[OpenLayers-Commits] r11441 - in sandbox/pinch: build examples
commits-20090109 at openlayers.org
Thu Feb 24 12:26:04 EST 2011
Author: tschaub
Date: 2011-02-24 09:26:04 -0800 (Thu, 24 Feb 2011)
New Revision: 11441
sandbox/pinch/build/OpenLayers.js
sandbox/pinch/examples/mobile-navigation.html
sandbox/pinch/examples/mobile-navigation.js
Update to use a slim build.
Modified: sandbox/pinch/build/OpenLayers.js
--- sandbox/pinch/build/OpenLayers.js 2011-02-24 17:22:52 UTC (rev 11440)
+++ sandbox/pinch/build/OpenLayers.js 2011-02-24 17:26:04 UTC (rev 11441)
@@ -122,17 +122,19 @@
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
* POSSIBILITY OF SUCH DAMAGE.
- */(function(){if(window.google&&google.gears){return;}
-var factory=null;if(typeof GearsFactory!='undefined'){factory=new GearsFactory();}else{try{factory=new ActiveXObject('Gears.Factory');if(factory.getBuildInfo().indexOf('ie_mobile')!=-1){factory.privateSetGlobalObject(this);}}catch(e){if((typeof navigator.mimeTypes!='undefined')&&navigator.mimeTypes["application/x-googlegears"]){factory=document.createElement("object");factory.style.display="none";factory.width=0;factory.height=0;factory.type="application/x-googlegears";document.documentElement.appendChild(factory);}}}
-if(!factory){return;}
-if(!window.google){google={};}
-if(!google.gears){google.gears={factory:factory};}})();var OpenLayers={VERSION_NUMBER:"$Revision: 10995 $",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
+ */var OpenLayers={VERSION_NUMBER:"$Revision: 10995 $",singleFile:true,_getScriptLocation:(function(){var r=new RegExp("(^|(.*?\\/))(OpenLayers\.js)(\\?|$)"),s=document.getElementsByTagName('script'),src,m,l="";for(var i=0,len=s.length;i<len;i++){src=s[i].getAttribute('src');if(src){var m=src.match(r);if(m){l=m[1];break;}}}
return(function(){return l;});})()};OpenLayers.Class=function(){var len=arguments.length;var P=arguments[0];var F=arguments[len-1];var C=typeof F.initialize=="function"?F.initialize:function(){P.apply(this,arguments);};if(len>1){var newArgs=[C,P].concat(Array.prototype.slice.call(arguments).slice(1,len-1),F);OpenLayers.inherit.apply(null,newArgs);}else{C.prototype=F;}
return C;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(P){var C=function(){P.call(this);};var newArgs=[C].concat(Array.prototype.slice.call(arguments));OpenLayers.inherit.apply(null,newArgs);return C.prototype;};OpenLayers.inherit=function(C,P){var F=function(){};F.prototype=P.prototype;C.prototype=new F;var i,l,o;for(i=2,l=arguments.length;i<l;i++){o=arguments[i];if(typeof o==="function"){o=o.prototype;}
OpenLayers.Util.extend(C.prototype,o);}};OpenLayers.Util=OpenLayers.Util||{};OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty("toString")){destination.toString=source.toString;}}
-return destination;};OpenLayers.Protocol=OpenLayers.Class({format:null,options:null,autoDestroy:true,defaultFilter:null,initialize:function(options){options=options||{};OpenLayers.Util.extend(this,options);this.options=options;},mergeWithDefaultFilter:function(filter){var merged;if(filter&&this.defaultFilter){merged=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.defaultFilter,filter]});}else{merged=filter||this.defaultFilter||undefined;}
-return merged;},destroy:function(){this.options=null;this.format=null;},read:function(options){options=options||{};options.filter=this.mergeWithDefaultFilter(options.filter);},create:function(){},update:function(){},"delete":function(){},commit:function(){},abort:function(response){},createCallback:function(method,response,options){return OpenLayers.Function.bind(function(){method.apply(this,[response,options]);},this);},CLASS_NAME:"OpenLayers.Protocol"});OpenLayers.Protocol.Response=OpenLayers.Class({code:null,requestType:null,last:true,features:null,reqFeatures:null,priv:null,initialize:function(options){OpenLayers.Util.extend(this,options);},success:function(){return this.code>0;},CLASS_NAME:"OpenLayers.Protocol.Response"});OpenLayers.Protocol.Response.SUCCESS=1;OpenLayers.Protocol.Response.FAILURE=0;OpenLayers.Protocol.SQL=OpenLayers.Class(OpenLayers.Protocol,{databaseName:'ol',tableName:"ol_vector_features",postReadFiltering:true,initialize:function(options){OpenLayers.
Protocol.prototype.initialize.apply(this,[options]);},destroy:function(){OpenLayers.Protocol.prototype.destroy.apply(this);},supported:function(){return false;},evaluateFilter:function(feature,filter){return filter&&this.postReadFiltering?filter.evaluate(feature):true;},CLASS_NAME:"OpenLayers.Protocol.SQL"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Lang={code:null,defaultCode:"en",ge
tCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
+return destination;};OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},userError:function(error){alert(error);},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){var scripts=document.getElementsByTagName("script");for(var i=0,len=scripts.length;i<len;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){if(console){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=fini
sh;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
+this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
+if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
+window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
+var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
+this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
+if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Lang={code:null,defaultCode:"en",getCode:function()
return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.BROWSER_NAME=="msie")?navigator.userLanguage:navigator.language;}
var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
@@ -301,30 +303,7 @@
str+=coordinateminutes+"'";if(dmsOption.indexOf('dms')>=0){if(coordinateseconds<10){coordinateseconds="0"+coordinateseconds;}
str+=coordinateseconds+'"';}}
if(axis=="lon"){str+=coordinate<0?OpenLayers.i18n("W"):OpenLayers.i18n("E");}else{str+=coordinate<0?OpenLayers.i18n("S"):OpenLayers.i18n("N");}
-return str;};OpenLayers.Format=OpenLayers.Class({options:null,externalProjection:null,internalProjection:null,data:null,keepData:false,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},destroy:function(){},read:function(data){OpenLayers.Console.userError(OpenLayers.i18n("readNotImplemented"));},write:function(object){OpenLayers.Console.userError(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:" ",space:" ",newline:"\n",level:0,pretty:false,nativeJSON:(function(){return!!(window.JSON&&typeof JSON.parse=="function"&&typeof JSON.stringify=="function");})(),initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(json,filter){var object;if(this.nativeJSON){object=JSON.parse(json,filter);}else try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\
d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
-return filter(k,v);}
-object=walk('',object);}}}catch(e){}
-if(this.keepData){this.data=object;}
-return object;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){try{json=(!this.pretty&&this.nativeJSON)?JSON.stringify(value):this.serialize[type].apply(this,[value]);}catch(err){OpenLayers.Console.error("Trouble serializing: "+err);}}
-return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
-return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
-if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
-if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
-var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0,len=array.length;i<len;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),json);}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
-c=b.charCodeAt();return'\\u00'+
-Math.floor(c/16).toString(16)+
-(c%16).toString(16);})+'"';}
-return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
-return'"'+date.getFullYear()+'-'+
-format(date.getMonth()+1)+'-'+
-format(date.getDate())+'T'+
-format(date.getHours())+':'+
-format(date.getMinutes())+':'+
-format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+return str;};OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isSingleTouch:function(event){return event.touches&&event.touches.length==1;},isMultiTouch:function(event){return event.touches&&event.touches.length>1;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},isRightClick:function(event){return(((event.which)&&(event.which==3))||((event.button)&&(event.button==2)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
if(!this.observers){this.observers={};}
@@ -360,720 +339,7 @@
if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);}
return new OpenLayers.Pixel((evt.clientX+this.element.scrolls[0])-this.element.offsets[0]
-this.element.lefttop[0],(evt.clientY+this.element.scrolls[1])-this.element.offsets[1]
--this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(url,size,offset,calculateOffset){this.url=url;this.size=(size)?size:new OpenLayers.Size(20,20);this.offset=offset?offset:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=calculateOffset;var id=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(id);},destroy:function(){this.erase();OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null;},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset);},setSize:function(size){if(size!=null){this.size=size;}
-this.draw();},setUrl:function(url){if(url!=null){this.url=url;}
-this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},erase:function(){if(this.imageDiv!=null&&this.imageDiv.parentNode!=null){OpenLayers.Element.remove(this.imageDiv);}},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
-if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
-var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},isDrawn:function(){var isDrawn=(this.imageDiv&&this.imageDiv.parentNode&&(this.imageDiv.parentNode.nodeType!=11));return isDrawn;},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
-this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.erase();this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},erase:function(){if(this.icon!=null){this.icon.erase();}},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
-this.lonlat=this.map.getLonLatFromLayerPx(px);},isDrawn:function(){var isDrawn=(this.icon&&this.icon.isDrawn());return isDrawn;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,contentSize:null,size:null,contentHTML:null,backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,displayClass:"olPopup",contentDisplayClass:"olPopupContent",padding:0,disableFirefoxOverflowHack:fals
e,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,keepInMap:false,closeOnMove:false,map:null,initialize:function(id,lonlat,contentSize,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
-this.id=id;this.lonlat=lonlat;this.contentSize=(contentSize!=null)?contentSize:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
-this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className=this.displayClass;var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.contentSize.clone(),null,"relative");this.contentDiv.className=this.contentDisplayClass;this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
-this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;if(this.closeOnMove&&this.map){this.map.events.unregister("movestart",this,this.hide);}
-this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
-this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
-this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
-if(this.closeOnMove){this.map.events.register("movestart",this,this.hide);}
-if(!this.disableFirefoxOverflowHack&&OpenLayers.BROWSER_NAME=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
-this.moveTo(px);if(!this.autoSize&&!this.size){this.setSize(this.contentSize);}
-this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
-return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){OpenLayers.Element.show(this.div);if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){OpenLayers.Element.hide(this.div);},setSize:function(contentSize){this.size=contentSize.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth
+contentDivPadding.right;}
-this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.BROWSER_NAME=="msie"){this.contentSize.w+=contentDivPadding.left+contentDivPadding.right;this.contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
-if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
-if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},updateSize:function(){var preparedHTML="<div class='"+this.contentDisplayClass+"'>"+
-this.contentDiv.innerHTML+"</div>";var containerElement=(this.map)?this.map.layerContainerDiv:document.body;var realSize=OpenLayers.Util.getRenderedDimensions(preparedHTML,null,{displayClass:this.displayClass,containerElement:containerElement});var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(preparedHTML,fixedSize,{displayClass:this.contentDisplayClass,containerElement:containerElement});var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
-newSize=this.getSafeContentSize(clippedSize);}}
-this.setSize(newSize);},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
-if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
-if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
-if((this.contentDiv!=null)&&(this.contentHTML!=null)&&(this.contentHTML!=this.contentDiv.innerHTML)){this.contentDiv.innerHTML=this.contentHTML;if(this.autoSize){this.registerImageListeners();this.updateSize();}}},registerImageListeners:function(){var onImgLoad=function(){this.popup.updateSize();if(this.popup.visible()&&this.popup.panMapIfOutOfView){this.popup.panIntoView();}
-OpenLayers.Event.stopObserving(this.img,"load",this.img._onImageLoad);};var images=this.contentDiv.getElementsByTagName("img");for(var i=0,len=images.length;i<len;i++){var img=images[i];if(img.width==0||img.height==0){var context={'popup':this,'img':img};img._onImgLoad=OpenLayers.Function.bind(onImgLoad,context);OpenLayers.Event.observe(img,'load',img._onImgLoad);}}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
-if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
-if(this.map&&this.map.size){var extraX=0,extraY=0;if(this.keepInMap&&!this.panMapIfOutOfView){var px=this.map.getPixelFromLonLat(this.lonlat);switch(this.relativePosition){case"tr":extraX=px.x;extraY=this.map.size.h-px.y;break;case"tl":extraX=this.map.size.w-px.x;extraY=this.map.size.h-px.y;break;case"bl":extraX=this.map.size.w-px.x;extraY=px.y;break;case"br":extraX=px.x;extraY=px.y;break;default:extraX=px.x;extraY=this.map.size.h-px.y;break;}}
-var maxY=this.map.size.h-
-this.map.paddingForPopups.top-
-this.map.paddingForPopups.bottom-
-hPadding-extraY;var maxX=this.map.size.w-
-this.map.paddingForPopups.left-
-this.map.paddingForPopups.right-
-wPadding-extraX;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
-return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){if(this.div.parentNode==null){this.div.style.display="none";document.body.appendChild(this.div);}
-contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;if(this.div.parentNode==document.body){document.body.removeChild(this.div);this.div.style.display="";}}
-return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
-if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
-if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
-if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Popup.Anchored=OpenLayers.Class(OpenL
ayers.Popup,{relativePosition:null,keepInMap:true,anchor:null,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=[id,lonlat,contentSize,contentHTML,closeBox,closeBoxCallback];OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePosition!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(contentSize){OpenLayers.Popup.pro
totype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var size=this.size||this.contentSize;var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:fu
nction(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.
toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
-shortHexCode.charAt(i));}}
-if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
-var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),"backgroundColor","background-color");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
-if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
-if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
-else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
-else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
-else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
-return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
-var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
-brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
-if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
-hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
-return{h:hue,s:saturation,b:brightness};};OpenLayers.Rico=OpenLayers.Rico||{};OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
-var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
-this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColo
r){if(this.options.border){this._renderBorder(e,bgColor);}
-if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
-if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
-el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
-el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
-else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
-if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
-this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
-if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
-if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
-return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
-if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
-if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
-return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
-else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
-else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
-else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
-else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
-if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
-var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
-return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.Anc
horedBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"
OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
-if(this.layer!=null&&this.marker!=null){this.layer.removeMarker(this.marker);}
-this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
-if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
-return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){var id=this.id+"_popup";var anchor=(this.marker)?this.marker.icon:null;if(!this.popup){this.popup=new this.popupClass(id,this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
-if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
-this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,bounds:null,state:null,style:null,url:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry?geometry:null;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
-this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry?this.geometry.clone():null,this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
-return onScreen;},getVisibility:function(){return!(this.style&&this.style.display=='none'||!this.layer||this.layer&&this.layer.styleMap&&this.layer.styleMap.createSymbolizer(this,this.renderIntent).display=='none'||this.layer&&!this.layer.getVisibility());},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
-return atPoint;},destroyPopup:function(){},move:function(location){if(!this.layer||!this.geometry.move){return undefined;}
-var pixel;if(location.CLASS_NAME=="OpenLayers.LonLat"){pixel=this.layer.getViewPortPxFromLonLat(location);}else{pixel=location;}
-var lastPixel=this.layer.getViewPortPxFromLonLat(this.geometry.getBounds().getCenterLonLat());var res=this.layer.map.getResolution();this.geometry.move(res*(pixel.x-lastPixel.x),res*(lastPixel.y-pixel.y));this.layer.drawFeature(this);return lastPixel;},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fil
lOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"inherit"},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"#66cccc",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#66cccc",strokeOpacity:1,strokeLinecap:"round",strokeWidth:2,strokeDashstyle:"solid",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvent
s:"visiblePainted",cursor:"inherit"},'delete':{display:"none"}};OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
-if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&type!="geometrycollection"&&typeof features=="object"){for(var i=0,len=features.length;i<len;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
-return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
-var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
-for(var i=0,len=collection.length;i<len;++i){if(isCollection&&i>0){pieces.push(',');}
-geometry=collection[i].geometry;pieces.push(this.extractGeometry(geometry));}
-if(isCollection){pieces.push(')');}
-return pieces.join('');},extractGeometry:function(geometry){var type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var wktType=type=='collection'?'GEOMETRYCOLLECTION':type.toUpperCase();var data=wktType+'('+this.extract[type].apply(this,[geometry])+')';return data;},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push('('+
-this.extract.point.apply(this,[multipoint.components[i]])+')');}
-return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push('('+
-this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
-return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push('('+
-this.extract.linestring.apply(this,[polygon.components[i]])+')');}
-return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push('('+
-this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
-return array.join(',');},'collection':function(collection){var array=[];for(var i=0,len=collection.components.length;i<len;++i){array.push(this.extractGeometry.apply(this,[collection.components[i]]));}
-return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var point;var points=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=points.length;i<len;++i){point=points[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.point.apply(this,[point]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0,len=points.length;i<len;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=lines.length;i<len;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0,len=rings.length;i<len;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0,len=polygons.length;i<len;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0,len=wktArray.length;i<len;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
-return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Protocol.SQL.Gears=OpenLayers.Class(OpenLayers.Protocol.SQL,{FID_PREFIX:'__gears_fid__',NULL_GEOMETRY:'__gears_null_geometry__',NULL_FEATURE_STATE:'__gears_null_feature_state__',jsonParser:null,wktParser:null,fidRegExp:null,saveFeatureState:true,typeOfFid:"string",db:null,initialize:function(options){if(!this.supported()){return;}
-OpenLayers.Protocol.SQL.prototype.initialize.apply(this,[options]);this.jsonParser=new OpenLayers.Format.JSON();this.wktParser=new OpenLayers.Format.WKT();this.fidRegExp=new RegExp('^'+this.FID_PREFIX);this.initializeDatabase();},initializeDatabase:function(){this.db=google.gears.factory.create('beta.database');this.db.open(this.databaseName);this.db.execute("CREATE TABLE IF NOT EXISTS "+this.tableName+" (fid TEXT UNIQUE, geometry TEXT, properties TEXT,"+" state TEXT)");},destroy:function(){this.db.close();this.db=null;this.jsonParser=null;this.wktParser=null;OpenLayers.Protocol.SQL.prototype.destroy.apply(this);},supported:function(){return!!(window.google&&google.gears);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.applyDefaults(options,this.options);var feature,features=[];var rs=this.db.execute("SELECT * FROM "+this.tableName);while(rs.isValidRow()){feature=this.unfreezeFeature(rs);if(this.evaluateFilter(featur
e,options.filter)){if(!options.noFeatureStateReset){feature.state=null;}
-features.push(feature);}
-rs.next();}
-rs.close();var resp=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"read",features:features});if(options&&options.callback){options.callback.call(options.scope,resp);}
-return resp;},unfreezeFeature:function(row){var feature;var wkt=row.fieldByName('geometry');if(wkt==this.NULL_GEOMETRY){feature=new OpenLayers.Feature.Vector();}else{feature=this.wktParser.read(wkt);}
-feature.attributes=this.jsonParser.read(row.fieldByName('properties'));feature.fid=this.extractFidFromField(row.fieldByName('fid'));var state=row.fieldByName('state');if(state==this.NULL_FEATURE_STATE){state=null;}
-feature.state=state;return feature;},extractFidFromField:function(field){if(!field.match(this.fidRegExp)&&this.typeOfFid=="number"){field=parseFloat(field);}
-return field;},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="create";if(options&&options.callback){options.callback.call(options.scope,resp);}
-return resp;},update:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=this.createOrUpdate(features);resp.requestType="update";if(options&&options.callback){options.callback.call(options.scope,resp);}
-return resp;},createOrUpdate:function(features){if(!(features instanceof Array)){features=[features];}
-var i,len=features.length,feature;var insertedFeatures=new Array(len);for(i=0;i<len;i++){feature=features[i];var params=this.freezeFeature(feature);this.db.execute("REPLACE INTO "+this.tableName+" (fid, geometry, properties, state)"+" VALUES (?, ?, ?, ?)",params);var clone=feature.clone();clone.fid=this.extractFidFromField(params[0]);insertedFeatures[i]=clone;}
-return new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,features:insertedFeatures,reqFeatures:features});},freezeFeature:function(feature){feature.fid=feature.fid!=null?""+feature.fid:OpenLayers.Util.createUniqueID(this.FID_PREFIX);var geometry=feature.geometry!=null?feature.geometry.toString():this.NULL_GEOMETRY;var properties=this.jsonParser.write(feature.attributes);var state=this.getFeatureStateForFreeze(feature);return[feature.fid,geometry,properties,state];},getFeatureStateForFreeze:function(feature){var state;if(!this.saveFeatureState){state=this.NULL_FEATURE_STATE;}else if(this.createdOffline(feature)){state=OpenLayers.State.INSERT;}else{state=feature.state;}
-return state;},"delete":function(features,options){if(!(features instanceof Array)){features=[features];}
-options=OpenLayers.Util.applyDefaults(options,this.options);var i,len,feature;for(i=0,len=features.length;i<len;i++){feature=features[i];if(this.saveFeatureState&&!this.createdOffline(feature)){var toDelete=feature.clone();toDelete.fid=feature.fid;if(toDelete.geometry){toDelete.geometry.destroy();toDelete.geometry=null;}
-toDelete.state=feature.state;this.createOrUpdate(toDelete);}else{this.db.execute("DELETE FROM "+this.tableName+" WHERE fid = ?",[feature.fid]);}}
-var resp=new OpenLayers.Protocol.Response({code:OpenLayers.Protocol.Response.SUCCESS,requestType:"delete",reqFeatures:features});if(options&&options.callback){options.callback.call(options.scope,resp);}
-return resp;},createdOffline:function(feature){return(typeof feature.fid=="string"&&!!(feature.fid.match(this.fidRegExp)));},commit:function(features,options){var opt,resp=[],nRequests=0,nResponses=0;function callback(resp){if(++nResponses<nRequests){resp.last=false;}
-this.callUserCallback(options,resp);}
-var feature,toCreate=[],toUpdate=[],toDelete=[];for(var i=features.length-1;i>=0;i--){feature=features[i];switch(feature.state){case OpenLayers.State.INSERT:toCreate.push(feature);break;case OpenLayers.State.UPDATE:toUpdate.push(feature);break;case OpenLayers.State.DELETE:toDelete.push(feature);break;}}
-if(toCreate.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options.create);resp.push(this.create(toCreate,opt));}
-if(toUpdate.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options.update);resp.push(this.update(toUpdate,opt));}
-if(toDelete.length>0){nRequests++;opt=OpenLayers.Util.applyDefaults({"callback":callback,"scope":this},options["delete"]);resp.push(this["delete"](toDelete,opt));}
-return resp;},clear:function(){this.db.execute("DELETE FROM "+this.tableName);},callUserCallback:function(options,resp){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}
-if(resp.last&&options.callback){options.callback.call(options.scope);}},CLASS_NAME:"OpenLayers.Protocol.SQL.Gears"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{namespaces:null,namespaceAlias:null,defaultPrefix:null,readers:{},writers:{},xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
-OpenLayers.Format.prototype.initialize.apply(this,[options]);this.namespaces=OpenLayers.Util.extend({},this.namespaces);this.namespaceAlias={};for(var alias in this.namespaces){this.namespaceAlias[this.namespaces[alias]]=alias;}},destroy:function(){this.xmldom=null;OpenLayers.Format.prototype.destroy.apply(this,arguments);},setNamespace:function(alias,uri){this.namespaces[alias]=uri;this.namespaceAlias[uri]=alias;},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
-xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});if(this.keepData){this.data=node;}
-return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
-doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
-return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
-return element;},createTextNode:function(text){var node;if(typeof text!=="string"){text=String(text);}
-if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
-return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0,len=allNodes.length;i<len;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
-return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0,len=attributes.length;i<len;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
-return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
-return attributeValue;},getChildValue:function(node,def){var value=def||"";if(node){for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 3:case 4:value+=child.nodeValue;}}}
-return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
-child=child.nextSibling;}
-if(value==""&&def!=undefined){value=def;}
-return value;},isSimpleContent:function(node){var simple=true;for(var child=node.firstChild;child;child=child.nextSibling){if(child.nodeType===1){simple=false;break;}}
-return simple;},contentType:function(node){var simple=false,complex=false;var type=OpenLayers.Format.XML.CONTENT_TYPE.EMPTY;for(var child=node.firstChild;child;child=child.nextSibling){switch(child.nodeType){case 1:complex=true;break;case 8:break;default:simple=true;}
-if(complex&&simple){break;}}
-if(complex&&simple){type=OpenLayers.Format.XML.CONTENT_TYPE.MIXED;}else if(complex){return OpenLayers.Format.XML.CONTENT_TYPE.COMPLEX;}else if(simple){return OpenLayers.Format.XML.CONTENT_TYPE.SIMPLE;}
-return type;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
-return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},createElementNSPlus:function(name,options){options=options||{};var uri=options.uri||this.namespaces[options.prefix];if(!uri){var loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
-if(!uri){uri=this.namespaces[this.defaultPrefix];}
-var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
-var value=options.value;if(value!=null){node.appendChild(this.createTextNode(value));}
-return node;},setAttributes:function(node,obj){var value,uri;for(var name in obj){if(obj[name]!=null&&obj[name].toString){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}}},readNode:function(node,obj){if(!obj){obj={};}
-var group=this.readers[node.namespaceURI?this.namespaceAlias[node.namespaceURI]:this.defaultPrefix];if(group){var local=node.localName||node.nodeName.split(":").pop();var reader=group[local]||group["*"];if(reader){reader.apply(this,[node,obj]);}}
-return obj;},readChildNodes:function(node,obj){if(!obj){obj={};}
-var children=node.childNodes;var child;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){this.readNode(child,obj);}}
-return obj;},writeNode:function(name,obj,parent){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{if(parent){prefix=this.namespaceAlias[parent.namespaceURI];}else{prefix=this.defaultPrefix;}
-local=name;}
-var child=this.writers[prefix][local].apply(this,[obj]);if(parent){parent.appendChild(child);}
-return child;},getChildEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.firstChild,name,uri);},getNextEl:function(node,name,uri){return node&&this.getThisOrNextEl(node.nextSibling,name,uri);},getThisOrNextEl:function(node,name,uri){outer:for(var sibling=node;sibling;sibling=sibling.nextSibling){switch(sibling.nodeType){case 1:if((!name||name===(sibling.localName||sibling.nodeName.split(":").pop()))&&(!uri||uri===sibling.namespaceURI)){break outer;}
-sibling=null;break outer;case 3:if(/^\s*$/.test(sibling.nodeValue)){break;}
-case 4:case 6:case 12:case 10:case 11:sibling=null;break outer;}}
-return sibling||null;},lookupNamespaceURI:function(node,prefix){var uri=null;if(node){if(node.lookupNamespaceURI){uri=node.lookupNamespaceURI(prefix);}else{outer:switch(node.nodeType){case 1:if(node.namespaceURI!==null&&node.prefix===prefix){uri=node.namespaceURI;break outer;}
-var len=node.attributes.length;if(len){var attr;for(var i=0;i<len;++i){attr=node.attributes[i];if(attr.prefix==="xmlns"&&attr.name==="xmlns:"+prefix){uri=attr.value||null;break outer;}else if(attr.name==="xmlns"&&prefix===null){uri=attr.value||null;break outer;}}}
-uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;case 2:uri=this.lookupNamespaceURI(node.ownerElement,prefix);break outer;case 9:uri=this.lookupNamespaceURI(node.documentElement,prefix);break outer;case 6:case 12:case 10:case 11:break outer;default:uri=this.lookupNamespaceURI(node.parentNode,prefix);break outer;}}}
-return uri;},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Format.XML.CONTENT_TYPE={EMPTY:0,SIMPLE:1,COMPLEX:2,MIXED:3};OpenLayers.Format.XML.lookupNamespaceURI=OpenLayers.Function.bind(OpenLayers.Format.XML.prototype.lookupNamespaceURI,OpenLayers.Format.XML.prototype);OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
-return this.bounds;},calculateBounds:function(){},distanceTo:function(geometry,options){},getVertices:function(nodes){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
-return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},getCentroid:function(){return null;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(wkt){var format=arguments.callee.format;if(!format){format=new OpenLayers.Format.WKT();arguments.callee.format=format;}
-var geom;var result=format.read(wkt);if(result instanceof OpenLayers.Feature.Vector){geom=result.geometry;}else if(result instanceof Array){var len=result.length;var components=new Array(len);for(var i=0;i<len;++i){components[i]=result[i].geometry;}
-geom=new OpenLayers.Geometry.Collection(components);}
-return geom;};OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,options){var point=options&&options.point;var tolerance=options&&options.tolerance;var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
-if(tolerance){var dist;if(intersection){if(point){var segs=[seg1,seg2];var seg,x,y;outer:for(var i=0;i<2;++i){seg=segs[i];for(var j=1;j<3;++j){x=seg["x"+j];y=seg["y"+j];dist=Math.sqrt(Math.pow(x-intersection.x,2)+
-Math.pow(y-intersection.y,2));if(dist<tolerance){intersection.x=x;intersection.y=y;break outer;}}}}}else{var segs=[seg1,seg2];var source,target,x,y,p,result;outer:for(var i=0;i<2;++i){source=segs[i];target=segs[(i+1)%2];for(var j=1;j<3;++j){p={x:source["x"+j],y:source["y"+j]};result=OpenLayers.Geometry.distanceToSegment(p,target);if(result.distance<tolerance){if(point){intersection=new OpenLayers.Geometry.Point(p.x,p.y);}else{intersection=true;}
-break outer;}}}}}
-return intersection;};OpenLayers.Geometry.distanceToSegment=function(point,segment){var x0=point.x;var y0=point.y;var x1=segment.x1;var y1=segment.y1;var x2=segment.x2;var y2=segment.y2;var dx=x2-x1;var dy=y2-y1;var along=((dx*(x0-x1))+(dy*(y0-y1)))/(Math.pow(dx,2)+Math.pow(dy,2));var x,y;if(along<=0.0){x=x1;y=y1;}else if(along>=1.0){x=x2;y=y2;}else{x=x1+along*dx;y=y1+along*dy;}
-return{distance:Math.sqrt(Math.pow(x-x0,2)+Math.pow(y-y0,2)),x:x,y:y};};OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var distance,x0,y0,x1,y1,result;if(geometry instanceof OpenLayers.Geometry.Point){x0=this.x;y0=this.y;x1=geometry.x;y1=geometry.y;distance=Math.sqrt(Math.pow(x0-x1,2)+Math.pow(y0-y1,2));result=!details?distance:{x0:x0,y0:y0,x1:x1,y1:y1,distance:distance};}else{result=geometry.distanceTo(this,options);if(details){result={x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0,distance:result.distance};}}
-return result;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
-return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},getCentroid:function(){return new OpenLayers.Geometry.Point(this.x,this.y);},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();return this;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
-return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);this.bounds=null;}
-return this;},getVertices:function(nodes){return[this];},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;OpenLayers.Geometry.prototype.destroy.apply(this,arguments);},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0,len=this.components.length;i<len;i++){geometry.addComponent(this.components[i].clone());}
-OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0,len=this.components.length;i<len;i++){strings.push(this.components[i].toShortString());}
-return strings.join(",");},calculateBounds:function(){this.bounds=null;var bounds=new OpenLayers.Bounds();var components=this.components;if(components){for(var i=0,len=components.length;i<len;i++){bounds.extend(components[i].getBounds());}}
-if(bounds.left!=null&&bounds.bottom!=null&&bounds.right!=null&&bounds.top!=null){this.setBounds(bounds);}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=0,len=components.length;i<len;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
-component.parent=this;this.clearBounds();added=true;}}
-return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getLength();}
-return length;},getArea:function(){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getArea();}
-return area;},getGeodesicArea:function(projection){var area=0.0;for(var i=0,len=this.components.length;i<len;i++){area+=this.components[i].getGeodesicArea(projection);}
-return area;},getCentroid:function(weighted){if(!weighted){return this.components.length&&this.components[0].getCentroid();}
-var len=this.components.length;if(!len){return false;}
-var areas=[];var centroids=[];var areaSum=0;var minArea=Number.MAX_VALUE;var component;for(var i=0;i<len;++i){component=this.components[i];var area=component.getArea();var centroid=component.getCentroid(true);if(isNaN(area)||isNaN(centroid.x)||isNaN(centroid.y)){continue;}
-areas.push(area);areaSum+=area;minArea=(area<minArea&&area>0)?area:minArea;centroids.push(centroid);}
-len=areas.length;if(areaSum===0){for(var i=0;i<len;++i){areas[i]=1;}
-areaSum=areas.length;}else{for(var i=0;i<len;++i){areas[i]/=minArea;}
-areaSum/=minArea;}
-var xSum=0,ySum=0,centroid,area;for(var i=0;i<len;++i){centroid=centroids[i];area=areas[i];xSum+=centroid.x*area;ySum+=centroid.y*area;}
-return new OpenLayers.Geometry.Point(xSum/areaSum,ySum/areaSum);},getGeodesicLength:function(projection){var length=0.0;for(var i=0,len=this.components.length;i<len;i++){length+=this.components[i].getGeodesicLength(projection);}
-return length;},move:function(x,y){for(var i=0,len=this.components.length;i<len;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}
-return this;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best,distance;var min=Number.POSITIVE_INFINITY;for(var i=0,len=this.components.length;i<len;++i){result=this.components[i].distanceTo(geometry,options);distance=details?result.distance:result;if(distance<min){min=distance;best=result;if(min==0){break;}}}
-return best;},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0,len=this.components.length;i<len;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
-return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len;i++){var component=this.components[i];component.transform(source,dest);}
-this.bounds=null;}
-return this;},intersects:function(geometry){var intersect=false;for(var i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-return intersect;},getVertices:function(nodes){var vertices=[];for(var i=0,len=this.components.length;i<len;++i){Array.prototype.push.apply(vertices,this.components[i].getVertices(nodes));}
-return vertices;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1,len=this.components.length;i<len;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
-return length;},getGeodesicLength:function(projection){var geom=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){geom=this.clone().transform(projection,gg);}}
-var length=0.0;if(geom.components&&(geom.components.length>1)){var p1,p2;for(var i=1,len=geom.components.length;i<len;i++){p1=geom.components[i-1];p2=geom.components[i];length+=OpenLayers.Util.distVincenty({lon:p1.x,lat:p1.y},{lon:p2.x,lat:p2.y});}}
-return length*1000;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
-var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0,len=segs1.length;i<len;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0,jlen=segs2.length;j<jlen;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
-if(seg2.x2<seg1x1){continue;}
-seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
-if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
-if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
-return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg),point1,point2;for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
-function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
-return segments.sort(byX1);},splitWithSegment:function(seg,options){var edge=!(options&&options.edge===false);var tolerance=options&&options.tolerance;var lines=[];var verts=this.getVertices();var points=[];var intersections=[];var split=false;var vert1,vert2,point;var node,vertex,target;var interOptions={point:true,tolerance:tolerance};var result=null;for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];points.push(vert1.clone());vert2=verts[i+1];target={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};point=OpenLayers.Geometry.segmentsIntersect(seg,target,interOptions);if(point instanceof OpenLayers.Geometry.Point){if((point.x===seg.x1&&point.y===seg.y1)||(point.x===seg.x2&&point.y===seg.y2)||point.equals(vert1)||point.equals(vert2)){vertex=true;}else{vertex=false;}
-if(vertex||edge){if(!point.equals(intersections[intersections.length-1])){intersections.push(point.clone());}
-if(i===0){if(point.equals(vert1)){continue;}}
-if(point.equals(vert2)){continue;}
-split=true;if(!point.equals(vert1)){points.push(point);}
-lines.push(new OpenLayers.Geometry.LineString(points));points=[point.clone()];}}}
-if(split){points.push(vert2.clone());lines.push(new OpenLayers.Geometry.LineString(points));}
-if(intersections.length>0){var xDir=seg.x1<seg.x2?1:-1;var yDir=seg.y1<seg.y2?1:-1;result={lines:lines,points:intersections.sort(function(p1,p2){return(xDir*p1.x-xDir*p2.x)||(yDir*p1.y-yDir*p2.y);})};}
-return result;},split:function(target,options){var results=null;var mutual=options&&options.mutual;var sourceSplit,targetSplit,sourceParts,targetParts;if(target instanceof OpenLayers.Geometry.LineString){var verts=this.getVertices();var vert1,vert2,seg,splits,lines,point;var points=[];sourceParts=[];for(var i=0,stop=verts.length-2;i<=stop;++i){vert1=verts[i];vert2=verts[i+1];seg={x1:vert1.x,y1:vert1.y,x2:vert2.x,y2:vert2.y};targetParts=targetParts||[target];if(mutual){points.push(vert1.clone());}
-for(var j=0;j<targetParts.length;++j){splits=targetParts[j].splitWithSegment(seg,options);if(splits){lines=splits.lines;if(lines.length>0){lines.unshift(j,1);Array.prototype.splice.apply(targetParts,lines);j+=lines.length-2;}
-if(mutual){for(var k=0,len=splits.points.length;k<len;++k){point=splits.points[k];if(!point.equals(vert1)){points.push(point);sourceParts.push(new OpenLayers.Geometry.LineString(points));if(point.equals(vert2)){points=[];}else{points=[point.clone()];}}}}}}}
-if(mutual&&sourceParts.length>0&&points.length>0){points.push(vert2.clone());sourceParts.push(new OpenLayers.Geometry.LineString(points));}}else{results=target.splitWith(this,options);}
-if(targetParts&&targetParts.length>1){targetSplit=true;}else{targetParts=[];}
-if(sourceParts&&sourceParts.length>1){sourceSplit=true;}else{sourceParts=[];}
-if(targetSplit||sourceSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
-return results;},splitWith:function(geometry,options){return geometry.split(this,options);},getVertices:function(nodes){var vertices;if(nodes===true){vertices=[this.components[0],this.components[this.components.length-1]];}else if(nodes===false){vertices=this.components.slice(1,this.components.length-1);}else{vertices=this.components.slice();}
-return vertices;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var details=edge&&options&&options.details;var result,best={};var min=Number.POSITIVE_INFINITY;if(geometry instanceof OpenLayers.Geometry.Point){var segs=this.getSortedSegments();var x=geometry.x;var y=geometry.y;var seg;for(var i=0,len=segs.length;i<len;++i){seg=segs[i];result=OpenLayers.Geometry.distanceToSegment(geometry,seg);if(result.distance<min){min=result.distance;best=result;if(min===0){break;}}else{if(seg.x2>x&&((y>seg.y1&&y<seg.y2)||(y<seg.y1&&y>seg.y2))){break;}}}
-if(details){best={distance:best.distance,x0:best.x,y0:best.y,x1:x,y1:y};}else{best=best.distance;}}else if(geometry instanceof OpenLayers.Geometry.LineString){var segs0=this.getSortedSegments();var segs1=geometry.getSortedSegments();var seg0,seg1,intersection,x0,y0;var len1=segs1.length;var interOptions={point:true};outer:for(var i=0,len=segs0.length;i<len;++i){seg0=segs0[i];x0=seg0.x1;y0=seg0.y1;for(var j=0;j<len1;++j){seg1=segs1[j];intersection=OpenLayers.Geometry.segmentsIntersect(seg0,seg1,interOptions);if(intersection){min=0;best={distance:0,x0:intersection.x,y0:intersection.y,x1:intersection.x,y1:intersection.y};break outer;}else{result=OpenLayers.Geometry.distanceToSegment({x:x0,y:y0},seg1);if(result.distance<min){min=result.distance;best={distance:min,x0:x0,y0:y0,x1:result.x,y1:result.y};}}}}
-if(!details){best=best.distance;}
-if(min!==0){if(seg0){result=geometry.distanceTo(new OpenLayers.Geometry.Point(seg0.x2,seg0.y2),options);var dist=details?result.distance:result;if(dist<min){if(details){best={distance:min,x0:result.x1,y0:result.y1,x1:result.x0,y1:result.y0};}else{best=dist;}}}}}else{best=geometry.distanceTo(this,options);if(details){best={distance:best.distance,x0:best.x1,y0:best.y1,x1:best.x0,y1:best.y0};}}
-return best;},simplify:function(tolerance){if(this&&this!==null){var points=this.getVertices();if(points.length<3){return this;}
-var compareNumbers=function(a,b){return(a-b);};var douglasPeuckerReduction=function(points,firstPoint,lastPoint,tolerance){var maxDistance=0;var indexFarthest=0;for(var index=firstPoint,distance;index<lastPoint;index++){distance=perpendicularDistance(points[firstPoint],points[lastPoint],points[index]);if(distance>maxDistance){maxDistance=distance;indexFarthest=index;}}
-if(maxDistance>tolerance&&indexFarthest!=firstPoint){pointIndexsToKeep.push(indexFarthest);douglasPeuckerReduction(points,firstPoint,indexFarthest,tolerance);douglasPeuckerReduction(points,indexFarthest,lastPoint,tolerance);}};var perpendicularDistance=function(point1,point2,point){var area=Math.abs(0.5*(point1.x*point2.y+point2.x*point.y+point.x*point1.y-point2.x*point1.y-point.x*point2.y-point1.x*point.y));var bottom=Math.sqrt(Math.pow(point1.x-point2.x,2)+Math.pow(point1.y-point2.y,2));var height=area/bottom*2;return height;};var firstPoint=0;var lastPoint=points.length-1;var pointIndexsToKeep=[];pointIndexsToKeep.push(firstPoint);pointIndexsToKeep.push(lastPoint);while(points[firstPoint].equals(points[lastPoint])){lastPoint--;pointIndexsToKeep.push(lastPoint);}
-douglasPeuckerReduction(points,firstPoint,lastPoint,tolerance);var returnPoints=[];pointIndexsToKeep.sort(compareNumbers);for(var index=0;index<pointIndexsToKeep.length;index++){returnPoints.push(points[pointIndexsToKeep[index]]);}
-return new OpenLayers.Geometry.LineString(returnPoints);}
-else{return this;}},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
-var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0,len=this.components.length;i<len-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0,len=this.components.length;i<len-1;++i){this.components[i].resize(scale,origin,ratio);}
-return this;},transform:function(source,dest){if(source&&dest){for(var i=0,len=this.components.length;i<len-1;i++){var component=this.components[i];component.transform(source,dest);}
-this.bounds=null;}
-return this;},getCentroid:function(){if(this.components&&(this.components.length>2)){var sumX=0.0;var sumY=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sumX+=(b.x+c.x)*(b.x*c.y-c.x*b.y);sumY+=(b.y+c.y)*(b.x*c.y-c.x*b.y);}
-var area=-1*this.getArea();var x=sumX/(6*area);var y=sumY/(6*area);return new OpenLayers.Geometry.Point(x,y);}else{return null;}},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0,len=this.components.length;i<len-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
-area=-sum/2.0;}
-return area;},getGeodesicArea:function(projection){var ring=this;if(projection){var gg=new OpenLayers.Projection("EPSG:4326");if(!gg.equals(projection)){ring=this.clone().transform(projection,gg);}}
-var area=0.0;var len=ring.components&&ring.components.length;if(len>2){var p1,p2;for(var i=0;i<len-1;i++){p1=ring.components[i];p2=ring.components[i+1];area+=OpenLayers.Util.rad(p2.x-p1.x)*(2+Math.sin(OpenLayers.Util.rad(p1.y))+
-Math.sin(OpenLayers.Util.rad(p2.y)));}
-area=area*6378137.0*6378137.0/2.0;}
-return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
-var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
-continue;}
-cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
-if(cx<=px){continue;}
-if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
-if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
-var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0,len=geometry.components.length;i<len;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},getVertices:function(nodes){return(nodes===true)?[]:this.components.slice(0,this.components.length-1);},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getArea());}}
-return area;},getGeodesicArea:function(projection){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getGeodesicArea(projection));for(var i=1,len=this.components.length;i<len;i++){area-=Math.abs(this.components[i].getGeodesicArea(projection));}}
-return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
-break;}}}}}
-return contained;},intersects:function(geometry){var intersect=false;var i,len;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0,len=this.components.length;i<len;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-if(!intersect){for(i=0,len=geometry.components.length;i<len;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0,len=geometry.components.length;i<len;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
-if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0,len=ring.components.length;i<len;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
-return intersect;},distanceTo:function(geometry,options){var edge=!(options&&options.edge===false);var result;if(!edge&&this.intersects(geometry)){result=0;}else{result=OpenLayers.Geometry.Collection.prototype.distanceTo.apply(this,[geometry,options]);}
-return result;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
-var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},URL_SPLIT_REGEX:/([^:]*:)\/\/([^:]*:?[^@]*@)?([^:\/\?]*):?([^\/\?]*)/,events:new OpenLayers.Events(this,null,["complete","success","failure"]),issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=OpenLayers.Util.urlAppend(config.url,OpenLayers.Util.getParameterString(config.params||{}));var sameOrigin=!(url.indexOf("http")==0);var urlParts=!sameOrigin&&url.match(this.URL_SPLIT_REGEX);if(urlParts){var location=window.location;sameOrigin=urlParts[1]==location.protoco
l&&urlParts[3]==location.hostname;var uPort=urlParts[4],lPort=location.port;if(uPort!=80&&uPort!=""||lPort!="80"&&lPort!=""){sameOrigin=sameOrigin&&uPort==lPort;}}
-if(!sameOrigin){if(config.proxy){if(typeof config.proxy=="function"){url=config.proxy(url);}else{url=config.proxy+encodeURIComponent(url);}}else{OpenLayers.Console.warn(OpenLayers.i18n("proxyNeeded"),{url:url});}}
-request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
-var events=this.events;var self=this;request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){var proceed=events.triggerEvent("complete",{request:request,config:config,requestUrl:url});if(proceed!==false){self.runCallbacks({request:request,config:config,requestUrl:url});}}};if(config.async===false){request.send(config.data);}else{window.setTimeout(function(){if(request.readyState!==0){request.send(config.data);}},0);}
-return request;},runCallbacks:function(options){var request=options.request;var config=options.config;var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
-var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
-complete(request);if(!request.status||(request.status>=200&&request.status<300)){this.events.triggerEvent("success",options);if(success){success(request);}}
-if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("failure",options);if(failure){failure(request);}}},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
-return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
-return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera,bIE7=bIE&&window.navigator.userAgent.match(/MSIE 7.0/);function fXMLHttpRequest(){this._object=oXMLHttpRequest&&!bIE7?new oXMLHttpRequest:new window.ActiveXObject("Microsoft.XMLHTTP");this._listeners=[];};function cXMLHttpRequest(){return new fXMLHttpRequest;};cXMLHttpRequest.prototype=fXMLHttpRequest.prototype;if(bGecko&&oXMLHttpRequest.wrapped)
-cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText='';cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText='';cXMLHttpRequest.prototype.priority="NORMAL";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){delete this._headers;if(arguments.length<3)
-bAsync=true;this._async=bAsync;var oRequest=this,nState=this.readyState,fOnUnload;if(bIE&&bAsync){fOnUnload=function(){if(nState!=cXMLHttpRequest.DONE){fCleanTransport(oRequest);oRequest.abort();}};window.attachEvent("onunload",fOnUnload);}
-if(cXMLHttpRequest.onopen)
-cXMLHttpRequest.onopen.apply(this,arguments);if(arguments.length>4)
-this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);else
-if(arguments.length>3)
-this._object.open(sMethod,sUrl,bAsync,sUser);else
-this._object.open(sMethod,sUrl,bAsync);this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
-return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
-if(oRequest.readyState==cXMLHttpRequest.DONE){delete oRequest._data;fCleanTransport(oRequest);if(bIE&&bAsync)
-window.detachEvent("onunload",fOnUnload);}
-if(nState!=oRequest.readyState)
-fReadyStateChange(oRequest);nState=oRequest.readyState;}};function fXMLHttpRequest_send(oRequest){oRequest._object.send(oRequest._data);if(bGecko&&!oRequest._async){oRequest.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(oRequest);while(oRequest.readyState<cXMLHttpRequest.DONE){oRequest.readyState++;fReadyStateChange(oRequest);if(oRequest._aborted)
-return;}}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
-cXMLHttpRequest.onsend.apply(this,arguments);if(!arguments.length)
-vData=null;if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!oRequest._headers["Content-Type"])
-oRequest._object.setRequestHeader("Content-Type","application/xml");}
-this._data=vData;fXMLHttpRequest_send(this);};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
-cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
-this._aborted=true;this._object.abort();fCleanTransport(this);this.readyState=cXMLHttpRequest.UNSENT;delete this._data;};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
-this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.addEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-if(oListener[0]==sName&&oListener[1]==fHandler&&oListener[2]==bUseCapture)
-return;this._listeners.push([sName,fHandler,bUseCapture]);};cXMLHttpRequest.prototype.removeEventListener=function(sName,fHandler,bUseCapture){for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-break;if(oListener)
