[OpenLayers-Commits] r11389 - in trunk/openlayers: lib
lib/OpenLayers lib/OpenLayers/Handler tests tests/Handler
commits-20090109 at openlayers.org
Thu Feb 24 05:05:49 EST 2011
Author: tschaub
Date: 2011-02-24 02:05:49 -0800 (Thu, 24 Feb 2011)
New Revision: 11389
Added:
trunk/openlayers/lib/OpenLayers/Handler/Pinch.js
trunk/openlayers/tests/Handler/Pinch.html
trunk/openlayers/lib/OpenLayers.js
trunk/openlayers/lib/OpenLayers/Events.js
trunk/openlayers/tests/list-tests.html
Adding a pinch handler for multi-touch devices. Great patch from Bruno. p=bbinet, r=me (closes #3077)
Modified: trunk/openlayers/lib/OpenLayers/Events.js
--- trunk/openlayers/lib/OpenLayers/Events.js 2011-02-24 09:58:10 UTC (rev 11388)
+++ trunk/openlayers/lib/OpenLayers/Events.js 2011-02-24 10:05:49 UTC (rev 11389)
@@ -105,6 +105,20 @@
+ * Method: isMultiTouch
+ * Determine whether event was caused by a multi touch
+ * Parameters:
+ * event - {Event}
+ * Returns:
+ * {Boolean}
+ isMultiTouch: function(event) {
+ return event.touches && event.touches.length > 1;
* Method: isLeftClick
* Determine whether event was caused by a left click.
Added: trunk/openlayers/lib/OpenLayers/Handler/Pinch.js
--- trunk/openlayers/lib/OpenLayers/Handler/Pinch.js (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Handler/Pinch.js 2011-02-24 10:05:49 UTC (rev 11389)
@@ -0,0 +1,227 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Handler.js
+ * Class: OpenLayers.Handler.Pinch
+ * The pinch handler is used to deal with sequences of browser events related
+ * to pinch gestures. The handler is used by controls that want to know
+ * when a pinch sequence begins, when a pinch is happening, and when it has
+ * finished.
+ * Controls that use the pinch handler typically construct it with callbacks
+ * for 'start', 'move', and 'done'. Callbacks for these keys are
+ * called when the pinch begins, with each change, and when the pinch is
+ * done.
+ * Create a new pinch handler with the <OpenLayers.Handler.Pinch> constructor.
+ * Inherits from:
+ * - <OpenLayers.Handler>
+OpenLayers.Handler.Pinch = OpenLayers.Class(OpenLayers.Handler, {
+ * Property: started
+ * {Boolean} When a touchstart event is received, we want to record it,
+ * but not set 'pinching' until the touchmove get started after
+ * starting.
+ started: false,
+ * Property: stopDown
+ * {Boolean} Stop propagation of touchstart events from getting to
+ * listeners on the same element. Default is true.
+ stopDown: true,
+ * Property: pinching
+ * {Boolean}
+ pinching: false,
+ * Property: last
+ * {Object} Object that store informations related to pinch last touch.
+ last: null,
+ * Property: start
+ * {Object} Object that store informations related to pinch touchstart.
+ start: null,
+ * Constructor: OpenLayers.Handler.Pinch
+ * Returns OpenLayers.Handler.Pinch
+ * Parameters:
+ * control - {<OpenLayers.Control>} The control that is making use of
+ * this handler. If a handler is being used without a control, the
+ * handlers setMap method must be overridden to deal properly with
+ * the map.
+ * callbacks - {Object} An object containing functions to be called when
+ * the pinch operation start, change, or is finished. The callbacks
+ * should expect to receive an object argument, which contains
+ * information about scale, distance, and position of touch points.
+ * options - {Object}
+ initialize: function(control, callbacks, options) {
+ OpenLayers.Handler.prototype.initialize.apply(this, arguments);
+ * Method: touchstart
+ * Handle touchstart events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Boolean} Let the event propagate.
+ touchstart: function(evt) {
+ var propagate = true;
+ this.pinching = false;
+ if (OpenLayers.Event.isMultiTouch(evt)) {
+ this.started = true;
+ this.last = this.start = {
+ distance: this.getDistance(evt.touches),
+ delta: 0,
+ scale: 1
+ this.callback("start", [evt, this.start]);
+ propagate = !this.stopDown;
+ } else {
+ this.started = false;
+ this.start = null;
+ this.last = null;
+ OpenLayers.Event.stop(evt);
+ return propagate;
+ * Method: touchmove
+ * Handle touchmove events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ touchmove: function(evt) {
+ if (this.started && OpenLayers.Event.isMultiTouch(evt)) {
+ this.pinching = true;
+ var current = this.getPinchData(evt);
+ this.callback("move", [evt, current]);
+ this.last = current;
+ return true;
+ * Method: touchend
+ * Handle touchend events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ touchend: function(evt) {
+ if (this.started) {
+ this.callback("done", [evt, this.start, this.last]);
+ this.last = null;
+ return true;
+ * Method: activate
+ * Activate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully activated.
+ activate: function() {
+ var activated = false;
+ if (OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
+ activated = true;
+ return activated;
+ * Method: deactivate
+ * Deactivate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully deactivated.
