[OpenLayers-Commits] r11425 -
sandbox/ahocevar/layercontainer/lib/OpenLayers
commits-20090109 at openlayers.org
Thu Feb 24 10:52:03 EST 2011
Author: ahocevar
Date: 2011-02-24 07:52:03 -0800 (Thu, 24 Feb 2011)
New Revision: 11425
sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
switch between centerPx and center, depending on the method we used for positioning/moving the map
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-24 15:48:11 UTC (rev 11424)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Layer.js 2011-02-24 15:52:03 UTC (rev 11425)
@@ -1211,21 +1211,16 @@
getLonLatFromViewPortPx: function (viewPortPx) {
var lonlat = null;
if (viewPortPx != null) {
- var size = this.map.getSize();
- var center = this.map.getCenter();
- if (center) {
- var res = this.map.getResolution();
- var delta_x = viewPortPx.x - (size.w / 2);
- var delta_y = viewPortPx.y - (size.h / 2);
- lonlat = new OpenLayers.LonLat(center.lon + delta_x * res ,
- center.lat - delta_y * res);
+ var map = this.map;
+ var res = map.getResolution();
+ var maxExtent = map.getMaxExtent();
+ var lon = (viewPortPx.x - map.minPx.x) * res + maxExtent.left;
+ var lat = (map.minPx.y - viewPortPx.y) * res + maxExtent.top;
+ lonlat = new OpenLayers.LonLat(lon, lat);
- if (this.wrapDateLine) {
- lonlat = lonlat.wrapDateLine(this.maxExtent);
- } // else { DEBUG STATEMENT }
+ if (this.wrapDateLine) {
+ lonlat = lonlat.wrapDateLine(this.maxExtent);
return lonlat;
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-24 15:48:11 UTC (rev 11424)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-24 15:52:03 UTC (rev 11425)
@@ -1152,7 +1152,7 @@
if (OpenLayers.Util.indexOf(this.layers, newBaseLayer) != -1) {
// preserve center and scale when changing base layers
- var center = this.getCenter();
+ var center = this.getCachedCenter();
var newResolution = OpenLayers.Util.getResolutionFromScale(
this.getScale(), newBaseLayer.units
@@ -1414,7 +1414,7 @@
this.layers[i].onMapResize();
if (this.baseLayer != null && center != null) {
var zoom = this.getZoom();
@@ -1465,7 +1465,7 @@
var extent = null;
if (center == null) {
- center = this.getCenter();
+ center = this.getCachedCenter();
if (resolution == null) {
resolution = this.getResolution();
@@ -1505,23 +1505,24 @@
getCenter: function () {
var center = null;
- if (this.center) {
- center = this.center.clone();
+ var cachedCenter = this.getCachedCenter();
+ if (cachedCenter) {
+ center = cachedCenter.clone();
return center;
- * Method: getCachedCenterPx
+ * Method: getCachedCenter
* Returns:
- * {<OpenLayers.Pixel>}
+ * {<OpenLayers.LonLat>}
- getCachedCenterPx: function() {
- if (!this.centerPx) {
- this.centerPx = this.getViewPortPxFromLonLat(this.getCenter());
+ getCachedCenter: function() {
+ if (!this.center) {
+ this.center = this.getLonLatFromViewPortPx(this.centerPx);
- return this.centerPx;
+ return this.center;
@@ -1553,11 +1554,14 @@
if (options.dragging) {
if (dx != 0 || dy != 0) {
+ if (!this.centerPx) {
+ this.centerPx = this.getViewPortPxFromLonLat(this.center);
this.moveByPx(dx, dy);
} else {
// getCenter
- var centerPx = this.getCachedCenterPx();
+ var centerPx = this.getViewPortPxFromLonLat(this.getCachedCenter());
// adjust
var newCenterPx = centerPx.add(dx, dy);
@@ -1570,6 +1574,7 @@
this.setCenter(newCenterLonLat, null, options.dragging);
+ this.centerPx = null;
@@ -1587,7 +1592,7 @@
if (!this.panTween) {
this.panTween = new OpenLayers.Tween(this.panMethod);
// center will not change, don't do nothing
if (lonlat.lon == center.lon &&
@@ -1660,13 +1665,14 @@
* dy - {Number}
moveByPx: function(dx, dy) {
- var centerPx = this.getCachedCenterPx().add(dx, dy);
+ var centerPx = this.centerPx.add(dx, dy);
var valid = centerPx.x <= this.maxPx.x &&
centerPx.x >= this.minPx.x &&
centerPx.y <= this.maxPx.y &&
centerPx.y >= this.minPx.y;
if (valid === true) {
this.center = null;
+ this.centerPx = centerPx;
if (dx) {
this.layerContainerDiv.style.left =
parseInt(this.layerContainerDiv.style.left) - dx + "px";
@@ -1722,14 +1728,14 @@
this.panTween.stop();
- if (!this.center && !this.isValidLonLat(lonlat)) {
+ if (!this.getCachedCenter() && !this.isValidLonLat(lonlat)) {
lonlat = this.maxExtent.getCenterLonLat();
if(this.restrictedExtent != null) {
// In 3.0, decide if we want to change interpretation of maxExtent.