-this._listeners.splice(nIndex,1);};cXMLHttpRequest.prototype.dispatchEvent=function(oEvent){var oEventPseudo={'type':oEvent.type,'target':this,'currentTarget':this,'eventPhase':2,'bubbles':oEvent.bubbles,'cancelable':oEvent.cancelable,'timeStamp':oEvent.timeStamp,'stopPropagation':function(){},'preventDefault':function(){},'initEvent':function(){}};if(oEventPseudo.type=="readystatechange"&&this.onreadystatechange)
-(this.onreadystatechange.handleEvent||this.onreadystatechange).apply(this,[oEventPseudo]);for(var nIndex=0,oListener;oListener=this._listeners[nIndex];nIndex++)
-if(oListener[0]==oEventPseudo.type&&!oListener[2])
-(oListener[1].handleEvent||oListener[1]).apply(this,[oEventPseudo]);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(cXMLHttpRequest.onreadystatechange)
-cXMLHttpRequest.onreadystatechange.apply(oRequest);oRequest.dispatchEvent({'type':"readystatechange",'bubbles':false,'cancelable':false,'timeStamp':new Date+0});};function fGetDocument(oRequest){var oDocument=oRequest.responseXML,sResponse=oRequest.responseText;if(bIE&&sResponse&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new window.ActiveXObject("Microsoft.XMLDOM");oDocument.async=false;oDocument.validateOnParse=false;oDocument.loadXML(sResponse);}
-if(oDocument)
-if((bIE&&oDocument.parseError!=0)||!oDocument.documentElement||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
-return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
-try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
-try{oRequest.status=oRequest._object.status;}catch(e){}
-try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
-oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Proj
ection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
-return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
-OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{kml:"http://www.opengis.net/kml/2.2",gx:"http://www.google.com/kml/ext/2.2"},kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,extractTracks:false,trackAttributes:null,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.sty
les={};this.fetched={};var options={depth:0,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0,len=types.length;i<len;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
-switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
-break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
-break;case"placemark":this.parseFeatures(nodes,options);break;}}
-return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
-var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0,len=nodes.length;i<len;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=OpenLayers.Request.GET({url:href,async:false});if(request){return request.responseText;}},parseStyles:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var style=this.parseStyle(nodes[i]);if(style){var styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseKmlColor:function(kmlColor){var color=null;if(kmlColor){var matches=kmlColor.match(this.regExes.kmlColor);if(matches){color={color:'#'+matches[4]+matches[3]+matches[2],opacity:parseInt(matches[1],16)/255};}}
-return color;},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle","LabelStyle"];var type,styleTypeNode,nodeList,geometry,parser;for(var i=0,len=types.length;i<len;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
-switch(type.toLowerCase()){case"linestyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["strokeColor"]=color.color;style["strokeOpacity"]=color.opacity;}
-var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
-break;case"polystyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fillOpacity"]=color.opacity;style["fillColor"]=color.color;}
-var fill=this.parseProperty(styleTypeNode,"*","fill");if(fill=="0"){style["fillColor"]="none";}
-var outline=this.parseProperty(styleTypeNode,"*","outline");if(outline=="0"){style["strokeWidth"]="0";}
-break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
-w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
-if(h){height=parseInt(h)*scale;}
-var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
-+palette+"/icon"+pos+file_extension;}
-style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
-var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
-else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
-else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
-var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
-else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
-else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
-style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
-break;case"labelstyle":var kmlColor=this.parseProperty(styleTypeNode,"*","color");var color=this.parseKmlColor(kmlColor);if(color){style["fontColor"]=color.color;style["fontOpacity"]=color.opacity;}
-break;default:}}
-if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
-var id=node.getAttribute("id");if(id&&style){style.id=id;}
-return style;},parseStyleMaps:function(nodes,options){for(var i=0,len=nodes.length;i<len;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0,jlen=pairs.length;j<jlen;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
-if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=[];for(var i=0,len=nodes.length;i<len;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl,options);}
-if(this.extractStyles){var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend(feature.style,inlineStyle);}}}
-if(this.extractTracks){var tracks=this.getElementsByTagNameNS(featureNode,this.namespaces.gx,"Track");if(tracks&&tracks.length>0){var track=tracks[0];var container={features:[],feature:feature};this.readNode(track,container);if(container.features.length>0){features.push.apply(features,container.features);}}}else{features.push(feature);}}else{throw"Bad Placemark: "+i;}}
-this.features=this.features.concat(features);},readers:{"kml":{"when":function(node,container){container.whens.push(OpenLayers.Date.parse(this.getChildValue(node)));},"_trackPointAttribute":function(node,container){var name=node.nodeName.split(":").pop();container.attributes[name].push(this.getChildValue(node));}},"gx":{"Track":function(node,container){var obj={whens:[],points:[],angles:[]};if(this.trackAttributes){var name;obj.attributes={};for(var i=0,ii=this.trackAttributes.length;i<ii;++i){name=this.trackAttributes[i];obj.attributes[name]=[];if(!(name in this.readers.kml)){this.readers.kml[name]=this.readers.kml._trackPointAttribute;}}}
-this.readChildNodes(node,obj);if(obj.whens.length!==obj.points.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:coord ("+obj.points.length+") elements.");}
-var hasAngles=obj.angles.length>0;if(hasAngles&&obj.whens.length!==obj.angles.length){throw new Error("gx:Track with unequal number of when ("+obj.whens.length+") and gx:angles ("+obj.angles.length+") elements.");}
-var feature,point,angles;for(var i=0,ii=obj.whens.length;i<ii;++i){feature=container.feature.clone();feature.fid=container.feature.fid||container.feature.id;point=obj.points[i];feature.geometry=point;if("z"in point){feature.attributes.altitude=point.z;}
-if(this.internalProjection&&this.externalProjection){feature.geometry.transform(this.externalProjection,this.internalProjection);}
-if(this.trackAttributes){for(var j=0,jj=this.trackAttributes.length;j<jj;++j){feature.attributes[name]=obj.attributes[this.trackAttributes[j]][i];}}
-feature.attributes.when=obj.whens[i];feature.attributes.trackId=container.feature.id;if(hasAngles){angles=obj.angles[i];feature.attributes.heading=parseFloat(angles[0]);feature.attributes.tilt=parseFloat(angles[1]);feature.attributes.roll=parseFloat(angles[2]);}
-container.features.push(feature);}},"coord":function(node,container){var str=this.getChildValue(node);var coords=str.replace(this.regExes.trimSpace,"").split(/\s+/);var point=new OpenLayers.Geometry.Point(coords[0],coords[1]);if(coords.length>2){point.z=parseFloat(coords[2]);}
-container.points.push(point);},"angles":function(node,container){var str=this.getChildValue(node);var parts=str.replace(this.regExes.trimSpace,"").split(/\s+/);container.angles.push(parts);}}},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0,len=order.length;i<len;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
-return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
-var style=OpenLayers.Util.extend({},this.styles[styleUrl]);return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
-var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
-point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
-return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
-points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
-pointList[i];}}
-if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
-return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0,len=nodeList.length;i<len;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
-return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
-return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var edNodes=node.getElementsByTagName("ExtendedData");if(edNodes.length){attributes=this.parseExtendedData(edNodes[0]);}
-var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length>=1&&grandchildren.length<=3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 2:var c1=grandchildren[0];var c2=grandchildren[1];grandchild=(c1.nodeType==3||c1.nodeType==4)?c1:c2;break;case 3:default:grandchild=grandchildren[1];break;}
-if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseExtendedData:function(node){var attributes={};var i,len,data,key;var dataNodes=node.getElementsByTagName("Data");for(i=0,len=dataNodes.length;i<len;i++){data=dataNodes[i];key=data.getAttribute("name");var ed={};var valueNode=data.getElementsByTagName("value");if(valueNode.length){ed['value']=this.getChildValue(valueNode[0]);}
-var nameNode=data.getElementsByTagName("displayName");if(nameNode.length){ed['displayName']=this.getChildValue(nameNode[0]);}
-attributes[key]=ed;}
-var simpleDataNodes=node.getElementsByTagName("SimpleData");for(i=0,len=simpleDataNodes.length;i<len;i++){var ed={};data=simpleDataNodes[i];key=data.getAttribute("name");ed['value']=this.getChildValue(data);ed['displayName']=key;attributes[key]=ed;}
-return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0,len=features.length;i<len;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
-kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folder=this.createElementNS(this.kmlns,"Folder");if(this.foldersName){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);folder.appendChild(folderName);}
-if(this.foldersDesc){var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);folder.appendChild(folderDesc);}
-return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=feature.style&&feature.style.label?feature.style.label:feature.attributes.name||feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=feature.attributes.description||this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
-return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0,len=rings.length;i<len;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[
i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
-return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0,len=geometry.components.length;i<len;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},split:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,sourceLine,sourceLines,sourceSplit,targetSplit;var sourceParts=[];var targetParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){sourceLine=this.components[i];sourceSplit=false;for(var j=0;j<targetParts.length;++j){splits=sourceLine.split(targetParts[j],options);if(splits){if(mutual){sourceLines=splits[0];for(var k=0,klen=sourceLines.length;k<klen;++k){if(k===0&&sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLines[k]);}else{sourceParts.push(new OpenLayers.Geometry.Mult
iLineString([sourceLines[k]]));}}
-sourceSplit=true;splits=splits[1];}
-if(splits.length){splits.unshift(j,1);Array.prototype.splice.apply(targetParts,splits);break;}}}
-if(!sourceSplit){if(sourceParts.length){sourceParts[sourceParts.length-1].addComponent(sourceLine.clone());}else{sourceParts=[new OpenLayers.Geometry.MultiLineString(sourceLine.clone())];}}}
-if(sourceSplit||targetSplit){if(mutual){results=[sourceParts,targetParts];}else{results=targetParts;}}
-return results;},splitWith:function(geometry,options){var results=null;var mutual=options&&options.mutual;var splits,targetLine,sourceLines,sourceSplit,targetSplit,sourceParts,targetParts;if(geometry instanceof OpenLayers.Geometry.LineString){targetParts=[];sourceParts=[geometry];for(var i=0,len=this.components.length;i<len;++i){targetSplit=false;targetLine=this.components[i];for(var j=0;j<sourceParts.length;++j){splits=sourceParts[j].split(targetLine,options);if(splits){if(mutual){sourceLines=splits[0];if(sourceLines.length){sourceLines.unshift(j,1);Array.prototype.splice.apply(sourceParts,sourceLines);j+=sourceLines.length-2;}
-splits=splits[1];if(splits.length===0){splits=[targetLine.clone()];}}
-for(var k=0,klen=splits.length;k<klen;++k){if(k===0&&targetParts.length){targetParts[targetParts.length-1].addComponent(splits[k]);}else{targetParts.push(new OpenLayers.Geometry.MultiLineString([splits[k]]));}}
-targetSplit=true;}}
-if(!targetSplit){if(targetParts.length){targetParts[targetParts.length-1].addComponent(targetLine.clone());}else{targetParts=[new OpenLayers.Geometry.MultiLineString([targetLine.clone()])];}}}}else{results=geometry.split(this);}
-return results;},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
-return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var bounds;var boxNodes=this.getElementsByTagNameNS(node,this.gmlns,"Box");for(i=0;i<boxNodes.length;++i){var boxNode=boxNodes[i];var box=this.parseGeometry["box"].apply(this,[boxNode]);var parentNode=boxNode.parentNode;var parentName=parentNode.localName||parentNode.nodeName.split(":").pop();if(parentName==="boundedBy"){bounds=box;}else{geometry=box.toGeometry();}}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);feature.bounds=bounds;feature.gml={featureType:node.firstChild.nodeName.split(":")[1],featureNS:node.firstChild.namespaceURI,featureNSPrefix:node.firstChild.prefix};var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
-childNode=childNode.nextSibling;}
-feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
-if(coords.length==2){coords[2]=null;}
-if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
-else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
-return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.getChildValue(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
-if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
-var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
-return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
-return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
-return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
-return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
-return envelope;},box:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");var coordString;var coords,beginPoint=null,endPoint=null;if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coords=coordString.split(" ");if(coords.length==2){beginPoint=coords[0].split(",");endPoint=coords[1].split(",");}}
-if(beginPoint!==null&&endPoint!==null){return new OpenLayers.Bounds(parseFloat(beginPoint[0]),parseFloat(beginPoint[1]),parseFloat(endPoint[0]),parseFloat(endPoint[1]));}}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}else{attributes[child.nodeName.split(":").pop()]=null;}}}
-break;}
-return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
-return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
-return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
-return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
-return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
-return gml;},bounds:function(bounds){var gml=this.createElementNS(this.gmlns,"gml:Box");gml.appendChild(this.buildCoordinatesNode(bounds));return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var parts=[];if(geometry instanceof OpenLayers.Bounds){parts.push(geometry.left+","+geometry.bottom);parts.push(geometry.right+","+geometry.top);}else{var points=(geometry.components)?geometry.components:[geometry];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}}
-var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});if(!OpenLayers.Format.GML){OpenLayers.Format.GML={};}
-OpenLayers.Format.GML.Base=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs"},defaultPrefix:"gml",schemaLocation:null,featureType:null,featureNS:null,geometryName:"geometry",extractAttributes:true,srsName:null,xy:true,geometryTypes:null,singleFeatureType:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.setGeometryTypes();if(options&&options.featureNS){this.setNamespace("feature",options.featureNS);}
-this.singleFeatureType=!options||(typeof options.featureType==="string");},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var features=[];this.readNode(data,{features:features});if(features.length==0){var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMember");if(elements.length){for(var i=0,len=elements.length;i<len;++i){this.readNode(elements[i],{features:features});}}else{var elements=this.getElementsByTagNameNS(data,this.namespaces.gml,"featureMembers");if(elements.length){this.readNode(elements[0],{features:features});}}}
-return features;},readers:{"gml":{"featureMember":function(node,obj){this.readChildNodes(node,obj);},"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"name":function(node,obj){obj.name=this.getChildValue(node);},"boundedBy":function(node,obj){var container={};this.readChildNodes(node,container);if(container.components&&container.components.length>0){obj.bounds=container.components[0];}},"Point":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-container.components.push(obj.points[0]);},"coordinates":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);var coords;var numPoints=pointList.length;var points=new Array(numPoints);for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");if(this.xy){points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{points[i]=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-obj.points=points;},"coord":function(node,obj){var coord={};this.readChildNodes(node,coord);if(!obj.points){obj.points=[];}
-obj.points.push(new OpenLayers.Geometry.Point(coord.x,coord.y,coord.z));},"X":function(node,coord){coord.x=this.getChildValue(node);},"Y":function(node,coord){coord.y=this.getChildValue(node);},"Z":function(node,coord){coord.z=this.getChildValue(node);},"MultiPoint":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiPoint(obj.components)];},"pointMember":function(node,obj){this.readChildNodes(node,obj);},"LineString":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-container.components.push(new OpenLayers.Geometry.LineString(obj.points));},"MultiLineString":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiLineString(obj.components)];},"lineStringMember":function(node,obj){this.readChildNodes(node,obj);},"Polygon":function(node,container){var obj={outer:null,inner:[]};this.readChildNodes(node,obj);obj.inner.unshift(obj.outer);if(!container.components){container.components=[];}
-container.components.push(new OpenLayers.Geometry.Polygon(obj.inner));},"LinearRing":function(node,obj){var container={};this.readChildNodes(node,container);obj.components=[new OpenLayers.Geometry.LinearRing(container.points)];},"MultiPolygon":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.MultiPolygon(obj.components)];},"polygonMember":function(node,obj){this.readChildNodes(node,obj);},"GeometryCollection":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);container.components=[new OpenLayers.Geometry.Collection(obj.components)];},"geometryMember":function(node,obj){this.readChildNodes(node,obj);}},"feature":{"*":function(node,obj){var name;var local=node.localName||node.nodeName.split(":").pop();if(obj.features){if(!this.singleFeatureType&&(OpenLayers.Util.indexOf(this.featureType,local)!==-1)){name="_typeName";}else if(local===this.featureType){name="_typeName";}}else
{if(node.childNodes.length==0||(node.childNodes.length==1&&node.firstChild.nodeType==3)){if(this.extractAttributes){name="_attribute";}}else{name="_geometry";}}
-if(name){this.readers.feature[name].apply(this,[node,obj]);}},"_typeName":function(node,obj){var container={components:[],attributes:{}};this.readChildNodes(node,container);if(container.name){container.attributes.name=container.name;}
-var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);if(!this.singleFeatureType){feature.type=node.nodeName.split(":").pop();feature.namespace=node.namespaceURI;}
-var fid=node.getAttribute("fid")||this.getAttributeNS(node,this.namespaces["gml"],"id");if(fid){feature.fid=fid;}
-if(this.internalProjection&&this.externalProjection&&feature.geometry){feature.geometry.transform(this.externalProjection,this.internalProjection);}
-if(container.bounds){feature.bounds=container.bounds;}
-obj.features.push(feature);},"_geometry":function(node,obj){this.readChildNodes(node,obj);},"_attribute":function(node,obj){var local=node.localName||node.nodeName.split(":").pop();var value=this.getChildValue(node);obj.attributes[local]=value;}},"wfs":{"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);}}},write:function(features){var name;if(features instanceof Array){name="featureMembers";}else{name="featureMember";}
-var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":{"featureMember":function(feature){var node=this.createElementNSPlus("gml:featureMember");this.writeNode("feature:_typeName",feature,node);return node;},"MultiPoint":function(geometry){var node=this.createElementNSPlus("gml:MultiPoint");for(var i=0;i<geometry.components.length;++i){this.writeNode("pointMember",geometry.components[i],node);}
-return node;},"pointMember":function(geometry){var node=this.createElementNSPlus("gml:pointMember");this.writeNode("Point",geometry,node);return node;},"MultiLineString":function(geometry){var node=this.createElementNSPlus("gml:MultiLineString");for(var i=0;i<geometry.components.length;++i){this.writeNode("lineStringMember",geometry.components[i],node);}
-return node;},"lineStringMember":function(geometry){var node=this.createElementNSPlus("gml:lineStringMember");this.writeNode("LineString",geometry,node);return node;},"MultiPolygon":function(geometry){var node=this.createElementNSPlus("gml:MultiPolygon");for(var i=0;i<geometry.components.length;++i){this.writeNode("polygonMember",geometry.components[i],node);}
-return node;},"polygonMember":function(geometry){var node=this.createElementNSPlus("gml:polygonMember");this.writeNode("Polygon",geometry,node);return node;},"GeometryCollection":function(geometry){var node=this.createElementNSPlus("gml:GeometryCollection");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("geometryMember",geometry.components[i],node);}
-return node;},"geometryMember":function(geometry){var node=this.createElementNSPlus("gml:geometryMember");var child=this.writeNode("feature:_geometry",geometry);node.appendChild(child.firstChild);return node;}},"feature":{"_typeName":function(feature){var node=this.createElementNSPlus("feature:"+this.featureType,{attributes:{fid:feature.fid}});if(feature.geometry){this.writeNode("feature:_geometry",feature.geometry,node);}
-for(var name in feature.attributes){var value=feature.attributes[name];if(value!=null){this.writeNode("feature:_attribute",{name:name,value:value},node);}}
-return node;},"_geometry":function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone().transform(this.internalProjection,this.externalProjection);}
-var node=this.createElementNSPlus("feature:"+this.geometryName);var type=this.geometryTypes[geometry.CLASS_NAME];var child=this.writeNode("gml:"+type,geometry,node);if(this.srsName){child.setAttribute("srsName",this.srsName);}
-return node;},"_attribute":function(obj){return this.createElementNSPlus("feature:"+obj.name,{value:obj.value});}},"wfs":{"FeatureCollection":function(features){var node=this.createElementNSPlus("wfs:FeatureCollection");for(var i=0,len=features.length;i<len;++i){this.writeNode("gml:featureMember",features[i],node);}
-return node;}}},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":"LineString","OpenLayers.Geometry.MultiLineString":"MultiLineString","OpenLayers.Geometry.Polygon":"Polygon","OpenLayers.Geometry.MultiPolygon":"MultiPolygon","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.Base"});OpenLayers.Format.GML.v2=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/2.1.2/feature.xsd",initialize:function(options){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[options]);},readers:{"gml":OpenLayers.Util.applyDefaults({"outerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"innerBoundaryIs":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]
);},"Box":function(node,container){var obj={};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(features instanceof Array){name="wfs:FeatureCollection";}else{name="gml:featureMember";}
-var root=this.writeNode(name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("coordinates",[geometry],node);return node;},"coordinates":function(points){var numPoints=points.length;var parts=new Array(numPoints);var point;for(var i=0;i<numPoints;++i){point=points[i];if(this.xy){parts[i]=point.x+","+point.y;}else{parts[i]=point.y+","+point.x;}
-if(point.z!=undefined){parts[i]+=","+point.z;}}
-return this.createElementNSPlus("gml:coordinates",{attributes:{decimal:".",cs:",",ts:" "},value:(numPoints==1)?parts[0]:parts.join(" ")});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("coordinates",geometry.components,node);return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("outerBoundaryIs",geometry.components[0],node);for(var i=1;i<geometry.components.length;++i){this.writeNode("innerBoundaryIs",geometry.components[i],node);}
-return node;},"outerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:outerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"innerBoundaryIs":function(ring){var node=this.createElementNSPlus("gml:innerBoundaryIs");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("coordinates",ring.components,node);return node;},"Box":function(bounds){var node=this.createElementNSPlus("gml:Box");this.writeNode("coordinates",[{x:bounds.left,y:bounds.bottom},{x:bounds.right,y:bounds.top}],node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
-return node;}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},CLASS_NAME:"OpenLayers.Format.GML.v2"});OpenLayers.Style=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,defaultsPerSymbolizer:false,propertyStyles:null,initialize:function(style,options){OpenLayers.Util.extend(this,options);this.rules=[];if(options&&options.rules){this.addRules(options.rules);}
-this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.defaultsPerSymbolizer?{}:this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0,len=rules.length;i<len;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0,len=elseRules.length;i<len;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;if(this.defaultsPerSymbolizer===true){var defaults=this.defaultStyle;OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:defaults.pointRadius});if(symbolizer.stroke===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{strokeWidth:defaults.strokeWidth,strokeColor:defaults.strokeColor,strokeOpacity:defaults.strokeOpacity,strokeDashstyle:defaults.strokeDashstyle,strokeLinecap:defaults.strokeLinecap});}
-if(symbolizer.fill===true||symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{fillColor:defaults.fillColor,fillOpacity:defaults.fillOpacity});}
-if(symbolizer.graphic===true){OpenLayers.Util.applyDefaults(symbolizer,{pointRadius:this.defaultStyle.pointRadius,externalGraphic:this.defaultStyle.externalGraphic,graphicName:this.defaultStyle.graphicName,graphicOpacity:this.defaultStyle.graphicOpacity,graphicWidth:this.defaultStyle.graphicWidth,graphicHeight:this.defaultStyle.graphicHeight,graphicXOffset:this.defaultStyle.graphicXOffset,graphicYOffset:this.defaultStyle.graphicYOffset});}}
-return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=OpenLayers.Util.extend({},feature.attributes||feature.data);OpenLayers.Util.extend(context,this.context);for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature,i);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0,len=rules.length;i<len;i++){symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){Array.prototype.push.apply(this.rules,rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=prefixes.length;i<len;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.rules){options.rules=[];for(var i=0,len=this.rules.length;i<len;++i){options.rules.push(this.rules[i].clone());}}
-options.context=this.context&&OpenLayers.Util.extend({},this.context);var defaultStyle=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(defaultStyle,options);},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature,property){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature,property]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon','Text','Raster'];OpenLayers.Symbolizer=OpenLayers.Class({zIndex:0,initialize:function(config){OpenLayers.Util.extend(this,config);},clone:function(){var Type=eval(this.CLASS_NAME);return new Type(OpenLayers.Util.extend({},this));},CLASS_NAME:"OpenLayers.Symbolizer"});OpenLayers.Symbolizer.Point=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Point"});OpenLayers.Symbolizer.Line=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Line"});OpenLayers.Symbolizer.Polygon=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Polygon"});OpenLayers.Symbolizer.T
ext=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Text"});OpenLayers.Symbolizer.Raster=OpenLayers.Class(OpenLayers.Symbolizer,{initialize:function(config){OpenLayers.Symbolizer.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Symbolizer.Raster"});OpenLayers.Rule=OpenLayers.Class({id:null,name:null,title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,symbolizers:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.symbolizer={};OpenLayers.Util.extend(this,options);if(this.symbolizers){delete this.symbolizer;}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;delete this.symbolizers;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-if(typeof this.context=="function"){context=this.context(feature);}
-return context;},clone:function(){var options=OpenLayers.Util.extend({},this);if(this.symbolizers){var len=this.symbolizers.length;options.symbolizers=new Array(len);for(var i=0;i<len;++i){options.symbolizers[i]=this.symbolizers[i].clone();}}else{options.symbolizer={};var value,type;for(var key in this.symbolizer){value=this.symbolizer[key];type=typeof value;if(type==="object"){options.symbolizer[key]=OpenLayers.Util.extend({},value);}else if(type==="string"){options.symbolizer[key]=value;}}}
-options.filter=this.filter&&this.filter.clone();options.context=this.context&&OpenLayers.Util.extend({},this.context);return new OpenLayers.Rule(options);},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},clone:function(){return null;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0,len=this.fids.length;i<len;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
-return false;},clone:function(){var filter=new OpenLayers.Filter.FeatureId();OpenLayers.Util.extend(filter,this);filter.fids=this.fids.slice();return filter;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){var i,len;switch(this.type){case OpenLayers.Filter.Logical.AND:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==false){return false;}}
-return true;case OpenLayers.Filter.Logical.OR:for(i=0,len=this.filters.length;i<len;i++){if(this.filters[i].evaluate(context)==true){return true;}}
-return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}
-return undefined;},clone:function(){var filters=[];for(var i=0,len=this.filters.length;i<len;++i){filters.push(this.filters[i].clone());}
-return new OpenLayers.Filter.Logical({type:this.type,filters:filters});},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,matchCase:true,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){if(context instanceof OpenLayers.Feature.Vector){context=context.attributes;}
-var result=false;var got=context[this.property];var exp;switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()==exp.toUpperCase());}else{result=(got==exp);}
-break;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:exp=this.value;if(!this.matchCase&&typeof got=="string"&&typeof exp=="string"){result=(got.toUpperCase()!=exp.toUpperCase());}else{result=(got!=exp);}
-break;case OpenLayers.Filter.Comparison.LESS_THAN:result=got<this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN:result=got>this.value;break;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:result=got<=this.value;break;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:result=got>=this.value;break;case OpenLayers.Filter.Comparison.BETWEEN:result=(got>=this.lowerBoundary)&&(got<=this.upperBoundary);break;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");result=regexp.test(got);break;}
-return result;},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar+"(.|$)","g"),"\\$1");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},clone:function(){return OpenLayers.Util.extend(new OpenLayers.Filter.Comparison(),this);},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_E
QUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.Spatial=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,distance:null,distanceUnits:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){var intersect=false;switch(this.type){case OpenLayers.Filter.Spatial.BBOX:case OpenLayers.Filter.Spatial.INTERSECTS:if(feature.geometry){var geom=this.value;if(this.value.CLASS_NAME=="OpenLayers.Bounds"){geom=this.value.toGeometry();}
-if(feature.geometry.intersects(geom)){intersect=true;}}
-break;default:OpenLayers.Console.error(OpenLayers.i18n("filterEvaluateNotImplemented"));break;}
-return intersect;},clone:function(){var options=OpenLayers.Util.applyDefaults({value:this.value&&this.value.clone&&this.value.clone()},this);return new OpenLayers.Filter.Spatial(options);},CLASS_NAME:"OpenLayers.Filter.Spatial"});OpenLayers.Filter.Spatial.BBOX="BBOX";OpenLayers.Filter.Spatial.INTERSECTS="INTERSECTS";OpenLayers.Filter.Spatial.DWITHIN="DWITHIN";OpenLayers.Filter.Spatial.WITHIN="WITHIN";OpenLayers.Filter.Spatial.CONTAINS="CONTAINS";OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,namedLayersAsArray:false,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-var sld=this.parser.read(data,options);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Filter=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(filter,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
-version;}
-return this.parser.write(filter);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var version=this.version;if(!version){version=this.defaultVersion;}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.Filter["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a Filter parser for version "+
-version;}
-var filter=this.parser.read(data);return filter;},CLASS_NAME:"OpenLayers.Format.Filter"});OpenLayers.Format.Filter.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"ogc",schemaLocation:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var obj={};this.readers.ogc["Filter"].apply(this,[data,obj]);return obj.filter;},readers:{"ogc":{"Filter":function(node,parent){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){parent.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){parent.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers
.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filt
ers.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=OpenLayers.String.numericIf(this.getChildValue(node));},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"UpperBoundary":function(node,filter){filter.upperBoundary=OpenLayers.String.numericIf(this.readOgcExpression(node));},"Intersects":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.INTERSECTS);},"Within":function(node,obj){this.readSpatial(node,obj
,OpenLayers.Filter.Spatial.WITHIN);},"Contains":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.CONTAINS);},"DWithin":function(node,obj){this.readSpatial(node,obj,OpenLayers.Filter.Spatial.DWITHIN);},"Distance":function(node,obj){obj.distance=parseInt(this.getChildValue(node));obj.distanceUnits=node.getAttribute("units");}}},readSpatial:function(node,obj,type){var filter=new OpenLayers.Filter.Spatial({type:type});this.readChildNodes(node,filter);filter.value=filter.components[0];delete filter.components;obj.filters.push(filter);},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(value===undefined){value=this.getChildValue(node);}
-return value;},write:function(filter){return this.writers.ogc["Filter"].apply(this,[filter]);},writers:{"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");var sub=filter.CLASS_NAME.split(".").pop();if(sub=="FeatureId"){for(var i=0;i<filter.fids.length;++i){this.writeNode("FeatureId",filter.fids[i],node);}}else{this.writeNode(this.getFilterType(filter),filter,node);}
-return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(this.getFilterType(childFilter),childFilter,node);}
-return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(this.getFilterType(childFilter),childFilter,node);}
-return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];this.writeNode(this.getFilterType(childFilter),childFilter,node);return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode("PropertyName",filter,node);this.wri
teNode("Literal",filter.value,node);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode("PropertyName",filter,node);this.writeNode("LowerBoundary",filter,node);this.writeNode("UpperBoundary",filter,node);return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeNode("Literal",filter.lowerBoundary,node);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode("Literal",filter.upperBoundary,node);return node;},"INTERSECTS":function(filter){return this.writeSpatial(filter,"Intersects");},"WITHIN":function(filter){return this.writeSpatial(filter,"Within");},"CONTAINS":function(filter){return this.wri
teSpatial(filter,"Contains");},"DWITHIN":function(filter){var node=this.writeSpatial(filter,"DWithin");this.writeNode("Distance",filter,node);return node;},"Distance":function(filter){return this.createElementNSPlus("ogc:Distance",{attributes:{units:filter.distanceUnits},value:filter.distance});}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"Filter writing not supported for rule type: "+filter.type;}
-return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike","BBOX":"BBOX","DWITHIN":"DWITHIN","WITHIN":"WITHIN","CONTAINS":"CONTAINS","INTERSECTS":"INTERSECTS"},CLASS_NAME:"OpenLayers.Format.Filter.v1"});OpenLayers.Format.Filter.v1_0_0=OpenLayers.Class(OpenLayers.Format.GML.v2,OpenLayers.Format.Filter.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.0.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v2.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,
obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.creat
eElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Box",filter.value,node);if(filter.projection){box.setAttribute("srsName",filter.projection);}
-return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Box",filter.value);}
-if(filter.projection){child.setAttribute("srsName",filter.projection);}
-node.appendChild(child);return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_0_0"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.Filter.v1_0_0,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,multipleSymbolizers:false,featureTypeCounter:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,strokeDashstyle:"solid",pointRadius:3,graphicName:"square"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);},read:function(data,options){options=OpenLayers.Util.applyDefaults(options,this.options);var sld={namedLayers:options.namedLayersAsArray===true?[]:{}};this.readChildNodes(data,sld);return sld;},readers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function
(node,sld){sld.version=node.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0,len=layer.userStyles.length;i<len;++i){layer.userStyles[i].layerName=layer.name;}
-if(sld.namedLayers instanceof Array){sld.namedLayers.push(layer);}else{sld.namedLayers[layer.name]=layer;}},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildName(node.firstChild));},"UserStyle":function(node,layer){var obj={defaultsPerSymbolizer:true,rules:[]};this.featureTypeCounter=-1;this.readChildNodes(node,obj);var style;if(this.multipleSymbolizers){delete obj.defaultsPerSymbolizer;style=new OpenLayers.Style2(obj);}else{style=new OpenLayers.Style(this.defaultSymbolizer,obj);}
-layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){++this.featureTypeCounter;var obj={rules:this.multipleSymbolizers?style.rules:[]};this.readChildNodes(node,obj);if(!this.multipleSymbolizers){style.rules=obj.rules;}},"Rule":function(node,obj){var config;if(this.multipleSymbolizers){config={symbolizers:[]};}
-var rule=new OpenLayers.Rule(config);this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=parseFloat(this.getChildValue(node));},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=parseFloat(this.getChildValue(node));},"TextSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Text(config));}else{rule.symbolizer["Text"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Text"]);}},"Label":function(node,symbolizer){var obj={};this.readChildNodes(node,obj);if(obj.property){symbolizer.label="${"+obj.property+"}";}else{var value=this.readOgcExpression(node);if(value){symbolizer.label=value;}}},"Font":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Halo":function(node,symbolizer){var
obj={};this.readChildNodes(node,obj);symbolizer.haloRadius=obj.haloRadius;symbolizer.haloColor=obj.fillColor;symbolizer.haloOpacity=obj.fillOpacity;},"Radius":function(node,symbolizer){var radius=this.readOgcExpression(node);if(radius!=null){symbolizer.haloRadius=radius;}},"RasterSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Raster(config));}else{rule.symbolizer["Raster"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Raster"]);}},"Geometry":function(node,obj){obj.geometry={};this.readChildNodes(node,obj.geometry);},"ColorMap":function(node,symbolizer){symbolizer.colorMap=[];this.readChildNodes(node,symbolizer.colorMap);},"ColorMapEntry":function(node,colorMap){var q=node.getAttribute("quantity");var o=node.getAttribute("opacity");colorMap.push({color:node.getAttribute("color"),quantity:q!==null?parseFloat(q):undefined,lab
el:node.getAttribute("label")||undefined,opacity:o!==null?parseFloat(o):undefined});},"LineSymbolizer":function(node,rule){var config={};this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Line(config));}else{rule.symbolizer["Line"]=OpenLayers.Util.applyDefaults(config,rule.symbolizer["Line"]);}},"PolygonSymbolizer":function(node,rule){var config={fill:false,stroke:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Polygon"]||config;}
-this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Polygon(config));}else{rule.symbolizer["Polygon"]=config;}},"PointSymbolizer":function(node,rule){var config={fill:false,stroke:false,graphic:false};if(!this.multipleSymbolizers){config=rule.symbolizer["Point"]||config;}
-this.readChildNodes(node,config);if(this.multipleSymbolizers){config.zIndex=this.featureTypeCounter;rule.symbolizers.push(new OpenLayers.Symbolizer.Point(config));}else{rule.symbolizer["Point"]=config;}},"Stroke":function(node,symbolizer){symbolizer.stroke=true;this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){symbolizer.fill=true;this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){symbolizer.graphic=true;var graphic={};this.readChildNodes(node,graphic);var properties=["stroke","strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fill","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0,len=properties.length;i<len;++i){prop=properties[i];value=graphic[prop];if(v
alue!=undefined){symbolizer[prop]=value;}}
-if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
-if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size/2;}
-if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}
-if(graphic.rotation!=undefined){symbolizer.rotation=graphic.rotation;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.readOgcExpression(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.readOgcExpression(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.readOgcExpression(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}}},OpenLayers.Format.Filter.v1_0_0.prototype.readers),cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","stroke-dasharray":"s
trokeDashstyle","fill":"fillColor","fill-opacity":"fillOpacity","font-family":"fontFamily","font-size":"fontSize","font-weight":"fontWeight","font-style":"fontStyle"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
-return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
-return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:OpenLayers.Util.applyDefaults({"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("sld:StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});root.setAttribute("xmlns:ogc",this.namespaces.ogc);root.setAttribute("xmlns:gml",this.namespaces.gml);if(sld.name){this.writeNode("Name",sld.name,root);}
-if(sld.title){this.writeNode("Title",sld.title,root);}
-if(sld.description){this.writeNode("Abstract",sld.description,root);}
-if(sld.namedLayers instanceof Array){for(var i=0,len=sld.namedLayers.length;i<len;++i){this.writeNode("NamedLayer",sld.namedLayers[i],root);}}else{for(var name in sld.namedLayers){this.writeNode("NamedLayer",sld.namedLayers[name],root);}}
-return root;},"Name":function(name){return this.createElementNSPlus("sld:Name",{value:name});},"Title":function(title){return this.createElementNSPlus("sld:Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("sld:Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("sld:NamedLayer");this.writeNode("Name",layer.name,node);if(layer.namedStyles){for(var i=0,len=layer.namedStyles.length;i<len;++i){this.writeNode("NamedStyle",layer.namedStyles[i],node);}}
-if(layer.userStyles){for(var i=0,len=layer.userStyles.length;i<len;++i){this.writeNode("UserStyle",layer.userStyles[i],node);}}
-return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("sld:NamedStyle");this.writeNode("Name",name,node);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("sld:UserStyle");if(style.name){this.writeNode("Name",style.name,node);}
-if(style.title){this.writeNode("Title",style.title,node);}
-if(style.description){this.writeNode("Abstract",style.description,node);}
-if(style.isDefault){this.writeNode("IsDefault",style.isDefault,node);}
-if(this.multipleSymbolizers&&style.rules){var rulesByZ={0:[]};var zValues=[0];var rule,ruleMap,symbolizer,zIndex,clone;for(var i=0,ii=style.rules.length;i<ii;++i){rule=style.rules[i];if(rule.symbolizers){ruleMap={};for(var j=0,jj=rule.symbolizers.length;j<jj;++j){symbolizer=rule.symbolizers[j];zIndex=symbolizer.zIndex;if(!(zIndex in ruleMap)){clone=rule.clone();clone.symbolizers=[];ruleMap[zIndex]=clone;}
-ruleMap[zIndex].symbolizers.push(symbolizer.clone());}
-for(zIndex in ruleMap){if(!(zIndex in rulesByZ)){zValues.push(zIndex);rulesByZ[zIndex]=[];}
-rulesByZ[zIndex].push(ruleMap[zIndex]);}}else{rulesByZ[0].push(rule.clone());}}
-zValues.sort();var rules;for(var i=0,ii=zValues.length;i<ii;++i){rules=rulesByZ[zValues[i]];if(rules.length>0){clone=style.clone();clone.rules=rulesByZ[zValues[i]];this.writeNode("FeatureTypeStyle",clone,node);}}}else{this.writeNode("FeatureTypeStyle",style,node);}
-return node;},"IsDefault":function(bool){return this.createElementNSPlus("sld:IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("sld:FeatureTypeStyle");for(var i=0,len=style.rules.length;i<len;++i){this.writeNode("Rule",style.rules[i],node);}
-return node;},"Rule":function(rule){var node=this.createElementNSPlus("sld:Rule");if(rule.name){this.writeNode("Name",rule.name,node);}
-if(rule.title){this.writeNode("Title",rule.title,node);}
-if(rule.description){this.writeNode("Abstract",rule.description,node);}
-if(rule.elseFilter){this.writeNode("ElseFilter",null,node);}else if(rule.filter){this.writeNode("ogc:Filter",rule.filter,node);}
-if(rule.minScaleDenominator!=undefined){this.writeNode("MinScaleDenominator",rule.minScaleDenominator,node);}
-if(rule.maxScaleDenominator!=undefined){this.writeNode("MaxScaleDenominator",rule.maxScaleDenominator,node);}
-var type,symbolizer;if(this.multipleSymbolizers&&rule.symbolizers){var symbolizer;for(var i=0,ii=rule.symbolizers.length;i<ii;++i){symbolizer=rule.symbolizers[i];type=symbolizer.CLASS_NAME.split(".").pop();this.writeNode(type+"Symbolizer",symbolizer,node);}}else{var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0,len=types.length;i<len;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(type+"Symbolizer",symbolizer,node);}}}
-return node;},"ElseFilter":function(){return this.createElementNSPlus("sld:ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("sld:MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("sld:MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:LineSymbolizer");this.writeNode("Stroke",symbolizer,node);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("sld:Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeColor"},node);}
-if(symbolizer.strokeOpacity!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"},node);}
-if(symbolizer.strokeWidth!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeWidth"},node);}
-if(symbolizer.strokeDashstyle!=undefined&&symbolizer.strokeDashstyle!=="solid"){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeDashstyle"},node);}
-if(symbolizer.strokeLinecap!=undefined){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"strokeLinecap"},node);}
-return node;},"CssParameter":function(obj){return this.createElementNSPlus("sld:CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"TextSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:TextSymbolizer");if(symbolizer.label!=null){this.writeNode("Label",symbolizer.label,node);}
-if(symbolizer.fontFamily!=null||symbolizer.fontSize!=null||symbolizer.fontWeight!=null||symbolizer.fontStyle!=null){this.writeNode("Font",symbolizer,node);}
-if(symbolizer.haloRadius!=null||symbolizer.haloColor!=null||symbolizer.haloOpacity!=null){this.writeNode("Halo",symbolizer,node);}
-if(symbolizer.fillColor!=null||symbolizer.fillOpacity!=null){this.writeNode("Fill",symbolizer,node);}
-return node;},"Font":function(symbolizer){var node=this.createElementNSPlus("sld:Font");if(symbolizer.fontFamily){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontFamily"},node);}
-if(symbolizer.fontSize){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontSize"},node);}
-if(symbolizer.fontWeight){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontWeight"},node);}
-if(symbolizer.fontStyle){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fontStyle"},node);}
-return node;},"Label":function(label){var node=this.createElementNSPlus("sld:Label");var tokens=label.split("${");node.appendChild(this.createTextNode(tokens[0]));var item,last;for(var i=1,len=tokens.length;i<len;i++){item=tokens[i];last=item.indexOf("}");if(last>0){this.writeNode("ogc:PropertyName",{property:item.substring(0,last)},node);node.appendChild(this.createTextNode(item.substring(++last)));}else{node.appendChild(this.createTextNode("${"+item));}}
-return node;},"Halo":function(symbolizer){var node=this.createElementNSPlus("sld:Halo");if(symbolizer.haloRadius){this.writeNode("Radius",symbolizer.haloRadius,node);}
-if(symbolizer.haloColor||symbolizer.haloOpacity){this.writeNode("Fill",{fillColor:symbolizer.haloColor,fillOpacity:symbolizer.haloOpacity},node);}
-return node;},"Radius":function(value){return this.createElementNSPlus("sld:Radius",{value:value});},"RasterSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:RasterSymbolizer");if(symbolizer.geometry){this.writeNode("Geometry",symbolizer.geometry,node);}
-if(symbolizer.opacity){this.writeNode("Opacity",symbolizer.opacity,node);}
-if(symbolizer.colorMap){this.writeNode("ColorMap",symbolizer.colorMap,node);}
-return node;},"Geometry":function(geometry){var node=this.createElementNSPlus("sld:Geometry");if(geometry.property){this.writeNode("ogc:PropertyName",geometry,node);}
-return node;},"ColorMap":function(colorMap){var node=this.createElementNSPlus("sld:ColorMap");for(var i=0,len=colorMap.length;i<len;++i){this.writeNode("ColorMapEntry",colorMap[i],node);}
-return node;},"ColorMapEntry":function(colorMapEntry){var node=this.createElementNSPlus("sld:ColorMapEntry");var a=colorMapEntry;node.setAttribute("color",a.color);a.opacity!==undefined&&node.setAttribute("opacity",parseFloat(a.opacity));a.quantity!==undefined&&node.setAttribute("quantity",parseFloat(a.quantity));a.label!==undefined&&node.setAttribute("label",a.label);return node;},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:PolygonSymbolizer");if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
-if(symbolizer.stroke!==false){this.writeNode("Stroke",symbolizer,node);}
-return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("sld:Fill");if(symbolizer.fillColor){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fillColor"},node);}
-if(symbolizer.fillOpacity!=null){this.writeNode("CssParameter",{symbolizer:symbolizer,key:"fillOpacity"},node);}
-return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("sld:PointSymbolizer");this.writeNode("Graphic",symbolizer,node);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("sld:Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode("ExternalGraphic",symbolizer,node);}else{this.writeNode("Mark",symbolizer,node);}
-if(symbolizer.graphicOpacity!=undefined){this.writeNode("Opacity",symbolizer.graphicOpacity,node);}
-if(symbolizer.pointRadius!=undefined){this.writeNode("Size",symbolizer.pointRadius*2,node);}
-if(symbolizer.rotation!=undefined){this.writeNode("Rotation",symbolizer.rotation,node);}
-return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("sld:ExternalGraphic");this.writeNode("OnlineResource",symbolizer.externalGraphic,node);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode("Format",format,node);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("sld:Mark");if(symbolizer.graphicName){this.writeNode("WellKnownName",symbolizer.graphicName,node);}
-if(symbolizer.fill!==false){this.writeNode("Fill",symbolizer,node);}
-return node;},"WellKnownName":function(name){return this.createElementNSPlus("sld:WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("sld:Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("sld:Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("sld:Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("sld:OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("sld:Format",{value:format});}}},OpenLayers.Format.Filter.v1_0_0.prototype.writers),CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[option
s]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Format.Context=OpenLayers.Class({version:null,layerOptions:null,layerParams:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");}
-var parser=this.getParser(version);var context=parser.read(data,options);var map;if(options&&options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{var mapOptions=options.map;if(OpenLayers.Util.isElement(mapOptions)||typeof mapOptions=="string"){mapOptions={div:mapOptions};}
-map=this.contextToMap(context,mapOptions);}}else{map=context;}
-return map;},getLayerFromContext:function(layerContext){var i,len;var options={queryable:layerContext.queryable,visibility:layerContext.visibility,maxExtent:layerContext.maxExtent,metadata:OpenLayers.Util.applyDefaults(layerContext.metadata,{styles:layerContext.styles}),numZoomLevels:layerContext.numZoomLevels,units:layerContext.units,isBaseLayer:layerContext.isBaseLayer,opacity:layerContext.opacity,displayInLayerSwitcher:layerContext.displayInLayerSwitcher,singleTile:layerContext.singleTile,tileSize:(layerContext.tileSize)?new OpenLayers.Size(layerContext.tileSize.width,layerContext.tileSize.height):undefined,minScale:layerContext.minScale||layerContext.maxScaleDenominator,maxScale:layerContext.maxScale||layerContext.minScaleDenominator};if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
-var params={layers:layerContext.name,transparent:layerContext.transparent,version:layerContext.version};if(layerContext.formats&&layerContext.formats.length>0){params.format=layerContext.formats[0].value;for(i=0,len=layerContext.formats.length;i<len;i++){var format=layerContext.formats[i];if(format.current==true){params.format=format.value;break;}}}
-if(layerContext.styles&&layerContext.styles.length>0){for(i=0,len=layerContext.styles.length;i<len;i++){var style=layerContext.styles[i];if(style.current==true){if(style.href){params.sld=style.href;}else if(style.body){params.sld_body=style.body;}else{params.styles=style.name;}