+ deactivate: function() {
+ var deactivated = false;
+ if (OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
+ this.last = null;
+ deactivated = true;
+ return deactivated;
+ * Method: getDistance
+ * Get the distance in pixels between two touches.
+ * Parameters:
+ * touches - {Array(Object)}
+ getDistance: function(touches) {
+ var t0 = touches[0];
+ var t1 = touches[1];
+ return Math.sqrt(
+ Math.pow(t0.clientX - t1.clientX, 2) +
+ Math.pow(t0.clientY - t1.clientY, 2)
+ * Method: getPinchData
+ * Get informations about the pinch event.
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Object} Object that contains data about the current pinch.
+ getPinchData: function(evt) {
+ var distance = this.getDistance(evt.touches);
+ var scale = distance / this.start.distance;
+ return {
+ distance: distance,
+ delta: this.last.distance - distance,
+ scale: scale
+ CLASS_NAME: "OpenLayers.Handler.Pinch"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js 2011-02-24 09:58:10 UTC (rev 11388)
+++ trunk/openlayers/lib/OpenLayers.js 2011-02-24 10:05:49 UTC (rev 11389)
@@ -170,6 +170,7 @@
"OpenLayers/Handler/Polygon.js",
"OpenLayers/Handler/Feature.js",
"OpenLayers/Handler/Drag.js",
+ "OpenLayers/Handler/Pinch.js",
"OpenLayers/Handler/RegularPolygon.js",
"OpenLayers/Handler/Box.js",
"OpenLayers/Handler/MouseWheel.js",
Added: trunk/openlayers/tests/Handler/Pinch.html
--- trunk/openlayers/tests/Handler/Pinch.html (rev 0)
+++ trunk/openlayers/tests/Handler/Pinch.html 2011-02-24 10:05:49 UTC (rev 11389)
@@ -0,0 +1,264 @@
+<html>
+<head>
+ <script src="../OLLoader.js"></script>
+ <script type="text/javascript">
+ function test_constructor(t) {
+ t.plan(3);
+ var control = new OpenLayers.Control();
+ control.id = Math.random();
+ var callbacks = {foo: "bar"};
+ var options = {bar: "foo"};
+ var oldInit = OpenLayers.Handler.prototype.initialize;
+ OpenLayers.Handler.prototype.initialize = function(con, call, opt) {
+ t.eq(con.id, control.id,
+ "constructor calls parent with the correct control");
+ t.eq(call, callbacks,
+ "constructor calls parent with the correct callbacks");
+ t.eq(opt, options,
+ "constructor calls parent with the correct options");
+ var handler = new OpenLayers.Handler.Pinch(control, callbacks, options);
+ OpenLayers.Handler.prototype.initialize = oldInit;
+ function test_activate(t) {
+ t.plan(3);
+ var map = new OpenLayers.Map('map');
+ map.addControl(control);
+ var handler = new OpenLayers.Handler.Pinch(control);
+ handler.active = true;
+ var activated = handler.activate();
+ t.ok(!activated,
+ "activate returns false if the handler was already active");
+ handler.active = false;
+ handler.pinching = true;
+ activated = handler.activate();
+ t.ok(activated,
+ "activate returns true if the handler was not already active");
+ t.ok(!handler.pinching,
+ "activate sets pinching to false");
+ function test_events(t) {
+ // each handled event should be activated twice when handler is
+ // activated, so:
+ // 27 = 4tests * 2*3events + 1tests * 3events
+ t.plan(27);
+ // list below events that should be handled (events) and those
+ // that should not be handled (nonevents) by the handler
+ var events = ["touchend", "touchmove", "touchstart"];
+ var nonevents = ["mousedown", "mouseup", "mousemove", "mouseout",
+ "click", "dblclick", "resize", "focus", "blur"];
+ map.events.registerPriority = function(type, obj, func) {
+ // this is one of the mock handler methods
+ t.eq(OpenLayers.Util.indexOf(nonevents, type), -1,
+ "registered method is not one of the events " +
+ "that should not be handled: " + type);
+ t.ok(OpenLayers.Util.indexOf(events, type) > -1,
+ "activate calls registerPriority with browser event: " + type);
+ t.eq(typeof func, "function",
+ "activate calls registerPriority with a function");
+ t.eq(obj["CLASS_NAME"], "OpenLayers.Handler.Pinch",
+ "activate calls registerPriority with the handler");
+ handler.activate();
+ handler.deactivate();
+ // set browser event like properties on the handler
+ for(var i=0; i<events.length; ++i) {
+ setMethod(events[i]);
+ function setMethod(key) {
+ handler[key] = function() {return key;};
+ var r = func();
+ if(typeof r == "string") {
+ t.eq(r, type,
+ "activate calls registerPriority with the correct method");
+ function test_callbacks(t) {
+ t.plan(23);
+ var map = new OpenLayers.Map('map', {controls: []});
+ // set fake values for touches
+ var testEvents = {
+ start: {
+ type: 'start',
