[OpenLayers-Commits] r11417 - in sandbox/ahocevar/layercontainer: lib/OpenLayers tests
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Thu Feb 24 09:08:25 EST 2011
Author: ahocevar
Date: 2011-02-24 06:08:25 -0800 (Thu, 24 Feb 2011)
New Revision: 11417
   sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
   sandbox/ahocevar/layercontainer/tests/Map.html
patch cleanup, reverted remaining caching stuff
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-24 13:42:39 UTC (rev 11416)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js	2011-02-24 14:08:25 UTC (rev 11417)
@@ -228,6 +228,10 @@
     center: null,
+     * Property: centerPx
+     * {OpenLayers.Pixel} Cached layer pixel position of the map center
     centerPx: null,
@@ -241,7 +245,7 @@
      * {Integer} The current zoom level of the map
     zoom: 0,
      * Property: panRatio
      * {Float} The ratio of the current extent within
@@ -1396,7 +1400,7 @@
         var newSize = this.getCurrentSize();
         if (newSize && !isNaN(newSize.h) && !isNaN(newSize.w)) {
             this.events.clearMouseCache();
-            var oldSize = this.size;
+            var oldSize = this.getSize();
             if (oldSize == null) {
                 this.size = oldSize = newSize;
@@ -1413,7 +1417,7 @@
                 var center = this.getCenter();
                 if (this.baseLayer != null && center != null) {
-                    var zoom = this.zoom;
+                    var zoom = this.getZoom();
                     this.zoom = null;
                     this.setCenter(center, zoom);
@@ -1469,7 +1473,7 @@
         if ((center != null) && (resolution != null)) {
-            var size = this.size;
+            var size = this.getSize();
             var w_deg = size.w * resolution;
             var h_deg = size.h * resolution;
@@ -1515,7 +1519,7 @@
     getCachedCenterPx: function() {
         if (!this.centerPx) {
-            this.centerPx = this.getViewPortPxFromLonLat(this.center);
+            this.centerPx = this.getViewPortPxFromLonLat(this.getCenter());
         return this.centerPx;
@@ -1868,13 +1872,12 @@
         if (!dragging && !noEvent) {
             this.events.triggerEvent("moveend");
         // Store the map dragging state for later use
         this.dragging = !!dragging;
      * Method: centerLayerContainer
      * This function takes care to recenter the layerContainerDiv.
@@ -1883,6 +1886,7 @@
      * lonlat - {<OpenLayers.LonLat>}
     centerLayerContainer: function (lonlat) {
         var originPx = this.getViewPortPxFromLonLat(this.layerContainerOrigin);
         var newPx = this.getViewPortPxFromLonLat(lonlat);
@@ -1900,7 +1904,7 @@
             this.minPx.y -= dy;
             this.maxPx.y -= dy;
@@ -2074,7 +2078,7 @@
         return extent;
      * APIMethod: getResolution
@@ -2223,7 +2227,7 @@
      * zoom - {int}
     zoomIn: function() {
-        this.zoomTo(this.zoom + 1);
+        this.zoomTo(this.getZoom() + 1);
@@ -2233,7 +2237,7 @@
      * zoom - {int}
     zoomOut: function() {
-        this.zoomTo(this.zoom - 1);
+        this.zoomTo(this.getZoom() - 1);
@@ -2311,7 +2315,7 @@
     zoomToScale: function(scale, closest) {
         var res = OpenLayers.Util.getResolutionFromScale(scale,
                                                          this.baseLayer.units);
         var w_deg = size.w * res;
         var h_deg = size.h * res;
@@ -2426,7 +2430,7 @@
      * {<OpenLayers.Size>} The geodesic size of the pixel in kilometers.
     getGeodesicPixelSize: function(px) {
-        var lonlat = px ? this.getLonLatFromPixel(px) : (this.getCenter() ||
+        var lonlat = px ? this.getLonLatFromPixel(px) : (this.getCenter() ||
             new OpenLayers.LonLat(0, 0));
         var res = this.getResolution();
         var left = lonlat.add(-res / 2, 0);
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-24 13:42:39 UTC (rev 11416)
+++ sandbox/ahocevar/layercontainer/tests/Map.html	2011-02-24 14:08:25 UTC (rev 11417)
@@ -1318,8 +1318,8 @@
         var m = {
             'baseLayer': { 'units': {} },
-            'size': {'w': 10, 'h': 15},
-            'getCenter': function() {return {'lon': -5, 'lat': -25};},
+            'getSize': function() {return {'w': 10, 'h': 15}; },
+            'getCenter': function() {return {'lon': -5, 'lat': -25}; },
             'zoomToExtent': function(extent, closest) {
                 t.ok(extent.equals(g_ExpectedExtent), "extent correctly calculated for zoomToExtent()");
                 t.ok(closest == g_Closest, "closest correctly passed on to zoomToExtent()");
More information about the Commits mailing list