-break;}}}
-if(this.layerParams){OpenLayers.Util.applyDefaults(params,this.layerParams);}
-var layer=null;var service=layerContext.service;if(service==OpenLayers.Format.Context.serviceTypes.WFS){options.strategies=[new OpenLayers.Strategy.BBOX()];options.protocol=new OpenLayers.Protocol.WFS({url:layerContext.url,featurePrefix:layerContext.name.split(":")[0],featureType:layerContext.name.split(":").pop()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.KML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.KML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);}else if(service==OpenLayers.Format.Context.serviceTypes.GML){options.strategies=[new OpenLayers.Strategy.Fixed()];options.protocol=new OpenLayers.Protocol.HTTP({url:layerContext.url,format:new OpenLayers.Format.GML()});layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.na
me,options);}else if(layerContext.features){layer=new OpenLayers.Layer.Vector(layerContext.title||layerContext.name,options);layer.addFeatures(layerContext.features);}else if(layerContext.categoryLayer!==true){layer=new OpenLayers.Layer.WMS(layerContext.title||layerContext.name,layerContext.url,params,options);}
-return layer;},getLayersFromContext:function(layersContext){var layers=[];for(var i=0,len=layersContext.length;i<len;i++){var layer=this.getLayerFromContext(layersContext[i]);if(layer!==null){layers.push(layer);}}
-return layers;},contextToMap:function(context,options){options=OpenLayers.Util.applyDefaults({maxExtent:context.maxExtent,projection:context.projection},options);var map=new OpenLayers.Map(options);map.addLayers(this.getLayersFromContext(context.layersContext));map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(this.getLayersFromContext(context.layersContext));return map;},write:function(obj,options){obj=this.toContext(obj);var version=options&&options.version;var parser=this.getParser(version);var context=parser.write(obj,options);return context;},CLASS_NAME:"OpenLayers.Format.Context"});OpenLayers.Format.Context.serviceTypes={"WMS":"urn:ogc:serviceType:WMS","WFS":"urn:ogc:serviceType:WFS","WCS":"urn:ogc:serviceType:WCS","GML":"urn:ogc:serviceType:GML","SLD":"urn:ogc:serviceType:SLD","FES":"urn:ogc:serviceType:FES","KML":"urn:ogc:serviceType:KML"};OpenLayers.Format.OWSC
ontext=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"0.3.1",getParser:function(version){var v=version||this.version||this.defaultVersion;if(v==="0.3.0"){v=this.defaultVersion;}
-if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.OWSContext["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a OWSContext parser for version "+v;}
-return this.parser;},toContext:function(obj){var context={};if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();context.layers=obj.layers;}
-return context;},CLASS_NAME:"OpenLayers.Format.OWSContext"});if(!OpenLayers.Format.OWSCommon){OpenLayers.Format.OWSCommon={};}
-OpenLayers.Format.OWSCommon.v1=OpenLayers.Class(OpenLayers.Format.XML,{regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},readers:{"ows":{"ServiceIdentification":function(node,obj){obj.serviceIdentification={};this.readChildNodes(node,obj.serviceIdentification);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,serviceIdentification){serviceIdentification["abstract"]=this.getChildValue(node);},"Keywords":function(node,serviceIdentification){serviceIdentification.keywords={};this.readChildNodes(node,serviceIdentification.keywords);},"Keyword":function(node,keywords){keywords[this.getChildValue(node)]=true;},"ServiceType":function(node,serviceIdentification){serviceIdentification.serviceType={codeSpace:node.getAttribute('codeSpace'),value:this.getChildValue(node)};},"ServiceTypeVersion":function(node,serviceIdentification){serviceIdentification.serviceTypeVersion=this.getChildValue(node);},"
Fees":function(node,serviceIdentification){serviceIdentification.fees=this.getChildValue(node);},"AccessConstraints":function(node,serviceIdentification){serviceIdentification.accessConstraints=this.getChildValue(node);},"ServiceProvider":function(node,obj){obj.serviceProvider={};this.readChildNodes(node,obj.serviceProvider);},"ProviderName":function(node,serviceProvider){serviceProvider.providerName=this.getChildValue(node);},"ProviderSite":function(node,serviceProvider){serviceProvider.providerSite=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ServiceContact":function(node,serviceProvider){serviceProvider.serviceContact={};this.readChildNodes(node,serviceProvider.serviceContact);},"IndividualName":function(node,serviceContact){serviceContact.individualName=this.getChildValue(node);},"PositionName":function(node,serviceContact){serviceContact.positionName=this.getChildValue(node);},"ContactInfo":function(node,serviceContact){serviceContact.contactInfo={};this.re
adChildNodes(node,serviceContact.contactInfo);},"Phone":function(node,contactInfo){contactInfo.phone={};this.readChildNodes(node,contactInfo.phone);},"Voice":function(node,phone){phone.voice=this.getChildValue(node);},"Address":function(node,contactInfo){contactInfo.address={};this.readChildNodes(node,contactInfo.address);},"DeliveryPoint":function(node,address){address.deliveryPoint=this.getChildValue(node);},"City":function(node,address){address.city=this.getChildValue(node);},"AdministrativeArea":function(node,address){address.administrativeArea=this.getChildValue(node);},"PostalCode":function(node,address){address.postalCode=this.getChildValue(node);},"Country":function(node,address){address.country=this.getChildValue(node);},"ElectronicMailAddress":function(node,address){address.electronicMailAddress=this.getChildValue(node);},"Role":function(node,serviceContact){serviceContact.role=this.getChildValue(node);},"OperationsMetadata":function(node,obj){obj.operationsMetadat
a={};this.readChildNodes(node,obj.operationsMetadata);},"Operation":function(node,operationsMetadata){var name=node.getAttribute("name");operationsMetadata[name]={};this.readChildNodes(node,operationsMetadata[name]);},"DCP":function(node,operation){operation.dcp={};this.readChildNodes(node,operation.dcp);},"HTTP":function(node,dcp){dcp.http={};this.readChildNodes(node,dcp.http);},"Get":function(node,http){http.get=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Post":function(node,http){http.post=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Parameter":function(node,operation){if(!operation.parameters){operation.parameters={};}
-var name=node.getAttribute("name");operation.parameters[name]={};this.readChildNodes(node,operation.parameters[name]);},"Value":function(node,allowedValues){allowedValues[this.getChildValue(node)]=true;},"OutputFormat":function(node,obj){obj.formats.push({value:this.getChildValue(node)});this.readChildNodes(node,obj);},"WGS84BoundingBox":function(node,obj){var boundingBox={};boundingBox.crs=node.getAttribute("crs");if(obj.BoundingBox){obj.BoundingBox.push(boundingBox);}else{obj.projection=boundingBox.crs;boundingBox=obj;}
-this.readChildNodes(node,boundingBox);},"BoundingBox":function(node,obj){this.readers['ows']['WGS84BoundingBox'].apply(this,[node,obj]);},"LowerCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.left=pointList[0];obj.bottom=pointList[1];},"UpperCorner":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");str=str.replace(this.regExes.trimComma,",");var pointList=str.split(this.regExes.splitSpace);obj.right=pointList[0];obj.top=pointList[1];obj.bounds=new OpenLayers.Bounds(obj.left,obj.bottom,obj.right,obj.top);delete obj.left;delete obj.bottom;delete obj.right;delete obj.top;}}},writers:{"ows":{"BoundingBox":function(options){var node=this.createElementNSPlus("ows:BoundingBox",{attributes:{crs:options.projection}});this.writeNode("ows:LowerCorner",options,node);this.writeNode("ows:UpperCorner",options,no
de);return node;},"LowerCorner":function(options){var node=this.createElementNSPlus("ows:LowerCorner",{value:options.bounds.left+" "+options.bounds.bottom});return node;},"UpperCorner":function(options){var node=this.createElementNSPlus("ows:UpperCorner",{value:options.bounds.right+" "+options.bounds.top});return node;},"Title":function(title){var node=this.createElementNSPlus("ows:Title",{value:title});return node;},"OutputFormat":function(format){var node=this.createElementNSPlus("ows:OutputFormat",{value:format});return node;}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});OpenLayers.Format.OWSCommon.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.0",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"]},writers:{"ows":OpenLayers.Format.OWSCommon.v1.prototype.writers["ows"]},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Format.OWSContext.v0_3_1=Open
Layers.Class(OpenLayers.Format.XML,{namespaces:{owc:"http://www.opengis.net/ows-context",gml:"http://www.opengis.net/gml",kml:"http://www.opengis.net/kml/2.2",ogc:"http://www.opengis.net/ogc",ows:"http://www.opengis.net/ows",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},VERSION:"0.3.1",schemaLocation:"http://www.opengis.net/ows-context http://www.ogcnetwork.net/schemas/owc/0.3.1/owsContext.xsd",defaultPrefix:"owc",extractAttributes:true,xy:true,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},featureNS:"http://mapserver.gis.umn.edu/mapserver",featureType:'vector',geometryName:'geometry',nestingLayerLookup:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);OpenLayers.Format.GML.v2.prototype.setGeometryTypes.call(this);},setNestingPath:function(l){if(l.layersContext){for(var i=0,len=l.layersContext.length;i<le
n;i++){var layerContext=l.layersContext[i];var nPath=[];var nTitle=l.title||"";if(l.metadata&&l.metadata.nestingPath){nPath=l.metadata.nestingPath.slice();}
-if(nTitle!=""){nPath.push(nTitle);}
-layerContext.metadata.nestingPath=nPath;if(layerContext.layersContext){this.setNestingPath(layerContext);}}}},decomposeNestingPath:function(nPath){var a=[];if(nPath instanceof Array){while(nPath.length>0){a.push(nPath.slice());nPath.pop();}
-a.reverse();}
-return a;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var context={};this.readNode(data,context);this.setNestingPath({layersContext:context.layersContext});var layers=[];this.processLayer(layers,context);delete context.layersContext;context.layersContext=layers;return context;},processLayer:function(layerArray,layer){if(layer.layersContext){for(var i=0,len=layer.layersContext.length;i<len;i++){var l=layer.layersContext[i];layerArray.push(l);if(l.layersContext){this.processLayer(layerArray,l);}}}},write:function(context,options){var name="OWSContext";this.nestingLayerLookup={};options=options||{};OpenLayers.Util.applyDefaults(options,context);var root=this.writeNode(name,options);this.nestingLayerLookup=null;this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},readers:{"kml":{"Document":function(node,obj){obj.features=new OpenLayers.Format.KML({kmlns:this.namespaces.kml,extractStyles:true}).read(node);}},"owc":{"OWSContext":fun
ction(node,obj){this.readChildNodes(node,obj);},"General":function(node,obj){this.readChildNodes(node,obj);},"ResourceList":function(node,obj){this.readChildNodes(node,obj);},"Layer":function(node,obj){var layerContext={metadata:{},visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),opacity:((node.getAttribute("opacity")!=null)?parseFloat(node.getAttribute("opacity")):null),name:node.getAttribute("name"),categoryLayer:(node.getAttribute("name")==null),formats:[],styles:[]};if(!obj.layersContext){obj.layersContext=[];}
-obj.layersContext.push(layerContext);this.readChildNodes(node,layerContext);},"InlineGeometry":function(node,obj){obj.features=[];var elements=this.getElementsByTagNameNS(node,this.namespaces.gml,"featureMember");var el;if(elements.length>=1){el=elements[0];}
-if(el&&el.firstChild){var featurenode=(el.firstChild.nextSibling)?el.firstChild.nextSibling:el.firstChild;this.setNamespace("feature",featurenode.namespaceURI);this.featureType=featurenode.localName||featurenode.nodeName.split(":").pop();this.readChildNodes(node,obj);}},"Server":function(node,obj){if((!obj.service&&!obj.version)||(obj.service!=OpenLayers.Format.Context.serviceTypes.WMS)){obj.service=node.getAttribute("service");obj.version=node.getAttribute("version");this.readChildNodes(node,obj);}},"Name":function(node,obj){obj.name=this.getChildValue(node);this.readChildNodes(node,obj);},"Title":function(node,obj){obj.title=this.getChildValue(node);this.readChildNodes(node,obj);},"StyleList":function(node,obj){this.readChildNodes(node,obj.styles);},"Style":function(node,obj){var style={};obj.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={};obj.legend=legend;this.readChildNodes(node,legend);},"OnlineResource":function(node,obj){obj
.url=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,obj);}},"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers.ows,"gml":OpenLayers.Format.GML.v2.prototype.readers.gml,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.readers.sld,"feature":OpenLayers.Format.GML.v2.prototype.readers.feature},writers:{"owc":{"OWSContext":function(options){var node=this.createElementNSPlus("OWSContext",{attributes:{version:this.VERSION,id:options.id||OpenLayers.Util.createUniqueID("OpenLayers_OWSContext_")}});this.writeNode("General",options,node);this.writeNode("ResourceList",options,node);return node;},"General":function(options){var node=this.createElementNSPlus("General");this.writeNode("ows:BoundingBox",options,node);this.writeNode("ows:Title",options.title||'OpenLayers OWSContext',node);return node;},"ResourceList":function(options){var node=this.createElementNSPlus("ResourceList");for(var i=0,len=options.layers.length;i<len;i++){var layer=options.layer
s[i];var decomposedPath=this.decomposeNestingPath(layer.metadata.nestingPath);this.writeNode("_Layer",{layer:layer,subPaths:decomposedPath},node);}
-return node;},"Server":function(options){var node=this.createElementNSPlus("Server",{attributes:{version:options.version,service:options.service}});this.writeNode("OnlineResource",options,node);return node;},"OnlineResource":function(options){var node=this.createElementNSPlus("OnlineResource",{attributes:{"xlink:href":options.url}});return node;},"InlineGeometry":function(layer){var node=this.createElementNSPlus("InlineGeometry");this.writeNode("gml:boundedBy",layer.getDataExtent(),node);for(var i=0,len=layer.features.length;i<len;i++){this.writeNode("gml:featureMember",layer.features[i],node);}
-return node;},"StyleList":function(styles){var node=this.createElementNSPlus("StyleList");for(var i=0,len=styles.length;i<len;i++){this.writeNode("Style",styles[i],node);}
-return node;},"Style":function(style){var node=this.createElementNSPlus("Style");this.writeNode("Name",style,node);this.writeNode("Title",style,node);this.writeNode("LegendURL",style,node);return node;},"Name":function(obj){var node=this.createElementNSPlus("Name",{value:obj.name});return node;},"Title":function(obj){var node=this.createElementNSPlus("Title",{value:obj.title});return node;},"LegendURL":function(style){var node=this.createElementNSPlus("LegendURL");this.writeNode("OnlineResource",style.legend,node);return node;},"_WMS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.params.LAYERS,queryable:layer.queryable?"1":"0",hidden:layer.visibility?"0":"1",opacity:layer.opacity?layer.opacity:null}});this.writeNode("ows:Title",layer.name,node);this.writeNode("ows:OutputFormat",layer.params.FORMAT,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WMS,version:layer.params.VERSION,url:layer.url},node);if(layer.met
adata.styles&&layer.metadata.styles.length>0){this.writeNode("StyleList",layer.metadata.styles,node);}
-return node;},"_Layer":function(options){var layer,subPaths,node,title;layer=options.layer;subPaths=options.subPaths;node=null;title=null;if(subPaths.length>0){var path=subPaths[0].join("/");var index=path.lastIndexOf("/");node=this.nestingLayerLookup[path];title=(index>0)?path.substring(index+1,path.length):path;if(!node){node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",title,node);this.nestingLayerLookup[path]=node;}
-options.subPaths.shift();this.writeNode("_Layer",options,node);return node;}else{if(layer instanceof OpenLayers.Layer.WMS){node=this.writeNode("_WMS",layer);}else if(layer instanceof OpenLayers.Layer.Vector){if(layer.protocol instanceof OpenLayers.Protocol.WFS.v1){node=this.writeNode("_WFS",layer);}else if(layer.protocol instanceof OpenLayers.Protocol.HTTP){if(layer.protocol.format instanceof OpenLayers.Format.GML){layer.protocol.format.version="2.1.2";node=this.writeNode("_GML",layer);}else if(layer.protocol.format instanceof OpenLayers.Format.KML){layer.protocol.format.version="2.2";node=this.writeNode("_KML",layer);}}else{this.setNamespace("feature",this.featureNS);node=this.writeNode("_InlineGeometry",layer);}}
-if(layer.options.maxScale){this.writeNode("sld:MinScaleDenominator",layer.options.maxScale,node);}
-if(layer.options.minScale){this.writeNode("sld:MaxScaleDenominator",layer.options.minScale,node);}
-this.nestingLayerLookup[layer.name]=node;return node;}},"_WFS":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:layer.protocol.featurePrefix+":"+layer.protocol.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.WFS,version:layer.protocol.version,url:layer.protocol.url},node);return node;},"_InlineGeometry":function(layer){var node=this.createElementNSPlus("Layer",{attributes:{name:this.featureType,hidden:layer.visibility?"0":"1"}});this.writeNode("ows:Title",layer.name,node);this.writeNode("InlineGeometry",layer,node);return node;},"_GML":function(layer){var node=this.createElementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.GML,url:layer.protocol.url,version:layer.protocol.format.version},node);return node;},"_KML":function(layer){var node=this.createE
lementNSPlus("Layer");this.writeNode("ows:Title",layer.name,node);this.writeNode("Server",{service:OpenLayers.Format.Context.serviceTypes.KML,version:layer.protocol.format.version,url:layer.protocol.url},node);return node;}},"gml":OpenLayers.Util.applyDefaults({"boundedBy":function(bounds){var node=this.createElementNSPlus("gml:boundedBy");this.writeNode("gml:Box",bounds,node);return node;}},OpenLayers.Format.GML.v2.prototype.writers.gml),"ows":OpenLayers.Format.OWSCommon.v1_0_0.prototype.writers.ows,"sld":OpenLayers.Format.SLD.v1_0_0.prototype.writers.sld,"feature":OpenLayers.Format.GML.v2.prototype.writers.feature},CLASS_NAME:"OpenLayers.Format.OWSContext.v0_3_1"});OpenLayers.Format.CSWGetRecords=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetRecords.DEFAULTS);var cls=OpenLayers.Format.CSWGetRecords["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetRecords version: "+options.version;}
-return new cls(options);};OpenLayers.Format.CSWGetRecords.DEFAULTS={"version":"2.0.2"};OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();this.events=null;}
-this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
-if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
-this.handlers=null;}
-if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
-if(this.title!=""){this.div.title=this.title;}}
-if(px!=null){this.position=px.clone();}
-this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
-if(this.handler){this.handler.activate();}
-this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
-this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
-this.events.triggerEvent("deactivate");return true;}
-return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,autoPan:false,handlers:null,resolutionFactor:1,maximized:false,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
-if(this.handlers.click){this.handlers.click.destroy();}
-if(this.handlers.drag){this.handlers.drag.destroy();}
-this.ovmap&&this.ovmap.viewPortDiv.removeChild(this.extentRectangle);this.extentRectangle=null;if(this.rectEvents){this.rectEvents.destroy();this.rectEvents=null;}
-if(this.ovmap){this.ovmap.destroy();this.ovmap=null;}
-this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
-if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
-this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
-this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.m
aximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0,len=eventsToStop.length;i<len;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
-this.minimizeControl();}else{this.element.style.display='';}
-if(this.map.getExtent()){this.update();}
-this.map.events.register('moveend',this,this.update);if(this.maximized){this.maximizeControl();}
-return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var
width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
-if(this.autoPan||!this.isSuitableOverview()){this.updateOverview();}
-this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));if(this.ovmap.getProjection()!=this.map.getProjection()){testExtent=testExtent.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}
-var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
-var center;if(this.ovmap.getProjection()!=this.map.getProjection()){center=this.map.center.clone();center.transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{center=this.map.center;}
-this.ovmap.setCenter(center,this.ovmap.getZoomForResolution(targetRes*this.resolutionFactor));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);this.ovmap.viewPortDiv.appendChild(this.extentRectangle);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});if(this.ovmap.getProjection()!=this.map.getProjection()){var sourceUnits=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;var targetUnits=this.ovmap.getProjectionObject
().getUnits()||this.ovmap.units||this.ovmap.baseLayer.units;this.resolutionFactor=sourceUnits&&targetUnits?OpenLayers.INCHES_PER_UNIT[sourceUnits]/OpenLayers.INCHES_PER_UNIT[targetUnits]:1;}},updateRectToMap:function(){var bounds;if(this.ovmap.getProjection()!=this.map.getProjection()){bounds=this.map.getExtent().transform(this.map.getProjectionObject(),this.ovmap.getProjectionObject());}else{bounds=this.map.getExtent();}
-var pxBounds=this.getRectBoundsFromMapBounds(bounds);if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);if(this.ovmap.getProjection()!=this.map.getProjection()){lonLatBounds=lonLatBounds.transform(this.ovmap.getProjectionObject(),this.map.getProjectionObject());}
-this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
-this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
-this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
-return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat))
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
-if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
-this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
-if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
-window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
-var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
-this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){this.stop();}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,O
verlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(div,options){if(argu
ments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
+-this.element.lefttop[1]);},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Feature:725,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,allOverlays:false,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,panRatio:1.5,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:
null,panMethod:OpenLayers.Easing.Expo.easeOut,panDuration:50,paddingForPopups:null,initialize:function(div,options){if(arguments.length===1&&typeof div==="object"){options=div;div=options&&options.div;}
this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.layers=[];this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);if(!this.div){this.div=document.createElement("div");this.div.style.height="1px";this.div.style.width="1px";}
OpenLayers.Element.addClass(this.div,'olMap');var id=this.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);var eventsDiv=document.createElement("div");eventsDiv.id=this.id+"_events";eventsDiv.style.position="absolute";eventsDiv.style.width="100%";eventsDiv.style.height="100%";eventsDiv.style.zIndex=this.Z_INDEX_BASE.Control-1;this.viewPortDiv.appendChild(eventsDiv);this.eventsDiv=eventsDiv;this.events=new OpenLayers.Events(this,this.eventsDiv,this.EVENT_TYPES,this.fallThrough,{includeXY:true});id=this.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.eventsDiv.appendChild(this.layerContainerDiv);this.updateSize();if(this.eventListeners instanceof Object){this.ev
this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
@@ -1170,7 +436,10 @@
return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getGeodesicPixelSize:function(px){var lonlat=px?this.getLonLatFromPixel(px):(this.getCenter()||new OpenLayers.LonLat(0,0));var res=this.getResolution();var left=lonlat.add(-res/2,0);var right=lonlat.add(res/2,0);var bottom=lonlat.add(0,-res/2);var top=lonlat.add(0,res/2);var dest=new OpenLayers.Projection("EPSG:4326");var source=this.getProjectionObject()||dest;if(!source.equals(dest)){left.transform(source,dest);right.transform(source,dest);bottom.transform(source,dest);top.transform(source,dest);}
return new OpenLayers.Size(OpenLayers.Util.distVincenty(left,right),OpenLayers.Util.distVincenty(bottom,top));},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution
:null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.div.dir="ltr";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
+return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,titleRegEx:/\+title=[^\+]*/,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){var p=projection,equals=false;if(p){if(window.Proj4js&&this.proj.defData&&p.proj.defData){equals=this.proj.defData.replace(this.titleRegEx,"")==p.proj.defData.replace(this.titleRegEx,"");}else if(p
.getCode){var source=this.getCode(),target=p.getCode();equals=source==target||!!OpenLayers.Projection.transforms[source]&&OpenLayers.Projection.transforms[source][target]===OpenLayers.Projection.nullTransform;}}
+return equals;},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
+return point;};OpenLayers.Projection.nullTransform=function(point){return point;};OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,alwaysInRange:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged","move","moveend","added","removed"],RESOLUTION_PROPERTIES:['scales','resolutions','maxScale','minScale','maxResolution','minResolution','numZoomLevels','maxZoomLevel'],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,restrictedMinZoom:0,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],metadata:{},initialize:function(name,options){this.addOptions(options);this.name=n
if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
@@ -1222,110 +491,7 @@
return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.div.childNodes.length;i<len;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}
if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}}},getZIndex:function(){return this.div.style.zIndex;},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
-return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
-return extent;},getLonLatFromViewPortPx:function(viewPortPx){return OpenLayers.Layer.prototype.getLonLatFromViewPortPx.apply(this,arguments);},getViewPortPxFromLonLat:function(lonlat){return OpenLayers.Layer.prototype.getViewPortPxFromLonLat.apply(this,arguments);},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.03390625;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
-this.units="m";this.projection=this.projection||"EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};(function(){var codes=["EPSG:900913","EPSG:3857","EPSG:102113","EPSG:102100"];var add=OpenLayers.Projection.addTransform;var merc=OpenLayers.Layer.SphericalMercator;var same=OpenLayers.Projection.nullTransform;var i,len,code,oth
er,j;for(i=0,len=codes.length;i<len;++i){code=codes[i];add("EPSG:4326",code,merc.projectForward);add(code,"EPSG:4326",merc.projectInverse);for(j=i+1;j<len;++j){other=codes[j];add(code,other,same);add(other,code,same);}}})();OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;this.pane=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.BROWSER_NAME=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLo
cation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
-this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);}
-OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.ap
ply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFr
omMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
-return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
-return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
-return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
-return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
-return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0,len=props.length;i<len;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
-if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
-var desiredZoomLevels;var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(((this.options.numZoomLevels==null)&&(this.options.maxZoomLevel!=null))||((this.numZoomLevels==null)&&(this.maxZoomLevel!=null))){desiredZoomLevels=this.maxZoomLevel-this.minZoomLevel+1;}else{desiredZoomLevels=this.numZoomLevels;}
-if(desiredZoomLevels!=null){this.numZoomLevels=Math.min(desiredZoomLevels,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}
-this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
-this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
-return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
-return zoom;},CLASS_NAME:"OpenLayers.Layer.FixedZoomLevels"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:21,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257,0.0000013411045074462891,0.00000067055225372314453],type:null,wrapDateLine:true,sphericalMercator:false,version:null,initialize:function(name,options){options=options||{};if(!options.version){options.version=typeof GMap2==="function"?"2":"3";}
-var mixin=OpenLayers.Layer.Google["v"+
-options.version.replace(/\./g,"_")];if(mixin){OpenLayers.Util.applyDefaults(options,mixin);}else{throw"Unsupported Google Maps API version: "+options.version;}
-OpenLayers.Util.applyDefaults(options,mixin.DEFAULTS);if(options.maxExtent){options.maxExtent=options.maxExtent.clone();}
-OpenLayers.Layer.EventPane.prototype.initialize.apply(this,[name,options]);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,[name,options]);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},clone:function(){return new OpenLayers.Layer.Google(this.name,this.getOptions());},setVisibility:function(visible){var opacity=this.opacity==null?1:this.opacity;OpenLayers.Layer.EventPane.prototype.setVisibility.apply(this,arguments);this.setOpacity(opacity);},display:function(visible){if(!this._dragging){this.setGMapVisibility(visible);}
-OpenLayers.Layer.EventPane.prototype.display.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){this._dragging=dragging;OpenLayers.Layer.EventPane.prototype.moveTo.apply(this,arguments);delete this._dragging;},setOpacity:function(opacity){if(opacity!==this.opacity){if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"opacity"});}
-this.opacity=opacity;}
-if(this.getVisibility()){var container=this.getMapContainer();OpenLayers.Util.modifyDOMElement(container,null,null,null,null,null,null,opacity);}},destroy:function(){if(this.map){this.setGMapVisibility(false);var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache&&cache.count<=1){this.removeGMapElements();}}
-OpenLayers.Layer.EventPane.prototype.destroy.apply(this,arguments);},removeGMapElements:function(){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject&&this.getMapContainer();if(container&&container.parentNode){container.parentNode.removeChild(container);}
-var termsOfUse=cache.termsOfUse;if(termsOfUse&&termsOfUse.parentNode){termsOfUse.parentNode.removeChild(termsOfUse);}
-var poweredBy=cache.poweredBy;if(poweredBy&&poweredBy.parentNode){poweredBy.parentNode.removeChild(poweredBy);}}},removeMap:function(map){if(this.visibility&&this.mapObject){this.setGMapVisibility(false);}
-var cache=OpenLayers.Layer.Google.cache[map.id];if(cache){if(cache.count<=1){this.removeGMapElements();delete OpenLayers.Layer.Google.cache[map.id];}else{--cache.count;}}
-delete this.termsOfUse;delete this.poweredBy;delete this.mapObject;delete this.dragObject;OpenLayers.Layer.EventPane.prototype.removeMap.apply(this,arguments);},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
-olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
-return olBounds;},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Google.cache={};OpenLayers.Layer.Google.v2={termsOfUse:null,poweredBy:null,dragObject:null,loadMapObject:function(){if(!this.type){this.type=G_NORMAL_MAP;}
-var mapObject,termsOfUse,poweredBy;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;termsOfUse=cache.termsOfUse;poweredBy=cache.poweredBy;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMap2Container";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);try{mapObject=new GMap2(div);termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.right="";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright";poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.right="";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy gmnoprint";}catch(e){throw(e);}
-OpenLayers.Layer.Google.cache[this.map.id]={mapObject:mapObject,termsOfUse:termsOfUse,poweredBy:poweredBy,count:1};}
-this.mapObject=mapObject;this.termsOfUse=termsOfUse;this.poweredBy=poweredBy;if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)===-1){this.mapObject.addMapType(this.type);}
-if(typeof mapObject.getDragObject=="function"){this.dragObject=mapObject.getDragObject();}else{this.dragPanMapObject=null;}
-if(this.isBaseLayer===false){this.setGMapVisibility(this.div.style.display!=="none");}},onMapResize:function(){if(this.visibility&&this.mapObject.isLoaded()){this.mapObject.checkResize();}else{if(!this._resized){var layer=this;var handle=GEvent.addListener(this.mapObject,"load",function(){GEvent.removeListener(handle);delete layer._resized;layer.mapObject.checkResize();layer.moveTo(layer.map.getCenter(),layer.map.getZoom());});}
-this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var container=this.mapObject.getContainer();if(visible===true){this.mapObject.setMapType(this.type);container.style.display="";this.termsOfUse.style.left="";this.termsOfUse.style.display="";this.poweredBy.style.display="";cache.displayed=this.id;}else{if(cache.displayed===this.id){delete cache.displayed;}
-if(!cache.displayed){container.style.display="none";this.termsOfUse.style.display="none";this.termsOfUse.style.left="-9999px";this.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getContainer();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
-return moBounds;},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);}};OpenLayers.Format.WFST=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.WFST.DEFAULTS);var cls=OpenLayers.Format.WFST["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFST version: "+options.version;}
-return new cls(options);};OpenLayers.Format.WFST.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.WFST.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",wfs:"http://www.opengis.net/wfs",gml:"http://www.opengis.net/gml",ogc:"http://www.opengis.net/ogc"},defaultPrefix:"wfs",version:null,schemaLocations:null,srsName:null,extractAttributes:true,xy:true,stateName:null,initialize:function(options){this.stateName={};this.stateName[OpenLayers.State.INSERT]="wfs:Insert";this.stateName[OpenLayers.State.UPDATE]="wfs:Update";this.stateName[OpenLayers.State.DELETE]="wfs:Delete";OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},getSrsName:function(feature,options){var srsName=options&&options.srsName;if(!srsName){if(feature&&feature.layer){srsName=feature.layer.projection.getCode();}else{srsName=this.srsName;}}
-return srsName;},read:function(data,options){options=options||{};OpenLayers.Util.applyDefaults(options,{output:"features"});if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var obj={};if(data){this.readNode(data,obj);}
-if(obj.features&&options.output==="features"){obj=obj.features;}
-return obj;},readers:{"wfs":{"FeatureCollection":function(node,obj){obj.features=[];this.readChildNodes(node,obj);}}},write:function(features){var node=this.writeNode("wfs:Transaction",features);var value=this.schemaLocationAttr();if(value){this.setAttributeNS(node,this.namespaces["xsi"],"xsi:schemaLocation",value);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"wfs":{"GetFeature":function(options){var node=this.createElementNSPlus("wfs:GetFeature",{attributes:{service:"WFS",version:this.version,outputFormat:options&&options.outputFormat,maxFeatures:options&&options.maxFeatures,"xsi:schemaLocation":this.schemaLocationAttr(options)}});if(typeof this.featureType=="string"){this.writeNode("Query",options,node);}else{for(var i=0,len=this.featureType.length;i<len;i++){options.featureType=this.featureType[i];this.writeNode("Query",options,node);}}
-return node;},"Transaction":function(features){var node=this.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});if(features){var name,feature;for(var i=0,len=features.length;i<len;++i){feature=features[i];name=this.stateName[feature.state];if(name){this.writeNode(name,feature,node);}}}
-return node;},"Insert":function(feature){var node=this.createElementNSPlus("wfs:Insert");this.srsName=this.getSrsName(feature);this.writeNode("feature:_typeName",feature,node);return node;},"Update":function(feature){var node=this.createElementNSPlus("wfs:Update",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
-this.featureType}});if(this.featureNS){node.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);}
-if(this.geometryName!==null){this.srsName=this.getSrsName(feature);this.writeNode("Property",{name:this.geometryName,value:feature.geometry},node);}
-for(var key in feature.attributes){if(feature.attributes[key]!==undefined){this.writeNode("Property",{name:key,value:feature.attributes[key]},node);}}
-this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;},"Property":function(obj){var node=this.createElementNSPlus("wfs:Property");this.writeNode("Name",obj.name,node);if(obj.value!==null){this.writeNode("Value",obj.value,node);}
-return node;},"Name":function(name){return this.createElementNSPlus("wfs:Name",{value:name});},"Value":function(obj){var node;if(obj instanceof OpenLayers.Geometry){node=this.createElementNSPlus("wfs:Value");var geom=this.writeNode("feature:_geometry",obj).firstChild;node.appendChild(geom);}else{node=this.createElementNSPlus("wfs:Value",{value:obj});}
-return node;},"Delete":function(feature){var node=this.createElementNSPlus("wfs:Delete",{attributes:{typeName:(this.featureNS?this.featurePrefix+":":"")+
-this.writeNode("ogc:Filter",new OpenLayers.Filter.FeatureId({fids:[feature.fid]}),node);return node;}}},schemaLocationAttr:function(options){options=OpenLayers.Util.extend({featurePrefix:this.featurePrefix,schema:this.schema},options);var schemaLocations=OpenLayers.Util.extend({},this.schemaLocations);if(options.schema){schemaLocations[options.featurePrefix]=options.schema;}
-var parts=[];var uri;for(var key in schemaLocations){uri=this.namespaces[key];if(uri){parts.push(uri+" "+schemaLocations[key]);}}
-var value=parts.join(" ")||undefined;return value;},setFilterProperty:function(filter){if(filter.filters){for(var i=0,len=filter.filters.length;i<len;++i){this.setFilterProperty(filter.filters[i]);}}else{if(filter instanceof OpenLayers.Filter.Spatial){filter.property=this.geometryName;}}},CLASS_NAME:"OpenLayers.Format.WFST.v1"});OpenLayers.Format.GML.v3=OpenLayers.Class(OpenLayers.Format.GML.Base,{schemaLocation:"http://www.opengis.net/gml http://schemas.opengis.net/gml/3.1.1/profiles/gmlsfProfile/1.0.0/gmlsf.xsd",curve:false,multiCurve:true,surface:false,multiSurface:true,initialize:function(options){OpenLayers.Format.GML.Base.prototype.initialize.apply(this,[options]);},readers:{"gml":OpenLayers.Util.applyDefaults({"featureMembers":function(node,obj){this.readChildNodes(node,obj);},"Curve":function(node,container){var obj={points:[]};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-container.components.push(new OpenLayers.Geometry.LineString(obj.points));},"segments":function(node,obj){this.readChildNodes(node,obj);},"LineStringSegment":function(node,container){var obj={};this.readChildNodes(node,obj);if(obj.points){Array.prototype.push.apply(container.points,obj.points);}},"pos":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var point;if(this.xy){point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{point=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}
-obj.points=[point];},"posList":function(node,obj){var str=this.getChildValue(node).replace(this.regExes.trimSpace,"");var coords=str.split(this.regExes.splitSpace);var dim=parseInt(node.getAttribute("dimension"))||2;var j,x,y,z;var numPoints=coords.length/dim;var points=new Array(numPoints);for(var i=0,len=coords.length;i<len;i+=dim){x=coords[i];y=coords[i+1];z=(dim==2)?undefined:coords[i+2];if(this.xy){points[i/dim]=new OpenLayers.Geometry.Point(x,y,z);}else{points[i/dim]=new OpenLayers.Geometry.Point(y,x,z);}}
-obj.points=points;},"Surface":function(node,obj){this.readChildNodes(node,obj);},"patches":function(node,obj){this.readChildNodes(node,obj);},"PolygonPatch":function(node,obj){this.readers.gml.Polygon.apply(this,[node,obj]);},"exterior":function(node,container){var obj={};this.readChildNodes(node,obj);container.outer=obj.components[0];},"interior":function(node,container){var obj={};this.readChildNodes(node,obj);container.inner.push(obj.components[0]);},"MultiCurve":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiLineString(obj.components)];}},"curveMember":function(node,obj){this.readChildNodes(node,obj);},"MultiSurface":function(node,container){var obj={components:[]};this.readChildNodes(node,obj);if(obj.components.length>0){container.components=[new OpenLayers.Geometry.MultiPolygon(obj.components)];}},"surfaceMember":function(node,obj){this.readChildNodes(node,obj
);},"surfaceMembers":function(node,obj){this.readChildNodes(node,obj);},"pointMembers":function(node,obj){this.readChildNodes(node,obj);},"lineStringMembers":function(node,obj){this.readChildNodes(node,obj);},"polygonMembers":function(node,obj){this.readChildNodes(node,obj);},"geometryMembers":function(node,obj){this.readChildNodes(node,obj);},"Envelope":function(node,container){var obj={points:new Array(2)};this.readChildNodes(node,obj);if(!container.components){container.components=[];}
-var min=obj.points[0];var max=obj.points[1];container.components.push(new OpenLayers.Bounds(min.x,min.y,max.x,max.y));},"lowerCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[0]=obj.points[0];},"upperCorner":function(node,container){var obj={};this.readers.gml.pos.apply(this,[node,obj]);container.points[1]=obj.points[0];}},OpenLayers.Format.GML.Base.prototype.readers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.readers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.readers["wfs"]},write:function(features){var name;if(features instanceof Array){name="featureMembers";}else{name="featureMember";}
-var root=this.writeNode("gml:"+name,features);this.setAttributeNS(root,this.namespaces["xsi"],"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},writers:{"gml":OpenLayers.Util.applyDefaults({"featureMembers":function(features){var node=this.createElementNSPlus("gml:featureMembers");for(var i=0,len=features.length;i<len;++i){this.writeNode("feature:_typeName",features[i],node);}
-return node;},"Point":function(geometry){var node=this.createElementNSPlus("gml:Point");this.writeNode("pos",geometry,node);return node;},"pos":function(point){var pos=(this.xy)?(point.x+" "+point.y):(point.y+" "+point.x);return this.createElementNSPlus("gml:pos",{value:pos});},"LineString":function(geometry){var node=this.createElementNSPlus("gml:LineString");this.writeNode("posList",geometry.components,node);return node;},"Curve":function(geometry){var node=this.createElementNSPlus("gml:Curve");this.writeNode("segments",geometry,node);return node;},"segments":function(geometry){var node=this.createElementNSPlus("gml:segments");this.writeNode("LineStringSegment",geometry,node);return node;},"LineStringSegment":function(geometry){var node=this.createElementNSPlus("gml:LineStringSegment");this.writeNode("posList",geometry.components,node);return node;},"posList":function(points){var len=points.length;var parts=new Array(len);var point;for(var i=0;i<len;++i){point=points[i];if
(this.xy){parts[i]=point.x+" "+point.y;}else{parts[i]=point.y+" "+point.x;}}
-return this.createElementNSPlus("gml:posList",{value:parts.join(" ")});},"Surface":function(geometry){var node=this.createElementNSPlus("gml:Surface");this.writeNode("patches",geometry,node);return node;},"patches":function(geometry){var node=this.createElementNSPlus("gml:patches");this.writeNode("PolygonPatch",geometry,node);return node;},"PolygonPatch":function(geometry){var node=this.createElementNSPlus("gml:PolygonPatch",{attributes:{interpolation:"planar"}});this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
-return node;},"Polygon":function(geometry){var node=this.createElementNSPlus("gml:Polygon");this.writeNode("exterior",geometry.components[0],node);for(var i=1,len=geometry.components.length;i<len;++i){this.writeNode("interior",geometry.components[i],node);}
-return node;},"exterior":function(ring){var node=this.createElementNSPlus("gml:exterior");this.writeNode("LinearRing",ring,node);return node;},"interior":function(ring){var node=this.createElementNSPlus("gml:interior");this.writeNode("LinearRing",ring,node);return node;},"LinearRing":function(ring){var node=this.createElementNSPlus("gml:LinearRing");this.writeNode("posList",ring.components,node);return node;},"MultiCurve":function(geometry){var node=this.createElementNSPlus("gml:MultiCurve");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("curveMember",geometry.components[i],node);}
-return node;},"curveMember":function(geometry){var node=this.createElementNSPlus("gml:curveMember");if(this.curve){this.writeNode("Curve",geometry,node);}else{this.writeNode("LineString",geometry,node);}
-return node;},"MultiSurface":function(geometry){var node=this.createElementNSPlus("gml:MultiSurface");for(var i=0,len=geometry.components.length;i<len;++i){this.writeNode("surfaceMember",geometry.components[i],node);}
-return node;},"surfaceMember":function(polygon){var node=this.createElementNSPlus("gml:surfaceMember");if(this.surface){this.writeNode("Surface",polygon,node);}else{this.writeNode("Polygon",polygon,node);}
-return node;},"Envelope":function(bounds){var node=this.createElementNSPlus("gml:Envelope");this.writeNode("lowerCorner",bounds,node);this.writeNode("upperCorner",bounds,node);if(this.srsName){node.setAttribute("srsName",this.srsName);}
-return node;},"lowerCorner":function(bounds){var pos=(this.xy)?(bounds.left+" "+bounds.bottom):(bounds.bottom+" "+bounds.left);return this.createElementNSPlus("gml:lowerCorner",{value:pos});},"upperCorner":function(bounds){var pos=(this.xy)?(bounds.right+" "+bounds.top):(bounds.top+" "+bounds.right);return this.createElementNSPlus("gml:upperCorner",{value:pos});}},OpenLayers.Format.GML.Base.prototype.writers["gml"]),"feature":OpenLayers.Format.GML.Base.prototype.writers["feature"],"wfs":OpenLayers.Format.GML.Base.prototype.writers["wfs"]},setGeometryTypes:function(){this.geometryTypes={"OpenLayers.Geometry.Point":"Point","OpenLayers.Geometry.MultiPoint":"MultiPoint","OpenLayers.Geometry.LineString":(this.curve===true)?"Curve":"LineString","OpenLayers.Geometry.MultiLineString":(this.multiCurve===false)?"MultiLineString":"MultiCurve","OpenLayers.Geometry.Polygon":(this.surface===true)?"Surface":"Polygon","OpenLayers.Geometry.MultiPolygon":(this.multiSurface===false)?"MultiPoly
gon":"MultiSurface","OpenLayers.Geometry.Collection":"GeometryCollection"};},CLASS_NAME:"OpenLayers.Format.GML.v3"});OpenLayers.Format.Filter.v1_1_0=OpenLayers.Class(OpenLayers.Format.GML.v3,OpenLayers.Format.Filter.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/ogc/filter/1.1.0/filter.xsd",initialize:function(options){OpenLayers.Format.GML.v3.prototype.initialize.apply(this,[options]);},readers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var matchCase=node.getAttribute("matchCase");var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO,matchCase:!(matchCase==="false"||matchCase==="0")});this.readChildNodes(node,
filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escapeChar");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);}},OpenLayers.Format.Filter.v1.prototype.readers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"]},writers:{"ogc":OpenLayers.Util.applyDefaults({"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo",{attributes:{matchCase:filter.matchCase}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo",{attributes:{matchCase:filter.matchC
ase}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.value,node);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escapeChar:"!"}});this.writeNode("PropertyName",filter,node);this.writeNode("Literal",filter.regex2value(),node);return node;},"BBOX":function(filter){var node=this.createElementNSPlus("ogc:BBOX");this.writeNode("PropertyName",filter,node);var box=this.writeNode("gml:Envelope",filter.value);if(filter.projection){box.setAttribute("srsName",filter.projection);}
-node.appendChild(box);return node;}},OpenLayers.Format.Filter.v1.prototype.writers["ogc"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"]},writeSpatial:function(filter,name){var node=this.createElementNSPlus("ogc:"+name);this.writeNode("PropertyName",filter,node);var child;if(filter.value instanceof OpenLayers.Geometry){child=this.writeNode("feature:_geometry",filter.value).firstChild;}else{child=this.writeNode("gml:Envelope",filter.value);}
-if(filter.projection){child.setAttribute("srsName",filter.projection);}
-node.appendChild(child);return node;},CLASS_NAME:"OpenLayers.Format.Filter.v1_1_0"});OpenLayers.Format.WFST.v1_1_0=OpenLayers.Class(OpenLayers.Format.Filter.v1_1_0,OpenLayers.Format.WFST.v1,{version:"1.1.0",schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_1_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){obj.numberOfFeatures=parseInt(node.getAttribute("numberOfFeatures"));OpenLayers.Format.WFST.v1.prototype.readers["wfs"]["FeatureCollection"].apply(this,arguments);},"TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"TransactionSummary":function(node,obj){obj.success=true;},"InsertResults":function(node,obj){this.readChildNodes(node,obj);},"Feature":function(node,container){var obj={fids:[]}
;this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.readers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"GetFeature":function(options){var node=OpenLayers.Format.WFST.v1.prototype.writers["wfs"]["GetFeature"].apply(this,arguments);options&&options.resultType&&this.setAttributes(node,{resultType:options.resultType});return node;},"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
-options.featureType,srsName:options.srsName}});if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
-if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("wfs:PropertyName",{property:options.propertyNames[i]},node);}}
-if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;},"PropertyName":function(obj){return this.createElementNSPlus("wfs:PropertyName",{value:obj.property});}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v3.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v3.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_1_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_1_0"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515],type:null,wrapDateLine:true,sphericalMercator:false,animationEnabled:true,initialize:function(name,options){OpenLay
ers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w+"px";veDiv.style.height=sz.h+"px";this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
-if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",OpenLayers.Function.True);}catch(e){}
-this.mapObject.HideDashboard();if(typeof this.mapObject.SetAnimationEnabled=="function"){this.mapObject.SetAnimationEnabled(this.animationEnabled);}}
-if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},onMapResize:function(){this.mapObject.Resize(this.map.size.w,this.map.size.h);},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return(typeof VEPixel!='undefined')?this.mapObject.PixelToLatLong(moPixel):this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:f
unction(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return(typeof VEPixel!='undefined')?new VEPixel(x,y):new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}
-this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
-if(this.saveState===true){this.defaultControl=null;}
-this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];this.activeState[control.id]=control.deactivate();}
-this.redraw();return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.addControlsToMap(this.controls);return this.div;},redraw:function(){for(var l=this.div.childNodes.length,i=l-1;i>=0;i--){this.div.removeChild(this.div.childNodes[i]);}
-this.div.innerHTML="";if(this.active){for(var i=0,len=this.controls.length;i<len;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
-this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
-if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();this.redraw();return;}
-if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
-return;}
-var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
-control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
-this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var element=document.createElement("div");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
-OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
-if(this.map){this.addControlsToMap(controls);this.redraw();}},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
-control.events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},onDoubleClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomIn();},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this
.map.zoomOut();},CLASS_NAME:"OpenLayers.Control.ZoomOut"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.ZoomIn(),new OpenLayers.Control.ZoomToMaxExtent(),new OpenLayers.Control.ZoomOut()]);},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:f
unction(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
+return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.getOptions());}
obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);var ret=this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"params"});}
return ret;},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0,len=paramString.length;i<len;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
@@ -1352,7 +518,72 @@
if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0,len=this.grid.length;i<len;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,t
his.url,this.size);}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
+this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
+var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
+this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
+var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
+this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,touch:false,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize
.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt;return true;};}},mousedown:null,touchstart:function(evt){this.touch=true;this.down=evt;this.last=null;return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
+return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
+return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}
+return!this.stopSingle;},dblclick:function(evt){if(this.passesTolerance(evt)&&(!evt.lastTouches||evt.lastTouches.length==1)){if(this["double"]){this.callback('dblclick',[evt]);}
+this.clearTimer();}
+return!this.stopDouble;},touchmove:function(evt){this.last=evt;},touchend:function(evt){var last=this.last||this.down;if(!evt||!last){return false;}
+evt.xy=last.xy;evt.lastTouches=last.touches;return evt.xy?this.click(evt):false;},click:function(evt){if(this.touch===true&&evt.type==="click"){return!this.stopSingle;}
+if(this.passesTolerance(evt)){if(this.timerId!=null){if(evt.lastTouches){this.dblclick(evt);}else{this.clearTimer();}}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
+return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){var dpx=Math.sqrt(Math.pow(this.down.xy.x-evt.xy.x,2)+
+Math.pow(this.down.xy.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