+ touches: [{
+ clientX: 100,
+ clientY: 0
+ clientX: 0,
+ clientY: 0
+ move: {
+ type: 'move',
+ touches: [{
+ clientX: 100,
+ clientY: 0
+ clientX: 20,
+ clientY: 0
+ done: {
+ type: 'done',
+ touches: []
+ // set callback methods
+ var customCb = OpenLayers.Function.False;
+ var cb = function(evt) {
+ var tch = testEvents[evt.type].touches;
+ t.ok(evt.touches[0].clientX == tch[0].clientX &&
+ evt.touches[0].clientY == tch[0].clientY,
+ "touchstart sets first touch position correctly in evt");
+ t.ok(evt.touches[1].clientX == tch[1].clientX &&
+ evt.touches[1].clientY == tch[1].clientY,
+ "touchstart sets second touch position correctly in evt");
+ t.eq(handler.start.distance, 100, "start distance is " +
+ "always the same");
+ customCb.apply(this, arguments);
+ var callbacks = {
+ start: cb,
+ move: cb,
+ done: customCb
+ var handler = new OpenLayers.Handler.Pinch(control, callbacks);
+ var old_isMultiTouch = OpenLayers.Event.isMultiTouch;
+ var old_stop = OpenLayers.Event.stop;
+ // test single touch
+ OpenLayers.Event.isMultiTouch = function() {
+ return false;
+ handler.started = true;
+ handler.start = {
+ distance: 100,
+ delta: 0,
+ scale: 1
+ handler.last = {
+ distance: 150,
+ delta: 10,
+ scale: 1.5
+ map.events.triggerEvent("touchstart", testEvents.start);
+ t.ok(!handler.started, "1) touchstart (singletouch) sets started to false");
+ t.eq(handler.start, null, "1) touchstart (singletouch) sets start to null");
+ t.eq(handler.last, null, "1) touchstart (singletouch) sets last to null");
+ OpenLayers.Event.stop = function(evt, allowDefault) {
+ if(allowDefault) {
+ t.fail(
+ "touchstart is prevented from falling to other elements");
+ OpenLayers.Event.isMultiTouch = function(evt) {
+ var res = old_isMultiTouch(evt);
+ t.ok(res, "fake event is a mutitouch touch event");
+ return res;
+ customCb = function(evt, pinchdata) {
+ t.eq(pinchdata.distance, 100, "2) calculated distance is correct");
+ t.eq(pinchdata.delta, 0, "2) calculated delta is correct");
+ t.eq(pinchdata.scale, 1, "2) calculated scale is correct");
+ t.ok(handler.started, "2) touchstart sets the started flag to true");
+ t.ok(!handler.pinching, "2) touchstart sets the pinching flag to false");
+ t.eq(pinchdata.distance, 80, "3) calculated distance is correct");
+ t.eq(pinchdata.delta, 20, "3) calculated delta is correct");
+ t.eq(pinchdata.scale, 0.8, "3) calculated scale is correct");
+ map.events.triggerEvent("touchmove", testEvents.move);
+ t.ok(handler.started, "3) started flag still set to true");
+ t.ok(handler.pinching, "3) touchmove sets the pinching flag to true");
+ customCb = function(evt, first, last) {
+ t.eq(first.distance, 100, "4) calculated distance is correct");
+ t.eq(first.delta, 0, "4) calculated delta is correct");
+ t.eq(first.scale, 1, "4) calculated scale is correct");
+ t.eq(last.distance, 80, "4) calculated distance is correct");
+ t.eq(last.delta, 20, "4) calculated delta is correct");
+ t.eq(last.scale, 0.8, "4) calculated scale is correct");
+ map.events.triggerEvent("touchend", testEvents.done);
+ t.ok(!handler.started, "4) started flag is set to false");
+ t.ok(!handler.pinching, "4) touchdone sets the pinching flag to false");
+ OpenLayers.Event.stop = old_stop;
+ OpenLayers.Event.isMultiTouch = old_isMultiTouch;
+ // test move or done before start
+ customCb = function(evt) {
+ t.fail("should not pass here")
+ map.events.triggerEvent("touchend", testEvents.end);
+ function test_deactivate(t) {
+ t.plan(6);
+ var deactivated = handler.deactivate();
+ t.ok(!deactivated,
+ "deactivate returns false if the handler was not already active");
+ deactivated = handler.deactivate();
+ t.ok(deactivated,
+ "deactivate returns true if the handler was active already");
+ "deactivate sets started to false");
+ "deactivate sets pinching to false");
+ t.ok(handler.start == null,
+ "deactivate sets start to null");
+ t.ok(handler.last == null,
+ </script>
+</head>
+<body>
+ <div id="map" style="width: 300px; height: 150px;"/>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html 2011-02-24 09:58:10 UTC (rev 11388)
+++ trunk/openlayers/tests/list-tests.html 2011-02-24 10:05:49 UTC (rev 11389)
@@ -118,6 +118,7 @@
<li>Handler/Box.html</li>
<li>Handler/Click.html</li>
<li>Handler/Drag.html</li>
+ <li>Handler/Pinch.html</li>
<li>Handler/Feature.html</li>
<li>Handler/Hover.html</li>
<li>Handler/Keyboard.html</li>
More information about the Commits
