 04:08:00 EST 2011
Author: crschmidt
Date: 2011-02-24 01:08:00 -0800 (Thu, 24 Feb 2011)
New Revision: 11382
trunk/openlayers/build/build.py
Add an option to build.py to specify a compressor or 'none' for uncompressed.
Modified: trunk/openlayers/build/build.py
--- trunk/openlayers/build/build.py 2011-02-24 09:00:49 UTC (rev 11381)
+++ trunk/openlayers/build/build.py 2011-02-24 09:08:00 UTC (rev 11382)
@@ -3,40 +3,46 @@
import sys
sys.path.append("../tools")
import mergejs
+import optparse
-def build():
- have_compressor = None
+def build(config_file = None, output_file = None, options = None):
+ have_compressor = []
try:
import jsmin
- have_compressor = "jsmin"
+ have_compressor.append("jsmin")
except ImportError:
- try:
- import minimize
- have_compressor = "minimize"
- except Exception, E:
- print E
- pass
+ print "No jsmin"
+ try:
+ import minimize
+ have_compressor.append("minimize")
+ except ImportError:
+ print "No minimize"
+ use_compressor = None
+ if options.compressor and options.compressor in have_compressor:
+ use_compressor = options.compressor
sourceDirectory = "../lib"
configFilename = "full.cfg"
outputFilename = "OpenLayers.js"
- if len(sys.argv) > 1:
- configFilename = sys.argv[1]
+ if config_file:
+ configFilename = config_file
extension = configFilename[-4:]
if extension != ".cfg":
- configFilename = sys.argv[1] + ".cfg"
+ configFilename = config_file + ".cfg"
- if len(sys.argv) > 2:
- outputFilename = sys.argv[2]
+ if output_file:
+ outputFilename = output_file
print "Merging libraries."
merged = mergejs.run(sourceDirectory, None, configFilename)
- if have_compressor == "jsmin":
+ if use_compressor == "jsmin":
print "Compressing using jsmin."
minimized = jsmin.jsmin(merged)
- elif have_compressor == "minimize":
+ elif use_compressor == "minimize":
print "Compressing using minimize."
minimized = minimize.minimize(merged)
else: # fallback
@@ -51,4 +57,7 @@
print "Done."
if __name__ == '__main__':
- build()
\ No newline at end of file
+ opt = optparse.OptionParser(usage="%s [options] [config_file] [output_file]\n Default config_file is 'full.cfg', Default output_file is 'OpenLayers.js'")
+ opt.add_option("-c", "--compressor", dest="compressor", help="compression method: one of 'jsmin', 'minimize', or 'none'", default="jsmin")
+ (options, args) = opt.parse_args()
+ build(*args, options=options)
More information about the Commits