+return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
+if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.last=null;deactivated=true;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){clearInterval(this.timerId);this.timerId=undefined;this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>this.nbPoints){this.points.pop();}},end:function(xy){var last,now=new Date().getTime();for(var i=0,l=this.points.length,point;i<l;i++){point=this.points[i];if(now-point.tick>this.delay){break;}
+last=point;}
+if(!last){return;}
+var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
+Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
+var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
+return{speed:speed,theta:theta};},move:function(info,callback){var v0=info.speed;var fx=Math.cos(info.theta);var fy=-Math.sin(info.theta);var time=0;var initialTime=new Date().getTime();var lastX=0;var lastY=0;var timerCallback=function(){if(this.timerId==null){return;}
+time+=this.interval;var realTime=new Date().getTime()-initialTime;var t=(time+realTime)/2.0;var p=(-this.deceleration*Math.pow(t,2))/2.0+v0*t;var x=p*fx;var y=p*fy;var args={};args.end=false;var v=-this.deceleration*t+v0;if(v<=0){clearInterval(this.timerId);this.timerId=null;args.end=true;}
+args.x=x-lastX;args.y=y-lastY;lastX=x;lastY=y;callback(args.x,args.y,args.end);};this.timerId=window.setInterval(OpenLayers.Function.bind(timerCallback,this),this.interval);},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",autoActivate:false,active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
+this.events.destroy();this.events=null;}
+this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
+if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
+this.handlers=null;}
+if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=OpenLayers.Function.False;}
+if(this.title!=""){this.div.title=this.title;}}
+if(px!=null){this.position=px.clone();}
+this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
+if(this.handler){this.handler.activate();}
+this.active=true;if(this.map){OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
+this.active=false;if(this.map){OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass.replace(/ /g,"")+"Active");}
+this.events.triggerEvent("deactivate");return true;}
+return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,autoActivate:true,defaultControl:null,saveState:false,activeState:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];this.activeState={};},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
+OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}
+this.activeState=null;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];if(control===this.defaultControl||(this.saveState&&this.activeState[control.id])){control.activate();}}
+if(this.saveState===true){this.defaultControl=null;}
+this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){var control;for(var i=0,len=this.controls.length;i<len;i++){control=this.controls[i];this.activeState[control.id]=control.deactivate();}
+this.redraw();return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.addControlsToMap(this.controls);return this.div;},redraw:function(){for(var l=this.div.childNodes.length,i=l-1;i>=0;i--){this.div.removeChild(this.div.childNodes[i]);}
+this.div.innerHTML="";if(this.active){for(var i=0,len=this.controls.length;i<len;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
+this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
+if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();this.redraw();return;}
+if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
+return;}
+var c;for(var i=0,len=this.controls.length;i<len;i++){c=this.controls[i];if(c!=control&&(c.type===OpenLayers.Control.TYPE_TOOL||c.type==null)){c.deactivate();}}
+control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
+this.controls=this.controls.concat(controls);for(var i=0,len=controls.length;i<len;i++){var element=document.createElement("div");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
+OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"dblclick",OpenLayers.Function.bind(this.onDoubleClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
+if(this.map){this.addControlsToMap(controls);this.redraw();}},addControlsToMap:function(controls){var control;for(var i=0,len=controls.length;i<len;i++){control=controls[i];if(control.autoActivate===true){control.autoActivate=false;this.map.addControl(control);control.autoActivate=true;}else{this.map.addControl(control);control.deactivate();}
+control.events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},onDoubleClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.ZoomIn=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this.map.zoomIn();},CLASS_NAME:"OpenLayers.Control.ZoomIn"});OpenLayers.Control.ZoomOut=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){this
.map.zoomOut();},CLASS_NAME:"OpenLayers.Control.ZoomOut"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Control.ZoomPanel=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.ZoomIn(),new OpenLayers.Control.ZoomToMaxExtent(),new OpenLayers.Control.ZoomOut()]);},CLASS_NAME:"OpenLayers.Control.ZoomPanel"});OpenLayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,pinching:false,last:null,start:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=t
his.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
+OpenLayers.Event.stop(evt);return propagate;},touchmove:function(evt){var propagate=true;if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;propagate=false;}
+return propagate;},touchend:function(evt){var propagate=true;if(this.started){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;propagate=false;}
+return propagate;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
+return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
+return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.clientX-t1.clientX,2)+
+Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.Pinch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerOrigin,scope:this});this.updateContainerOrigin();}
+return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.apply(this,arguments);if(this.map&&this.map.events){this.map.events.un({moveend:this.updateContainerOrigin,scope:this});}
+return deactivated;},updateContainerOrigin:function(){var container=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(container.style.left,10),y:parseInt(container.style.top,10)};},pinchStart:function(evt,pinchData){this.pinchOrigin=evt.xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerOrigin=this.containerOrigin;var pinchOrigin=this.pinchOrigin;var current=evt.xy;var dx=(current.x-pinchOrigin.x)+(scale-1)*(containerOrigin.x-pinchOrigin.x);var dy=(current.y-pinchOrigin.y)+(scale-1)*(containerOrigin.y-pinchOrigin.y);var style=this.map.layerContainerDiv.style;var transform="translate("+dx+"px, "+dy+"px) scale("+scale+")";style['-webkit-transform']=transform;style['-moz-transform']=transform;this.currentCenter=current;},pinchDone:function(evt,start,last){var zoom=this.map.getZoomForResolution(this.map.getResolution()/last.scale,true);var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin
);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.setCenter(location,zoom);var style=this.map.layerContainerDiv.style;style['-webkit-transform']="";style['-moz-transform']="";},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,initialize:function(layer,position,bounds,url,size,options){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);OpenLayers.Util.extend(this,options);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){this.layer=null;this.bounds=nul
l;this.size=null;this.position=null;this.events.destroy();this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));this.shouldDraw=(withinMaxExtent||this.layer.displayOutsideMaxExtent);this.clear();return this.shouldDraw;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,maxGetUrlLength:null,initialize:function(layer,position,bounds,url,size,options){OpenLayers.Tile.prototype.initialize.apply(this,arguments);if(this.maxGetUrlLength!=null){OpenLayers.Util.extend(this,OpenLayers.Tile.Image.IFrame);}
@@ -1378,210 +609,11 @@
var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Format.ArcXML=OpenLayers.Class(OpenLayers.Format.XML,{fontStyleKeys:['antialiasing','blockout','font','fontcolor','fontsize','fontstyle','glowing','interval','outline','printmode','shadow','transparency'],request:null,response:null,initialize:function(options){this.request=new OpenLayers.Format.ArcXML.Request();this.response=new OpenLayers.Format.ArcXML.Response();if(options){if(options.requesttype=="feature"){this.request.get_image=null;var qry=this.request.get_feature.query;this.addCoordSys(qry.featurecoordsys,options.featureCoordSys);thi
s.addCoordSys(qry.filtercoordsys,options.filterCoordSys);if(options.polygon){qry.isspatial=true;qry.spatialfilter.polygon=options.polygon;}else if(options.envelope){qry.isspatial=true;qry.spatialfilter.envelope={minx:0,miny:0,maxx:0,maxy:0};this.parseEnvelope(qry.spatialfilter.envelope,options.envelope);}}else if(options.requesttype=="image"){this.request.get_feature=null;var props=this.request.get_image.properties;this.parseEnvelope(props.envelope,options.envelope);this.addLayers(props.layerlist,options.layers);this.addImageSize(props.imagesize,options.tileSize);this.addCoordSys(props.featurecoordsys,options.featureCoordSys);this.addCoordSys(props.filtercoordsys,options.filterCoordSys);}else{this.request=null;}}
-OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},parseEnvelope:function(env,arr){if(arr&&arr.length==4){env.minx=arr[0];env.miny=arr[1];env.maxx=arr[2];env.maxy=arr[3];}},addLayers:function(ll,lyrs){for(var lind=0,len=lyrs.length;lind<len;lind++){ll.push(lyrs[lind]);}},addImageSize:function(imsize,olsize){if(olsize!==null){imsize.width=olsize.w;imsize.height=olsize.h;imsize.printwidth=olsize.w;imsize.printheight=olsize.h;}},addCoordSys:function(featOrFilt,fsys){if(typeof fsys=="string"){featOrFilt.id=parseInt(fsys);featOrFilt.string=fsys;}
-else if(typeof fsys=="object"&&fsys.proj!==null){featOrFilt.id=fsys.proj.srsProjNumber;featOrFilt.string=fsys.proj.srsCode;}else{featOrFilt=fsys;}},iserror:function(data){var ret=null;if(!data){ret=(this.response.error!=='');}else{data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);var errorNodes=data.documentElement.getElementsByTagName("ERROR");ret=(errorNodes!==null&&errorNodes.length>0);}
-return ret;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var arcNode=null;if(data&&data.documentElement){if(data.documentElement.nodeName=="ARCXML"){arcNode=data.documentElement;}else{arcNode=data.documentElement.getElementsByTagName("ARCXML")[0];}}
-if(!arcNode||arcNode.firstChild.nodeName==='parsererror'){var error,source;try{error=data.firstChild.nodeValue;source=data.firstChild.childNodes[1].firstChild.nodeValue;}catch(err){}
-throw{message:"Error parsing the ArcXML request",error:error,source:source};}
-var response=this.parseResponse(arcNode);return response;},write:function(request){if(!request){request=this.request;}
-var root=this.createElementNS("","ARCXML");root.setAttribute("version","1.1");var reqElem=this.createElementNS("","REQUEST");if(request.get_image!=null){var getElem=this.createElementNS("","GET_IMAGE");reqElem.appendChild(getElem);var propElem=this.createElementNS("","PROPERTIES");getElem.appendChild(propElem);var props=request.get_image.properties;if(props.featurecoordsys!=null){var feat=this.createElementNS("","FEATURECOORDSYS");propElem.appendChild(feat);if(props.featurecoordsys.id===0){feat.setAttribute("string",props.featurecoordsys['string']);}
-else{feat.setAttribute("id",props.featurecoordsys.id);}}
-if(props.filtercoordsys!=null){var filt=this.createElementNS("","FILTERCOORDSYS");propElem.appendChild(filt);if(props.filtercoordsys.id===0){filt.setAttribute("string",props.filtercoordsys.string);}
-else{filt.setAttribute("id",props.filtercoordsys.id);}}
-if(props.envelope!=null){var env=this.createElementNS("","ENVELOPE");propElem.appendChild(env);env.setAttribute("minx",props.envelope.minx);env.setAttribute("miny",props.envelope.miny);env.setAttribute("maxx",props.envelope.maxx);env.setAttribute("maxy",props.envelope.maxy);}
-var imagesz=this.createElementNS("","IMAGESIZE");propElem.appendChild(imagesz);imagesz.setAttribute("height",props.imagesize.height);imagesz.setAttribute("width",props.imagesize.width);if(props.imagesize.height!=props.imagesize.printheight||props.imagesize.width!=props.imagesize.printwidth){imagesz.setAttribute("printheight",props.imagesize.printheight);imagesz.setArrtibute("printwidth",props.imagesize.printwidth);}
-if(props.background!=null){var backgrnd=this.createElementNS("","BACKGROUND");propElem.appendChild(backgrnd);backgrnd.setAttribute("color",props.background.color.r+","+
-props.background.color.g+","+
-props.background.color.b);if(props.background.transcolor!==null){backgrnd.setAttribute("transcolor",props.background.transcolor.r+","+
-props.background.transcolor.g+","+
-props.background.transcolor.b);}}
-if(props.layerlist!=null&&props.layerlist.length>0){var layerlst=this.createElementNS("","LAYERLIST");propElem.appendChild(layerlst);for(var ld=0;ld<props.layerlist.length;ld++){var ldef=this.createElementNS("","LAYERDEF");layerlst.appendChild(ldef);ldef.setAttribute("id",props.layerlist[ld].id);ldef.setAttribute("visible",props.layerlist[ld].visible);if(typeof props.layerlist[ld].query=="object"){var query=props.layerlist[ld].query;if(query.where.length<0){continue;}
-var queryElem=null;if(typeof query.spatialfilter=="boolean"&&query.spatialfilter){queryElem=this.createElementNS("","SPATIALQUERY");}
-else{queryElem=this.createElementNS("","QUERY");}
-queryElem.setAttribute("where",query.where);if(typeof query.accuracy=="number"&&query.accuracy>0){queryElem.setAttribute("accuracy",query.accuracy);}
-if(typeof query.featurelimit=="number"&&query.featurelimit<2000){queryElem.setAttribute("featurelimit",query.featurelimit);}
-if(typeof query.subfields=="string"&&query.subfields!="#ALL#"){queryElem.setAttribute("subfields",query.subfields);}
-if(typeof query.joinexpression=="string"&&query.joinexpression.length>0){queryElem.setAttribute("joinexpression",query.joinexpression);}
-if(typeof query.jointables=="string"&&query.jointables.length>0){queryElem.setAttribute("jointables",query.jointables);}
-ldef.appendChild(queryElem);}
-if(typeof props.layerlist[ld].renderer=="object"){this.addRenderer(ldef,props.layerlist[ld].renderer);}}}}else if(request.get_feature!=null){var getElem=this.createElementNS("","GET_FEATURES");getElem.setAttribute("outputmode","newxml");getElem.setAttribute("checkesc","true");if(request.get_feature.geometry){getElem.setAttribute("geometry",request.get_feature.geometry);}
-else{getElem.setAttribute("geometry","false");}
-if(request.get_feature.compact){getElem.setAttribute("compact",request.get_feature.compact);}
-if(request.get_feature.featurelimit=="number"){getElem.setAttribute("featurelimit",request.get_feature.featurelimit);}
-getElem.setAttribute("globalenvelope","true");reqElem.appendChild(getElem);if(request.get_feature.layer!=null&&request.get_feature.layer.length>0){var lyrElem=this.createElementNS("","LAYER");lyrElem.setAttribute("id",request.get_feature.layer);getElem.appendChild(lyrElem);}
-var fquery=request.get_feature.query;if(fquery!=null){var qElem=null;if(fquery.isspatial){qElem=this.createElementNS("","SPATIALQUERY");}else{qElem=this.createElementNS("","QUERY");}
-getElem.appendChild(qElem);if(typeof fquery.accuracy=="number"){qElem.setAttribute("accuracy",fquery.accuracy);}
-if(fquery.featurecoordsys!=null){var fcsElem1=this.createElementNS("","FEATURECOORDSYS");if(fquery.featurecoordsys.id==0){fcsElem1.setAttribute("string",fquery.featurecoordsys.string);}else{fcsElem1.setAttribute("id",fquery.featurecoordsys.id);}
-qElem.appendChild(fcsElem1);}
-if(fquery.filtercoordsys!=null){var fcsElem2=this.createElementNS("","FILTERCOORDSYS");if(fquery.filtercoordsys.id===0){fcsElem2.setAttribute("string",fquery.filtercoordsys.string);}else{fcsElem2.setAttribute("id",fquery.filtercoordsys.id);}
-qElem.appendChild(fcsElem2);}
-if(fquery.buffer>0){var bufElem=this.createElementNS("","BUFFER");bufElem.setAttribute("distance",fquery.buffer);qElem.appendChild(bufElem);}
-if(fquery.isspatial){var spfElem=this.createElementNS("","SPATIALFILTER");spfElem.setAttribute("relation",fquery.spatialfilter.relation);qElem.appendChild(spfElem);if(fquery.spatialfilter.envelope){var envElem=this.createElementNS("","ENVELOPE");envElem.setAttribute("minx",fquery.spatialfilter.envelope.minx);envElem.setAttribute("miny",fquery.spatialfilter.envelope.miny);envElem.setAttribute("maxx",fquery.spatialfilter.envelope.maxx);envElem.setAttribute("maxy",fquery.spatialfilter.envelope.maxy);spfElem.appendChild(envElem);}else if(typeof fquery.spatialfilter.polygon=="object"){spfElem.appendChild(this.writePolygonGeometry(fquery.spatialfilter.polygon));}}
-if(fquery.where!=null&&fquery.where.length>0){qElem.setAttribute("where",fquery.where);}}}
-root.appendChild(reqElem);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},addGroupRenderer:function(ldef,toprenderer){var topRelem=this.createElementNS("","GROUPRENDERER");ldef.appendChild(topRelem);for(var rind=0;rind<toprenderer.length;rind++){var renderer=toprenderer[rind];this.addRenderer(topRelem,renderer);}},addRenderer:function(topRelem,renderer){if(renderer instanceof Array){this.addGroupRenderer(topRelem,renderer);}else{var renderElem=this.createElementNS("",renderer.type.toUpperCase()+"RENDERER");topRelem.appendChild(renderElem);if(renderElem.tagName=="VALUEMAPRENDERER"){this.addValueMapRenderer(renderElem,renderer);}else if(renderElem.tagName=="VALUEMAPLABELRENDERER"){this.addValueMapLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SIMPLELABELRENDERER"){this.addSimpleLabelRenderer(renderElem,renderer);}else if(renderElem.tagName=="SCALEDEPENDENTRENDERER"){this.addScaleDependentRenderer(renderElem,renderer);}}},addScaleDependentRen
derer:function(renderElem,renderer){if(typeof renderer.lower=="string"||typeof renderer.lower=="number"){renderElem.setAttribute("lower",renderer.lower);}
-if(typeof renderer.upper=="string"||typeof renderer.upper=="number"){renderElem.setAttribute("upper",renderer.upper);}
-this.addRenderer(renderElem,renderer.renderer);},addValueMapLabelRenderer:function(renderElem,renderer){renderElem.setAttribute("lookupfield",renderer.lookupfield);renderElem.setAttribute("labelfield",renderer.labelfield);if(typeof renderer.exacts=="object"){for(var ext=0,extlen=renderer.exacts.length;ext<extlen;ext++){var exact=renderer.exacts[ext];var eelem=this.createElementNS("","EXACT");if(typeof exact.value=="string"){eelem.setAttribute("value",exact.value);}
-if(typeof exact.label=="string"){eelem.setAttribute("label",exact.label);}
-if(typeof exact.method=="string"){eelem.setAttribute("method",exact.method);}
-renderElem.appendChild(eelem);if(typeof exact.symbol=="object"){var selem=null;if(exact.symbol.type=="text"){selem=this.createElementNS("","TEXTSYMBOL");}
-if(selem!=null){var keys=this.fontStyleKeys;for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(exact.symbol[key]){selem.setAttribute(key,exact.symbol[key]);}}
-eelem.appendChild(selem);}}}}},addValueMapRenderer:function(renderElem,renderer){renderElem.setAttribute("lookupfield",renderer.lookupfield);if(typeof renderer.ranges=="object"){for(var rng=0,rnglen=renderer.ranges.length;rng<rnglen;rng++){var range=renderer.ranges[rng];var relem=this.createElementNS("","RANGE");relem.setAttribute("lower",range.lower);relem.setAttribute("upper",range.upper);renderElem.appendChild(relem);if(typeof range.symbol=="object"){var selem=null;if(range.symbol.type=="simplepolygon"){selem=this.createElementNS("","SIMPLEPOLYGONSYMBOL");}
-if(selem!=null){if(typeof range.symbol.boundarycolor=="string"){selem.setAttribute("boundarycolor",range.symbol.boundarycolor);}
-if(typeof range.symbol.fillcolor=="string"){selem.setAttribute("fillcolor",range.symbol.fillcolor);}
-if(typeof range.symbol.filltransparency=="number"){selem.setAttribute("filltransparency",range.symbol.filltransparency);}
-relem.appendChild(selem);}}}}else if(typeof renderer.exacts=="object"){for(var ext=0,extlen=renderer.exacts.length;ext<extlen;ext++){var exact=renderer.exacts[ext];var eelem=this.createElementNS("","EXACT");if(typeof exact.value=="string"){eelem.setAttribute("value",exact.value);}
-renderElem.appendChild(eelem);if(typeof exact.symbol=="object"){var selem=null;if(exact.symbol.type=="simplemarker"){selem=this.createElementNS("","SIMPLEMARKERSYMBOL");}
-if(selem!=null){if(typeof exact.symbol.antialiasing=="string"){selem.setAttribute("antialiasing",exact.symbol.antialiasing);}
-if(typeof exact.symbol.color=="string"){selem.setAttribute("color",exact.symbol.color);}
-if(typeof exact.symbol.outline=="string"){selem.setAttribute("outline",exact.symbol.outline);}
-if(typeof exact.symbol.overlap=="string"){selem.setAttribute("overlap",exact.symbol.overlap);}
-if(typeof exact.symbol.shadow=="string"){selem.setAttribute("shadow",exact.symbol.shadow);}
-if(typeof exact.symbol.transparency=="number"){selem.setAttribute("transparency",exact.symbol.transparency);}
-if(typeof exact.symbol.usecentroid=="string"){selem.setAttribute("usecentroid",exact.symbol.usecentroid);}
-if(typeof exact.symbol.width=="number"){selem.setAttribute("width",exact.symbol.width);}
-eelem.appendChild(selem);}}}}},addSimpleLabelRenderer:function(renderElem,renderer){renderElem.setAttribute("field",renderer.field);var keys=['featureweight','howmanylabels','labelbufferratio','labelpriorities','labelweight','linelabelposition','rotationalangles'];for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(renderer[key]){renderElem.setAttribute(key,renderer[key]);}}
-if(renderer.symbol.type=="text"){var symbol=renderer.symbol;var selem=this.createElementNS("","TEXTSYMBOL");renderElem.appendChild(selem);var keys=this.fontStyleKeys;for(var i=0,len=keys.length;i<len;i++){var key=keys[i];if(symbol[key]){selem.setAttribute(key,renderer[key]);}}}},writePolygonGeometry:function(polygon){if(!(polygon instanceof OpenLayers.Geometry.Polygon)){throw{message:'Cannot write polygon geometry to ArcXML with an '+
-polygon.CLASS_NAME+' object.',geometry:polygon};}
-var polyElem=this.createElementNS("","POLYGON");for(var ln=0,lnlen=polygon.components.length;ln<lnlen;ln++){var ring=polygon.components[ln];var ringElem=this.createElementNS("","RING");for(var rn=0,rnlen=ring.components.length;rn<rnlen;rn++){var point=ring.components[rn];var pointElem=this.createElementNS("","POINT");pointElem.setAttribute("x",point.x);pointElem.setAttribute("y",point.y);ringElem.appendChild(pointElem);}
-polyElem.appendChild(ringElem);}
-return polyElem;},parseResponse:function(data){if(typeof data=="string"){var newData=new OpenLayers.Format.XML();data=newData.read(data);}
-var response=new OpenLayers.Format.ArcXML.Response();var errorNode=data.getElementsByTagName("ERROR");if(errorNode!=null&&errorNode.length>0){response.error=this.getChildValue(errorNode,"Unknown error.");}else{var responseNode=data.getElementsByTagName("RESPONSE");if(responseNode==null||responseNode.length==0){response.error="No RESPONSE tag found in ArcXML response.";return response;}
-var rtype=responseNode[0].firstChild.nodeName;if(rtype=="#text"){rtype=responseNode[0].firstChild.nextSibling.nodeName;}
-if(rtype=="IMAGE"){var envelopeNode=data.getElementsByTagName("ENVELOPE");var outputNode=data.getElementsByTagName("OUTPUT");if(envelopeNode==null||envelopeNode.length==0){response.error="No ENVELOPE tag found in ArcXML response.";}else if(outputNode==null||outputNode.length==0){response.error="No OUTPUT tag found in ArcXML response.";}else{var envAttr=this.parseAttributes(envelopeNode[0]);var outputAttr=this.parseAttributes(outputNode[0]);if(typeof outputAttr.type=="string"){response.image={envelope:envAttr,output:{type:outputAttr.type,data:this.getChildValue(outputNode[0])}};}else{response.image={envelope:envAttr,output:outputAttr};}}}else if(rtype=="FEATURES"){var features=responseNode[0].getElementsByTagName("FEATURES");var featureCount=features[0].getElementsByTagName("FEATURECOUNT");response.features.featurecount=featureCount[0].getAttribute("count");if(response.features.featurecount>0){var envelope=features[0].getElementsByTagName("ENVELOPE");response.features.envelop
e=this.parseAttributes(envelope[0],typeof(0));var featureList=features[0].getElementsByTagName("FEATURE");for(var fn=0;fn<featureList.length;fn++){var feature=new OpenLayers.Feature.Vector();var fields=featureList[fn].getElementsByTagName("FIELD");for(var fdn=0;fdn<fields.length;fdn++){var fieldName=fields[fdn].getAttribute("name");var fieldValue=fields[fdn].getAttribute("value");feature.attributes[fieldName]=fieldValue;}
-var geom=featureList[fn].getElementsByTagName("POLYGON");if(geom.length>0){var ring=geom[0].getElementsByTagName("RING");var polys=[];for(var rn=0;rn<ring.length;rn++){var linearRings=[];linearRings.push(this.parsePointGeometry(ring[rn]));var holes=ring[rn].getElementsByTagName("HOLE");for(var hn=0;hn<holes.length;hn++){linearRings.push(this.parsePointGeometry(holes[hn]));}
-holes=null;polys.push(new OpenLayers.Geometry.Polygon(linearRings));linearRings=null;}
-ring=null;if(polys.length==1){feature.geometry=polys[0];}else
-{feature.geometry=new OpenLayers.Geometry.MultiPolygon(polys);}}
-response.features.feature.push(feature);}}}else{response.error="Unidentified response type.";}}
-return response;},parseAttributes:function(node,type){var attributes={};for(var attr=0;attr<node.attributes.length;attr++){if(type=="number"){attributes[node.attributes[attr].nodeName]=parseFloat(node.attributes[attr].nodeValue);}else{attributes[node.attributes[attr].nodeName]=node.attributes[attr].nodeValue;}}
-return attributes;},parsePointGeometry:function(node){var ringPoints=[];var coords=node.getElementsByTagName("COORDS");if(coords.length>0){var coordArr=this.getChildValue(coords[0]);coordArr=coordArr.split(/;/);for(var cn=0;cn<coordArr.length;cn++){var coordItems=coordArr[cn].split(/ /);ringPoints.push(new OpenLayers.Geometry.Point(parseFloat(coordItems[0]),parseFloat(coordItems[1])));}
-coords=null;}else{var point=node.getElementsByTagName("POINT");if(point.length>0){for(var pn=0;pn<point.length;pn++){ringPoints.push(new OpenLayers.Geometry.Point(parseFloat(point[pn].getAttribute("x")),parseFloat(point[pn].getAttribute("y"))));}}
-point=null;}
-return new OpenLayers.Geometry.LinearRing(ringPoints);},CLASS_NAME:"OpenLayers.Format.ArcXML"});OpenLayers.Format.ArcXML.Request=OpenLayers.Class({initialize:function(params){var defaults={get_image:{properties:{background:null,draw:true,envelope:{minx:0,miny:0,maxx:0,maxy:0},featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},imagesize:{height:0,width:0,dpi:96,printheight:0,printwidth:0,scalesymbols:false},layerlist:[],output:{baseurl:"",legendbaseurl:"",legendname:"",legendpath:"",legendurl:"",name:"",path:"",type:"jpg",url:""}}},get_feature:{layer:"",query:{isspatial:false,featurecoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},filtercoordsys:{id:0,string:"",datumtransformid:0,datumtransformstring:""},buffer:0,where:"",spatialfilter:{relation:"envelope_intersection",envelope:null}}},environment:{separators:{cs:" ",ts:";"}},layer:[],workspaces:[]};return O
penLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Request"});OpenLayers.Format.ArcXML.Response=OpenLayers.Class({initialize:function(params){var defaults={image:{envelope:null,output:''},features:{featurecount:0,envelope:null,feature:[]},error:''};return OpenLayers.Util.extend(this,defaults);},CLASS_NAME:"OpenLayers.Format.ArcXML.Response"});OpenLayers.Layer.ArcIMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{ClientVersion:"9.2",ServiceName:''},tileSize:null,featureCoordSys:"4326",filterCoordSys:"4326",layers:null,async:true,name:"ArcIMS",isBaseLayer:true,DEFAULT_OPTIONS:{tileSize:new OpenLayers.Size(512,512),featureCoordSys:"4326",filterCoordSys:"4326",layers:null,isBaseLayer:true,async:true,name:"ArcIMS"},initialize:function(name,url,options){this.tileSize=new OpenLayers.Size(512,512);this.params=OpenLayers.Util.applyDefaults({ServiceName:options.serviceName},this.DEFAULT_PARAMS);this.options=OpenLayers.Util.applyDefaults(options,this.D
EFAULT_OPTIONS);OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,this.params,options]);if(this.transparent){if(!this.isBaseLayer){this.isBaseLayer=false;}
-if(this.format=="image/jpeg"){this.format=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}
-if(this.options.layers===null){this.options.layers=[];}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},getURL:function(bounds){var url="";bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));var req=new OpenLayers.Request.POST({url:this.getFullRequestString(),data:axlReq.write(),async:false});if(req!=null){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
-var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);url=this.getUrlOrImage(arcxml.image.output);}
-return url;},getURLasync:function(bounds,scope,prop,callback){bounds=this.adjustBounds(bounds);var axlReq=new OpenLayers.Format.ArcXML(OpenLayers.Util.extend(this.options,{requesttype:"image",envelope:bounds.toArray(),tileSize:this.tileSize}));OpenLayers.Request.POST({url:this.getFullRequestString(),async:true,data:axlReq.write(),callback:function(req){var doc=req.responseXML;if(!doc||!doc.documentElement){doc=req.responseText;}
-var axlResp=new OpenLayers.Format.ArcXML();var arcxml=axlResp.read(doc);scope[prop]=this.getUrlOrImage(arcxml.image.output);callback.apply(scope);},scope:this});},getUrlOrImage:function(output){var ret="";if(output.url){ret=output.url;}else if(output.data){ret="data:image/"+output.type+";base64,"+output.data;}
-return ret;},setLayerQuery:function(id,querydef){for(var lyr=0;lyr<this.options.layers.length;lyr++){if(id==this.options.layers[lyr].id){this.options.layers[lyr].query=querydef;return;}}
-this.options.layers.push({id:id,visible:true,query:querydef});},getFeatureInfo:function(geometry,layer,options){var buffer=options.buffer||1;var callback=options.callback||function(){};var scope=options.scope||window;var requestOptions={};OpenLayers.Util.extend(requestOptions,this.options);requestOptions.requesttype="feature";if(geometry instanceof OpenLayers.LonLat){requestOptions.polygon=null;requestOptions.envelope=[geometry.lon-buffer,geometry.lat-buffer,geometry.lon+buffer,geometry.lat+buffer];}else if(geometry instanceof OpenLayers.Geometry.Polygon){requestOptions.envelope=null;requestOptions.polygon=geometry;}
-var arcxml=new OpenLayers.Format.ArcXML(requestOptions);OpenLayers.Util.extend(arcxml.request.get_feature,options);arcxml.request.get_feature.layer=layer.id;if(typeof layer.query.accuracy=="number"){arcxml.request.get_feature.query.accuracy=layer.query.accuracy;}else{var mapCenter=this.map.getCenter();var viewPx=this.map.getViewPortPxFromLonLat(mapCenter);viewPx.x++;var mapOffCenter=this.map.getLonLatFromPixel(viewPx);arcxml.request.get_feature.query.accuracy=mapOffCenter.lon-mapCenter.lon;}
-arcxml.request.get_feature.query.where=layer.query.where;arcxml.request.get_feature.query.spatialfilter.relation="area_intersection";OpenLayers.Request.POST({url:this.getFullRequestString({'CustomService':'Query'}),data:arcxml.write(),callback:function(request){var response=arcxml.parseResponse(request.responseText);if(!arcxml.iserror()){callback.call(scope,response.features);}else{callback.call(scope,null);}}});},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcIMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.ArcIMS"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);this.removeButtons();this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);thi
s._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv(this.id+"_"+id,xy,sz,imgLocation,"absolute");btn.style.cursor="pointer";this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;if(!this.slideRatio){var slideFactorPixels
=this.slideFactor;var getSlideFactor=function(){return slideFactorPixels;};}else{var slideRatio=this.slideRatio;var getSlideFactor=function(dim){return this.map.getSize()[dim]*slideRatio;};}
-btn.getSlideFactor=getSlideFactor;this.buttons.push(btn);return btn;},_removeButton:function(btn){OpenLayers.Event.stopObservingElement(btn);btn.map=null;btn.getSlideFactor=null;this.div.removeChild(btn);OpenLayers.Util.removeItem(this.buttons,btn);},removeButtons:function(){for(var i=this.buttons.length-1;i>=0;--i){this._removeButton(this.buttons[i]);}},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-switch(this.action){case"panup":this.map.pan(0,-this.getSlideFactor("h"));break;case"pandown":this.map.pan(0,this.getSlideFactor("h"));break;case"panleft":this.map.pan(-this.getSlideFactor("w"),0);break;case"panright":this.map.pan(this.getSlideFactor("w"),0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
-OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoombarDiv:null,divEvents:null,zoomWorldIcon:false,forceFixedZoomLevel:false,mouseDragStart:null,deltaY:null,zoomStart:null,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this._removeZoomBar();this.map.events.un({"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);delete this.mouseDragStart;delete this.zoomStart;},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.removeButtons();this._removeZoomBar();}
-this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
-this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
-this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id=this.id+"_"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");slider.style.cursor="move";this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true,{includeXY:true});this.sliderEvents.on({"touchstart":this.zoomBarDown,"touchmove":this.zoomBarDrag,"touchend":this.zoomBarUp,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.z
oomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id=this.id+"_"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h+"px";}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
-div.style.cursor="pointer";this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true,{includeXY:true});this.divEvents.on({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},_removeZoomBar:function(){this.sliderEvents.un({"touchmove":this.zoomBarDrag,"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});this.sliderEvents.destroy();this.divEvents.un({"touchmove":this.passEventToSlider,"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.divEvents.destroy();this.div.removeChi
ld(this.zoombarDiv);this.zoombarDiv=null;this.div.removeChild(this.slider);this.slider=null;this.map.events.unregister("zoomend",this,this.moveZoomBar);},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var levels=evt.xy.y/this.zoomStopHeight;if(this.forceFixedZoomLevel||!this.map.fractionalZoom){levels=Math.floor(levels);}
-var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&!OpenLayers.Event.isSingleTouch(evt)){return;}
-this.map.events.on({"touchmove":this.passEventToSlider,"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";this.mouseDragStart=evt.xy.clone();}
-this.deltaY=this.zoomStart.y-evt.xy.y;OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)&&evt.type!=="touchend"){return;}
-if(this.mouseDragStart){this.div.style.cursor="";this.map.events.un({"touchmove":this.passEventToSlider,"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var zoomLevel=this.map.zoom;if(!this.forceFixedZoomLevel&&this.map.fractionalZoom){zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=this.deltaY/this.zoomStopHeight;zoomLevel=Math.max(Math.round(zoomLevel),0);}
-this.map.zoomTo(zoomLevel);this.mouseDragStart=null;this.zoomStart=null;this.deltaY=0;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.WFSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.0",version:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-var constr=OpenLayers.Format.WFSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a WFS capabilities parser for version "+version;}
-var parser=new constr(this.options);var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WFSCapabilities"});OpenLayers.Format.WFSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.WFSCapabilities,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var capabilities={};var root=data.documentElement;this.runChildNodes(capabilities,root);return capabilities;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){processor=this["read_cap_"+childNode.nodeName];if(processor){processor.apply(this,[obj,childNode]);}}}},read_cap_FeatureTypeList:function(request,node){var featureTypeList={featureTypes:[]};this.runChildNodes(featureTypeList,node);request.featureTypeList=featureTypeList;},read_cap_FeatureType:function(featureTypeList,node,parentLayer){var featureType={};this.runChildNodes(featureType,node);featureTypeList.featureTypes.push(featureType);},read_cap_Name:function(obj,node){var name=this.getChildValue(node);if(name){var parts=name.split(":");obj.name=parts.pop();if(parts.length>0){obj.featureNS=this.lookupNamespaceURI(node,parts[0]);}}},read_cap_Title:function(obj,node){var title=this.getChildValue(node);
if(title){obj.title=title;}},read_cap_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1"});OpenLayers.Format.WFSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_1_0"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.maxExtent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;}
-OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.getOptions());}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
-OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);this.addTileMonitoringHooks(this.tile);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
-this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){this.events.triggerEvent("loadstart");};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.events.triggerEvent("loadend");};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Strategy=OpenLayers.Class({layer:null,options:null,active:null,autoActivate:true,autoDestroy:true,initialize:function
(options){OpenLayers.Util.extend(this,options);this.options=options;this.active=false;},destroy:function(){this.deactivate();this.layer=null;this.options=null;},setLayer:function(layer){this.layer=layer;},activate:function(){if(!this.active){this.active=true;return true;}
-return false;},deactivate:function(){if(this.active){this.active=false;return true;}
-return false;},CLASS_NAME:"OpenLayers.Strategy"});OpenLayers.Strategy.Save=OpenLayers.Class(OpenLayers.Strategy,{EVENT_TYPES:["start","success","fail"],events:null,auto:false,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.auto){if(typeof this.auto==="number"){this.timer=window.setInterval(OpenLayers.Function.bind(this.save,this),this.auto*1000);}else{this.layer.events.on({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){if(this.auto){if(typeof this.auto==="number"){window.clearInterval(this.timer);}else{this.layer.events.un({"featureadded":this.triggerSave,"afterfeaturemodified":this.triggerSave,scope:this});}}}
-return deactivated;},triggerSave:function(event){var feature=event.feature;if(feature.state===OpenLayers.State.INSERT||feature.state===OpenLayers.State.UPDATE||feature.state===OpenLayers.State.DELETE){this.save([event.feature]);}},save:function(features){if(!features){features=this.layer.features;}
-this.events.triggerEvent("start",{features:features});var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var len=features.length;var clones=new Array(len);var orig,clone;for(var i=0;i<len;++i){orig=features[i];clone=orig.clone();clone.fid=orig.fid;clone.state=orig.state;if(orig.url){clone.url=orig.url;}
-clone._original=orig;clone.geometry.transform(local,remote);clones[i]=clone;}
-features=clones;}
-this.layer.protocol.commit(features,{callback:this.onCommit,scope:this});},onCommit:function(response){var evt={"response":response};if(response.success()){var features=response.reqFeatures;var state,feature;var destroys=[];var insertIds=response.insertIds||[];var j=0;for(var i=0,len=features.length;i<len;++i){feature=features[i];feature=feature._original||feature;state=feature.state;if(state){if(state==OpenLayers.State.DELETE){destroys.push(feature);}else if(state==OpenLayers.State.INSERT){feature.fid=insertIds[j];++j;}
-feature.state=null;}}
-if(destroys.length>0){this.layer.destroyFeatures(destroys);}
-this.events.triggerEvent("success",evt);}else{this.events.triggerEvent("fail",evt);}},CLASS_NAME:"OpenLayers.Strategy.Save"});OpenLayers.Format.GPX=OpenLayers.Class(OpenLayers.Format.XML,{extractWaypoints:true,extractTracks:true,extractRoutes:true,extractAttributes:true,initialize:function(options){this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var features=[];if(this.extractTracks){var tracks=doc.getElementsByTagName("trk");for(var i=0,len=tracks.length;i<len;i++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(tracks[i]);}
-var segs=this.getElementsByTagNameNS(tracks[i],tracks[i].namespaceURI,"trkseg");for(var j=0,seglen=segs.length;j<seglen;j++){var track=this.extractSegment(segs[j],"trkpt");features.push(new OpenLayers.Feature.Vector(track,attrs));}}}
-if(this.extractRoutes){var routes=doc.getElementsByTagName("rte");for(var k=0,klen=routes.length;k<klen;k++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(routes[k]);}
-var route=this.extractSegment(routes[k],"rtept");features.push(new OpenLayers.Feature.Vector(route,attrs));}}
-if(this.extractWaypoints){var waypoints=doc.getElementsByTagName("wpt");for(var l=0,len=waypoints.length;l<len;l++){var attrs={};if(this.extractAttributes){attrs=this.parseAttributes(waypoints[l]);}
-var wpt=new OpenLayers.Geometry.Point(waypoints[l].getAttribute("lon"),waypoints[l].getAttribute("lat"));features.push(new OpenLayers.Feature.Vector(wpt,attrs));}}
-if(this.internalProjection&&this.externalProjection){for(var g=0,featLength=features.length;g<featLength;g++){features[g].geometry.transform(this.externalProjection,this.internalProjection);}}
-return features;},extractSegment:function(segment,segmentType){var points=this.getElementsByTagNameNS(segment,segment.namespaceURI,segmentType);var point_features=[];for(var i=0,len=points.length;i<len;i++){point_features.push(new OpenLayers.Geometry.Point(points[i].getAttribute("lon"),points[i].getAttribute("lat")));}
-return new OpenLayers.Geometry.LineString(point_features);},parseAttributes:function(node){var attributes={};var attrNode=node.firstChild,value,name;while(attrNode){if(attrNode.nodeType==1){value=attrNode.firstChild;if(value.nodeType==3||value.nodeType==4){name=(attrNode.prefix)?attrNode.nodeName.split(":")[1]:attrNode.nodeName;if(name!="trkseg"&&name!="rtept"){attributes[name]=value.nodeValue;}}}
-attrNode=attrNode.nextSibling;}
-return attributes;},CLASS_NAME:"OpenLayers.Format.GPX"});OpenLayers.Format.WFSDescribeFeatureType=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xsd:"http://www.w3.org/2001/XMLSchema"},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},readers:{"xsd":{"schema":function(node,obj){var complexTypes=[];var customTypes={};var schema={complexTypes:complexTypes,customTypes:customTypes};this.readChildNodes(node,schema);var attributes=node.attributes;var attr,name;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];name=attr.name;if(name.indexOf("xmlns")==0){this.setNamespace(name.split(":")[1]||"",attr.value);}else{obj[name]=attr.value;}}
-obj.featureTypes=complexTypes;obj.targetPrefix=this.namespaceAlias[obj.targetNamespace];var complexType,customType;for(var i=0,len=complexTypes.length;i<len;++i){complexType=complexTypes[i];customType=customTypes[complexType.typeName];if(customTypes[complexType.typeName]){complexType.typeName=customType.name;}}},"complexType":function(node,obj){var complexType={"typeName":node.getAttribute("name")};this.readChildNodes(node,complexType);obj.complexTypes.push(complexType);},"complexContent":function(node,obj){this.readChildNodes(node,obj);},"extension":function(node,obj){this.readChildNodes(node,obj);},"sequence":function(node,obj){var sequence={elements:[]};this.readChildNodes(node,sequence);obj.properties=sequence.elements;},"element":function(node,obj){if(obj.elements){var element={};var attributes=node.attributes;var attr;for(var i=0,len=attributes.length;i<len;++i){attr=attributes[i];element[attr.name]=attr.value;}
-var type=element.type;if(!type){type={};this.readChildNodes(node,type);element.restriction=type;element.type=type.base;}
-var fullType=type.base||type;element.localType=fullType.split(":").pop();obj.elements.push(element);}
-if(obj.complexTypes){var type=node.getAttribute("type");var localType=type.split(":").pop();obj.customTypes[localType]={"name":node.getAttribute("name"),"type":type};}},"simpleType":function(node,obj){this.readChildNodes(node,obj);},"restriction":function(node,obj){obj.base=node.getAttribute("base");this.readRestriction(node,obj);}}},readRestriction:function(node,obj){var children=node.childNodes;var child,nodeName,value;for(var i=0,len=children.length;i<len;++i){child=children[i];if(child.nodeType==1){nodeName=child.nodeName.split(":").pop();value=child.getAttribute("value");if(!obj[nodeName]){obj[nodeName]=value;}else{if(typeof obj[nodeName]=="string"){obj[nodeName]=[obj[nodeName]];}
-obj[nodeName].push(value);}}}},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var schema={};this.readNode(data,schema);return schema;},CLASS_NAME:"OpenLayers.Format.WFSDescribeFeatureType"});OpenLayers.Renderer=OpenLayers.Class({container:null,root:null,extent:null,locked:false,size:null,resolution:null,map:null,initialize:function(containerID,options){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent,resolutionChanged){this.extent=extent.clone();if(resolutionChanged){this.resolution=null;}},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
-if(feature.geometry){var bounds=feature.geometry.getBounds();if(bounds){if(!bounds.intersectsBounds(this.extent)){style={display:"none"};}
-var rendered=this.drawGeometry(feature.geometry,style,feature.id);if(style.display!="none"&&style.label&&rendered!==false){var location=feature.geometry.getCentroid();if(style.labelXOffset||style.labelYOffset){var xOffset=isNaN(style.labelXOffset)?0:style.labelXOffset;var yOffset=isNaN(style.labelYOffset)?0:style.labelYOffset;var res=this.getResolution();location.move(xOffset*res,yOffset*res);}
-this.drawText(feature.id,style,location);}else{this.removeText(feature.id);}
-return rendered;}}},drawGeometry:function(geometry,style,featureId){},drawText:function(featureId,style,location){},removeText:function(featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=0,len=features.length;i<len;++i){var feature=features[i];this.eraseGeometry(feature.geometry,feature.id);this.removeText(feature.id);}},eraseGeometry:function(geometry,featureId){},moveRoot:function(renderer){},getRenderLayerId:function(){return this.container.id;},applyDefaultSymbolizer:function(symbolizer){var result=OpenLayers.Util.extend({},OpenLayers.Renderer.defaultSymbolizer);if(symbolizer.stroke===false){delete result.strokeWidth;delete result.strokeColor;}
-if(symbolizer.fill===false){delete result.fillColor;}
-OpenLayers.Util.extend(result,symbolizer);return result;},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Renderer.defaultSymbolizer={fillColor:"#000000",strokeColor:"#000000",strokeWidth:2,fillOpacity:1,strokeOpacity:1,pointRadius:0};OpenLayers.Renderer.Canvas=OpenLayers.Class(OpenLayers.Renderer,{canvas:null,features:null,initialize:function(containerID){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.root=document.createElement("canvas");this.container.appendChild(this.root);this.canvas=this.root.getContext("2d");this.features={};},eraseGeometry:function(geometry,featureId){this.eraseFeatures(this.features[featureId][0]);},supported:function(){var canvas=document.createElement("canvas");return!!canvas.getContext;},setSize:function(size){this.size=size.clone();this.root.style.width=size.w+"px";this.root.style.height=size.h+"px";this.root.width=size.w;this.root.height=size.h;this.resolution=null;},drawFeature:function(feature,style){style=style||feature.st
yle;style=this.applyDefaultSymbolizer(style);this.features[feature.id]=[feature,style];this.redraw();},drawGeometry:function(geometry,style){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style);}
-return;}
-switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(geometry,style);break;case"OpenLayers.Geometry.LineString":this.drawLineString(geometry,style);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(geometry,style);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(geometry,style);break;default:break;}},drawExternalGraphic:function(pt,style){var img=new Image();if(style.graphicTitle){img.title=style.graphicTitle;}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var context={img:img,x:(pt[0]+xOffset),y:(pt[1]+yOffset),width:width,height:height,opacity:style.graphicOpacity||style.fillOpacity,canvas:this.canvas};img.onload=OpenLayers.Function.bind(function(){this.canvas.globalAlpha=this.opacity;this.canvas.drawImage(this.img,this.x,this.y,this.width,this.height);},context);img.src=style.externalGraphic;},setCanvasStyle:function(type,style){if(type=="fill"){this.canvas.globalAlpha=style['fillOpacity'];this.canvas.fillStyle=style['fillColor'];}else if(type=="stroke"){this.canvas.globalAlpha=style['strokeOpacity'];this.canvas.strokeStyle=style['strokeColor'];this.canvas.lineWidth=style['strokeWidth'];}e
lse{this.canvas.globalAlpha=0;this.canvas.lineWidth=1;}},drawPoint:function(geometry,style){if(style.graphic!==false){var pt=this.getLocalXY(geometry);if(style.externalGraphic){this.drawExternalGraphic(pt,style);}else{if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();this.canvas.arc(pt[0],pt[1],style.pointRadius,0,Math.PI*2,true);this.canvas.fill();}
-if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();this.canvas.arc(pt[0],pt[1],style.pointRadius,0,Math.PI*2,true);this.canvas.stroke();this.setCanvasStyle("reset");}}}},drawLineString:function(geometry,style){if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();var start=this.getLocalXY(geometry.components[0]);this.canvas.moveTo(start[0],start[1]);for(var i=1;i<geometry.components.length;i++){var pt=this.getLocalXY(geometry.components[i]);this.canvas.lineTo(pt[0],pt[1]);}
-this.canvas.stroke();}
-this.setCanvasStyle("reset");},drawLinearRing:function(geometry,style){if(style.fill!==false){this.setCanvasStyle("fill",style);this.canvas.beginPath();var start=this.getLocalXY(geometry.components[0]);this.canvas.moveTo(start[0],start[1]);for(var i=1;i<geometry.components.length-1;i++){var pt=this.getLocalXY(geometry.components[i]);this.canvas.lineTo(pt[0],pt[1]);}
-this.canvas.fill();}
-if(style.stroke!==false){this.setCanvasStyle("stroke",style);this.canvas.beginPath();var start=this.getLocalXY(geometry.components[0]);this.canvas.moveTo(start[0],start[1]);for(var i=1;i<geometry.components.length;i++){var pt=this.getLocalXY(geometry.components[i]);this.canvas.lineTo(pt[0],pt[1]);}
-this.setCanvasStyle("reset");},drawPolygon:function(geometry,style){this.drawLinearRing(geometry.components[0],style);for(var i=1;i<geometry.components.length;i++){this.drawLinearRing(geometry.components[i],{fillOpacity:0,strokeWidth:0,strokeOpacity:0,strokeColor:'#000000',fillColor:'#000000'});}},drawText:function(location,style){style=OpenLayers.Util.extend({fontColor:"#000000",labelAlign:"cm"},style);var pt=this.getLocalXY(location);this.setCanvasStyle("reset");this.canvas.fillStyle=style.fontColor;this.canvas.globalAlpha=style.fontOpacity||1.0;var fontStyle=style.fontWeight+" "+style.fontSize+" "+style.fontFamily;if(this.canvas.fillText){var labelAlign=OpenLayers.Renderer.Canvas.LABEL_ALIGN[style.labelAlign[0]]||"center";this.canvas.font=fontStyle;this.canvas.textAlign=labelAlign;this.canvas.fillText(style.label,pt[0],pt[1]);}else if(this.canvas.mozDrawText){this.canvas.mozTextStyle=fontStyle;var len=this.canvas.mozMeasureText(style.label);switch(style.labelAlign[0]){cas
e"l":break;case"r":pt[0]-=len;break;case"c":default:pt[0]-=len/2;}
-this.canvas.translate(pt[0],pt[1]);this.canvas.mozDrawText(style.label);this.canvas.translate(-1*pt[0],-1*pt[1]);}
-this.setCanvasStyle("reset");},getLocalXY:function(point){var resolution=this.getResolution();var extent=this.extent;var x=(point.x/resolution+(-extent.left/resolution));var y=((extent.top/resolution)-point.y/resolution);return[x,y];},clear:function(){this.canvas.clearRect(0,0,this.root.width,this.root.height);this.features={};},getFeatureIdFromEvent:function(evt){var loc=this.map.getLonLatFromPixel(evt.xy);var resolution=this.getResolution();var bounds=new OpenLayers.Bounds(loc.lon-resolution*5,loc.lat-resolution*5,loc.lon+resolution*5,loc.lat+resolution*5);var geom=bounds.toGeometry();for(var feat in this.features){if(!this.features.hasOwnProperty(feat)){continue;}
-if(this.features[feat][0].geometry.intersects(geom)){return feat;}}
-return null;},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=0;i<features.length;++i){delete this.features[features[i].id];}
-this.redraw();},redraw:function(){if(!this.locked){this.canvas.clearRect(0,0,this.root.width,this.root.height);var labelMap=[];var feature,style;for(var id in this.features){if(!this.features.hasOwnProperty(id)){continue;}
-feature=this.features[id][0];style=this.features[id][1];if(!feature.geometry){continue;}
-this.drawGeometry(feature.geometry,style);if(style.label){labelMap.push([feature,style]);}}
-var item;for(var i=0,len=labelMap.length;i<len;++i){item=labelMap[i];this.drawText(item[0].geometry.getCentroid(),item[1]);}}},CLASS_NAME:"OpenLayers.Renderer.Canvas"});OpenLayers.Renderer.Canvas.LABEL_ALIGN={"l":"left","r":"right"};OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
-layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
-layer_defaults.areaTags=area;this.externalProjection=new OpenLayers.Projection("EPSG:4326");OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
-var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
-if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
-for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
-tags=result[0];}else{tags=this.getTags(node.node);}
-var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
-feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
-node.node=null;}
-return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
-return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
-return_ways.push(way_object);}
-return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
-return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
-if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
-return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
-this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
-return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
-if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
-this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
-this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var id;var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
-var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
-this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
-this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
-if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;var map=this.map||control.map;if(map){this.setMap(map);}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
-var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
-this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0,len=events.length;i<len;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply
(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;}
+this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(OpenLayers.IS_GECKO===true){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.BROWSER_NAME=="safari"||OpenLayers.BROWSER_NAME=="opera");OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:900913"},options);}
+url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(url instanceof Array){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
+return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;return{'x':x,'y':y,'z':z};},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(o
bj){if(obj==null){obj=new OpenLayers.Layer.OSM(this.name,this.url,this.getOptions());}
+obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.documentDrag===true){var me=this;this._docMove=function(evt){me.mousemove({xy:{x:evt.clientX,y:evt.clientY},element:document});};this._docUp=function(evt){me.mouseup({xy:{x:evt.clientX,y:evt.clientY}});};}},dragstart:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&(OpenLayers.Event.isLeftClick(evt)||OpenLayers.Event.isSingleTouch(evt))){this.started=true;this.start=evt.xy;this.last=evt.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.