if(lonlat == null) {
- lonlat = this.getCenter();
+ lonlat = this.getCachedCenter();
if(zoom == null) {
@@ -1765,7 +1771,7 @@
(zoom != this.getZoom()) );
var centerChanged = (this.isValidLonLat(lonlat)) &&
- (!lonlat.equals(this.center));
+ (!lonlat.equals(this.getCachedCenter()));
// if neither center nor zoom will change, no need to do anything
@@ -1776,24 +1782,26 @@
if (centerChanged) {
- if ((!zoomChanged) && (this.center)) {
+ if ((!zoomChanged) && (this.getCachedCenter())) {
// if zoom hasnt changed, just slide layerContainer
// (must be done before setting this.center to new value)
this.centerLayerContainer(lonlat);
this.center = lonlat.clone();
// (re)set the layerContainerDiv's location
if ((zoomChanged) || (this.layerContainerOrigin == null)) {
- this.layerContainerOrigin = this.center.clone();
+ this.layerContainerOrigin = this.getCachedCenter();
this.layerContainerDiv.style.left = "0px";
this.layerContainerDiv.style.top = "0px";
var res = this.resolution || this.getResolutionForZoom(zoom);
var maxExtent = this.getMaxExtent();
var maxExtentCenter = maxExtent.getCenterLonLat();
- var lonDelta = this.center.lon - maxExtentCenter.lon;
- var latDelta = maxExtentCenter.lat - this.center.lat;
+ var lonDelta = cachedCenter.lon - maxExtentCenter.lon;
+ var latDelta = maxExtentCenter.lat - cachedCenter.lat;
var extentWidth = Math.round(maxExtent.getWidth() / res);
var extentHeight = Math.round(maxExtent.getHeight() / res);
var left = (this.size.w - extentWidth) / 2 - lonDelta / res;
@@ -1886,7 +1894,6 @@
* lonlat - {<OpenLayers.LonLat>}
centerLayerContainer: function (lonlat) {
var originPx = this.getViewPortPxFromLonLat(this.layerContainerOrigin);
var newPx = this.getViewPortPxFromLonLat(lonlat);
@@ -1903,8 +1910,8 @@
this.maxPx.x -= dx;
this.minPx.y -= dy;
this.maxPx.y -= dy;
+ this.centerPx = this.getViewPortPxFromLonLat(lonlat);
@@ -2318,7 +2325,7 @@
var size = this.getSize();
var w_deg = size.w * res;
var h_deg = size.h * res;
var extent = new OpenLayers.Bounds(center.lon - w_deg / 2,
center.lat - h_deg / 2,
@@ -2430,8 +2437,8 @@
* {<OpenLayers.Size>} The geodesic size of the pixel in kilometers.
getGeodesicPixelSize: function(px) {
- var lonlat = px ? this.getLonLatFromPixel(px) : (this.getCenter() ||
- new OpenLayers.LonLat(0, 0));
+ var lonlat = px ? this.getLonLatFromPixel(px) : (
+ this.getCachedCenter() || new OpenLayers.LonLat(0, 0));
var res = this.getResolution();
var left = lonlat.add(-res / 2, 0);
var right = lonlat.add(res / 2, 0);
More information about the Commits