document.onselectstart=OpenLayers.Function.False;propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
return propagate;},dragmove:function(evt){if(this.started&&!this.timeoutId&&(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y)){if(this.documentDrag===true&&this.documentEvents){if(evt.element===document){this.adjustXY(evt);this.setEvent(evt);}else{this.removeDocumentEvents();}}
if(this.interval>0){this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);}
@@ -1594,1108 +626,13 @@
if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}}
return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDragDown");}
-return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickTolerance:4,geomet
ryTypes:null,stopClick:true,stopDown:true,stopUp:false,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){if(!this.callbacks['over']&&!this.callbacks['out']){return true;}
-this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){if(this.feature&&!this.feature.layer){this.feature=null;}
-var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature&&!this.feature.layer){this.feature=null;}
-if(this.lastFeature&&!this.lastFeature.layer){this.lastFeature=null;}
-if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){if(this.lastFeature){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
-this.lastFeature=this.feature;handled=true;}else{if(this.lastFeature&&(previouslyIn&&inNew||click)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(this.lastFeature&&(previouslyIn||click)){this.triggerCallback(type,'out',[this.lastFeature]);}}
-return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.moveLayerToTop();this.map.events.on({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.moveLayerBack();this.feature=null;this.lastFeature=null;this.down=null;this.up=null;this.map.events.un({"removelayer":this.handleMapEvents,"changelayer":this.handleMapEvents,scope:this});deactivated=true;}
-return deactivated;},handleMapEvents:function(evt){if(!evt.property||evt.property=="order"){this.moveLayerToTop();}},moveLayerToTop:function(){var index=Math.max(this.map.Z_INDEX_BASE['Feature']-1,this.layer.getZIndex())+1;this.layer.setZIndex(index);},moveLayerBack:function(){var index=this.layer.getZIndex()-1;if(index>=this.map.Z_INDEX_BASE['Feature']){this.layer.setZIndex(index);}else{this.map.setLayerZIndex(this.layer,this.map.getLayerIndex(this.layer));}},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},onEnter:function(feature){},onLeave:function(feature){},documentDrag:false,layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new Op
enLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks),{documentDrag:this.documentDrag}),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.
handlers.drag.activate();this.over=true;OpenLayers.Element.addClass(this.map.viewPortDiv,this.displayClass+"Over");this.onEnter(feature);}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();OpenLayers.Element.removeClass(this.map.viewPortDiv,this.displayClass+"Over");this.onLeave(feature);this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function()
{this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"]),"delete":new OpenLayers.Style(OpenLayers.Feature.Vector.style["delete"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;this.styles["delete"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles
[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);this.styles["delete"]=new OpenLayers.Style(style);break;}}}
-OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
-this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
-if(!this.styles[intent]){intent="default";}
-feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
-return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers,context){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],context:context,filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","beforefeaturesadded","featureadded","featuresadded","beforefeatureremoved","beforefeaturesremoved","featureremoved","featuresremoved","beforefeatureselected","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified","vertexmodified","vertexremoved","sketchstarted","sketchmodified","sketchcomplete","refresh"],isBaseLayer:false,isFixed:false,features:null,filter:null,selectedFeatures:null,unrenderedFeatures:null,reportError:true,style:null,styleMap:null,strategies:null,protocol:null,renderers:['SVG','VML','Canvas'],renderer:null,rendererOptions:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply
(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
-if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
-if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
-this.features=[];this.selectedFeatures=[];this.unrenderedFeatures={};if(this.strategies){for(var i=0,len=this.strategies.length;i<len;i++){this.strategies[i].setLayer(this);}}},destroy:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoDestroy){strategy.destroy();}}
-this.strategies=null;}
-if(this.protocol){if(this.protocol.autoDestroy){this.protocol.destroy();}
-this.protocol=null;}
-this.destroyFeatures();this.features=null;this.selectedFeatures=null;this.unrenderedFeatures=null;if(this.renderer){this.renderer.destroy();}
-this.renderer=null;this.geometryType=null;this.drawn=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Vector(this.name,this.getOptions());}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);var features=this.features;var len=features.length;var clonedFeatures=new Array(len);for(var i=0;i<len;++i){clonedFeatures[i]=features[i].clone();}
-obj.features=clonedFeatures;return obj;},refresh:function(obj){if(this.calculateInRange()&&this.visibility){this.events.triggerEvent("refresh",obj);}},assignRenderer:function(){for(var i=0,len=this.renderers.length;i<len;i++){var rendererClass=this.renderers[i];var renderer=(typeof rendererClass=="function")?rendererClass:OpenLayers.Renderer[rendererClass];if(renderer&&renderer.prototype.supported()){this.renderer=new renderer(this.div,this.rendererOptions);break;}}},displayError:function(){if(this.reportError){OpenLayers.Console.userError(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},afterAdd:function(){if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){
strategy.activate();}}}},removeMap:function(map){this.drawn=false;if(this.strategies){var strategy,i,len;for(i=0,len=this.strategies.length;i<len;i++){strategy=this.strategies[i];if(strategy.autoActivate){strategy.deactivate();}}}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var coordSysUnchanged=true;if(!dragging){this.renderer.root.style.visibility="hidden";this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();coordSysUnchanged=this.renderer.setExtent(extent,zoomChanged);this.renderer.root.style.visibility="visible";if(OpenLayers.IS_GECKO===true){this.div.scrollLeft=this.div.scrollLeft;}
-if(!zoomChanged&&coordSysUnchanged){for(var i in this.unrenderedFeatures){var feature=this.unrenderedFeatures[i];this.drawFeature(feature);}}}
-if(!this.drawn||zoomChanged||!coordSysUnchanged){this.drawn=true;var feature;for(var i=0,len=this.features.length;i<len;i++){this.renderer.locked=(i!==(len-1));feature=this.features[i];this.drawFeature(feature);}}},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);var currentDisplay=this.div.style.display;if(currentDisplay!=this.renderer.root.style.display){this.renderer.root.style.display=currentDisplay;}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
-var notify=!options||!options.silent;if(notify){var event={features:features};var ret=this.events.triggerEvent("beforefeaturesadded",event);if(ret===false){return;}
-features=event.features;}
-var featuresAdded=[];for(var i=0,len=features.length;i<len;i++){if(i!=(features.length-1)){this.renderer.locked=true;}else{this.renderer.locked=false;}
-var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
-feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){if(this.events.triggerEvent("beforefeatureadded",{feature:feature})===false){continue;};this.preFeatureInsert(feature);}
-featuresAdded.push(feature);this.features.push(feature);this.drawFeature(feature);if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
-if(notify){this.events.triggerEvent("featuresadded",{features:featuresAdded});}},removeFeatures:function(features,options){if(!features||features.length===0){return;}
-if(features===this.features){return this.removeAllFeatures(options);}
-if(!(features instanceof Array)){features=[features];}
-if(features===this.selectedFeatures){features=features.slice();}
-var notify=!options||!options.silent;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
-for(var i=features.length-1;i>=0;i--){if(i!=0&&features[i-1].geometry){this.renderer.locked=true;}else{this.renderer.locked=false;}
-var feature=features[i];delete this.unrenderedFeatures[feature.id];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
-this.features=OpenLayers.Util.removeItem(this.features,feature);feature.layer=null;if(feature.geometry){this.renderer.eraseFeatures(feature);}
-if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
-if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
-if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},removeAllFeatures:function(options){var notify=!options||!options.silent;var features=this.features;if(notify){this.events.triggerEvent("beforefeaturesremoved",{features:features});}
-var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(notify){this.events.triggerEvent("beforefeatureremoved",{feature:feature});}
-feature.layer=null;if(notify){this.events.triggerEvent("featureremoved",{feature:feature});}}
-this.renderer.clear();this.features=[];this.unrenderedFeatures={};this.selectedFeatures=[];if(notify){this.events.triggerEvent("featuresremoved",{features:features});}},destroyFeatures:function(features,options){var all=(features==undefined);if(all){features=this.features;}
-if(features){this.removeFeatures(features,options);for(var i=features.length-1;i>=0;i--){features[i].destroy();}}},drawFeature:function(feature,style){if(!this.drawn){return;}
-if(typeof style!="object"){if(!style&&feature.state===OpenLayers.State.DELETE){style="delete";}
-var renderIntent=style||feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-if(!this.renderer.drawFeature(feature,style)){this.unrenderedFeatures[feature.id]=feature;}else{delete this.unrenderedFeatures[feature.id];};},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
-var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureBy:function(property,value){var feature=null;for(var i=0,len=this.features.length;i<len;++i){if(this.features[i][property]==value){feature=this.features[i];break;}}
-return feature;},getFeatureById:function(featureId){return this.getFeatureBy('id',featureId);},getFeatureByFid:function(featureFid){return this.getFeatureBy('fid',featureFid);},getFeaturesByAttribute:function(attrName,attrValue){var i,feature,len=this.features.length,foundFeatures=[];for(i=0;i<len;i++){feature=this.features[i];if(feature&&feature.attributes){if(feature.attributes[attrName]===attrValue){foundFeatures.push(feature);}}}
-return foundFeatures;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},getDataExtent:function(){var maxExtent=null;var features=this.features;if(features&&(features.length>0)){maxExtent=new OpenLayers.Bounds();var geometry=null;for(var i=0,len=features.length;i<len;i++){geometry=features[i].geometry;if(geometry){maxExtent.extend(geometry.getBounds());}}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.Vector.RootContainer=OpenLayers.Class(OpenLayers.Layer.Vector,{displayInLayerSwitcher:false,layers:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},display:function(){},getFeatureFromEvent:function(evt){var layers=this.layers;var feature;for(var i=0;i<layers.length;i++){feature=layers[i].getFeatureFromEvent(evt);if(feature){return feature;}}},setMap:function(map){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);this.collectRoots();map.events.register("changelayer",this,this.handleChangeLayer);},removeMap:function(map){map.events.unregister("changelayer",this,this.handleChangeLayer);this.resetRoots();OpenLayers.Layer.Vector.prototype.removeMap.apply(this,arguments);},collectRoots:function(){var layer;for(var i=0;i<this.map.layers.length;++i){layer=this.map.layers[i];if(OpenLayers.Util.indexOf(this.layers,layer)!=-1){layer.renderer
.moveRoot(this.renderer);}}},resetRoots:function(){var layer;for(var i=0;i<this.layers.length;++i){layer=this.layers[i];if(this.renderer&&layer.renderer.getRenderLayerId()==this.id){this.renderer.moveRoot(layer.renderer);}}},handleChangeLayer:function(evt){var layer=evt.layer;if(evt.property=="order"&&OpenLayers.Util.indexOf(this.layers,layer)!=-1){this.resetRoots();this.collectRoots();}},CLASS_NAME:"OpenLayers.Layer.Vector.RootContainer"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforefeaturehighlighted","featurehighlighted","featureunhighlighted"],multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,highlightOnly:false,box:false,onBeforeSelect:function(){},onSelect:function(){},onUnselect:function(){},scope:null,geometryTypes:null,layer:null,layers:null,callbacks:null,selectStyle:null,renderIntent:"select",handlers:null,initialize:function(layers,options){this.EVENT_TYPES=OpenLayers.Control.Select
Feature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.scope===null){this.scope=this;}
-this.initLayer(layers);var callbacks={click:this.clickFeature,clickout:this.clickoutFeature};if(this.hover){callbacks.over=this.overFeature;callbacks.out=this.outFeature;}
-this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlers={feature:new OpenLayers.Handler.Feature(this,this.layer,this.callbacks,{geometryTypes:this.geometryTypes})};if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},{boxDivClassName:"olHandlerBoxSelectFeature"});}},initLayer:function(layers){if(layers instanceof Array){this.layers=layers;this.layer=new OpenLayers.Layer.Vector.RootContainer(this.id+"_container",{layers:layers});}else{this.layer=layers;}},destroy:function(){if(this.active&&this.layers){this.map.removeLayer(this.layer);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.layers){this.layer.destroy();}},activate:function(){if(!this.active){if(this.layers){this.map.addLayer(this.layer);}
-this.handlers.feature.activate();if(this.box&&this.handlers.box){this.handlers.box.activate();}}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){this.handlers.feature.deactivate();if(this.handlers.box){this.handlers.box.deactivate();}
-if(this.layers){this.map.removeLayer(this.layer);}}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},unselectAll:function(options){var layers=this.layers||[this.layer];var layer,feature;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=layer.selectedFeatures.length-1;i>=0;--i){feature=layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(feature.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||(this.handlers.feature.evt&&this.handlers.feature.evt[this.multipleKey]);},toggleSelect:function(){return this.toggle||(this.handlers.feature.evt&&this.handlers.feature.evt[this.toggleKey]);},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){var layer=feature.layer;if(this.hover){if(this.highlightOnly){this.highlight(feature);}else if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}},outFeature:function(feature){if(this.hover){if(this.highlightOnly){if(feature._lastHighlighter==this.id){if(feature._prevHighlighter&&feature._prevHighlighter!=this.id){delete feature._lastHighlighter;var control=this.map.getControl(feature._prevHighlighter);if(control){control.highlight(feature);}}else{this.unhighlight(feature);}}}else{this.unselect(feature);}}},highlight:function(feature){var layer=feature.layer;var cont
=this.events.triggerEvent("beforefeaturehighlighted",{feature:feature});if(cont!==false){feature._prevHighlighter=feature._lastHighlighter;feature._lastHighlighter=this.id;var style=this.selectStyle||this.renderIntent;layer.drawFeature(feature,style);this.events.triggerEvent("featurehighlighted",{feature:feature});}},unhighlight:function(feature){var layer=feature.layer;feature._lastHighlighter=feature._prevHighlighter;delete feature._prevHighlighter;layer.drawFeature(feature,feature.style||feature.layer.style||"default");this.events.triggerEvent("featureunhighlighted",{feature:feature});},select:function(feature){var cont=this.onBeforeSelect.call(this.scope,feature);var layer=feature.layer;if(cont!==false){cont=layer.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){layer.selectedFeatures.push(feature);this.highlight(feature);if(!this.handlers.feature.lastFeature){this.handlers.feature.lastFeature=layer.selectedFeatures[0];}
-layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect.call(this.scope,feature);}}},unselect:function(feature){var layer=feature.layer;this.unhighlight(feature);OpenLayers.Util.removeItem(layer.selectedFeatures,feature);layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect.call(this.scope,feature);},selectBox:function(position){if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);if(!this.multipleSelect()){this.unselectAll();}
-var prevMultiple=this.multiple;this.multiple=true;var layers=this.layers||[this.layer];var layer;for(var l=0;l<layers.length;++l){layer=layers[l];for(var i=0,len=layer.features.length;i<len;++i){var feature=layer.features[i];if(!feature.getVisibility()){continue;}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1){if(bounds.toGeometry().intersects(feature.geometry)){if(OpenLayers.Util.indexOf(layer.selectedFeatures,feature)==-1){this.select(feature);}}}}}
-this.multiple=prevMultiple;}},setMap:function(map){this.handlers.feature.setMap(map);if(this.box){this.handlers.box.setMap(map);}
-OpenLayers.Control.prototype.setMap.apply(this,arguments);},setLayer:function(layers){var isActive=this.active;this.unselectAll();this.deactivate();if(this.layers){this.layer.destroy();this.layers=null;}
-this.initLayer(layers);this.handlers.feature.layer=this.layer;if(isActive){this.activate();}},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.observe(document,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0,len=this.KEY_EVENTS.length;i<len;i++){OpenLayers.Event.stopObserving(document,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,standalone:false,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,vertexRenderIntent:null,mode:null,modified:false,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){options=options||{};this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer(null,options.vertexRenderIntent));this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,68];this.mode=OpenLayers.Control.ModifyFeature
.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle,onBeforeSelect:this.beforeSelectFeature,onSelect:this.selectFeature,onUnselect:this.unselectFeature,scope:this};if(this.standalone===false){this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);}
-var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature,pixel){control.dragVertex.apply(control,[feature,pixel]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);},featureCallbacks:{over:function(feature){if(control.standalone!==true||feature._sketch||control.feature===feature){control.dragControl.overFeature.apply(control.dragControl,[feature]);}}}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keydown:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer=null;this.standalone||this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return((this.standalone||this.selectControl.activate())&&this.handlers.keyb
oard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices,{silent:true});this.layer.removeFeatures(this.virtualVertices,{silent:true});this.vertices=[];this.dragControl.deactivate();var feature=this.feature;var valid=feature&&feature.geometry&&feature.layer;if(this.standalone===false){if(valid){this.selectControl.unselect.apply(this.selectControl,[feature]);}
-this.selectControl.deactivate();}else{if(valid){this.unselectFeature(feature);}}
-this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},beforeSelectFeature:function(feature){return this.layer.events.triggerEvent("beforefeaturemodified",{feature:feature});},selectFeature:function(feature){if(!this.standalone||this.beforeSelectFeature(feature)!==false){this.feature=feature;this.modified=false;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);}},unselectFeature:function(feature){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:feature,modified:this.modified});this.modified=false;},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.standalone===false&&this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.standalone||this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex,pixel){this.modified=true;if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}
-this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}}else if(vertex!==this.radiusHandle){this.layer.events.triggerEvent("vertexmodified",{vertex:vertex.geometry,feature:this.feature,pixel:pixel});}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},setFeatureState:function(){if(this.feature.state!=OpenLayers.State.INSERT&&this.feature.state!=OpenLayers.State.DELETE){this.feature.state=OpenLayers.State.UPDATE;}},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices,{silent:true});this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices,{silent:true});this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle],{silent:true});this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle],{silent:true});this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE){if(!(this.mode&OpenLayers.Control.ModifyFeature.RESIZE)){this.collectVertices();}}}},handleKeypress:function(evt){var code=evt.keyCode;if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.events.triggerEvent("vertexremoved",{vertex:vertex.geometry,feature:this.feature,pixel:evt.xy});this.layer.drawFeature(this.feature,this.standalone?undefined:this.selectControl.renderIntent);this.resetVertices();this.setFeatureState();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component,l
en;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);vertex._sketch=true;vertex.renderIntent=control.vertexRenderIntent;control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0,len=geometry.components.length;i<len-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;point._sketch=true;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.virtualVertices,{silent:true});this.layer.addFeatures(this.vertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};origin._sketch=true;this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&O
penLayers.Control.ModifyFeature.RESIZE);var reshape=(this.mode&OpenLayers.Control.ModifyFeature.RESHAPE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var scale,ratio;if(reshape){scale=dy1/dy0;ratio=(dx1/dx0)/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-geometry.resize(scale,originGeometry,ratio);}};radius._sketch=true;this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.standalone||this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Layer.XYZ=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,sphericalMercator:false,zoomOffset:0,serverResolutions:null,initialize:function(name,url,options){if(options&&options.sphericalMercator||this.sphericalMercator){options=OpenLayers.Util.extend({maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),maxResolution:156543.03390625,numZoomLevels:19,units:"m",projection:"EPSG:9009
13"},options);}
-url=url||this.url;name=name||this.name;var newArguments=[name,url,{},options];OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.XYZ(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var xyz=this.getXYZ(bounds);var url=this.url;if(url instanceof Array){var s=''+xyz.x+xyz.y+xyz.z;url=this.selectUrl(s,url);}
-return OpenLayers.String.format(url,xyz);},getXYZ:function(bounds){var res=this.map.getResolution();var x=Math.round((bounds.left-this.maxExtent.left)/(res*this.tileSize.w));var y=Math.round((this.maxExtent.top-bounds.top)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;return{'x':x,'y':y,'z':z};},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.XYZ"});OpenLayers.Layer.OSM=OpenLayers.Class(OpenLayers.Layer.XYZ,{name:"OpenStreetMap",attribution:"Data CC-By-SA by <a href='http://openstreetmap.org/'>OpenStreetMap</a>",sphericalMercator:true,url:'http://tile.openstreetmap.org/${z}/${x}/${y}.png',clone:function(o
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.OSM"});OpenLayers.Layer.Bing=OpenLayers.Class(OpenLayers.Layer.XYZ,{attributionTemplate:'<span class="olBingAttribution ${type}">'+'<div><a target="_blank" href="http://www.bing.com/maps/">'+'<img src="${logo}"></img></div></a>${copyrights}'+'<a style="white-space: nowrap" target="_blank" '+'href="http://www.microsoft.com/maps/product/terms.html">'+'Terms of Use</a></span>',metadata:null,type:"Road",metadataParams:null,initialize:function(options){options=OpenLayers.Util.applyDefaults({restrictedMinZoom:1,sphericalMercator:true},options);var name=options.name||"Bing "+(options.type||this.type);var newArgs=[name,null,options];OpenLayers.Layer.XYZ.prototype.initialize.apply(this,newArgs);this.loadMetadata();},loadMetadata:function(){this._callbackId="_callback_"+this.id.replace(/\./g,"_");window[this._callbackId]=OpenLayers.Function.bind(OpenLayers.Layer.Bing.processMetadata,th
is);var params=OpenLayers.Util.applyDefaults({key:this.key,jsonp:this._callbackId,include:"ImageryProviders"},this.metadataParams);var url="http://dev.virtualearth.net/REST/v1/Imagery/Metadata/"+
-this.type+"?"+OpenLayers.Util.getParameterString(params);var script=document.createElement("script");script.type="text/javascript";script.src=url;script.id=this._callbackId;document.getElementsByTagName("head")[0].appendChild(script);},initLayer:function(){var res=this.metadata.resourceSets[0].resources[0];var url=res.imageUrl.replace("{quadkey}","${quadkey}");this.url=[];for(var i=0;i<res.imageUrlSubdomains.length;++i){this.url.push(url.replace("{subdomain}",res.imageUrlSubdomains[i]));};this.addOptions({restrictedMinZoom:res.zoomMin,numZoomLevels:res.zoomMax+1});this.updateAttribution();this.redraw();},getURL:function(bounds){if(!this.url){return OpenLayers.Util.getImagesLocation()+"blank.gif";}
-var xyz=this.getXYZ(bounds),x=xyz.x,y=xyz.y,z=xyz.z;var quadDigits=[];for(var i=z;i>0;--i){var digit='0';var mask=1<<(i-1);if((x&mask)!=0){digit++;}
-if((y&mask)!=0){digit++;digit++;}
-quadDigits.push(digit);}
-var quadKey=quadDigits.join("");var url=this.selectUrl(''+x+y+z,this.url);return OpenLayers.String.format(url,{'quadkey':quadKey});},updateAttribution:function(){var metadata=this.metadata;if(!metadata||!this.map||!this.map.center){return;}
-var res=metadata.resourceSets[0].resources[0];var extent=this.map.getExtent().transform(this.map.getProjectionObject(),new OpenLayers.Projection("EPSG:4326"));var providers=res.imageryProviders,zoom=this.map.getZoom()+1,copyrights="",provider,i,ii,j,jj,bbox,coverage;for(i=0,ii=providers.length;i<ii;++i){provider=providers[i];for(j=0,jj=provider.coverageAreas.length;j<jj;++j){coverage=provider.coverageAreas[j];bbox=OpenLayers.Bounds.fromArray(coverage.bbox);if(extent.intersectsBounds(bbox)&&zoom<=coverage.zoomMax&&zoom>=coverage.zoomMin){copyrights+=provider.attribution+" ";}}}
-this.attribution=OpenLayers.String.format(this.attributionTemplate,{type:this.type.toLowerCase(),logo:metadata.brandLogoUri,copyrights:copyrights});this.map&&this.map.events.triggerEvent("changelayer",{layer:this});},setMap:function(){OpenLayers.Layer.XYZ.prototype.setMap.apply(this,arguments);this.updateAttribution();this.map.events.register("moveend",this,this.updateAttribution);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Bing(this.options);}
-obj=OpenLayers.Layer.XYZ.prototype.clone.apply(this,[obj]);return obj;},destroy:function(){this.map&&this.map.events.unregister("moveend",this,this.updateAttribution);OpenLayers.Layer.XYZ.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.Bing"});OpenLayers.Layer.Bing.processMetadata=function(metadata){this.metadata=metadata;this.initLayer();var script=document.getElementById(this._callbackId);script.parentNode.removeChild(script);window[this._callbackId]=undefined;delete this._callbackId;};OpenLayers.Format.SOSGetFeatureOfInterest=OpenLayers.Class(OpenLayers.Format.XML,{VERSION:"1.0.0",namespaces:{sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",sa:"http://www.opengis.net/sampling/1.0",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosAll.xsd",defaultPrefix:"sos",regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\
s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var info={features:[]};this.readNode(data,info);var features=[];for(var i=0,len=info.features.length;i<len;i++){var container=info.features[i];if(this.internalProjection&&this.externalProjection&&container.components[0]){container.components[0].transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(container.components[0],container.attributes);features.push(feature);}
-return features;},readers:{"sa":{"SamplingPoint":function(node,obj){if(!obj.attributes){var feature={attributes:{}};obj.features.push(feature);obj=feature;}
-obj.attributes.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"position":function(node,obj){this.readChildNodes(node,obj);}},"gml":OpenLayers.Util.applyDefaults({"FeatureCollection":function(node,obj){this.readChildNodes(node,obj);},"featureMember":function(node,obj){var feature={attributes:{}};obj.features.push(feature);this.readChildNodes(node,feature);},"name":function(node,obj){obj.attributes.name=this.getChildValue(node);},"pos":function(node,obj){if(!this.externalProjection){this.externalProjection=new OpenLayers.Projection(node.getAttribute("srsName"));}
-OpenLayers.Format.GML.v3.prototype.readers.gml.pos.apply(this,[node,obj]);}},OpenLayers.Format.GML.v3.prototype.readers.gml)},writers:{"sos":{"GetFeatureOfInterest":function(options){var node=this.createElementNSPlus("GetFeatureOfInterest",{attributes:{version:this.VERSION,service:'SOS',"xsi:schemaLocation":this.schemaLocation}});for(var i=0,len=options.fois.length;i<len;i++){this.writeNode("FeatureOfInterestId",{foi:options.fois[i]},node);}
-return node;},"FeatureOfInterestId":function(options){var node=this.createElementNSPlus("FeatureOfInterestId",{value:options.foi});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetFeatureOfInterest"});OpenLayers.Format.SOSGetObservation=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ows:"http://www.opengis.net/ows",gml:"http://www.opengis.net/gml",sos:"http://www.opengis.net/sos/1.0",ogc:"http://www.opengis.net/ogc",om:"http://www.opengis.net/om/1.0",sa:"http://www.opengis.net/sampling/1.0",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sos/1.0 http://schemas.opengis.net/sos/1.0.0/sosGetObservation.xsd",defaultPrefix:"sos",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.
-var info={measurements:[],observations:[]};this.readNode(data,info);return info;},write:function(options){var node=this.writeNode("sos:GetObservation",options);node.setAttribute("xmlns:om",this.namespaces.om);node.setAttribute("xmlns:ogc",this.namespaces.ogc);this.setAttributeNS(node,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},readers:{"om":{"ObservationCollection":function(node,obj){obj.id=this.getAttributeNS(node,this.namespaces.gml,"id");this.readChildNodes(node,obj);},"member":function(node,observationCollection){this.readChildNodes(node,observationCollection);},"Measurement":function(node,observationCollection){var measurement={};observationCollection.measurements.push(measurement);this.readChildNodes(node,measurement);},"Observation":function(node,observationCollection){var observation={};observationCollection.observations.push(observation);this.readChildNodes(node,observation);},"sampl
ingTime":function(node,measurement){var samplingTime={};measurement.samplingTime=samplingTime;this.readChildNodes(node,samplingTime);},"observedProperty":function(node,measurement){measurement.observedProperty=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"procedure":function(node,measurement){measurement.procedure=this.getAttributeNS(node,this.namespaces.xlink,"href");this.readChildNodes(node,measurement);},"featureOfInterest":function(node,observation){var foi={features:[]};observation.fois=[];observation.fois.push(foi);this.readChildNodes(node,foi);var features=[];for(var i=0,len=foi.features.length;i<len;i++){var feature=foi.features[i];features.push(new OpenLayers.Feature.Vector(feature.components[0],feature.attributes));}
-foi.features=features;},"result":function(node,measurement){var result={};measurement.result=result;if(this.getChildValue(node)!==''){result.value=this.getChildValue(node);result.uom=node.getAttribute("uom");}else{this.readChildNodes(node,result);}}},"sa":OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.sa,"gml":OpenLayers.Util.applyDefaults({"TimeInstant":function(node,samplingTime){var timeInstant={};samplingTime.timeInstant=timeInstant;this.readChildNodes(node,timeInstant);},"timePosition":function(node,timeInstant){timeInstant.timePosition=this.getChildValue(node);}},OpenLayers.Format.SOSGetFeatureOfInterest.prototype.readers.gml)},writers:{"sos":{"GetObservation":function(options){var node=this.createElementNSPlus("GetObservation",{attributes:{version:this.VERSION,service:'SOS'}});this.writeNode("offering",options,node);if(options.eventTime){this.writeNode("eventTime",options,node);}
-for(var procedure in options.procedures){this.writeNode("procedure",options.procedures[procedure],node);}
-for(var observedProperty in options.observedProperties){this.writeNode("observedProperty",options.observedProperties[observedProperty],node);}
-if(options.foi){this.writeNode("featureOfInterest",options.foi,node);}
-this.writeNode("responseFormat",options,node);if(options.resultModel){this.writeNode("resultModel",options,node);}
-if(options.responseMode){this.writeNode("responseMode",options,node);}
-return node;},"featureOfInterest":function(foi){var node=this.createElementNSPlus("featureOfInterest");this.writeNode("ObjectID",foi.objectId,node);return node;},"ObjectID":function(options){return this.createElementNSPlus("ObjectID",{value:options});},"responseFormat":function(options){return this.createElementNSPlus("responseFormat",{value:options.responseFormat});},"procedure":function(procedure){return this.createElementNSPlus("procedure",{value:procedure});},"offering":function(options){return this.createElementNSPlus("offering",{value:options.offering});},"observedProperty":function(observedProperty){return this.createElementNSPlus("observedProperty",{value:observedProperty});},"eventTime":function(options){var node=this.createElementNSPlus("eventTime");if(options.eventTime==='latest'){this.writeNode("ogc:TM_Equals",options,node);}
-return node;},"resultModel":function(options){return this.createElementNSPlus("resultModel",{value:options.resultModel});},"responseMode":function(options){return this.createElementNSPlus("responseMode",{value:options.responseMode});}},"ogc":{"TM_Equals":function(options){var node=this.createElementNSPlus("ogc:TM_Equals");this.writeNode("ogc:PropertyName",{property:"urn:ogc:data:time:iso8601"},node);if(options.eventTime==='latest'){this.writeNode("gml:TimeInstant",{value:'latest'},node);}
-return node;},"PropertyName":function(options){return this.createElementNSPlus("ogc:PropertyName",{value:options.property});}},"gml":{"TimeInstant":function(options){var node=this.createElementNSPlus("gml:TimeInstant");this.writeNode("gml:timePosition",options,node);return node;},"timePosition":function(options){var node=this.createElementNSPlus("gml:timePosition",{value:options.value});return node;}}},CLASS_NAME:"OpenLayers.Format.SOSGetObservation"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,interval:0,delta:0,cumulative:true,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
-var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
-overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
-if(!overLayerDiv){for(var i=0,len=this.map.layers.length;i<len;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
-overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
-if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-this.delta=this.delta+delta;if(this.interval){window.clearTimeout(this._timeoutId);this._timeoutId=window.setTimeout(OpenLayers.Function.bind(function(){this.wheelZoom(e);},this),this.interval);}else{this.wheelZoom(e);}}
-OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=this.delta;this.delta=0;if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
-if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,this.cumulative?delta:-1]);}else{this.callback("up",[e,this.cumulative?delta:1]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Format.WFST.v1_0_0=OpenLayers.Class(OpenLayers.For
mat.Filter.v1_0_0,OpenLayers.Format.WFST.v1,{version:"1.0.0",srsNameInQuery:false,schemaLocations:{"wfs":"http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd"},initialize:function(options){OpenLayers.Format.Filter.v1_0_0.prototype.initialize.apply(this,[options]);OpenLayers.Format.WFST.v1.prototype.initialize.apply(this,[options]);},readers:{"wfs":OpenLayers.Util.applyDefaults({"WFS_TransactionResponse":function(node,obj){obj.insertIds=[];obj.success=false;this.readChildNodes(node,obj);},"InsertResult":function(node,container){var obj={fids:[]};this.readChildNodes(node,obj);container.insertIds.push(obj.fids[0]);},"TransactionResult":function(node,obj){this.readChildNodes(node,obj);},"Status":function(node,obj){this.readChildNodes(node,obj);},"SUCCESS":function(node,obj){obj.success=true;}},OpenLayers.Format.WFST.v1.prototype.readers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.readers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.readers["feature"],"ogc":OpenL
ayers.Format.Filter.v1_0_0.prototype.readers["ogc"]},writers:{"wfs":OpenLayers.Util.applyDefaults({"Query":function(options){options=OpenLayers.Util.extend({featureNS:this.featureNS,featurePrefix:this.featurePrefix,featureType:this.featureType,srsName:this.srsName,srsNameInQuery:this.srsNameInQuery},options);var node=this.createElementNSPlus("wfs:Query",{attributes:{typeName:(options.featureNS?options.featurePrefix+":":"")+
-options.featureType}});if(options.srsNameInQuery&&options.srsName){node.setAttribute("srsName",options.srsName);}
-if(options.featureNS){node.setAttribute("xmlns:"+options.featurePrefix,options.featureNS);}
-if(options.propertyNames){for(var i=0,len=options.propertyNames.length;i<len;i++){this.writeNode("ogc:PropertyName",{property:options.propertyNames[i]},node);}}
-if(options.filter){this.setFilterProperty(options.filter);this.writeNode("ogc:Filter",options.filter,node);}
-return node;}},OpenLayers.Format.WFST.v1.prototype.writers["wfs"]),"gml":OpenLayers.Format.GML.v2.prototype.writers["gml"],"feature":OpenLayers.Format.GML.v2.prototype.writers["feature"],"ogc":OpenLayers.Format.Filter.v1_0_0.prototype.writers["ogc"]},CLASS_NAME:"OpenLayers.Format.WFST.v1_0_0"});OpenLayers.ElementsIndexer=OpenLayers.Class({maxZIndex:null,order:null,indices:null,compare:null,initialize:function(yOrdering){this.compare=yOrdering?OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_Y_ORDER:OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER_DRAWING_ORDER;this.order=[];this.indices={};this.maxZIndex=0;},insert:function(newNode){if(this.exists(newNode)){this.remove(newNode);}
-var nodeId=newNode.id;this.determineZIndex(newNode);var leftIndex=-1;var rightIndex=this.order.length;var middle;while(rightIndex-leftIndex>1){middle=parseInt((leftIndex+rightIndex)/2);var placement=this.compare(this,newNode,OpenLayers.Util.getElement(this.order[middle]));if(placement>0){leftIndex=middle;}else{rightIndex=middle;}}
-this.order.splice(rightIndex,0,nodeId);this.indices[nodeId]=this.getZIndex(newNode);return this.getNextElement(rightIndex);},remove:function(node){var nodeId=node.id;var arrayIndex=OpenLayers.Util.indexOf(this.order,nodeId);if(arrayIndex>=0){this.order.splice(arrayIndex,1);delete this.indices[nodeId];if(this.order.length>0){var lastId=this.order[this.order.length-1];this.maxZIndex=this.indices[lastId];}else{this.maxZIndex=0;}}},clear:function(){this.order=[];this.indices={};this.maxZIndex=0;},exists:function(node){return(this.indices[node.id]!=null);},getZIndex:function(node){return node._style.graphicZIndex;},determineZIndex:function(node){var zIndex=node._style.graphicZIndex;if(zIndex==null){zIndex=this.maxZIndex;node._style.graphicZIndex=zIndex;}else if(zIndex>this.maxZIndex){this.maxZIndex=zIndex;}},getNextElement:function(index){var nextIndex=index+1;if(nextIndex<this.order.length){var nextElement=OpenLayers.Util.getElement(this.order[nextIndex]);if(nextElement==undefin
ed){nextElement=this.getNextElement(nextIndex);}
-return nextElement;}else{return null;}},CLASS_NAME:"OpenLayers.ElementsIndexer"});OpenLayers.ElementsIndexer.IndexingMethods={Z_ORDER:function(indexer,newNode,nextNode){var newZIndex=indexer.getZIndex(newNode);var returnVal=0;if(nextNode){var nextZIndex=indexer.getZIndex(nextNode);returnVal=newZIndex-nextZIndex;}
-return returnVal;},Z_ORDER_DRAWING_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal==0){returnVal=1;}
-return returnVal;},Z_ORDER_Y_ORDER:function(indexer,newNode,nextNode){var returnVal=OpenLayers.ElementsIndexer.IndexingMethods.Z_ORDER(indexer,newNode,nextNode);if(nextNode&&returnVal===0){var result=nextNode._boundsBottom-newNode._boundsBottom;returnVal=(result===0)?1:result;}
-return returnVal;}};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,vectorRoot:null,textRoot:null,xmlns:null,indexer:null,BACKGROUND_ID_SUFFIX:"_background",LABEL_ID_SUFFIX:"_label",initialize:function(containerID,options){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot("_root");this.vectorRoot=this.createRoot("_vroot");this.textRoot=this.createRoot("_troot");this.root.appendChild(this.vectorRoot);this.root.appendChild(this.textRoot);this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);if(options&&(options.zIndexing||options.yOrdering)){this.indexer=new OpenLayers.ElementsIndexer(options.yOrdering);}},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){var child;var root=this.vectorRoot;if(root){while(c
hild=root.firstChild){root.removeChild(child);}}
-root=this.textRoot;if(root){while(child=root.firstChild){root.removeChild(child);}}
-if(this.indexer){this.indexer.clear();}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;var rendered=true;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0,len=geometry.components.length;i<len;i++){rendered=this.drawGeometry(geometry.components[i],style,featureId)&&rendered;}
-return rendered;};rendered=false;var removeBackground=false;if(style.display!="none"){if(style.backgroundGraphic){this.redrawBackgroundNode(geometry.id,geometry,style,featureId);}else{removeBackground=true;}
-rendered=this.redrawNode(geometry.id,geometry,style,featureId);}
-if(rendered==false){var node=document.getElementById(geometry.id);if(node){if(node._style.backgroundGraphic){removeBackground=true;}
-node.parentNode.removeChild(node);}}
-if(removeBackground){var node=document.getElementById(geometry.id+this.BACKGROUND_ID_SUFFIX);if(node){node.parentNode.removeChild(node);}}
-return rendered;},redrawNode:function(id,geometry,style,featureId){style=this.applyDefaultSymbolizer(style);var node=this.nodeFactory(id,this.getNodeType(geometry,style));node._featureId=featureId;node._boundsBottom=geometry.getBounds().bottom;node._geometryClass=geometry.CLASS_NAME;node._style=style;var drawResult=this.drawGeometryNode(node,geometry,style);if(drawResult===false){return false;}
-node=drawResult.node;if(this.indexer){var insert=this.indexer.insert(node);if(insert){this.vectorRoot.insertBefore(node,insert);}else{this.vectorRoot.appendChild(node);}}else{if(node.parentNode!==this.vectorRoot){this.vectorRoot.appendChild(node);}}
-this.postDraw(node);return drawResult.complete;},redrawBackgroundNode:function(id,geometry,style,featureId){var backgroundStyle=OpenLayers.Util.extend({},style);backgroundStyle.externalGraphic=backgroundStyle.backgroundGraphic;backgroundStyle.graphicXOffset=backgroundStyle.backgroundXOffset;backgroundStyle.graphicYOffset=backgroundStyle.backgroundYOffset;backgroundStyle.graphicZIndex=backgroundStyle.backgroundGraphicZIndex;backgroundStyle.graphicWidth=backgroundStyle.backgroundWidth||backgroundStyle.graphicWidth;backgroundStyle.graphicHeight=backgroundStyle.backgroundHeight||backgroundStyle.graphicHeight;backgroundStyle.backgroundGraphic=null;backgroundStyle.backgroundXOffset=null;backgroundStyle.backgroundYOffset=null;backgroundStyle.backgroundGraphicZIndex=null;return this.redrawNode(id+this.BACKGROUND_ID_SUFFIX,geometry,backgroundStyle,null);},drawGeometryNode:function(node,geometry,style){style=style||node._style;var options={'isFilled':style.fill===undefined?true:style.
fill,'isStroked':style.stroke===undefined?!!style.strokeWidth:style.stroke};var drawn;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.graphic===false){options.isFilled=false;options.isStroked=false;}
-drawn=this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;drawn=this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":drawn=this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":drawn=this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":drawn=this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":drawn=this.drawRectangle(node,geometry);break;default:break;}
-node._options=options;if(drawn!=false){return{node:this.setStyle(node,style,options,geometry),complete:drawn};}else{return false;}},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},removeText:function(featureId){var label=document.getElementById(featureId+this.LABEL_ID_SUFFIX);if(label){this.textRoot.removeChild(label);}},getFeatureIdFromEvent:function(evt){var target=evt.target;var useElement=target&&target.correspondingUseElement;var node=useElement?useElement:(target||evt.srcElement);var featureId=node._featureId;return featureId;},eraseGeometry:function(geometry,featureId){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.G
eometry.MultiPolygon")||(geometry.CLASS_NAME=="OpenLayers.Geometry.Collection")){for(var i=0,len=geometry.components.length;i<len;i++){this.eraseGeometry(geometry.components[i],featureId);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){if(element.geometry){element.geometry.destroy();element.geometry=null;}
-element.parentNode.removeChild(element);if(this.indexer){this.indexer.remove(element);}
-if(element._style.backgroundGraphic){var backgroundId=geometry.id+this.BACKGROUND_ID_SUFFIX;var bElem=OpenLayers.Util.getElement(backgroundId);if(bElem&&bElem.parentNode){bElem.parentNode.removeChild(bElem);}}}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
-return node;},nodeTypeCompare:function(node,type){},createNode:function(type,id){},moveRoot:function(renderer){var root=this.root;if(renderer.root.parentNode==this.rendererRoot){root=renderer.root;}
-root.parentNode.removeChild(root);renderer.rendererRoot.appendChild(root);},getRenderLayerId:function(){return this.root.parentNode.parentNode.id;},isComplexSymbol:function(graphicName){return(graphicName!="circle")&&!!graphicName;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Renderer.symbol={"star":[350,75,379,161,469,161,397,215,423,301,350,250,277,301,303,215,231,161,321,161,350,75],"cross":[4,0,6,0,6,4,10,4,10,6,6,6,6,10,4,10,4,6,0,6,0,4,4,4,4,0],"x":[0,0,25,0,50,35,75,0,100,0,65,50,100,100,75,100,50,65,25,100,0,100,35,50,0,0],"square":[0,0,0,1,1,1,1,0,0,0],"triangle":[0,10,10,10,5,0,0,10]};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},getParameters:function(url){url=url||window.location.href;var parameters=OpenLayers.Util.getParameters(url);var index=url.indexOf('#');if(index>0){url='?'+url.s
ubstring(index+1,url.length);OpenLayers.Util.extend(parameters,OpenLayers.Util.getParameters(url));}
-return parameters;},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){var args=this.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
-if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
-this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
-this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0,len=this.layers.length;i<len;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{argParserClass:OpenLayers.Control.ArgParser,element:null,anchor:false,base:'',displayProjection:null,initialize:function(element,base,options){if(element!==null&&typeof element=='object'&&!OpenLayers.Util.isElement(element)){options=element;this.base=document.location.href;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(this.element!=null){this.element=OpenLayers.Util.getElement(this.element);}}
-else{OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;}},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
-this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0,len=this.map.controls.length;i<len;i++){var control=this.map.controls[i];if(control.CLASS_NAME==this.argParserClass.CLASS_NAME){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){this.map.addControl(new this.argParserClass({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element&&!this.anchor){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
-this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});this.updateLink();return this.div;},updateLink:function(){var separator=this.anchor?'#':'?';var href=this.base;if(href.indexOf(separator)!=-1){href=href.substring(0,href.indexOf(separator));}
-href+=separator+OpenLayers.Util.getParameterString(this.createParams());if(this.anchor&&!this.element){window.location.href=href;}
-else{this.element.href=href;}},createParams:function(center,zoom,layers){center=center||this.map.getCenter();var params=OpenLayers.Util.getParameters(this.base);if(center){params.zoom=zoom||this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
-params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;layers=layers||this.map.layers;params.layers='';for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}}
-return params;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,serverResolutions:null,zoomOffset:0,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom()+this.zoomOffset;var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-return url+path;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Strategy.Fixed=OpenLayers.Class(OpenLayers.Strategy,{preload:false,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},destroy:function(){OpenLayers.Strategy.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Strategy.prototype.activate.apply(this,arguments)){this.layer.events.on({"refresh":this.load,scope:this});if(this.layer.visibility==true||this.preload){this.load();}else{this.layer.events.on({"visibilitychanged":this.load,scope:this});}
-return true;}
-return false;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"refresh":this.load,"visibilitychanged":this.load,scope:this});}
-return deactivated;},load:function(options){var layer=this.layer;layer.events.triggerEvent("loadstart");layer.protocol.read(OpenLayers.Util.applyDefaults({callback:OpenLayers.Function.bind(this.merge,this,layer.map.getProjectionObject()),filter:layer.filter},options));layer.events.un({"visibilitychanged":this.load,scope:this});},merge:function(mapProjection,resp){var layer=this.layer;layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){if(!mapProjection.equals(layer.projection)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(layer.projection,mapProjection);}}}
-layer.addFeatures(features);}
-layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.Fixed"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserve
r);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);}
-document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
-this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();}
-this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
-this.removeZoomBox();}},removeZoomBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
-elem=elem.parentNode;}
-if(inMap){var delta=0;if(!e){e=window.event;}
-if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
-OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
-if(direction){this.direction=direction;}
-this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
-OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util
.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
-OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
-this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
-this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
-document.onselectstart=OpenLayers.Function.False;OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
-if(this.mode=="measure"&&mode!="measure"){for(var i=0,len=this.measureDivs.length;i<len;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
-this.measureDivs=[];this.measureStart=null;}
-this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
-switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
-break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
-this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
-var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0,len=pointFeatures.length;i<len;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
-if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
-startPoint=endPoint;}
-this.addFeatures(lines);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Protocol.WFS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.WFS.DEFAULTS);var cls=OpenLayers.Protocol.WFS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported WFS version: "+options.version;}
-return new cls(options);};OpenLayers.Protocol.WFS.fromWMSLayer=function(layer,options){var typeName,featurePrefix;var param=layer.params["LAYERS"];var parts=(param instanceof Array?param[0]:param).split(":");if(parts.length>1){featurePrefix=parts[0];}
-typeName=parts.pop();var protocolOptions={url:layer.url,featureType:typeName,featurePrefix:featurePrefix,srsName:layer.projection&&layer.projection.getCode()||layer.map&&layer.map.getProjectionObject().getCode(),version:"1.1.0"};return new OpenLayers.Protocol.WFS(OpenLayers.Util.applyDefaults(options,protocolOptions));};OpenLayers.Protocol.WFS.DEFAULTS={"version":"1.0.0"};OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0,len=this.markers.length;i<len;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged
||!this.drawn){for(var i=0,len=this.markers.length;i<len;i++){this.drawMarker(this.markers[i]);}
-this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
-if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);marker.erase();}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{if(!marker.isDrawn()){var markerImg=marker.draw(px);this.div.appendChild(markerImg);}else if(marker.icon){marker.icon.moveTo(px);}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0,len=this.markers.length;i<len;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Control.Pan=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,slideRatio:null,direction:null,type:OpenLayers.Control.TYPE_BUTTON,initialize:function(direction,options){this.direction=direction;this.CLASS_NAME+=this.direction;OpenLayers.Control.prototype.initialize.apply(this,[options]);},trigger:function(){var getSlideFactor=OpenLayers.Function.bind(function(dim){return this.slideRatio?this.map.getSize()[dim]*this.slideRatio:this.slideFactor;},this);switch(this.direction){case OpenLayers.Control.Pan.NORTH:this.map.pan(0,-getSlideFactor("h"));break;case OpenLayers.Control.Pan.SOUTH:this.map.pan(0,getSlideFactor("h"));break;case OpenLayers.Control.Pan.WEST:this.map.pan(-getSlideFactor("w"),0);break;case OpenLayers.Control.Pan.EAST:this.map.pan(getSlideFactor("w"),0);break;}},CLASS_NAME:"OpenLayers.Control.Pan"});OpenLayers.Control.Pan.NORTH="North";OpenLayers.Control.Pan.SOUTH="South";OpenLayers.Control.Pa
n.EAST="East";OpenLayers.Control.Pan.WEST="West";OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,noMagic:false,yx:{'EPSG:4326':true},initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);if(parseFloat(params.VERSION)>=1.3&&!params.EXCEPTIONS){params.EXCEPTIONS="INIMAGE";}
-newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(!this.noMagic&&this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},reverseAxisOrder:function(){return(parseFloat(this.params.VERSION)>=1.3&&!!this.yx[this.map.getProjectionObject().getCode()]);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={};var reverseAxisOrder=this.reverseAxisOrder();newParams.BBOX=this.encodeBBOX?bounds.toBBOX(null,reverseAxisOrder):bounds.toArray(reverseAxisOrder);newParams.WIDTH=imageSize.w;newParams.HEIGHT=imageSize.h;var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,this.tileOptions);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var mapProjection=
this.map.getProjectionObject();var projectionCode=this.projection.equals(mapProjection)?this.projection.getCode():mapProjection.getCode();var value=(projectionCode=="none")?null:projectionCode;if(parseFloat(this.params.VERSION)>=1.3){this.params.CRS=value;}else{this.params.SRS=value;}
-return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Format.ArcXML.Features=OpenLayers.Class(OpenLayers.Format.XML,{initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var axl=new OpenLayers.Format.ArcXML();var parsed=axl.read(data);return parsed.features.feature;}});OpenLayers.Control.Snapping=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesnap","snap","unsnap"],DEFAULTS:{tolerance:10,node:true,edge:true,vertex:true},greedy:true,precedence:["node","vertex","edge"],resolution:null,geoToleranceCache:null,layer:null,feature:null,point:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype
.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.layer){this.setLayer(this.options.layer);}
-var defaults=OpenLayers.Util.extend({},this.options.defaults);this.defaults=OpenLayers.Util.applyDefaults(defaults,this.DEFAULTS);this.setTargets(this.options.targets);if(this.targets.length===0&&this.layer){this.addTargetLayer(this.layer);}
-this.geoToleranceCache={};},setLayer:function(layer){if(this.active){this.deactivate();this.layer=layer;this.activate();}else{this.layer=layer;}},setTargets:function(targets){this.targets=[];if(targets&&targets.length){var target;for(var i=0,len=targets.length;i<len;++i){target=targets[i];if(target instanceof OpenLayers.Layer.Vector){this.addTargetLayer(target);}else{this.addTarget(target);}}}},addTargetLayer:function(layer){this.addTarget({layer:layer});},addTarget:function(target){target=OpenLayers.Util.applyDefaults(target,this.defaults);target.nodeTolerance=target.nodeTolerance||target.tolerance;target.vertexTolerance=target.vertexTolerance||target.tolerance;target.edgeTolerance=target.edgeTolerance||target.tolerance;this.targets.push(target);},removeTargetLayer:function(layer){var target;for(var i=this.targets.length-1;i>=0;--i){target=this.targets[i];if(target.layer===layer){this.removeTarget(target);}}},removeTarget:function(target){return OpenLayers.Util.removeItem(t
his.targets,target);},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(this.layer&&this.layer.events){this.layer.events.on({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.layer&&this.layer.events){this.layer.events.un({sketchstarted:this.onSketchModified,sketchmodified:this.onSketchModified,vertexmodified:this.onVertexModified,scope:this});}}
-this.feature=null;this.point=null;return deactivated;},onSketchModified:function(event){this.feature=event.feature;this.considerSnapping(event.vertex,event.vertex);},onVertexModified:function(event){this.feature=event.feature;var loc=this.layer.map.getLonLatFromViewPortPx(event.pixel);this.considerSnapping(event.vertex,new OpenLayers.Geometry.Point(loc.lon,loc.lat));},considerSnapping:function(point,loc){var best={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY,x:null,y:null};var snapped=false;var result,target;for(var i=0,len=this.targets.length;i<len;++i){target=this.targets[i];result=this.testTarget(target,loc);if(result){if(this.greedy){best=result;best.target=target;snapped=true;break;}else{if((result.rank<best.rank)||(result.rank===best.rank&&result.dist<best.dist)){best=result;best.target=target;snapped=true;}}}}
-if(snapped){var proceed=this.events.triggerEvent("beforesnap",{point:point,x:best.x,y:best.y,distance:best.dist,layer:best.target.layer,snapType:this.precedence[best.rank]});if(proceed!==false){point.x=best.x;point.y=best.y;this.point=point;this.events.triggerEvent("snap",{point:point,snapType:this.precedence[best.rank],layer:best.target.layer,distance:best.dist});}else{snapped=false;}}
-if(this.point&&!snapped){point.x=loc.x;point.y=loc.y;this.point=null;this.events.triggerEvent("unsnap",{point:point});}},testTarget:function(target,loc){var resolution=this.layer.map.getResolution();if("minResolution"in target){if(resolution<target.minResolution){return null;}}
-if("maxResolution"in target){if(resolution>=target.maxResolution){return null;}}
-var tolerance={node:this.getGeoTolerance(target.nodeTolerance,resolution),vertex:this.getGeoTolerance(target.vertexTolerance,resolution),edge:this.getGeoTolerance(target.edgeTolerance,resolution)};var maxTolerance=Math.max(tolerance.node,tolerance.vertex,tolerance.edge);var result={rank:Number.POSITIVE_INFINITY,dist:Number.POSITIVE_INFINITY};var eligible=false;var features=target.layer.features;var feature,type,vertices,vertex,closest,dist,found;var numTypes=this.precedence.length;var ll=new OpenLayers.LonLat(loc.x,loc.y);for(var i=0,len=features.length;i<len;++i){feature=features[i];if(feature!==this.feature&&!feature._sketch&&feature.state!==OpenLayers.State.DELETE&&(!target.filter||target.filter.evaluate(feature.attributes))){if(feature.atPoint(ll,maxTolerance,maxTolerance)){for(var j=0,stop=Math.min(result.rank+1,numTypes);j<stop;++j){type=this.precedence[j];if(target[type]){if(type==="edge"){closest=feature.geometry.distanceTo(loc,{details:true});dist=closest.distance;i
f(dist<=tolerance[type]&&dist<result.dist){result={rank:j,dist:dist,x:closest.x0,y:closest.y0};eligible=true;break;}}else{vertices=feature.geometry.getVertices(type==="node");found=false;for(var k=0,klen=vertices.length;k<klen;++k){vertex=vertices[k];dist=vertex.distanceTo(loc);if(dist<=tolerance[type]&&(j<result.rank||(j===result.rank&&dist<result.dist))){result={rank:j,dist:dist,x:vertex.x,y:vertex.y};eligible=true;found=true;}}
-if(found){break;}}}}}}}
-return eligible?result:null;},getGeoTolerance:function(tolerance,resolution){if(resolution!==this.resolution){this.resolution=resolution;this.geoToleranceCache={};}
-var geoTolerance=this.geoToleranceCache[tolerance];if(geoTolerance===undefined){geoTolerance=tolerance*resolution;this.geoToleranceCache[tolerance]=geoTolerance;}
-return geoTolerance;},destroy:function(){if(this.active){this.deactivate();}
-delete this.layer;delete this.targets;OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Snapping"});OpenLayers.Format.CSWGetDomain=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Format.CSWGetDomain.DEFAULTS);var cls=OpenLayers.Format.CSWGetDomain["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported CSWGetDomain version: "+options.version;}
-return new cls(options);};OpenLayers.Format.CSWGetDomain.DEFAULTS={"version":"2.0.2"};OpenLayers.Format.CSWGetDomain.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",PropertyName:null,ParameterName:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetDomainResponse":function(node,obj){this.readChildNodes(node,obj);},"DomainValues":function(node,obj){if(!(obj.DomainValues instanceof Array)){obj.DomainValues=[];}
-var attrs=node.attributes;var domainValue={};for(var i=0,len=attrs.length;i<len;++i){domainValue[attrs[i].name]=attrs[i].nodeValue;}
-this.readChildNodes(node,domainValue);obj.DomainValues.push(domainValue);},"PropertyName":function(node,obj){obj.PropertyName=this.getChildValue(node);},"ParameterName":function(node,obj){obj.ParameterName=this.getChildValue(node);},"ListOfValues":function(node,obj){if(!(obj.ListOfValues instanceof Array)){obj.ListOfValues=[];}
-this.readChildNodes(node,obj.ListOfValues);},"Value":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
-value.value=this.getChildValue(node);obj.push({Value:value});},"ConceptualScheme":function(node,obj){obj.ConceptualScheme={};this.readChildNodes(node,obj.ConceptualScheme);},"Name":function(node,obj){obj.Name=this.getChildValue(node);},"Document":function(node,obj){obj.Document=this.getChildValue(node);},"Authority":function(node,obj){obj.Authority=this.getChildValue(node);},"RangeOfValues":function(node,obj){obj.RangeOfValues={};this.readChildNodes(node,obj.RangeOfValues);},"MinValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
-value.value=this.getChildValue(node);obj.MinValue=value;},"MaxValue":function(node,obj){var attrs=node.attributes;var value={};for(var i=0,len=attrs.length;i<len;++i){value[attrs[i].name]=attrs[i].nodeValue;}
-value.value=this.getChildValue(node);obj.MaxValue=value;}}},write:function(options){var node=this.writeNode("csw:GetDomain",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetDomain":function(options){var node=this.createElementNSPlus("csw:GetDomain",{attributes:{service:"CSW",version:this.version}});if(options.PropertyName||this.PropertyName){this.writeNode("csw:PropertyName",options.PropertyName||this.PropertyName,node);}else if(options.ParameterName||this.ParameterName){this.writeNode("csw:ParameterName",options.ParameterName||this.ParameterName,node);}
-this.readChildNodes(node,options);return node;},"PropertyName":function(value){var node=this.createElementNSPlus("csw:PropertyName",{value:value});return node;},"ParameterName":function(value){var node=this.createElementNSPlus("csw:ParameterName",{value:value});return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetDomain.v2_0_2"});OpenLayers.Format.WMSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,profile:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;var profile=this.profile?"_"+this.profile:"";if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMSCapabilities["v"+version.replace(/\./g,"_")+profile];if(!constr){throw"Can't find a WMS capabilities parser for version "+
-version+profile;}
-this.parser=new constr(this.options);}
-var capabilities=this.parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.WMSCapabilities"});OpenLayers.Format.WMSCapabilities.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{wms:"http://www.opengis.net/wms",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"wms",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var capabilities={};this.readNode(data,capabilities);this.postProcessLayers(capabilities);return capabilities;},postProcessLayers:function(capabilities){if(capabilities.capability){capabilities.capability.layers=[];var layers=capabilities.capability.nestedLayers;for(var i=0,len=layers.length;i<len;++i){var layer=layers[i];this.processLayer(capabilities.capability,layer);}}},processLayer:function(capability,layer,parentLayer){if(layer.formats===undefined){layer.formats=capability.request.getmap.formats;}
-if(parentLayer){layer.styles=layer.styles.concat(parentLayer.styles);var attributes=["queryable","cascaded","fixedWidth","fixedHeight","opaque","noSubsets","llbbox","minScale","maxScale","attribution"];var complexAttr=["srs","bbox","dimensions","authorityURLs"];var key;for(var j=0;j<attributes.length;j++){key=attributes[j];if(key in parentLayer){if(layer[key]==null){layer[key]=parentLayer[key];}
-if(layer[key]==null){var intAttr=["cascaded","fixedWidth","fixedHeight"];var boolAttr=["queryable","opaque","noSubsets"];if(OpenLayers.Util.indexOf(intAttr,key)!=-1){layer[key]=0;}
-if(OpenLayers.Util.indexOf(boolAttr,key)!=-1){layer[key]=false;}}}}
-for(var j=0;j<complexAttr.length;j++){key=complexAttr[j];layer[key]=OpenLayers.Util.extend(layer[key],parentLayer[key]);}}
-for(var i=0,len=layer.nestedLayers.length;i<len;i++){var childLayer=layer.nestedLayers[i];this.processLayer(capability,childLayer,layer);}
-if(layer.name){capability.layers.push(layer);}},readers:{"wms":{"Service":function(node,obj){obj.service={};this.readChildNodes(node,obj.service);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj["abstract"]=this.getChildValue(node);},"BoundingBox":function(node,obj){var bbox={};bbox.bbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];var res={x:parseFloat(node.getAttribute("resx")),y:parseFloat(node.getAttribute("resy"))};if(!(isNaN(res.x)&&isNaN(res.y))){bbox.res=res;}
-return bbox;},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"ContactInformation":function(node,obj){obj.contactInformation={};this.readChildNodes(node,obj.contactInformation);},"ContactPersonPrimary":function(node,obj){obj.personPrimary={};this.readChildNodes(node,obj.personPrimary);},"ContactPerson":function(node,obj){obj.person=this.getChildValue(node);},"ContactOrganization":function(node,obj){obj.organization=this.getChildValue(node);},"ContactPosition":function(node,obj){obj.position=this.getChildValue(node);},"ContactAddress":function(node,obj){obj.contactAddress={};this.readChildNodes(node,obj.contactAddress);},"AddressType":function(node,obj){obj.type=this.getChildValue(node);},"Address":function(node,obj){obj.address=this.getChildValue(node);},"City":function(node,obj){obj.city=this.getChildValue(node);},"StateOrProvince":function(node,obj){obj.stateOrProvince=this.getChildValue(node);},"PostCode":function(node
,obj){obj.postcode=this.getChildValue(node);},"Country":function(node,obj){obj.country=this.getChildValue(node);},"ContactVoiceTelephone":function(node,obj){obj.phone=this.getChildValue(node);},"ContactFacsimileTelephone":function(node,obj){obj.fax=this.getChildValue(node);},"ContactElectronicMailAddress":function(node,obj){obj.email=this.getChildValue(node);},"Fees":function(node,obj){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){obj.fees=fees;}},"AccessConstraints":function(node,obj){var constraints=this.getChildValue(node);if(constraints&&constraints.toLowerCase()!="none"){obj.accessConstraints=constraints;}},"Capability":function(node,obj){obj.capability={nestedLayers:[]};this.readChildNodes(node,obj.capability);},"Request":function(node,obj){obj.request={};this.readChildNodes(node,obj.request);},"GetCapabilities":function(node,obj){obj.getcapabilities={formats:[]};this.readChildNodes(node,obj.getcapabilities);},"Format":function(node,obj){if(obj
.formats instanceof Array){obj.formats.push(this.getChildValue(node));}else{obj.format=this.getChildValue(node);}},"DCPType":function(node,obj){this.readChildNodes(node,obj);},"HTTP":function(node,obj){this.readChildNodes(node,obj);},"Get":function(node,obj){this.readChildNodes(node,obj);},"Post":function(node,obj){this.readChildNodes(node,obj);},"GetMap":function(node,obj){obj.getmap={formats:[]};this.readChildNodes(node,obj.getmap);},"GetFeatureInfo":function(node,obj){obj.getfeatureinfo={formats:[]};this.readChildNodes(node,obj.getfeatureinfo);},"Exception":function(node,obj){obj.exception={formats:[]};this.readChildNodes(node,obj.exception);},"Layer":function(node,obj){var attrNode=node.getAttributeNode("queryable");var queryable=(attrNode&&attrNode.specified)?node.getAttribute("queryable"):null;attrNode=node.getAttributeNode("cascaded");var cascaded=(attrNode&&attrNode.specified)?node.getAttribute("cascaded"):null;attrNode=node.getAttributeNode("opaque");var opaque=(att
rNode&&attrNode.specified)?node.getAttribute('opaque'):null;var noSubsets=node.getAttribute('noSubsets');var fixedWidth=node.getAttribute('fixedWidth');var fixedHeight=node.getAttribute('fixedHeight');var layer={nestedLayers:[],styles:[],srs:{},metadataURLs:[],bbox:{},dimensions:{},authorityURLs:{},identifiers:{},keywords:[],queryable:(queryable&&queryable!=="")?(queryable==="1"||queryable==="true"):null,cascaded:(cascaded!==null)?parseInt(cascaded):null,opaque:opaque?(opaque==="1"||opaque==="true"):null,noSubsets:(noSubsets!==null)?(noSubsets==="1"||noSubsets==="true"):null,fixedWidth:(fixedWidth!=null)?parseInt(fixedWidth):null,fixedHeight:(fixedHeight!=null)?parseInt(fixedHeight):null};obj.nestedLayers.push(layer);this.readChildNodes(node,layer);if(layer.name){var parts=layer.name.split(":");if(parts.length>0){layer.prefix=parts[0];}}},"Attribution":function(node,obj){obj.attribution={};this.readChildNodes(node,obj.attribution);},"LogoURL":function(node,obj){obj.logo={wid
th:node.getAttribute("width"),height:node.getAttribute("height")};this.readChildNodes(node,obj.logo);},"Style":function(node,obj){var style={};obj.styles.push(style);this.readChildNodes(node,style);},"LegendURL":function(node,obj){var legend={width:node.getAttribute("width"),height:node.getAttribute("height")};obj.legend=legend;this.readChildNodes(node,legend);},"MetadataURL":function(node,obj){var metadataURL={type:node.getAttribute("type")};obj.metadataURLs.push(metadataURL);this.readChildNodes(node,metadataURL);},"DataURL":function(node,obj){obj.dataURL={};this.readChildNodes(node,obj.dataURL);},"FeatureListURL":function(node,obj){obj.featureListURL={};this.readChildNodes(node,obj.featureListURL);},"AuthorityURL":function(node,obj){var name=node.getAttribute("name");var authority={};this.readChildNodes(node,authority);obj.authorityURLs[name]=authority.href;},"Identifier":function(node,obj){var authority=node.getAttribute("authority");obj.identifiers[authority]=this.getChi
ldValue(node);},"KeywordList":function(node,obj){this.readChildNodes(node,obj);},"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1"});OpenLayers.Format.WMSCapabilities.v1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMT_MS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Keyword":function(node,obj){if(obj.keywords){obj.keywords.push(this.getChildValue(node));}},"DescribeLayer":function(node,obj){obj.describelayer={formats:[]};this.readChildNodes(node,obj.describelayer);},"GetLegendGraphic":function(node,obj){obj.getlegendgraphic={formats:[]};this.readChildNodes(node,obj.getlegendgraphic);},"GetStyles":function(node,obj){obj.getstyles={formats:[]};this.readChildNodes(node,obj.getstyles);},"PutStyles":function(node,obj){obj.putstyles={formats:[]};this.readChildNodes(node,obj.putstyles);},"UserDefinedSymbolization":function(node,obj){var
userSymbols={supportSLD:parseInt(node.getAttribute("SupportSLD"))==1,userLayer:parseInt(node.getAttribute("UserLayer"))==1,userStyle:parseInt(node.getAttribute("UserStyle"))==1,remoteWFS:parseInt(node.getAttribute("RemoteWFS"))==1};obj.userSymbols=userSymbols;},"LatLonBoundingBox":function(node,obj){obj.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].BoundingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("SRS");obj.bbox[bbox.srs]=bbox;},"ScaleHint":function(node,obj){var min=node.getAttribute("min");var max=node.getAttribute("max");var rad2=Math.pow(2,0.5);var ipm=OpenLayers.INCHES_PER_UNIT["m"];obj.maxScale=parseFloat(((min/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecision(13));obj.minScale=parseFloat(((max/rad2)*ipm*OpenLayers.DOTS_PER_INCH).toPrecisio
n(13));},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol")};obj.dimensions[dim.name]=dim;},"Extent":function(node,obj){var name=node.getAttribute("name").toLowerCase();if(name in obj["dimensions"]){var extent=obj.dimensions[name];extent.nearestVal=node.getAttribute("nearestValue")==="1";extent.multipleVal=node.getAttribute("multipleValues")==="1";extent.current=node.getAttribute("current")==="1";extent["default"]=node.getAttribute("default")||"";var values=this.getChildValue(node);extent.values=values.split(",");}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1"});OpenLayers.Format.WMSCapabilities.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.0",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options])
;},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){var srs=this.getChildValue(node);var values=srs.split(/ +/);for(var i=0,len=values.length;i<len;i++){obj.srs[values[i]]=true;}}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_0"});OpenLayers.Protocol.WFS.v1=OpenLayers.Class(OpenLayers.Protocol,{version:null,srsName:"EPSG:4326",featureType:null,featureNS:null,geometryName:"the_geom",schema:null,featurePrefix:"feature",formatOptions:null,readFormat:null,readOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.format){this.format=OpenLayers.Format.WFST(OpenLayers.Util.extend({version:this.version,featureType:this.featureType,featureNS:this.featureNS,featurePrefix:this.featurePrefix,geometryName:this.geometryName,srsName:this.srsName,schema:this.schema},this.formatOptions));}
-if(!this.featureNS&&this.featurePrefix){var readNode=this.format.readNode;this.format.readNode=function(node,obj){if(!this.featureNS&&node.prefix==this.featurePrefix){this.featureNS=node.namespaceURI;this.setNamespace("feature",this.featureNS);}
-return readNode.apply(this,arguments);};}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
-this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[this.format.writeNode("wfs:GetFeature",options)]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),params:options.params,headers:options.headers,data:data});return response;},handleRead:function(response,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);if(options.callback){var request=response.priv;if(request.status>=200&&request.status<300){if(options.readOptions&&options.readOptions.output=="object"){OpenLayers.Util.extend(response,this.parseResponse(request,options.readOption
s));}else{response.features=this.parseResponse(request,options.readOptions);}
-response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
-options.callback.call(options.scope,response);}},parseResponse:function(request,options){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(!doc||doc.length<=0){return null;}
-return(this.readFormat!==null)?this.readFormat.read(doc):this.format.read(doc,options);},commit:function(features,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit",reqFeatures:features});response.priv=OpenLayers.Request.POST({url:options.url,data:this.format.write(features,options),callback:this.createCallback(this.handleCommit,response,options)});return response;},handleCommit:function(response,options){if(options.callback){var request=response.priv;var data=request.responseXML;if(!data||!data.documentElement){data=request.responseText;}
-var obj=this.format.read(data)||{};response.insertIds=obj.insertIds||[];response.code=(obj.success)?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.call(options.scope,response);}},filterDelete:function(filter,options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options);var response=new OpenLayers.Protocol.Response({requestType:"commit"});var root=this.format.createElementNSPlus("wfs:Transaction",{attributes:{service:"WFS",version:this.version}});var deleteNode=this.format.createElementNSPlus("wfs:Delete",{attributes:{typeName:(options.featureNS?this.featurePrefix+":":"")+
-options.featureType}});if(options.featureNS){deleteNode.setAttribute("xmlns:"+this.featurePrefix,options.featureNS);}
-var filterNode=this.format.writeNode("ogc:Filter",filter);deleteNode.appendChild(filterNode);root.appendChild(deleteNode);var data=OpenLayers.Format.XML.prototype.write.apply(this.format,[root]);return OpenLayers.Request.POST({url:this.url,callback:options.callback||function(){},data:data});},abort:function(response){if(response){response.priv.abort();}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1"});OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,multi:false,mouseDown:false,stoppedDown:null,lastDown:null,lastUp:null,persist:false,stopDown:false,stopUp:false,layerOptions:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);this.createFeature();return true;},createFeature:function(pixel){if(!pixel){pixel=new OpenLayers.Pixel(-50,-50);}
-var lonlat=this.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.callback("create",[this.point.geometry,this.point]);this.point.geometry.clearBounds();this.layer.addFeatures([this.point],{silent:true});},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-this.cancel(true);if(this.layer.map!=null){this.destroyFeature();this.layer.destroy(false);}
-this.layer=null;return true;},destroyFeature:function(){if(this.layer){this.layer.destroyFeatures();}
-this.point=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>1){this.layer.features[0].destroy();}},finalize:function(cancel,noNew){var key=cancel?"cancel":"done";this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback(key,[this.geometryClone()]);if(cancel||!this.persist){this.destroyFeature();}
-if(!noNew){this.createFeature();}},cancel:function(noNew){this.finalize(true,noNew);},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},modifyFeature:function(pixel){var lonlat=this.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.point,false]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},getGeometry:function(){var geometry=this.point&&this.point.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPoint([geometry]);}
-return geometry;},geometryClone:function(){var geom=this.getGeometry();return geom&&geom.clone();},mousedown:function(evt){this.mouseDown=true;this.lastDown=evt.xy;this.modifyFeature(evt.xy);this.stoppedDown=this.stopDown;return!this.stopDown;},mousemove:function(evt){if(!this.mouseDown||this.stoppedDown){this.modifyFeature(evt.xy);}
-return true;},mouseup:function(evt){this.mouseDown=false;this.stoppedDown=this.stopDown;if(!this.checkModifiers(evt)){return true;}
-if(this.lastUp&&this.lastUp.equals(evt.xy)){return true;}
-if(this.lastDown&&this.lastDown.equals(evt.xy)){if(this.persist){this.destroyPersistedFeature();}
-this.lastUp=evt.xy;this.finalize();return!this.stopUp;}else{return true;}},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.viewPortDiv)){this.stoppedDown=this.stopDown;this.mouseDown=false;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){if(!pixel){pixel=new OpenLayers.Pixel(-50,-50);}
-var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([this.point.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.line,this.point],{silent:true});},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);this.line=null;},destroyPersistedFeature:function(){var layer=this.layer;if(layer&&layer.features.length>2){this.layer.features[0].destroy();}},removePoint:function(){if(this.point){this.layer.removeFeatures([this.point]);}},addPoint:function(pixel){this.layer.removeFeatures([this.point]);var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line.geometry.addComponent(this.point.geometry,th
is.line.geometry.components.length);this.callback("point",[this.point.geometry,this.getGeometry()]);this.callback("modify",[this.point.geometry,this.getSketch()]);this.drawFeature();},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(pixel,drawing){var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.callback("modify",[this.point.geometry,this.getSketch(),drawing]);this.point.geometry.clearBounds();this.drawFeature();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.line;},getGeometry:function(){var geometry=this.line&&this.line.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiLineString([geometry]);}
-return geometry;},mousedown:function(evt){var stopDown=this.stopDown;if(this.freehandMode(evt)){stopDown=true;}
-if(!this.lastDown||!this.lastDown.equals(evt.xy)){this.modifyFeature(evt.xy,!!this.lastUp);}
-this.mouseDown=true;this.lastDown=evt.xy;this.stoppedDown=stopDown;return!stopDown;},mousemove:function(evt){if(this.stoppedDown&&this.freehandMode(evt)){if(this.persist){this.destroyPersistedFeature();}
-this.addPoint(evt.xy);return false;}
-if(!this.mouseDown||this.stoppedDown){this.modifyFeature(evt.xy,!!this.lastUp);}
-return true;},mouseup:function(evt){if(this.mouseDown&&(!this.lastUp||!this.lastUp.equals(evt.xy))){if(this.stoppedDown&&this.freehandMode(evt)){this.removePoint();this.finalize();}else{if(this.lastDown.equals(evt.xy)){if(this.lastUp==null&&this.persist){this.destroyPersistedFeature();}
-this.addPoint(evt.xy);this.lastUp=evt.xy;}}}
-this.stoppedDown=this.stopDown;this.mouseDown=false;return!this.stopUp;},finishGeometry:function(){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();},dblclick:function(evt){if(!this.freehandMode(evt)){this.finishGeometry();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},loadGML:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.url,success:this.requestSuccess,failure:this.requestFailure,scope:this});this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.loadGML();},requestSuccess:function(request){var do
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){OpenLayers.Console.userError(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Format.OWSCommon.v1_1_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1,{namespaces:{ows:"http://www.opengis.net/ows/1.1",xlink:"http://www.w3.org/1999/xlink"},readers:{"ows":OpenLayers.Util.applyDefaults({"AllowedValues":function(node,parameter){parameter.allowedValues={};this.readChildNodes(node,parameter.allowedValues);},"AnyValue":function(node,parameter){parameter.anyValue=true;},"Range":function(node,allowedValues){allowedValues.range={};this.readChildNodes(node,allowedValues.range);},"MinimumValue":function(node,range){range.minValue=this.getChildValue(node);},"MaximumValue":function(node,range){range.maxValue=this.getChildV
alue(node);},"Identifier":function(node,obj){obj.identifier=this.getChildValue(node);},"SupportedCRS":function(node,obj){obj.supportedCRS=this.getChildValue(node);}},OpenLayers.Format.OWSCommon.v1.prototype.readers["ows"])},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1_1_0"});OpenLayers.Control.PanPanel=OpenLayers.Class(OpenLayers.Control.Panel,{slideFactor:50,slideRatio:null,initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);var options={slideFactor:this.slideFactor,slideRatio:this.slideRatio};this.addControls([new OpenLayers.Control.Pan(OpenLayers.Control.Pan.NORTH,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.SOUTH,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.EAST,options),new OpenLayers.Control.Pan(OpenLayers.Control.Pan.WEST,options)]);},CLASS_NAME:"OpenLayers.Control.PanPanel"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(options){OpenLayers.
Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0,len=this.map.layers.length;i<len;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){if(OpenLayers.Util.indexOf(attributions,layer.attribution)===-1){attributions.push(layer.attribution);}}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Kinetic=OpenLayers.Class({threshold:0,interval:10,deceleration:0.0035,nbPoints:100,delay:200,points:undefined,timerId:undefined,initialize:function(options){OpenLayers.Util.extend(this,options);},begin:function(){clearInterval(this.timerId);this.timerId=undefined;this.points=[];},update:function(xy){this.points.unshift({xy:xy,tick:new Date().getTime()});if(this.points.length>this.nbPoints){this.points.pop();}},end:function(xy){var last,now=new Date().getTime();for(var i=0,l=this.points.length,point;i<l;i++){point=this.points[i];if(now-point.tick>this.delay){break;}
-last=point;}
-if(!last){return;}
-var time=new Date().getTime()-last.tick;var dist=Math.sqrt(Math.pow(xy.x-last.xy.x,2)+
-Math.pow(xy.y-last.xy.y,2));var speed=dist/time;if(speed==0||speed<this.threshold){return;}
-var theta=Math.asin((xy.y-last.xy.y)/dist);if(last.xy.x<=xy.x){theta=Math.PI-theta;}
-return{speed:speed,theta:theta};},move:function(info,callback){var v0=info.speed;var fx=Math.cos(info.theta);var fy=-Math.sin(info.theta);var time=0;var initialTime=new Date().getTime();var lastX=0;var lastY=0;var timerCallback=function(){if(this.timerId==null){return;}
-time+=this.interval;var realTime=new Date().getTime()-initialTime;var t=(time+realTime)/2.0;var p=(-this.deceleration*Math.pow(t,2))/2.0+v0*t;var x=p*fx;var y=p*fy;var args={};args.end=false;var v=-this.deceleration*t+v0;if(v<=0){clearInterval(this.timerId);this.timerId=null;args.end=true;}
-args.x=x-lastX;args.y=y-lastY;lastX=x;lastY=y;callback(args.x,args.y,args.end);};this.timerId=window.setInterval(OpenLayers.Function.bind(timerCallback,this),this.interval);},CLASS_NAME:"OpenLayers.Kinetic"});OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){OpenLayers.Console.userError(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){if(typeof params=='string'){params=OpenLayers.Util.getParameters(params);}
-var success=(onComplete)?onComplete:OpenLayers.nullHandler;var failure=(onFailure)?onFailure:OpenLayers.nullHandler;return OpenLayers.Request.GET({url:uri,params:params,success:success,failure:failure,scope:caller});};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
-this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=Op
enLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
-this.transport=OpenLayers.Ajax.getTransport();this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=OpenLayers.Util.extend({},this.options.parameters);if(this.method!='get'&&this.method!='post'){params['_method']=this.method;this.method='post';}
-this.parameters=params;if(params=OpenLayers.Util.getParameterString(params)){if(this.method=='get'){this.url+=((this.url.indexOf('?')>-1)?'&':'?')+params;}else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){params+='&_=';}}
-try{var response=new OpenLayers.Ajax.Response(this);if(this.options.onCreate){this.options.onCreate(response);}
-OpenLayers.Ajax.Responders.dispatch('onCreate',this,response);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous){window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,this,1),10);}
-this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType){this.onStateChange();}}catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete)){this.respondToReadyState(this.transport.readyState);}},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','Accept':'text/javascript, text/html, application/xml, text/xml, */*','OpenLayers':true};if(this.method=='post'){headers['Content-type']=this.options.contentType+
-(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005){headers['Connection']='close';}}
-if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function'){for(var i=0,length=extras.length;i<length;i+=2){headers[extras[i]]=extras[i+1];}}else{for(var i in extras){headers[i]=extras[i];}}}
-for(var name in headers){this.transport.setRequestHeader(name,headers[name]);}},success:function(){var status=this.getStatus();return!status||(status>=200&&status<300);},getStatus:function(){try{return this.transport.status||0;}catch(e){return 0;}},respondToReadyState:function(readyState){var state=OpenLayers.Ajax.Request.Events[readyState];var response=new OpenLayers.Ajax.Response(this);if(state=='Complete'){try{this._complete=true;(this.options['on'+response.status]||this.options['on'+(this.success()?'Success':'Failure')]||OpenLayers.Ajax.emptyFunction)(response);}catch(e){this.dispatchException(e);}
-var contentType=response.getHeader('Content-type');}
-try{(this.options['on'+state]||OpenLayers.Ajax.emptyFunction)(response);OpenLayers.Ajax.Responders.dispatch('on'+state,this,response);}catch(e){this.dispatchException(e);}
-if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
-if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
-if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.location,success:this.parseData,scope:this});this.loaded=true;}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadRSS();}},parseData:function(ajaxRequest){va
r doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
-if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
-catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
-if(name){this.setName(name);}}
-var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0,len=features.length;i<len;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
-var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){data.title=title;data.description=description;var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
-contentHTML+=title;if(link){contentHTML+='</a>';}
-contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
-var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
-this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
-if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Strategy.Filter=OpenLayers.Class(OpenLayers.Strategy,{filter:null,cache:null,caching:false,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.apply(this,arguments);if(activated){this.cache=[];this.layer.events.on({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
-return activated;},deactivate:function(){this.cache=null;if(this.layer&&this.layer.events){this.layer.events.un({"beforefeaturesadded":this.handleAdd,"beforefeaturesremoved":this.handleRemove,scope:this});}
-return OpenLayers.Strategy.prototype.deactivate.apply(this,arguments);},handleAdd:function(event){if(!this.caching&&this.filter){var features=event.features;event.features=[];var feature;for(var i=0,ii=features.length;i<ii;++i){feature=features[i];if(this.filter.evaluate(feature)){event.features.push(feature);}else{this.cache.push(feature);}}}},handleRemove:function(event){if(!this.caching){this.cache=[];}},setFilter:function(filter){this.filter=filter;var previousCache=this.cache;this.cache=[];this.handleAdd({features:this.layer.features});if(this.cache.length>0){this.caching=true;this.layer.removeFeatures(this.cache.slice(),{silent:true});this.caching=false;}
-if(previousCache.length>0){var event={features:previousCache};this.handleAdd(event);this.caching=true;this.layer.addFeatures(event.features,{silent:true});this.caching=false;}},CLASS_NAME:"OpenLayers.Strategy.Filter"});OpenLayers.Format.SOSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.SOSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw"Can't find a SOS capabilities parser for version "+version;}
-var parser=new constr(this.options);}
-var capabilities=parser.read(data);capabilities.version=version;return capabilities;},CLASS_NAME:"OpenLayers.Format.SOSCapabilities"});OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},calculateGridLayout:fun
ction(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Format.WMC=OpenLayers.Class(OpenLayers.Format.Context,{defaultVersion:"1.1.0",getParser:function(version){var v=version||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=v){var format=OpenLayers.Format.WMC["v"+v.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+v;}
-this.parser=new format(this.options);}
-return this.parser;},layerToContext:function(layer){var parser=this.getParser();var layerContext={queryable:layer.queryable,visibility:layer.visibility,name:layer.params["LAYERS"],title:layer.name,metadataURL:layer.metadataURL,version:layer.params["VERSION"],url:layer.url,maxExtent:layer.maxExtent,transparent:layer.params["TRANSPARENT"],numZoomLevels:layer.numZoomLevels,units:layer.units,isBaseLayer:layer.isBaseLayer,opacity:layer.opacity,displayInLayerSwitcher:layer.displayInLayerSwitcher,singleTile:layer.singleTile,tileSize:(layer.singleTile||!layer.tileSize)?undefined:{width:layer.tileSize.w,height:layer.tileSize.h},minScale:(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale)?layer.minScale:undefined,maxScale:(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale)?layer.maxScale:undefined,formats:[{value:layer.params["FORMAT"],current:true}],styles:[{href:layer.params["SLD"],
body:layer.params["SLD_BODY"],name:layer.params["STYLES"]||parser.defaultStyleName,title:parser.defaultStyleTitle,current:true}]};return layerContext;},toContext:function(obj){var context={};var layers=obj.layers;if(obj.CLASS_NAME=="OpenLayers.Map"){context.bounds=obj.getExtent();context.maxExtent=obj.maxExtent;context.projection=obj.projection;context.size=obj.getSize();}
-else{OpenLayers.Util.applyDefaults(context,obj);if(context.layers!=undefined){delete(context.layers);}}
-if(context.layersContext==undefined){context.layersContext=[];}
-if(layers!=undefined&&layers instanceof Array){for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];if(layer instanceof OpenLayers.Layer.WMS){context.layersContext.push(this.layerToContext(layer));}}}
-return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
-return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0,len=children.length;i<len;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layersContext=[];this.runChildNodes(cont
ext,node);},read_wmc_Layer:function(context,node){var layerContext={visibility:(node.getAttribute("hidden")!="1"),queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[]};this.runChildNodes(layerContext,node);context.layersContext.push(layerContext);},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerContext,node){layerContext.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerContext,node){layerContext.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerContext,node){layerContext.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerContext,node){layerContext.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerContext,node){laye
rContext.singleTile=(this.getChildValue(node)=="true");},read_ol_tileSize:function(layerContext,node){var obj={"width":node.getAttribute("width"),"height":node.getAttribute("height")};layerContext.tileSize=obj;},read_ol_isBaseLayer:function(layerContext,node){layerContext.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerContext,node){layerContext.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerContext,node){layerContext.version=node.getAttribute("version");var server={};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(server,links[0]);}
-layerContext.url=server.href;},read_wmc_FormatList:function(layerContext,node){this.runChildNodes(layerContext,node);},read_wmc_Format:function(layerContext,node){var format={value:this.getChildValue(node)};if(node.getAttribute("current")=="1"){format.current=true;}
-layerContext.formats.push(format);},read_wmc_StyleList:function(layerContext,node){this.runChildNodes(layerContext,node);},read_wmc_Style:function(layerContext,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){style.current=true;}
-layerContext.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_MetadataURL:function(layerContext,node){var metadataURL={};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(metadataURL,links[0]);}
-layerContext.metadataURL=metadataURL.href;},read_wmc_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height')};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(legend,links[0]);}
-style.legend=legend;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS(this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
-if(attributes){this.setAttributes(node,attributes);}
-return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
-var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));node.appendChild(this.write_ol_MapExtension(context));return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18)});node.appendChild(maxExtent);}
-return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");for(var i=0,len=context.layersContext.length;i<len;++i){list.appendChild(this.write_wmc_Layer(context.layersContext[i]));}
-return list;},write_wmc_Layer:function(context){var node=this.createElementDefaultNS("Layer",null,{queryable:context.queryable?"1":"0",hidden:context.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(context));node.appendChild(this.createElementDefaultNS("Name",context.name));node.appendChild(this.createElementDefaultNS("Title",context.title));if(context.metadataURL){node.appendChild(this.write_wmc_MetadataURL(context.metadataURL));}
-return node;},write_wmc_LayerExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(18),miny:bounds.bottom.toPrecision(18),maxx:bounds.right.toPrecision(18),maxy:bounds.top.toPrecision(18)});node.appendChild(maxExtent);if(context.tileSize&&!context.singleTile){var size=this.createElementNS(this.namespaces.ol,"ol:tileSize");this.setAttributes(size,context.tileSize);node.appendChild(size);}
-var properties=["transparent","numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0,len=properties.length;i<len;++i){child=this.createOLPropertyNode(context,properties[i]);if(child){node.appendChild(child);}}
-return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
-return node;},write_wmc_Server:function(context){var node=this.createElementDefaultNS("Server");this.setAttributes(node,{service:"OGC:WMS",version:context.version});node.appendChild(this.write_wmc_OnlineResource(context.url));return node;},write_wmc_MetadataURL:function(metadataURL){var node=this.createElementDefaultNS("MetadataURL");node.appendChild(this.write_wmc_OnlineResource(metadataURL));return node;},write_wmc_FormatList:function(context){var node=this.createElementDefaultNS("FormatList");for(var i=0,len=context.formats.length;i<len;i++){var format=context.formats[i];node.appendChild(this.createElementDefaultNS("Format",format.value,(format.current&&format.current==true)?{current:"1"}:null));}
-return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var styles=layer.styles;if(styles&&styles instanceof Array){var sld;for(var i=0,len=styles.length;i<len;i++){var s=styles[i];var style=this.createElementDefaultNS("Style",null,(s.current&&s.current==true)?{current:"1"}:null);if(s.href){sld=this.createElementDefaultNS("SLD");var link=this.write_wmc_OnlineResource(s.href);sld.appendChild(link);sld.appendChild(this.createElementDefaultNS("Name",s.name));if(s.title){sld.appendChild(this.createElementDefaultNS("Title",s.title));}
-style.appendChild(sld);}else if(s.body){sld=this.createElementDefaultNS("SLD");var doc=OpenLayers.Format.XML.prototype.read.apply(this,[s.body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
-sld.appendChild(imported);sld.appendChild(this.createElementDefaultNS("Name",s.name));if(s.title){sld.appendChild(this.createElementDefaultNS("Title",s.title));}
-style.appendChild(sld);}else{style.appendChild(this.createElementDefaultNS("Name",s.name));style.appendChild(this.createElementDefaultNS("Title",s.title));if(s['abstract']){style.appendChild(this.createElementDefaultNS("Abstract",s['abstract']));}}
-node.appendChild(style);}}
-return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerContext,node){var minScaleDenominator=parseFloat(this.getChildValue(node));if(minScaleDenominator>0){layerContext.maxScale=minScaleDenominator;}},read_sld_MaxScaleDenominator:function(layerContext,node){layerContext.minScale=parseFloat(this.getChildValue(node));},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.a
pply(this,[context]);if(context.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(context.maxScale.toPrecision(16)));node.appendChild(minSD);}
-if(context.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(context.minScale.toPrecision(16)));node.appendChild(maxSD);}
-node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));node.appendChild(this.write_wmc_LayerExtension(context));return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",xlinkns:"http://www.w3.org/1999/xlink",MAX_PIXEL:15000,translationParameters:null,symbolMetrics:null,initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);this.translationParameters={x:0,y:0};this.symbolMetrics={};},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y,xyOnly){var left=x+(xyOnly?0:this.translationParameters.x);var top=y+(xyOnly?0:this.translationParameters.y);return(left>=-this.MAX_PIXEL&&left<=this.MAX_PIXEL&&top>=-this.MAX_PIXEL&&top<=this.MAX_PIXEL);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=-extent.left/resolution;var top=extent.top/resolution;if(resolutionChanged)
{this.left=left;this.top=top;var extentString="0 0 "+this.size.w+" "+this.size.h;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);this.translate(0,0);return true;}else{var inRange=this.translate(left-this.left,top-this.top);if(!inRange){this.setExtent(extent,true);}
-return inRange;}},translate:function(x,y){if(!this.inValidRange(x,y,true)){return false;}else{var transformString="";if(x||y){transformString="translate("+x+","+y+")";}
-this.root.setAttributeNS(null,"transform",transformString);this.translationParameters={x:x,y:y};return true;}},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="image";}else if(this.isComplexSymbol(style.graphicName)){nodeType="svg";}else{nodeType="circle";}
-break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
-return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));var widthFactor=1;var pos;if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){node.style.visibility="";if(style.graphic===false){node.style.visibility="hidden";}else if(style.externalGraphic){pos=this.getPosition(node);if(style.graphicTitle){node.setAttributeNS(null,"title",style.graphicTitle);}
-if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(pos.x+xOffset).toFixed());node.setAttributeNS(null,"y",(pos.y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS(this.xlinkns,"href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);}else if(this.isComplexSymbol(style.graphicName)){var offset=style.pointRadius*3;var size=offset*2;var id=this.importSymbol(style.graphicName);pos=this.getPosition(node);widthFactor=this.symbolMetrics[id][0]*3/size;var parent=node.parentNode;var nextSibling=node.nextSibling;if(parent)
{parent.removeChild(node);}
-var src=document.getElementById(id);node.firstChild&&node.removeChild(node.firstChild);node.appendChild(src.firstChild.cloneNode(true));node.setAttributeNS(null,"viewBox",src.getAttributeNS(null,"viewBox"));node.setAttributeNS(null,"width",size);node.setAttributeNS(null,"height",size);node.setAttributeNS(null,"x",pos.x-offset);node.setAttributeNS(null,"y",pos.y-offset);if(nextSibling){parent.insertBefore(node,nextSibling);}else if(parent){parent.appendChild(node);}}else{node.setAttributeNS(null,"r",style.pointRadius);}
-var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)&&pos){node._rotation=rotation;rotation|=0;if(node.nodeName!=="svg"){node.setAttributeNS(null,"transform","rotate("+rotation+" "+pos.x+" "+
-pos.y+")");}else{var metrics=this.symbolMetrics[id];node.firstChild.setAttributeNS(null,"transform","rotate("
-+rotation+" "
-+metrics[1]+" "
-+metrics[2]+")");}}}
-if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
-if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth*widthFactor);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap||"round");node.setAttributeNS(null,"stroke-linejoin","round");style.strokeDashstyle&&node.setAttributeNS(null,"stroke-dasharray",this.dashStyle(style,widthFactor));}else{node.setAttributeNS(null,"stroke","none");}
-if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
-if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
-return node;},dashStyle:function(style,widthFactor){var w=style.strokeWidth*widthFactor;var str=style.strokeDashstyle;switch(str){case'solid':return'none';case'dot':return[1,4*w].join();case'dash':return[4*w,4*w].join();case'dashdot':return[4*w,4*w,1,4*w].join();case'longdash':return[8*w,4*w].join();case'longdashdot':return[8*w,4*w,1,4*w].join();default:return OpenLayers.String.trim(str).replace(/\s+/g,",");}},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
-return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"g");},createDefs:function(){var defs=this.nodeFactory(this.container.id+"_defs","defs");this.rendererRoot.appendChild(defs);return defs;},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);return node;}else{return false;}},drawLineString:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(components
Result.complete?node:null);}else{return false;}},drawLinearRing:function(node,geometry){var componentsResult=this.getComponentsString(geometry.components);if(componentsResult.path){node.setAttributeNS(null,"points",componentsResult.path);return(componentsResult.complete?node:null);}else{return false;}},drawPolygon:function(node,geometry){var d="";var draw=true;var complete=true;var linearRingResult,path;for(var j=0,len=geometry.components.length;j<len;j++){d+=" M";linearRingResult=this.getComponentsString(geometry.components[j].components," ");path=linearRingResult.path;if(path){d+=" "+path;complete=linearRingResult.complete&&complete;}else{draw=false;}}
-d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");return complete?node:null;}else{return false;}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);return node;}else{return false;}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0,len=geometry.components.length;i<len;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" "+component;}}
-d+=" Z";if(draw){node.setAttributeNS(null,"d",d);return node;}else{return false;}},drawText:function(featureId,style,location){var resolution=this.getResolution();var x=(location.x/resolution+this.left);var y=(location.y/resolution-this.top);var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"text");var tspan=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_tspan","tspan");label.setAttributeNS(null,"x",x);label.setAttributeNS(null,"y",-y);if(style.fontColor){label.setAttributeNS(null,"fill",style.fontColor);}
-if(style.fontOpacity){label.setAttributeNS(null,"opacity",style.fontOpacity);}
-if(style.fontFamily){label.setAttributeNS(null,"font-family",style.fontFamily);}
-if(style.fontSize){label.setAttributeNS(null,"font-size",style.fontSize);}
-if(style.fontWeight){label.setAttributeNS(null,"font-weight",style.fontWeight);}
-if(style.labelSelect===true){label.setAttributeNS(null,"pointer-events","visible");label._featureId=featureId;tspan._featureId=featureId;tspan._geometry=location;tspan._geometryClass=location.CLASS_NAME;}else{label.setAttributeNS(null,"pointer-events","none");}
-var align=style.labelAlign||"cm";label.setAttributeNS(null,"text-anchor",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]]||"middle");if(OpenLayers.IS_GECKO===true){label.setAttributeNS(null,"dominant-baseline",OpenLayers.Renderer.SVG.LABEL_ALIGN[align[1]]||"central");}else{tspan.setAttributeNS(null,"baseline-shift",OpenLayers.Renderer.SVG.LABEL_VSHIFT[align[1]]||"-35%");}
-tspan.textContent=style.label;if(!label.parentNode){label.appendChild(tspan);this.textRoot.appendChild(label);}},getComponentsString:function(components,separator){var renderCmp=[];var complete=true;var len=components.length;var strings=[];var str,component;for(var i=0;i<len;i++){component=components[i];renderCmp.push(component);str=this.getShortString(component);if(str){strings.push(str);}else{if(i>0){if(this.getShortString(components[i-1])){strings.push(this.clipLine(components[i],components[i-1]));}}
-if(i<len-1){if(this.getShortString(components[i+1])){strings.push(this.clipLine(components[i],components[i+1]));}}
-complete=false;}}
-return{path:strings.join(separator||","),complete:complete};},clipLine:function(badComponent,goodComponent){if(goodComponent.equals(badComponent)){return"";}
-var resolution=this.getResolution();var maxX=this.MAX_PIXEL-this.translationParameters.x;var maxY=this.MAX_PIXEL-this.translationParameters.y;var x1=goodComponent.x/resolution+this.left;var y1=this.top-goodComponent.y/resolution;var x2=badComponent.x/resolution+this.left;var y2=this.top-badComponent.y/resolution;var k;if(x2<-maxX||x2>maxX){k=(y2-y1)/(x2-x1);x2=x2<0?-maxX:maxX;y2=y1+(x2-x1)*k;}
-if(y2<-maxY||y2>maxY){k=(x2-x1)/(y2-y1);y2=y2<0?-maxY:maxY;x2=x1+(y2-y1)*k;}
-return x2+","+y2;},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},getPosition:function(node){return({x:parseFloat(node.getAttributeNS(null,"cx")),y:parseFloat(node.getAttributeNS(null,"cy"))});},importSymbol:function(graphicName){if(!this.defs){this.defs=this.createDefs();}
-var id=this.container.id+"-"+graphicName;if(document.getElementById(id)!=null){return id;}
-var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
-var symbolNode=this.nodeFactory(id,"symbol");var node=this.nodeFactory(null,"polygon");symbolNode.appendChild(node);var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var points=[];var x,y;for(var i=0;i<symbol.length;i=i+2){x=symbol[i];y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);points.push(x,",",y);}
-node.setAttributeNS(null,"points",points.join(" "));var width=symbolExtent.getWidth();var height=symbolExtent.getHeight();var viewBox=[symbolExtent.left-width,symbolExtent.bottom-height,width*3,height*3];symbolNode.setAttributeNS(null,"viewBox",viewBox.join(" "));this.symbolMetrics[id]=[Math.max(width,height),symbolExtent.getCenterLonLat().lon,symbolExtent.getCenterLonLat().lat];this.defs.appendChild(symbolNode);return symbolNode.id;},getFeatureIdFromEvent:function(evt){var featureId=OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this,arguments);if(!featureId){var target=evt.target;featureId=target.parentNode&&target!=this.rendererRoot&&target.parentNode._featureId;}
-return featureId;},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.SVG.LABEL_ALIGN={"l":"start","r":"end","b":"bottom","t":"hanging"};OpenLayers.Renderer.SVG.LABEL_VSHIFT={"t":"-70%","b":"0"};OpenLayers.Format.WMSDescribeLayer=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.1.1",version:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(version=="1.1.1"||version=="1.1.0"){version="1.1";}
-var constructor=OpenLayers.Format.WMSDescribeLayer["v"+version.replace(/\./g,"_")];if(!constructor){throw"Can't find a WMS DescribeLayer parser for version "+
-version;}
-var parser=new constructor(this.options);var describelayer=parser.read(data);describelayer.version=version;return describelayer;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer"});OpenLayers.Format.WMSDescribeLayer.v1_1=OpenLayers.Class(OpenLayers.Format.WMSDescribeLayer,{initialize:function(options){OpenLayers.Format.WMSDescribeLayer.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var children=root.childNodes;var describelayer=[];var childNode,nodeName;for(var i=0;i<children.length;++i){childNode=children[i];nodeName=childNode.nodeName;if(nodeName=='LayerDescription'){var layerName=childNode.getAttribute('name');var owsType='';var owsURL='';var typeName='';if(childNode.getAttribute('owsType')){owsType=childNode.getAttribute('owsType');owsURL=childNode.getAttribute('owsURL');}else{if(childNode.getAttribute('wfs')!=''){owsType='WFS';owsURL=childNode.getAttribute('wfs');}else if(childNode.getAttribute('wcs')!=''){owsType='WCS';owsURL=childNode.getAttribute('wcs');}}
-var query=childNode.getElementsByTagName('Query');if(query.length>0){typeName=query[0].getAttribute('typeName');if(!typeName){typeName=query[0].getAttribute('typename');}}
-describelayer.push({layerName:layerName,owsType:owsType,owsURL:owsURL,typeName:typeName});}}
-return describelayer;},CLASS_NAME:"OpenLayers.Format.WMSDescribeLayer.v1_1"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,geodesic:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
-this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
-this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
-return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
-var curMapUnits=this.map.getUnits();var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var geodesicRatio=1;if(this.geodesic===true){var maxSizeGeodesic=(this.map.getGeodesicPixelSize().w||0.000001)*this.maxWidth;var maxSizeKilometers=maxSizeData/inches["km"];geodesicRatio=maxSizeGeodesic/maxSizeKilometers;maxSizeData*=geodesicRatio;}
-var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
-var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res/geodesicRatio;var bottomPx=bottomMax/res/geodesicRatio;if(this.eBottom.style.visibility=="visible"){this.eBottom.style.width=Math.round(bottomPx)+"px";this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;}
-if(this.eTop.style.visibility=="visible"){this.eTop.style.width=Math.round(topPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;}},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{ignoreExtraDims:false,initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
-if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
-break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
-break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
-break;case"FeatureCollection":for(var i=0,len=obj.features.length;i<len;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;}}
-return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
-obj.type);}else{valid=true;}
-break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
-obj.type+" to "+type);}}
-return valid;},parseFeature:function(obj){var feature,geometry,attributes,bbox;attributes=(obj.properties)?obj.properties:{};bbox=(obj.geometry&&obj.geometry.bbox)||obj.bbox;try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
-feature=new OpenLayers.Feature.Vector(geometry,attributes);if(bbox){feature.bounds=OpenLayers.Bounds.fromArray(bbox);}
-if(obj.id){feature.fid=obj.id;}
-return feature;},parseGeometry:function(obj){if(obj==null){return null;}
-var geometry,collection=false;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
-var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);collection=true;}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
-if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
-try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
-if(this.internalProjection&&this.externalProjection&&!collection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},parseCoords:{"point":function(array){if(this.ignoreExtraDims==false&&array.length!=2){throw"Only 2D points are supported: "+array;}
-return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-lines.push(l);}
-return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0,len=array.length;i<len;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
-return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0,len=array.length;i<len;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
-polys.push(p);}
-return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
-geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
-return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"OGC","properties":{"urn":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"EPSG","properties":{"code":code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(geometry==null){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
-return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0,len=multipoint.components.length;i<len;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array;},'linestring':function(linestring){var array=[];for(var i=0,len=linestring.components.length;i<len;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0,len=multilinestring.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
-return array;},'polygon':function(polygon){var array=[];for(var i=0,len=polygon.components.length;i<len;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
-return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0,len=multipolygon.components.length;i<len;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
-return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
-return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Strategy.Paging=OpenLayers.Class(OpenLayers.Strategy,{features:null,length:10,num:null,paging:false,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"beforefeaturesadded":this.cacheFeatures,scope:this});}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.clearCache();this.layer.events.un({"beforefeaturesadded":this.cacheFeatures,scope:this});}
-return deactivated;},cacheFeatures:function(event){if(!this.paging){this.clearCache();this.features=event.features;this.pageNext(event);}},clearCache:function(){if(this.features){for(var i=0;i<this.features.length;++i){this.features[i].destroy();}}
-this.features=null;this.num=null;},pageCount:function(){var numFeatures=this.features?this.features.length:0;return Math.ceil(numFeatures/this.length);},pageNum:function(){return this.num;},pageLength:function(newLength){if(newLength&&newLength>0){this.length=newLength;}
-return this.length;},pageNext:function(event){var changed=false;if(this.features){if(this.num===null){this.num=-1;}
-var start=(this.num+1)*this.length;changed=this.page(start,event);}
-return changed;},pagePrevious:function(){var changed=false;if(this.features){if(this.num===null){this.num=this.pageCount();}
-var start=(this.num-1)*this.length;changed=this.page(start);}
-return changed;},page:function(start,event){var changed=false;if(this.features){if(start>=0&&start<this.features.length){var num=Math.floor(start/this.length);if(num!=this.num){this.paging=true;var features=this.features.slice(start,start+this.length);this.layer.removeFeatures(this.layer.features);this.num=num;if(event&&event.features){event.features=features;}else{this.layer.addFeatures(features);}
-this.paging=false;changed=true;}}}
-return changed;},CLASS_NAME:"OpenLayers.Strategy.Paging"});OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
-this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
-this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
-block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
-block.div=null;}
-this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(contentSize){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
-this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
-this.padding.top+"px";}
-this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
-var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
-if(this.size&&this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=(w<0?0:w)+'px';block.div.style.height=(h<0?0:h)+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',boxCharacteristics:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.dragHandler=new OpenLayers.Handler.Drag(this,{down:this.startBox,move:this.moveBox,out:this.removeBox,up:this.endBox},{keyMask:this.keyMask});},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);if(this.dragHandler){this.dragHandler.destroy();this.dragHandler=null;}},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',new OpenLayers.Pixel(-9999,-9999));this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.
zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);OpenLayers.Element.addClass(this.map.viewPortDiv,"olDrawBox");},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";var box=this.getBoxCharacteristics();if(box.newBoxModel){if(xy.x>startX){this.zoomBox.style.width=Math.max(1,deltaX-box.xOffset)+"px";}
-if(xy.y>startY){this.zoomBox.style.height=Math.max(1,deltaY-box.yOffset)+"px";}}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;this.boxCharacteristics=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olDrawBox");},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},getBoxCharacteristics:function(){if(!this.boxCharacteristics){var xOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-left-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-right-width"))+1;var yOffset=parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-top-width"))+parseInt(OpenLayers.Element.getStyle(this.zoomBox,"border-bottom-width"))+1;var newBoxModel=OpenLayers.BROWSER_NAME=="msie"?document.compatMode!="BackCompa
t":true;this.boxCharacteristics={xOffset:xOffset,yOffset:yOffset,newBoxModel:newBoxModel};}
-return this.boxCharacteristics;},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,alwaysZoom:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){var bounds;if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;
var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-var lastZoom=this.map.getZoom();this.map.zoomToExtent(bounds);if(lastZoom==this.map.getZoom()&&this.alwaysZoom==true){this.map.zoomTo(lastZoom+(this.out?-1:1));}}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLayers.Util.extend(config,this.enableKinetic);}
+return deactivated;},adjustXY:function(evt){var pos=OpenLayers.Util.pagePosition(this.map.viewPortDiv);evt.xy.x-=pos[0];evt.xy.y-=pos[1];},addDocumentEvents:function(){OpenLayers.Element.addClass(document.body,"olDragDown");this.documentEvents=true;OpenLayers.Event.observe(document,"mousemove",this._docMove);OpenLayers.Event.observe(document,"mouseup",this._docUp);},removeDocumentEvents:function(){OpenLayers.Element.removeClass(document.body,"olDragDown");this.documentEvents=false;OpenLayers.Event.stopObserving(document,"mousemove",this._docMove);OpenLayers.Event.stopObserving(document,"mouseup",this._docUp);},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,interval:25,documentDrag:false,kinetic:null,enableKinetic:false,kineticInterval:10,draw:function(){if(this.enableKinetic){var config={interval:this.kineticInterval};if(typeof this.enableKinetic==="object"){config=OpenLaye
this.kinetic=new OpenLayers.Kinetic(config);}
this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone,"down":this.panMapStart},{interval:this.interval,documentDrag:this.documentDrag});},panMapStart:function(){if(this.kinetic){this.kinetic.begin();}},panMap:function(xy){if(this.kinetic){this.kinetic.update(xy);}
this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:true,animate:false});},panMapDone:function(xy){if(this.panned){var res=null;if(this.kinetic){res=this.kinetic.end(xy);}
this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:!!res,animate:false});if(res){var self=this;this.kinetic.move(res,function(x,y,end){self.map.pan(x,y,{dragging:!end,animate:false});});}
-this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,last:null,touch:false,rightclickTimerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt;return true;};}},mousedown:null,touchstart:function(evt){this.touch=true;this.down=evt;this.last=null;return true;},mouseup:function(evt){var propagate=true;if(this.checkModifiers(evt)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(evt)){propagate=this.rightclick(evt);}
-return propagate;},rightclick:function(evt){if(this.passesTolerance(evt)){if(this.rightclickTimerId!=null){this.clearTimer();this.callback('dblrightclick',[evt]);return!this.stopDouble;}else{var clickEvent=this['double']?OpenLayers.Util.extend({},evt):this.callback('rightclick',[evt]);var delayedRightCall=OpenLayers.Function.bind(this.delayedRightCall,this,clickEvent);this.rightclickTimerId=window.setTimeout(delayedRightCall,this.delay);}}
-return!this.stopSingle;},delayedRightCall:function(evt){this.rightclickTimerId=null;if(evt){this.callback('rightclick',[evt]);}
-return!this.stopSingle;},dblclick:function(evt){if(this.passesTolerance(evt)&&(!evt.lastTouches||evt.lastTouches.length==1)){if(this["double"]){this.callback('dblclick',[evt]);}
-this.clearTimer();}
-return!this.stopDouble;},touchmove:function(evt){this.last=evt;},touchend:function(evt){var last=this.last||this.down;if(!evt||!last){return false;}
-evt.xy=last.xy;evt.lastTouches=last.touches;return evt.xy?this.click(evt):false;},click:function(evt){if(this.touch===true&&evt.type==="click"){return!this.stopSingle;}
-if(this.passesTolerance(evt)){if(this.timerId!=null){if(evt.lastTouches){this.dblclick(evt);}else{this.clearTimer();}}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
-return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down&&this.down.xy){var dpx=Math.sqrt(Math.pow(this.down.xy.x-evt.xy.x,2)+
-Math.pow(this.down.xy.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}
-if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();if(this.zoomBoxEnabled){this.zoomBox.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){if(this.handleRightClicks){this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;}
-var clickCallbacks={'dblclick':this.defaultDblClick,'dblrightclick':this.defaultDblRightClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown},this.mouseWheelOptions);},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},defaultDblRightClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom-1);},wheelChange:function(evt,deltaZ){var currentZoom=this.map.getZoom();var newZoom=this.map.getZoom()+
Math.round(deltaZ);newZoom=Math.max(newZoom,0);newZoom=Math.min(newZoom,this.map.getNumZoomLevels());if(newZoom===currentZoom){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt,delta){this.wheelChange(evt,delta||1);},wheelDown:function(evt,delta){this.wheelChange(evt,delta||-1);},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate();},enableZoomBox:function(){this.zoomBoxEnabled=true;if(this.active){this.zoomBox.activate();}},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,EVENT_TYPES:["featureadded"]
,multi:false,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){this.EVENT_TYPES=OpenLayers.Control.DrawFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature,modify:function(vertex,feature){this.layer.events.triggerEvent("sketchmodified",{vertex:vertex,feature:feature});},create:function(vertex,feature){this.layer.events.triggerEvent("sketchstarted",{vertex:vertex,feature:feature});}},this.callbacks);this.layer=layer;this.handlerOptions=this.handlerOptions||{};if(!("multi"in this.handlerOptions)){this.handlerOptions.multi=this.multi;}
-var sketchStyle=this.layer.styleMap&&this.layer.styleMap.styles.temporary;if(sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);var proceed=this.layer.events.triggerEvent("sketchcomplete",{feature:feature});if(proceed!==false){feature.state=OpenLayers.State.INSERT;this.layer.addFeatures([feature]);this.featureAdded(feature);this.events.triggerEvent("featureadded",{feature:feature});}},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{holeModifier:null,drawingHole:false,polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(pixel){if(!pixel){pixel=new OpenLayers.Pixel(-50,-50);}
-var lonlat=this.control.map.getLonLatFromPixel(pixel);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat));this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing([this.point.geometry]));this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon([this.line.geometry]));this.callback("create",[this.point.geometry,this.getSketch()]);this.point.geometry.clearBounds();this.layer.addFeatures([this.polygon,this.point],{silent:true});},addPoint:function(pixel){if(!this.drawingHole&&this.holeModifier&&this.evt&&this.evt[this.holeModifier]){var geometry=this.point.geometry;var features=this.control.layer.features;var candidate,polygon;for(var i=features.length-1;i>=0;--i){candidate=features[i].geometry;if((candidate instanceof OpenLayers.Geometry.Polygon||candidate instanceof OpenLayers.Geometry.MultiPolygon)&&candidate.intersects(geometry)){polygon=features[i];this.control.layer.removeFeatures([polygon],{sil
ent:true});this.control.layer.events.registerPriority("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.registerPriority("sketchmodified",this,this.enforceTopology);polygon.geometry.addComponent(this.line.geometry);this.polygon=polygon;this.drawingHole=true;break;}}}
-OpenLayers.Handler.Path.prototype.addPoint.apply(this,arguments);},enforceTopology:function(event){var point=event.vertex;var components=this.line.geometry.components;if(!this.polygon.geometry.intersects(point)){var last=components[components.length-3];point.x=last.x;point.y=last.y;}},finalizeInteriorRing:function(){var ring=this.line.geometry;var modified=(ring.getArea()!==0);if(modified){var rings=this.polygon.geometry.components;for(var i=rings.length-2;i>=0;--i){if(ring.intersects(rings[i])){modified=false;break;}}
-if(modified){var target;outer:for(var i=rings.length-2;i>0;--i){var points=rings[i].components;for(var j=0,jj=points.length;j<jj;++j){if(ring.containsPoint(points[j])){modified=false;break outer;}}}}}
-if(modified){if(this.polygon.state!==OpenLayers.State.INSERT){this.polygon.state=OpenLayers.State.UPDATE;}}else{this.polygon.geometry.removeComponent(ring);}
-this.restoreFeature();return false;},cancel:function(){if(this.drawingHole){this.polygon.geometry.removeComponent(this.line.geometry);this.restoreFeature(true);}
-return OpenLayers.Handler.Path.prototype.cancel.apply(this,arguments);},restoreFeature:function(cancel){this.control.layer.events.unregister("sketchcomplete",this,this.finalizeInteriorRing);this.control.layer.events.unregister("sketchmodified",this,this.enforceTopology);this.layer.removeFeatures([this.polygon],{silent:true});this.control.layer.addFeatures([this.polygon],{silent:true});this.drawingHole=false;if(!cancel){this.control.layer.events.triggerEvent("sketchcomplete",{feature:this.polygon});}},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);this.polygon=null;},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},getSketch:function(){return this.polygon;},getGeometry:function(){var geometry=this.polygon&&this.polygon.geometry;if(geometry&&this.multi){geometry=new OpenLayers.Geometry.MultiPolygon([geometry]);}
-return geometry;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.removePoint();this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});OpenLayers.Format.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Format.XML,{layerIdentifier:'_layer',featureIdentifier:'_featur
e',regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},gmlFormat:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,arguments);OpenLayers.Util.extend(this,options);this.options=options;},read:function(data){var result;if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;if(root){var scope=this;var read=this["read_"+root.nodeName];if(read){result=read.call(this,root);}else{result=new OpenLayers.Format.GML((this.options?this.options:{})).read(data);}}else{result=data;}
-return result;},read_msGMLOutput:function(data){var response=[];var layerNodes=this.getSiblingNodesByTagCriteria(data,this.layerIdentifier);if(layerNodes){for(var i=0,len=layerNodes.length;i<len;++i){var node=layerNodes[i];var layerName=node.nodeName;if(node.prefix){layerName=layerName.split(':')[1];}
-var layerName=layerName.replace(this.layerIdentifier,'');var featureNodes=this.getSiblingNodesByTagCriteria(node,this.featureIdentifier);if(featureNodes){for(var j=0;j<featureNodes.length;j++){var featureNode=featureNodes[j];var geomInfo=this.parseGeometry(featureNode);var attributes=this.parseAttributes(featureNode);var feature=new OpenLayers.Feature.Vector(geomInfo.geometry,attributes,null);feature.bounds=geomInfo.bounds;feature.type=layerName;response.push(feature);}}}}
-return response;},read_FeatureInfoResponse:function(data){var response=[];var featureNodes=this.getElementsByTagNameNS(data,'*','FIELDS');for(var i=0,len=featureNodes.length;i<len;i++){var featureNode=featureNodes[i];var geom=null;var attributes={};for(var j=0,jlen=featureNode.attributes.length;j<jlen;j++){var attribute=featureNode.attributes[j];attributes[attribute.nodeName]=attribute.nodeValue;}
-response.push(new OpenLayers.Feature.Vector(geom,attributes,null));}
-return response;},getSiblingNodesByTagCriteria:function(node,criteria){var nodes=[];var children,tagName,n,matchNodes,child;if(node&&node.hasChildNodes()){children=node.childNodes;n=children.length;for(var k=0;k<n;k++){child=children[k];while(child&&child.nodeType!=1){child=child.nextSibling;k++;}
-tagName=(child?child.nodeName:'');if(tagName.length>0&&tagName.indexOf(criteria)>-1){nodes.push(child);}else{matchNodes=this.getSiblingNodesByTagCriteria(child,criteria);if(matchNodes.length>0){(nodes.length==0)?nodes=matchNodes:nodes.push(matchNodes);}}}}
-return nodes;},parseAttributes:function(node){var attributes={};if(node.nodeType==1){var children=node.childNodes;var n=children.length;for(var i=0;i<n;++i){var child=children[i];if(child.nodeType==1){var grandchildren=child.childNodes;if(grandchildren.length==1){var grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseGeometry:function(node){if(!this.gmlFormat){this.gmlFormat=new OpenLayers.Format.GML();}
-var feature=this.gmlFormat.parseFeature(node);var geometry,bounds=null;if(feature){geometry=feature.geometry&&feature.geometry.clone();bounds=feature.bounds&&feature.bounds.clone();feature.destroy();}
-return{geometry:geometry,bounds:bounds};},CLASS_NAME:"OpenLayers.Format.WMSGetFeatureInfo"});OpenLayers.Strategy.BBOX=OpenLayers.Class(OpenLayers.Strategy,{bounds:null,resolution:null,ratio:2,resFactor:null,response:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"moveend":this.update,scope:this});this.layer.events.on({"refresh":this.update,scope:this});}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.layer.events.un({"moveend":this.update,scope:this});this.layer.events.un({"refresh":this.update,scope:this});}
-return deactivated;},update:function(options){var mapBounds=this.getMapBounds();if((options&&options.force)||this.invalidBounds(mapBounds)){this.calculateBounds(mapBounds);this.resolution=this.layer.map.getResolution();this.triggerRead();}},getMapBounds:function(){var bounds=this.layer.map.getExtent();if(!this.layer.projection.equals(this.layer.map.getProjectionObject())){bounds=bounds.clone().transform(this.layer.map.getProjectionObject(),this.layer.projection);}
-return bounds;},invalidBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
-var invalid=!this.bounds||!this.bounds.containsBounds(mapBounds);if(!invalid&&this.resFactor){var ratio=this.resolution/this.layer.map.getResolution();invalid=(ratio>=this.resFactor||ratio<=(1/this.resFactor));}
-return invalid;},calculateBounds:function(mapBounds){if(!mapBounds){mapBounds=this.getMapBounds();}
-var center=mapBounds.getCenterLonLat();var dataWidth=mapBounds.getWidth()*this.ratio;var dataHeight=mapBounds.getHeight()*this.ratio;this.bounds=new OpenLayers.Bounds(center.lon-(dataWidth/2),center.lat-(dataHeight/2),center.lon+(dataWidth/2),center.lat+(dataHeight/2));},triggerRead:function(){if(this.response){this.layer.protocol.abort(this.response);this.layer.events.triggerEvent("loadend");}
-this.layer.events.triggerEvent("loadstart");this.response=this.layer.protocol.read({filter:this.createFilter(),callback:this.merge,scope:this});},createFilter:function(){var filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,value:this.bounds,projection:this.layer.projection});if(this.layer.filter){filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND,filters:[this.layer.filter,filter]});}
-return filter;},merge:function(resp){this.layer.destroyFeatures();var features=resp.features;if(features&&features.length>0){var remote=this.layer.projection;var local=this.layer.map.getProjectionObject();if(!local.equals(remote)){var geom;for(var i=0,len=features.length;i<len;++i){geom=features[i].geometry;if(geom){geom.transform(remote,local);}}}
-this.layer.addFeatures(features);}
-this.response=null;this.layer.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Strategy.BBOX"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((b
ounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Protocol.WFS.v1_1_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.1.0",initialize:function(options){OpenLayers.Protocol.WFS.v1.prototype.initialize.apply(this,arguments);if(this.outputFormat&&!this.readFormat){if(this.outputFormat.toLowerCase()=="gml2"){this.readFormat=new OpenLayers.Format.GML.v2({featureType:this.featureType,featureNS:this.featureNS,geometryName:this.geometryName});}else if(this.outputFormat.toLowerCase()=="json"){this.readFormat=new OpenLayers.Format.GeoJSON();}}},CLASS_NAME:"OpenLayers.Protocol.WFS.v1_1_0"});OpenLayers.Format.WMTSCapabilities=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser
:null,yx:{"urn:ogc:def:crs:EPSG::4326":true},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);this.options=options;},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version||root.getAttribute("version")||this.defaultVersion;if(!this.parser||this.parser.version!==version){var constr=OpenLayers.Format.WMTSCapabilities["v"+version.replace(/\./g,"_")];if(!constr){throw new Error("Can't find a WMTS capabilities parser for version "+version);}
-this.parser=new constr(this.options);}
-return this.parser.read(data);},createLayer:function(capabilities,config){var layer;var required={layer:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
-var contents=capabilities.contents;var matrixSet=contents.tileMatrixSets[config.matrixSet];var layers=contents.layers;var layerDef;for(var i=0,ii=contents.layers.length;i<ii;++i){if(contents.layers[i].identifier===config.layer){layerDef=contents.layers[i];break;}}
-if(layerDef&&matrixSet){var style;for(var i=0,ii=layerDef.styles.length;i<ii;++i){style=layerDef.styles[i];if(style.isDefault){break;}}
-layer=new OpenLayers.Layer.WMTS(OpenLayers.Util.applyDefaults(config,{url:capabilities.operationsMetadata.GetTile.dcp.http.get,name:layerDef.title,style:style.identifier,matrixIds:matrixSet.matrixIds}));}
-return layer;},CLASS_NAME:"OpenLayers.Format.WMTSCapabilities"});OpenLayers.Layer.Google.v3={DEFAULTS:{maxExtent:new OpenLayers.Bounds(-128*156543.03390625,-128*156543.03390625,128*156543.03390625,128*156543.03390625),sphericalMercator:true,maxResolution:156543.03390625,units:"m",projection:"EPSG:900913"},animationEnabled:true,loadMapObject:function(){if(!this.type){this.type=google.maps.MapTypeId.ROADMAP;}
-var mapObject;var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){mapObject=cache.mapObject;++cache.count;}else{var container=this.map.viewPortDiv;var div=document.createElement("div");div.id=this.map.id+"_GMapContainer";div.style.position="absolute";div.style.width="100%";div.style.height="100%";container.appendChild(div);var center=this.map.getCenter();mapObject=new google.maps.Map(div,{center:center?new google.maps.LatLng(center.lat,center.lon):new google.maps.LatLng(0,0),zoom:this.map.getZoom()||0,mapTypeId:this.type,disableDefaultUI:true,keyboardShortcuts:false,draggable:false,disableDoubleClickZoom:true,scrollwheel:false,streetViewControl:false});cache={mapObject:mapObject,count:1};OpenLayers.Layer.Google.cache[this.map.id]=cache;this.repositionListener=google.maps.event.addListenerOnce(mapObject,"center_changed",OpenLayers.Function.bind(this.repositionMapElements,this));}
-this.mapObject=mapObject;this.setGMapVisibility(this.visibility);},repositionMapElements:function(){google.maps.event.trigger(this.mapObject,"resize");var div=this.mapObject.getDiv().firstChild;if(!div||div.childNodes.length<3){this.repositionTimer=window.setTimeout(OpenLayers.Function.bind(this.repositionMapElements,this),250);return false;}
-var cache=OpenLayers.Layer.Google.cache[this.map.id];var container=this.map.viewPortDiv;while(div.lastChild.style.display=="none"){container.appendChild(div.lastChild);}
-var termsOfUse=div.lastChild;container.appendChild(termsOfUse);termsOfUse.style.zIndex="1100";termsOfUse.style.bottom="";termsOfUse.className="olLayerGoogleCopyright olLayerGoogleV3";termsOfUse.style.display="";cache.termsOfUse=termsOfUse;var poweredBy=div.lastChild;container.appendChild(poweredBy);poweredBy.style.zIndex="1100";poweredBy.style.bottom="";poweredBy.className="olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";poweredBy.style.display="";cache.poweredBy=poweredBy;this.setGMapVisibility(this.visibility);},onMapResize:function(){if(this.visibility){google.maps.event.trigger(this.mapObject,"resize");}else{if(!this._resized){var layer=this;google.maps.event.addListenerOnce(this.mapObject,"tilesloaded",function(){delete layer._resized;google.maps.event.trigger(layer.mapObject,"resize");layer.moveTo(layer.map.getCenter(),layer.map.getZoom());});}
-this._resized=true;}},setGMapVisibility:function(visible){var cache=OpenLayers.Layer.Google.cache[this.map.id];if(cache){var type=this.type;var layers=this.map.layers;var layer;for(var i=layers.length-1;i>=0;--i){layer=layers[i];if(layer instanceof OpenLayers.Layer.Google&&layer.visibility===true&&layer.inRange===true){type=layer.type;visible=true;break;}}
-var container=this.mapObject.getDiv();if(visible===true){this.mapObject.setMapTypeId(type);container.style.left="";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.left="";cache.termsOfUse.style.display="";cache.poweredBy.style.display="";}
-cache.displayed=this.id;}else{delete cache.displayed;container.style.left="-9999px";if(cache.termsOfUse&&cache.termsOfUse.style){cache.termsOfUse.style.display="none";cache.termsOfUse.style.left="-9999px";cache.poweredBy.style.display="none";}}}},getMapContainer:function(){return this.mapObject.getDiv();},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new google.maps.LatLngBounds(new google.maps.LatLng(sw.lat,sw.lon),new google.maps.LatLng(ne.lat,ne.lon));}
-return moBounds;},getMapObjectLonLatFromMapObjectPixel:function(moPixel){var size=this.map.getSize();var lon=this.getLongitudeFromMapObjectLonLat(this.mapObject.center);var lat=this.getLatitudeFromMapObjectLonLat(this.mapObject.center);var res=this.map.getResolution();var delta_x=moPixel.x-(size.w/2);var delta_y=moPixel.y-(size.h/2);var lonlat=new OpenLayers.LonLat(lon+delta_x*res,lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}
-return this.getMapObjectLonLatFromLonLat(lonlat.lon,lonlat.lat);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);var res=this.map.getResolution();var extent=this.map.getExtent();var px=new OpenLayers.Pixel((1/res*(lon-extent.left)),(1/res*(extent.top-lat)));return this.getMapObjectPixelFromXY(px.x,px.y);},setMapObjectCenter:function(center,zoom){if(this.animationEnabled===false&&zoom!=this.mapObject.zoom){var mapContainer=this.getMapContainer();google.maps.event.addListenerOnce(this.mapObject,"idle",function(){mapContainer.style.visibility="";});mapContainer.style.visibility="hidden";}
-this.mapObject.setOptions({center:center,zoom:zoom});},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new google.maps.LatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new google.maps.LatLng(lat,lon);}
-return gLatLng;},getMapObjectPixelFromXY:function(x,y){return new google.maps.Point(x,y);},destroy:function(){if(this.repositionListener){google.maps.event.removeListener(this.repositionListener);}
-if(this.repositionTimer){window.clearTimeout(this.repositionTimer);}
-OpenLayers.Layer.Google.prototype.destroy.apply(this,arguments);}};OpenLayers.Format.CSWGetRecords.v2_0_2=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance",csw:"http://www.opengis.net/cat/csw/2.0.2",dc:"http://purl.org/dc/elements/1.1/",dct:"http://purl.org/dc/terms/",ows:"http://www.opengis.net/ows"},defaultPrefix:"csw",version:"2.0.2",schemaLocation:"http://www.opengis.net/cat/csw/2.0.2 http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd",requestId:null,resultType:null,outputFormat:null,outputSchema:null,startPosition:null,maxRecords:null,DistributedSearch:null,ResponseHandler:null,Query:null,regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[dat
a]);}
-if(data&&data.nodeType==9){data=data.documentElement;}
-var obj={};this.readNode(data,obj);return obj;},readers:{"csw":{"GetRecordsResponse":function(node,obj){obj.records=[];this.readChildNodes(node,obj);var version=this.getAttributeNS(node,"",'version');if(version!=""){obj.version=version;}},"RequestId":function(node,obj){obj.RequestId=this.getChildValue(node);},"SearchStatus":function(node,obj){obj.SearchStatus={};var timestamp=this.getAttributeNS(node,"",'timestamp');if(timestamp!=""){obj.SearchStatus.timestamp=timestamp;}},"SearchResults":function(node,obj){this.readChildNodes(node,obj);var attrs=node.attributes;var SearchResults={};for(var i=0,len=attrs.length;i<len;++i){if((attrs[i].name=="numberOfRecordsMatched")||(attrs[i].name=="numberOfRecordsReturned")||(attrs[i].name=="nextRecord")){SearchResults[attrs[i].name]=parseInt(attrs[i].nodeValue);}else{SearchResults[attrs[i].name]=attrs[i].nodeValue;}}
-obj.SearchResults=SearchResults;},"SummaryRecord":function(node,obj){var record={type:"SummaryRecord"};this.readChildNodes(node,record);obj.records.push(record);},"BriefRecord":function(node,obj){var record={type:"BriefRecord"};this.readChildNodes(node,record);obj.records.push(record);},"DCMIRecord":function(node,obj){var record={type:"DCMIRecord"};this.readChildNodes(node,record);obj.records.push(record);},"Record":function(node,obj){var record={type:"Record"};this.readChildNodes(node,record);obj.records.push(record);}},"dc":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(obj[name]instanceof Array)){obj[name]=new Array();}
-var dc_element={};var attrs=node.attributes;for(var i=0,len=attrs.length;i<len;++i){dc_element[attrs[i].name]=attrs[i].nodeValue;}
-dc_element.value=this.getChildValue(node);obj[name].push(dc_element);}},"dct":{"*":function(node,obj){var name=node.localName||node.nodeName.split(":").pop();if(!(obj[name]instanceof Array)){obj[name]=new Array();}
-obj[name].push(this.getChildValue(node));}},"ows":OpenLayers.Util.applyDefaults({"BoundingBox":function(node,obj){if(obj.bounds){obj.BoundingBox=[{crs:obj.projection,value:[obj.bounds.left,obj.bounds.bottom,obj.bounds.right,obj.bounds.top]}];delete obj.projection;delete obj.bounds;}
-OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"]["BoundingBox"].apply(this,arguments);}},OpenLayers.Format.OWSCommon.v1_0_0.prototype.readers["ows"])},write:function(options){var node=this.writeNode("csw:GetRecords",options);return OpenLayers.Format.XML.prototype.write.apply(this,[node]);},writers:{"csw":{"GetRecords":function(options){if(!options){options={};}
-var node=this.createElementNSPlus("csw:GetRecords",{attributes:{service:"CSW",version:this.version,requestId:options.requestId||this.requestId,resultType:options.resultType||this.resultType,outputFormat:options.outputFormat||this.outputFormat,outputSchema:options.outputSchema||this.outputSchema,startPosition:options.startPosition||this.startPosition,maxRecords:options.maxRecords||this.maxRecords}});if(options.DistributedSearch||this.DistributedSearch){this.writeNode("csw:DistributedSearch",options.DistributedSearch||this.DistributedSearch,node);}
-var ResponseHandler=options.ResponseHandler||this.ResponseHandler;if(ResponseHandler instanceof Array&&ResponseHandler.length>0){for(var i=0,len=ResponseHandler.length;i<len;i++){this.writeNode("csw:ResponseHandler",ResponseHandler[i],node);}}
-this.writeNode("Query",options.Query||this.Query,node);return node;},"DistributedSearch":function(options){var node=this.createElementNSPlus("csw:DistributedSearch",{attributes:{hopCount:options.hopCount}});return node;},"ResponseHandler":function(options){var node=this.createElementNSPlus("csw:ResponseHandler",{value:options.value});return node;},"Query":function(options){if(!options){options={};}
-var node=this.createElementNSPlus("csw:Query",{attributes:{typeNames:options.typeNames||"csw:Record"}});var ElementName=options.ElementName;if(ElementName instanceof Array&&ElementName.length>0){for(var i=0,len=ElementName.length;i<len;i++){this.writeNode("csw:ElementName",ElementName[i],node);}}else{this.writeNode("csw:ElementSetName",options.ElementSetName||{value:'summary'},node);}
-if(options.Constraint){this.writeNode("csw:Constraint",options.Constraint,node);}
-return node;},"ElementName":function(options){var node=this.createElementNSPlus("csw:ElementName",{value:options.value});return node;},"ElementSetName":function(options){var node=this.createElementNSPlus("csw:ElementSetName",{attributes:{typeNames:options.typeNames},value:options.value});return node;},"Constraint":function(options){var node=this.createElementNSPlus("csw:Constraint",{attributes:{version:options.version}});if(options.Filter){var format=new OpenLayers.Format.Filter({version:options.version});node.appendChild(format.write(options.Filter));}else if(options.CqlText){var child=this.createElementNSPlus("CqlText",{value:options.CqlText.value});node.appendChild(child);}
-return node;}}},CLASS_NAME:"OpenLayers.Format.CSWGetRecords.v2_0_2"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
-if(!width){width=2;}
-this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
-return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{defaultStyle:null,extractStyles:true,initialize:function(options){options=options||{};if(options.extractStyles!==false){options.defaultStyle={'externalGraphic':OpenLayers.Util.getImagesLocation()+"marker.png",'graphicWidth':21,'graphicHeight':25,'graphicXOffset':-10.5,'graphicYOffset':-12.5};}
-OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style=this.defaultStyle?OpenLayers.Util.applyDefaults({},this.defaultStyle):null;var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
-attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon'&&style){style['externalGraphic']=vals[valIndex];}else if(columns[valIndex]=='iconSize'&&style){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'&&style){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}else{attributes[columns[valIndex]]=vals[valIndex];}}}
-if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
-return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.Request.GET({url:this.location,success:this.parseData,failure:onFail,scope:this});this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options
,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var parser=new OpenLayers.Format.Text(options);var features=parser.read(text);for(var i=0,len=features.length;i<len;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
-if(feature.style.graphicXOffset!==undefined&&feature.style.graphicYOffset!==undefined){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
-if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
-if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
-data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
-this.addMarker(marker);}
-this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0,len=this.layer.map.popups.length;i<len;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
-if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',layerOptions:null,persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){if(!(options&&options.layerOptions&&options.layerOptions.styleMap)){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});}
-OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:{};},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options=OpenLayers.Util.extend({displayInLayerSwitcher:false,calculateInRange:OpenLayers.Function.True},this.layerOptions);this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
-this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
-if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.callback("create",[this.origin,this.feature]);this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
-this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
-this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
-this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();if(this.start==this.last){this.callback("done",[evt.xy]);}},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
-this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
-for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){if(this.layer){this.layer.renderer.clear();this.layer.destroyFeatures();}},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Control.SLDSelect=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["selected"],clearOnDeactivate:false,layers:null,callbacks:null,selectionSymbolizer:{'Polygon':{fillColor:'#FF0000',stroke:false},'Line':{strokeColor:'#FF0000',strokeWidth:2},'Point':{graphicName:'square',fillColor:'#FF0000',pointRadius:5}},layerOptions:null,handlerOptions:null,sketchStyle:null,wfsCache:{},layerCache:{},initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.SLDSelect.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.select,click:this.select},this.callbacks);this.handlerOptions=this.handlerOptions||{};this.layerOptions=OpenLayers.Util.applyDefaults(this.layerOptions,{displayInLayerSwitcher:false,tileOptions:{maxGetUrlLengt
h:2048}});if(this.sketchStyle){this.handlerOptions.layerOptions=OpenLayers.Util.applyDefaults(this.handlerOptions.layerOptions,{styleMap:new OpenLayers.StyleMap({"default":this.sketchStyle})});}
-this.handler=new handler(this,this.callbacks,this.handlerOptions);},destroy:function(){for(var key in this.layerCache){delete this.layerCache[key];}
-for(var key in this.wfsCache){delete this.wfsCache[key];}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},coupleLayerVisiblity:function(evt){this.setVisibility(evt.object.getVisibility());},createSelectionLayer:function(source){var selectionLayer;if(!this.layerCache[source.id]){selectionLayer=new OpenLayers.Layer.WMS(source.name,source.url,source.params,OpenLayers.Util.applyDefaults(this.layerOptions,source.getOptions()));this.layerCache[source.id]=selectionLayer;if(this.layerOptions.displayInLayerSwitcher===false){source.events.on({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});}
-this.map.addLayer(selectionLayer);}else{selectionLayer=this.layerCache[source.id];}
-return selectionLayer;},createSLD:function(layer,filters,geometryAttributes){var sld={version:"1.0.0",namedLayers:{}};var layerNames=[layer.params.LAYERS].join(",").split(",");for(var i=0,len=layerNames.length;i<len;i++){var name=layerNames[i];sld.namedLayers[name]={name:name,userStyles:[]};var symbolizer=this.selectionSymbolizer;var geometryAttribute=geometryAttributes[i];if(geometryAttribute.type.indexOf('Polygon')>=0){symbolizer={Polygon:this.selectionSymbolizer['Polygon']};}else if(geometryAttribute.type.indexOf('LineString')>=0){symbolizer={Line:this.selectionSymbolizer['Line']};}else if(geometryAttribute.type.indexOf('Point')>=0){symbolizer={Point:this.selectionSymbolizer['Point']};}
-var filter=filters[i];sld.namedLayers[name].userStyles.push({name:'default',rules:[new OpenLayers.Rule({symbolizer:symbolizer,filter:filter,maxScaleDenominator:layer.options.minScale})]});}
-return new OpenLayers.Format.SLD().write(sld);},parseDescribeLayer:function(request){var format=new OpenLayers.Format.WMSDescribeLayer();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var describeLayer=format.read(doc);var typeNames=[];var url=null;for(var i=0,len=describeLayer.length;i<len;i++){if(describeLayer[i].owsType=="WFS"){typeNames.push(describeLayer[i].typeName);url=describeLayer[i].owsURL;}}
-var options={url:url,params:{SERVICE:"WFS",TYPENAME:typeNames.toString(),REQUEST:"DescribeFeatureType",VERSION:"1.0.0"},callback:function(request){var format=new OpenLayers.Format.WFSDescribeFeatureType();var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var describeFeatureType=format.read(doc);this.control.wfsCache[this.layer.id]=describeFeatureType;this.control._queue&&this.control.applySelection();},scope:this};OpenLayers.Request.GET(options);},getGeometryAttributes:function(layer){var result=[];var cache=this.wfsCache[layer.id];for(var i=0,len=cache.featureTypes.length;i<len;i++){var typeName=cache.featureTypes[i];var properties=typeName.properties;for(var j=0,lenj=properties.length;j<lenj;j++){var property=properties[j];var type=property.type;if((type.indexOf('LineString')>=0)||(type.indexOf('GeometryAssociationType')>=0)||(type.indexOf('GeometryPropertyType')>=0)||(type.indexOf('Point')>=0)||(type.indexOf('Polygon')>=0)){result.push(property);}}}
-return result;},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&!this.wfsCache[layer.id]){var options={url:layer.url,params:{SERVICE:"WMS",VERSION:layer.params.VERSION,LAYERS:layer.params.LAYERS,REQUEST:"DescribeLayer"},callback:this.parseDescribeLayer,scope:{layer:layer,control:this}};OpenLayers.Request.GET(options);}}}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];if(layer&&this.clearOnDeactivate===true){var layerCache=this.layerCache;var selectionLayer=layerCache[layer.id];if(selectionLayer){layer.events.un({"visibilitychanged":this.coupleLayerVisiblity,scope:selectionLayer});selectionLayer.destroy();delete layerCache[layer.id];}}}}
-return deactivated;},setLayers:function(layers){if(this.active){this.deactivate();this.layers=layers;this.activate();}else{this.layers=layers;}},createFilter:function(geometryAttribute,geometry){var filter=null;if(this.handler instanceof OpenLayers.Handler.RegularPolygon){if(this.handler.irregular===true){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:geometryAttribute.name,value:geometry.getBounds()});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Polygon){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else if(this.handler instanceof OpenLayers.Handler.Path){if(geometryAttribute.type.indexOf('Point')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distanc
e:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}}else if(this.handler instanceof OpenLayers.Handler.Click){if(geometryAttribute.type.indexOf('Polygon')>=0){filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:geometryAttribute.name,value:geometry});}else{filter=new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,property:geometryAttribute.name,distance:this.map.getExtent().getWidth()*0.01,distanceUnits:this.map.getUnits(),value:geometry});}}
-return filter;},select:function(geometry){this._queue=function(){for(var i=0,len=this.layers.length;i<len;i++){var layer=this.layers[i];var geometryAttributes=this.getGeometryAttributes(layer);var filters=[];for(var j=0,lenj=geometryAttributes.length;j<lenj;j++){var geometryAttribute=geometryAttributes[j];if(geometryAttribute!==null){if(!(geometry instanceof OpenLayers.Geometry)){var point=this.map.getLonLatFromPixel(geometry.xy);geometry=new OpenLayers.Geometry.Point(point.lon,point.lat);}
-var filter=this.createFilter(geometryAttribute,geometry);if(filter!==null){filters.push(filter);}}}
-var selectionLayer=this.createSelectionLayer(layer);var sld=this.createSLD(layer,filters,geometryAttributes);this.events.triggerEvent("selected",{layer:layer,filters:filters});selectionLayer.mergeNewParams({SLD_BODY:sld});delete this._queue;}};this.applySelection();},applySelection:function(){var canApply=true;for(var i=0,len=this.layers.length;i<len;i++){if(!this.wfsCache[this.layers[i].id]){canApply=false;break;}}
-canApply&&this._queue.call(this);},CLASS_NAME:"OpenLayers.Control.SLDSelect"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,geodesic:false,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
-this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale;if(this.geodesic===true){var units=this.map.getUnits();if(!units){return;}
-var inches=OpenLayers.INCHES_PER_UNIT;scale=(this.map.getGeodesicPixelSize().w||0.000001)*inches["km"]*OpenLayers.DOTS_PER_INCH;}else{scale=this.map.getScale();}
-if(!scale){return;}
-if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,useHttpTile:false,singleTile:false,useOverlay:false,useAsyncOverlay:true,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},OVERLAY_PARAMS:{operation:'GETDYNAMICMAPOVERLAYIMAGE',format:'PNG',locale:'en',clip:'1',version:'2.0.0'},FOLDER_PARAMS:{tileColumnsPerFolder:30,tileRowsPerFolder:30,format:'png',querystring:null},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
-if(options&&options.useOverlay!=null){this.useOverlay=options.useOverlay;}
-if(this.singleTile){if(this.useOverlay){OpenLayers.Util.applyDefaults(this.params,this.OVERLAY_PARAMS);if(!this.useAsyncOverlay){this.params.version="1.0.0";}}else{OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}}else{if(this.useHttpTile){OpenLayers.Util.applyDefaults(this.params,this.FOLDER_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);}
-this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getSize();if(this.singleTile){var params={setdisplaydpi:OpenLayers.DOTS_PER_INCH,setdisplayheight:mapSize.h*this.ratio,setdisplaywidth:mapSize.w*this.ratio,setviewcenterx:center.lon,setviewcentery:center.lat,setviewscale:this.map.getScale()};if(this.useOverlay&&!this.useAsyncOverlay){var getVisParams={};getVisParams=OpenLayers.Util.extend(getVisParams,params);getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';url=this.getFullRequestString(getVisParams);OpenLayers.Request.GET({url:url,async:false});}
-url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);if(this.useHttpTile){url=this.getImageFilePath({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}else{url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}}
-return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
-var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},getImageFilePath:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
-var requestString=url;var tileRowGroup="";var tileColGroup="";if(newParams.tilerow<0){tileRowGroup='-';}
-if(newParams.tilerow==0){tileRowGroup+='0';}else{tileRowGroup+=Math.floor(Math.abs(newParams.tilerow/this.params.tileRowsPerFolder))*this.params.tileRowsPerFolder;}
-if(newParams.tilecol<0){tileColGroup='-';}
-if(newParams.tilecol==0){tileColGroup+='0';}else{tileColGroup+=Math.floor(Math.abs(newParams.tilecol/this.params.tileColumnsPerFolder))*this.params.tileColumnsPerFolder;}
-var tilePath='/S'+Math.floor(newParams.scaleindex)
-+'/'+this.params.basemaplayergroupname
-+'/R'+tileRowGroup
-+'/C'+tileColGroup
-+'/'+(newParams.tilerow%this.params.tileRowsPerFolder)
-+'_'+(newParams.tilecol%this.params.tileColumnsPerFolder)
-+'.'+this.params.format;if(this.params.querystring){tilePath+="?"+this.params.querystring;}
-requestString+=tilePath;return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Control.Measure=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:['measure','measurepartial'],handlerOptions:null,callbacks:null,displaySystem:'metri
c',geodesic:false,displaySystemUnits:{geographic:['dd'],english:['mi','ft','in'],metric:['km','m']},partialDelay:300,delayedTrigger:null,persist:false,immediate:false,initialize:function(handler,options){this.EVENT_TYPES=OpenLayers.Control.Measure.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);var callbacks={done:this.measureComplete,point:this.measurePartial};if(this.immediate){callbacks.modify=this.measureImmediate;}
-this.callbacks=OpenLayers.Util.extend(callbacks,this.callbacks);this.handlerOptions=OpenLayers.Util.extend({persist:this.persist},this.handlerOptions);this.handler=new handler(this,this.callbacks,this.handlerOptions);},deactivate:function(){this.cancelDelay();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},cancel:function(){this.cancelDelay();this.handler.cancel();},setImmediate:function(immediate){this.immediate=immediate;if(this.immediate){this.callbacks.modify=this.measureImmediate;}else{delete this.callbacks.modify;}},updateHandler:function(handler,options){var active=this.active;if(active){this.deactivate();}
-this.handler=new handler(this,this.callbacks,options);if(active){this.activate();}},measureComplete:function(geometry){this.cancelDelay();this.measure(geometry,"measure");},measurePartial:function(point,geometry){this.cancelDelay();geometry=geometry.clone();if(this.handler.freehandMode(this.handler.evt)){this.measure(geometry,"measurepartial");}else{this.delayedTrigger=window.setTimeout(OpenLayers.Function.bind(function(){this.delayedTrigger=null;this.measure(geometry,"measurepartial");},this),this.partialDelay);}},measureImmediate:function(point,feature,drawing){if(drawing&&this.delayedTrigger===null&&!this.handler.freehandMode(this.handler.evt)){this.measure(feature.geometry,"measurepartial");}},cancelDelay:function(){if(this.delayedTrigger!==null){window.clearTimeout(this.delayedTrigger);this.delayedTrigger=null;}},measure:function(geometry,eventType){var stat,order;if(geometry.CLASS_NAME.indexOf('LineString')>-1){stat=this.getBestLength(geometry);order=1;}else{stat=this.
getBestArea(geometry);order=2;}
-this.events.triggerEvent(eventType,{measure:stat[0],units:stat[1],order:order,geometry:geometry});},getBestArea:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,area;for(var i=0,len=units.length;i<len;++i){unit=units[i];area=this.getArea(geometry,unit);if(area>1){break;}}
-return[area,unit];},getArea:function(geometry,units){var area,geomUnits;if(this.geodesic){area=geometry.getGeodesicArea(this.map.getProjectionObject());geomUnits="m";}else{area=geometry.getArea();geomUnits=this.map.getUnits();}
-var inPerDisplayUnit=OpenLayers.INCHES_PER_UNIT[units];if(inPerDisplayUnit){var inPerMapUnit=OpenLayers.INCHES_PER_UNIT[geomUnits];area*=Math.pow((inPerMapUnit/inPerDisplayUnit),2);}
-return area;},getBestLength:function(geometry){var units=this.displaySystemUnits[this.displaySystem];var unit,length;for(var i=0,len=units.length;i<len;++i){unit=units[i];length=this.getLength(geometry,unit);if(length>1){break;}}
-return[length,unit];},getLength:function(geometry,units){var length,geomUnits;if(this.geodesic){length=geometry.getGeodesicLength(this.map.getProjectionObject());geomUnits="m";}else{length=geometry.getLength();geomUnits=this.map.getUnits();}
-var inPerDisplayUnit=OpenLayers.INCHES_PER_UNIT[units];if(inPerDisplayUnit){var inPerMapUnit=OpenLayers.INCHES_PER_UNIT[geomUnits];length*=(inPerMapUnit/inPerDisplayUnit);}
-return length;},CLASS_NAME:"OpenLayers.Control.Measure"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},write_wmc_Layer:function(context){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[context]);node.appendChild(this.write_wmc_FormatList(context));node.appendChild(this.write_wmc_StyleList(context));node.appendChild(this.write_wmc_LayerExtension(context));},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMTSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.OWSCommon.v1_1_0,{version:"1.0.0",namespaces:{ows:"http://www.opengis.net/ows/1.1",wmts:"http://www.opengis.net/wmts/1.0",xlink:"http://www.w3.org/1999/xlink"},yx:null,defaultPrefix:"wmts",initialize:function(options){OpenLayers.Format.XML.pr
ototype.initialize.apply(this,[options]);this.options=options;var yx=OpenLayers.Util.extend({},OpenLayers.Format.WMTSCapabilities.prototype.yx);this.yx=OpenLayers.Util.extend(yx,this.yx);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var capabilities={};this.readNode(data,capabilities);capabilities.version=this.version;return capabilities;},readers:{"wmts":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};obj.contents.layers=[];obj.contents.tileMatrixSets={};this.readChildNodes(node,obj.contents);},"Layer":function(node,obj){var layer={styles:[],formats:[],tileMatrixSetLinks:[]};layer.layers=[];this.readChildNodes(node,layer);obj.layers.push(layer);},"Style":function(node,obj){var style={};style.isDefault=(node.getAttribute("isDefault")==="true");this.readChildNodes(node,style);obj.styles.push(style);},"Format":function(node,obj){obj.formats.push(this.getChildValue(node));},"TileMatrixSetLink":function(node,obj){var tileMatrixSetLink={};this.readChildNodes(node,tileMatrixSetLink);obj.tileMatrixSetLinks.push(tileMatrixSetLink);},"TileMatrixSet":function(node,obj){if(obj.layers){var tileMatrixSet={matrixIds:[]};this.readChildNodes(node,tileMatr
ixSet);obj.tileMatrixSets[tileMatrixSet.identifier]=tileMatrixSet;}else{obj.tileMatrixSet=this.getChildValue(node);}},"TileMatrix":function(node,obj){var tileMatrix={supportedCRS:obj.supportedCRS};this.readChildNodes(node,tileMatrix);obj.matrixIds.push(tileMatrix);},"ScaleDenominator":function(node,obj){obj.scaleDenominator=parseFloat(this.getChildValue(node));},"TopLeftCorner":function(node,obj){var topLeftCorner=this.getChildValue(node);var coords=topLeftCorner.split(" ");var yx;if(obj.supportedCRS){var crs=obj.supportedCRS.replace(/urn:ogc:def:crs:(\w+):.+:(\w+)$/,"urn:ogc:def:crs:$1::$2");yx=!!this.yx[crs];}
-if(yx){obj.topLeftCorner=new OpenLayers.LonLat(coords[1],coords[0]);}else{obj.topLeftCorner=new OpenLayers.LonLat(coords[0],coords[1]);}},"TileWidth":function(node,obj){obj.tileWidth=parseInt(this.getChildValue(node));},"TileHeight":function(node,obj){obj.tileHeight=parseInt(this.getChildValue(node));},"MatrixWidth":function(node,obj){obj.matrixWidth=parseInt(this.getChildValue(node));},"MatrixHeight":function(node,obj){obj.matrixHeight=parseInt(this.getChildValue(node));},"ResourceURL":function(node,obj){obj.resourceUrl=obj.resourceUrl||{};obj.resourceUrl[node.getAttribute("resourceType")]={format:node.getAttribute("format"),template:node.getAttribute("template")};},"WSDL":function(node,obj){obj.wsdl={};obj.wsdl.href=node.getAttribute("xlink:href");},"ServiceMetadataURL":function(node,obj){obj.serviceMetadataUrl={};obj.serviceMetadataUrl.href=node.getAttribute("xlink:href");}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.W
MTSCapabilities.v1_0_0"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{contentDisplayClass:"olFramedCloudPopupContent",autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(1276,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,18),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-632)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-688)}]},"tr":{'offset':n
ew OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',19),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-631)},{size:new OpenLayers.Size(22,19),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-1238,-631)},{size:new OpenLayers.Size(81,35),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-687)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLaye
rs.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-1238,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-1238,-629)},{size:new OpenLayers.Size(81,33),anchor:
new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(1200,660),initialize:function(id,lonlat,contentSize,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className=this.contentDisplayClass;},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Tile.Image.IFrame={useIFrame:null,clear:function(){if(this.useIFrame){if(this.imgDiv){var iFrame=this.imgDiv.firstChild;OpenLayers.Event.stopObservingElement(iFrame);this.imgDiv.removeChild(iFrame);delete iFrame;}}else{OpenLayers.Tile.Image.prototype.clear.apply(this,arguments);}},renderTile:function(){if(OpenLayers.Tile.Image.prototype.renderTile.apply(this,arguments)&&this.useIFrame){var form=this.creat
eRequestForm();this.imgDiv.appendChild(form);form.submit();this.imgDiv.removeChild(form);delete form;}
-return true;},initImgDiv:function(){this.useIFrame=this.maxGetUrlLength!==null&&!this.layer.async&&this.url.length>this.maxGetUrlLength;if(this.imgDiv!=null){var nodeName=this.imgDiv.nodeName.toLowerCase();if((this.useIFrame&&nodeName=="img")||(!this.useIFrame&&nodeName=="div")){this.removeImgDiv();this.imgDiv=null;}}
-if(this.useIFrame){if(this.imgDiv==null){var eventPane=document.createElement("div");if(OpenLayers.BROWSER_NAME=="msie"){eventPane.style.backgroundColor='#FFFFFF';eventPane.style.filter='chroma(color=#FFFFFF)';}
-OpenLayers.Util.modifyDOMElement(eventPane,null,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");this.imgDiv=document.createElement("div");this.imgDiv.appendChild(eventPane);OpenLayers.Util.modifyDOMElement(this.imgDiv,this.id,null,this.layer.getImageSize(),"relative");this.imgDiv.className='olTileImage';this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
-this.imgDiv.map=this.layer.map;}
-this.imgDiv.viewRequestID=this.layer.map.viewRequestID;}else{OpenLayers.Tile.Image.prototype.initImgDiv.apply(this,arguments);}},createIFrame:function(){var id=this.id+'_iFrame';var iframe;if(OpenLayers.BROWSER_NAME=="msie"){iframe=document.createElement('<iframe name="'+id+'">');iframe.style.backgroundColor='#FFFFFF';iframe.style.filter='chroma(color=#FFFFFF)';}
-else{iframe=document.createElement('iframe');iframe.style.backgroundColor='transparent';iframe.name=id;}
-iframe.id=id;iframe.scrolling='no';iframe.marginWidth='0px';iframe.marginHeight='0px';iframe.frameBorder='0';OpenLayers.Util.modifyDOMElement(iframe,id,new OpenLayers.Pixel(0,0),this.layer.getImageSize(),"absolute");var onload=function(){this.show();if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};OpenLayers.Event.observe(iframe,'load',OpenLayers.Function.bind(onload,this));return iframe;},createRequestForm:function(){var form=document.createElement('form');form.method='POST';var cacheId=this.layer.params["_OLSALT"];cacheId=(cacheId?cacheId+"_":"")+this.bounds.toBBOX();form.action=OpenLayers.Util.urlAppend(this.layer.url,cacheId);this.imgDiv.insertBefore(this.createIFrame(),this.imgDiv.firstChild);form.target=this.id+'_iFrame';var imageSize=this.layer.getImageSize();var params=OpenLayers.Util.getParameters(this.url);for(var par in params){var field=document.createElement('input');field.type='hidden';field.name=par;field.value=params[par];form.ap
pendChild(field);}
-return form;}};OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Strategy.Refresh=OpenLayers.Class(OpenLayers.Strategy,{force:false,interval:0,timer:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){if(this.layer.visibility===true){this.start();}
-this.layer.events.on({"visibilitychanged":this.reset,scope:this});}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.stop();}
-return deactivated;},reset:function(){if(this.layer.visibility===true){this.start();}else{this.stop();}},start:function(){if(this.interval&&typeof this.interval==="number"&&this.interval>0){this.timer=window.setInterval(OpenLayers.Function.bind(this.refresh,this),this.interval);}},refresh:function(){if(this.layer&&this.layer.refresh&&typeof this.layer.refresh=="function"){this.layer.refresh({force:this.force});}},stop:function(){if(this.timer!==null){window.clearInterval(this.timer);this.timer=null;}},CLASS_NAME:"OpenLayers.Strategy.Refresh"});OpenLayers.Format.SOSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.SOSCapabilities,{namespaces:{ows:"http://www.opengis.net/ows/1.1",sos:"http://www.opengis.net/sos/1.0",gml:"http://www.opengis.net/gml",xlink:"http://www.w3.org/1999/xlink"},regExes:{trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options
-var capabilities={};this.readNode(data,capabilities);return capabilities;},readers:{"gml":OpenLayers.Util.applyDefaults({"name":function(node,obj){obj.name=this.getChildValue(node);},"TimePeriod":function(node,obj){obj.timePeriod={};this.readChildNodes(node,obj.timePeriod);},"beginPosition":function(node,timePeriod){timePeriod.beginPosition=this.getChildValue(node);},"endPosition":function(node,timePeriod){timePeriod.endPosition=this.getChildValue(node);}},OpenLayers.Format.GML.v3.prototype.readers["gml"]),"sos":{"Capabilities":function(node,obj){this.readChildNodes(node,obj);},"Contents":function(node,obj){obj.contents={};this.readChildNodes(node,obj.contents);},"ObservationOfferingList":function(node,contents){contents.offeringList={};this.readChildNodes(node,contents.offeringList);},"ObservationOffering":function(node,offeringList){var id=this.getAttributeNS(node,this.namespaces.gml,"id");offeringList[id]={procedures:[],observedProperties:[],featureOfInterestIds:[],respon
seFormats:[],resultModels:[],responseModes:[]};this.readChildNodes(node,offeringList[id]);},"time":function(node,offering){offering.time={};this.readChildNodes(node,offering.time);},"procedure":function(node,offering){offering.procedures.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"observedProperty":function(node,offering){offering.observedProperties.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"featureOfInterest":function(node,offering){offering.featureOfInterestIds.push(this.getAttributeNS(node,this.namespaces.xlink,"href"));},"responseFormat":function(node,offering){offering.responseFormats.push(this.getChildValue(node));},"resultModel":function(node,offering){offering.resultModels.push(this.getChildValue(node));},"responseMode":function(node,offering){offering.responseModes.push(this.getChildValue(node));;}},"ows":OpenLayers.Format.OWSCommon.v1_1_0.prototype.readers["ows"]},CLASS_NAME:"OpenLayers.Format.SOSCapabilities.v1_0_0"});OpenL
ayers.Handler.Pinch=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,pinching:false,last:null,start:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},touchstart:function(evt){var propagate=true;this.pinching=false;if(OpenLayers.Event.isMultiTouch(evt)){this.started=true;this.last=this.start={distance:this.getDistance(evt.touches),delta:0,scale:1};this.callback("start",[evt,this.start]);propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-OpenLayers.Event.stop(evt);return propagate;},touchmove:function(evt){var propagate=true;if(this.started&&OpenLayers.Event.isMultiTouch(evt)){this.pinching=true;var current=this.getPinchData(evt);this.callback("move",[evt,current]);this.last=current;propagate=false;}
-return propagate;},touchend:function(evt){if(this.started){this.started=false;this.pinching=false;this.callback("done",[evt,this.start,this.last]);this.start=null;this.last=null;}
-return true;},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.pinching=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.pinching=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},getDistance:function(touches){var t0=touches[0];var t1=touches[1];return Math.sqrt(Math.pow(t0.clientX-t1.clientX,2)+
-Math.pow(t0.clientY-t1.clientY,2));},getPinchData:function(evt){var distance=this.getDistance(evt.touches);var scale=distance/this.start.distance;return{distance:distance,delta:this.last.distance-distance,scale:scale};},CLASS_NAME:"OpenLayers.Handler.Pinch"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Control.PinchZoom=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,containerOrigin:null,pinchOrigin:null,currentCenter:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.handler=new OpenLayers.Handler.P
inch(this,{start:this.pinchStart,move:this.pinchMove,done:this.pinchDone},this.handlerOptions);},activate:function(){var activated=OpenLayers.Control.prototype.activate.apply(this,arguments);if(activated){this.map.events.on({moveend:this.updateContainerOrigin,scope:this});this.updateContainerOrigin();}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.apply(this,arguments);if(this.map&&this.map.events){this.map.events.un({moveend:this.updateContainerOrigin,scope:this});}
-return deactivated;},updateContainerOrigin:function(){var container=this.map.layerContainerDiv;this.containerOrigin={x:parseInt(container.style.left,10),y:parseInt(container.style.top,10)};},pinchStart:function(evt,pinchData){this.pinchOrigin=evt.xy;},pinchMove:function(evt,pinchData){var scale=pinchData.scale;var containerOrigin=this.containerOrigin;var pinchOrigin=this.pinchOrigin;var current=evt.xy;var dx=(current.x-pinchOrigin.x)+(scale-1)*(containerOrigin.x-pinchOrigin.x);var dy=(current.y-pinchOrigin.y)+(scale-1)*(containerOrigin.y-pinchOrigin.y);var style=this.map.layerContainerDiv.style;var transform="translate("+dx+"px, "+dy+"px) scale("+scale+")";style['-webkit-transform']=transform;style['-moz-transform']=transform;this.currentCenter=current;},pinchDone:function(evt,start,last){var zoom=this.map.getZoomForResolution(this.map.getResolution()/last.scale,true);var resolution=this.map.getResolutionForZoom(zoom);var location=this.map.getLonLatFromPixel(this.pinchOrigin
);var zoomPixel=this.currentCenter;var size=this.map.getSize();location.lon+=resolution*((size.w/2)-zoomPixel.x);location.lat-=resolution*((size.h/2)-zoomPixel.y);this.map.setCenter(location,zoom);var style=this.map.layerContainerDiv.style;style['-webkit-transform']="";style['-moz-transform']="";},CLASS_NAME:"OpenLayers.Control.PinchZoom"});OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEve
nt("loadstart");}
-this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
-this.request=OpenLayers.Request.GET({url:this.url,success:success,failure:failure,scope:this});},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var xml=new OpenLayers.Format.XML();if(typeof doc=="string"){doc=xml.read(doc);}
-var resultFeatures=xml.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","featureMember");this.addResults(resultFeatures);}}
-if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.Geolocate=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["locationupdated","locationfailed","locationuncapable"],geolocation:navigator.geolocation,bind:true,watch:false,geolocationOptions:null,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.Geolocate.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);this.geolocationOptions={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},activate:function(){if(!this.geolocation){this.events.triggerEvent("locationuncapable");return false;}
-if(OpenLayers.Control.prototype.activate.apply(this,arguments)){if(this.watch){this.watchId=this.geolocation.watchPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);}else{this.getCurrentLocation();}
-return true;}
-return false;},deactivate:function(){if(this.active&&this.watchId!==null){this.geolocation.clearWatch(this.watchId);}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},geolocate:function(position){var center=new OpenLayers.LonLat(position.coords.longitude,position.coords.latitude).transform(new OpenLayers.Projection("EPSG:4326"),this.map.getProjectionObject());if(this.bind){this.map.setCenter(center);}
-this.events.triggerEvent("locationupdated",{position:position,point:new OpenLayers.Geometry.Point(center.lon,center.lat)});},getCurrentLocation:function(){if(!this.active||this.watch){return false;}
-this.geolocation.getCurrentPosition(OpenLayers.Function.bind(this.geolocate,this),OpenLayers.Function.bind(this.failure,this),this.geolocationOptions);return true;},failure:function(error){this.events.triggerEvent("locationfailed",{error:error});},CLASS_NAME:"OpenLayers.Control.Geolocate"});OpenLayers.Layer.ArcGIS93Rest=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{format:"png"},isBaseLayer:true,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="jpg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"gif":"png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.ArcGIS93Rest(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var projWords=this.projection.getCode().split(":");var srid=projWords[projWords.length-1];var imageSize=this.getImageSize();var newParams={'BBOX':bounds.toBBOX(),'SIZE':imageSize.w+","+imageSize.h,'F':"image",'BBOXSR':srid,'IMAGESR':srid};if(this.layerDefs){var layerDefStrList=[];var layerID;for(layerID in this.layerDefs){if(this.layerDefs.hasOwnProperty(layerID)){if(this.layerDefs[layerID]){layerDefStrList.push(layerID);layerDefStrList.push(":");layerDefStrList.push(this.layerDefs[layerID]);layerDefStrList.push(";");}}}
-if(layerDefStrList.length>0){newParams['LAYERDEFS']=layerDefStrList.join("");}}
-var requestString=this.getFullRequestString(newParams);return requestString;},setLayerFilter:function(id,queryDef){if(!this.layerDefs){this.layerDefs={};}
-if(queryDef){this.layerDefs[id]=queryDef;}else{delete this.layerDefs[id];}},clearLayerFilter:function(id){if(id){delete this.layerDefs[id];}else{delete this.layerDefs;}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.ArcGIS93Rest"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="tr
ue")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.getOptions());}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
-return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
-return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
-Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Control.GetFeature=OpenLayers.Class(OpenLayers.Control,{protocol:null,multipleKey:null,toggleKey:null,modifiers:null,multiple:false,click:true,single:true,clickout:true,toggle:false,clickTolerance:5,hover:false,box:false,maxFeatures:10,features:null,hoverFeature:null,handlerOptions:null,handlers:null,hoverResponse:null,filterType:OpenLayers.Filter.Spatial.BBOX,EVENT_TYPES:["featureselected","featuresselected","featureunselected","clickout","beforefeatureselected","beforefeaturesselected","hoverfeature","outfeature"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.GetFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);this.features={};this.handlers={};if(this.click){this.handlers.click=new OpenLayers.Handler.Click(this,{click:this.selectClick},this.han
dlerOptions.click||{});}
-if(this.box){this.handlers.box=new OpenLayers.Handler.Box(this,{done:this.selectBox},OpenLayers.Util.extend(this.handlerOptions.box,{boxDivClassName:"olHandlerBoxSelectFeature"}));}
-if(this.hover){this.handlers.hover=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.selectHover},OpenLayers.Util.extend(this.handlerOptions.hover,{'delay':250}));}},activate:function(){if(!this.active){for(var i in this.handlers){this.handlers[i].activate();}}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){if(this.active){for(var i in this.handlers){this.handlers[i].deactivate();}}
-return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},selectClick:function(evt){var bounds=this.pixelToBounds(evt.xy);this.setModifiers(evt);this.request(bounds,{single:this.single});},selectBox:function(position){var bounds;if(position instanceof OpenLayers.Bounds){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{if(this.click){return;}
-bounds=this.pixelToBounds(position);}
-this.setModifiers(this.handlers.box.dragHandler.evt);this.request(bounds);},selectHover:function(evt){var bounds=this.pixelToBounds(evt.xy);this.request(bounds,{single:true,hover:true});},cancelHover:function(){if(this.hoverResponse){this.protocol.abort(this.hoverResponse);this.hoverResponse=null;OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");}},request:function(bounds,options){options=options||{};var filter=new OpenLayers.Filter.Spatial({type:this.filterType,value:bounds});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");var response=this.protocol.read({maxFeatures:options.single==true?this.maxFeatures:undefined,filter:filter,callback:function(result){if(result.success()){if(result.features.length){if(options.single==true){this.selectBestFeature(result.features,bounds.getCenterLonLat(),options);}else{this.select(result.features);}}else if(options.hover){this.hoverSelect();}else{this.events.triggerEvent("clickout");if(this.clickout){this.
unselectAll();}}}
-OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");},scope:this});if(options.hover==true){this.hoverResponse=response;}},selectBestFeature:function(features,clickPosition,options){options=options||{};if(features.length){var point=new OpenLayers.Geometry.Point(clickPosition.lon,clickPosition.lat);var feature,resultFeature,dist;var minDist=Number.MAX_VALUE;for(var i=0;i<features.length;++i){feature=features[i];if(feature.geometry){dist=point.distanceTo(feature.geometry,{edge:false});if(dist<minDist){minDist=dist;resultFeature=feature;if(minDist==0){break;}}}}
-if(options.hover==true){this.hoverSelect(resultFeature);}else{this.select(resultFeature||features);}}},setModifiers:function(evt){this.modifiers={multiple:this.multiple||(this.multipleKey&&evt[this.multipleKey]),toggle:this.toggle||(this.toggleKey&&evt[this.toggleKey])};},select:function(features){if(!this.modifiers.multiple&&!this.modifiers.toggle){this.unselectAll();}
-if(!(features instanceof Array)){features=[features];}
-var cont=this.events.triggerEvent("beforefeaturesselected",{features:features});if(cont!==false){var selectedFeatures=[];var feature;for(var i=0,len=features.length;i<len;++i){feature=features[i];if(this.features[feature.fid||feature.id]){if(this.modifiers.toggle){this.unselect(this.features[feature.fid||feature.id]);}}else{cont=this.events.triggerEvent("beforefeatureselected",{feature:feature});if(cont!==false){this.features[feature.fid||feature.id]=feature;selectedFeatures.push(feature);this.events.triggerEvent("featureselected",{feature:feature});}}}
-this.events.triggerEvent("featuresselected",{features:selectedFeatures});}},hoverSelect:function(feature){var fid=feature?feature.fid||feature.id:null;var hfid=this.hoverFeature?this.hoverFeature.fid||this.hoverFeature.id:null;if(hfid&&hfid!=fid){this.events.triggerEvent("outfeature",{feature:this.hoverFeature});this.hoverFeature=null;}
-if(fid&&fid!=hfid){this.events.triggerEvent("hoverfeature",{feature:feature});this.hoverFeature=feature;}},unselect:function(feature){delete this.features[feature.fid||feature.id];this.events.triggerEvent("featureunselected",{feature:feature});},unselectAll:function(){for(var fid in this.features){this.unselect(this.features[fid]);}},setMap:function(map){for(var i in this.handlers){this.handlers[i].setMap(map);}
-OpenLayers.Control.prototype.setMap.apply(this,arguments);},pixelToBounds:function(pixel){var llPx=pixel.add(-this.clickTolerance/2,this.clickTolerance/2);var urPx=pixel.add(this.clickTolerance/2,-this.clickTolerance/2);var ll=this.map.getLonLatFromPixel(llPx);var ur=this.map.getLonLatFromPixel(urPx);return new OpenLayers.Bounds(ll.lon,ll.lat,ur.lon,ur.lat);},CLASS_NAME:"OpenLayers.Control.GetFeature"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,emptyString:null,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.events.register('mousemove',this,this.redraw);this.map.events.register('mouseout',t
his,this.reset);this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('mousemove',this,this.redraw);this.map.events.unregister('mouseout',this,this.reset);this.element.innerHTML="";return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
-return this.div;},redraw:function(evt){var lonLat;if(evt==null){this.reset();return;}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
-{this.lastXy=evt.xy;return;}
-lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
-if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
-this.lastXy=evt.xy;}
-var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},reset:function(evt){if(this.emptyString!=null){this.element.innerHTML=this.emptyString;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
-lonLat.lon.toFixed(digits)+
-this.separator+
-lonLat.lat.toFixed(digits)+
-this.suffix;return newHtml;},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Protocol.HTTP=OpenLayers.Class(OpenLayers.Protocol,{url:null,headers:null,params:null,callback:null,scope:null,readWithPOST:false,wildcarded:false,srsInBBOX:false,initialize:function(options){options=options||{};this.params={};this.headers={};OpenLayers.Protocol.prototype.initialize.apply(this,arguments);},destroy:function(){this.params=null;this.headers=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){OpenLayers.Protocol.prototype.read.apply(this,arguments);options=OpenLayers.Util.applyDefaults(options,this.options);options.params=OpenLayers.Util.applyDefaults(options.params,this.options.params);if(options.filter){options.params=this.filterToParams(options.filter,options.params);}
-var readWithPOST=(options.readWithPOST!==undefined)?options.readWithPOST:this.readWithPOST;var resp=new OpenLayers.Protocol.Response({requestType:"read"});if(readWithPOST){resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,resp,options),data:OpenLayers.Util.getParameterString(options.params),headers:{"Content-Type":"application/x-www-form-urlencoded"}});}else{resp.priv=OpenLayers.Request.GET({url:options.url,callback:this.createCallback(this.handleRead,resp,options),params:options.params,headers:options.headers});}
-return resp;},handleRead:function(resp,options){this.handleResponse(resp,options);},filterToParams:function(filter,params){params=params||{};var className=filter.CLASS_NAME;var filterType=className.substring(className.lastIndexOf(".")+1);switch(filterType){case"Spatial":switch(filter.type){case OpenLayers.Filter.Spatial.BBOX:params.bbox=filter.value.toArray();if(this.srsInBBOX&&filter.projection){params.bbox.push(filter.projection.getCode());}
-break;case OpenLayers.Filter.Spatial.DWITHIN:params.tolerance=filter.distance;case OpenLayers.Filter.Spatial.WITHIN:params.lon=filter.value.x;params.lat=filter.value.y;break;default:OpenLayers.Console.warn("Unknown spatial filter type "+filter.type);}
-break;case"Comparison":var op=OpenLayers.Protocol.HTTP.COMP_TYPE_TO_OP_STR[filter.type];if(op!==undefined){var value=filter.value;if(filter.type==OpenLayers.Filter.Comparison.LIKE){value=this.regex2value(value);if(this.wildcarded){value="%"+value+"%";}}
-params[filter.property+"__"+op]=value;params.queryable=params.queryable||[];params.queryable.push(filter.property);}else{OpenLayers.Console.warn("Unknown comparison filter type "+filter.type);}
-break;case"Logical":if(filter.type===OpenLayers.Filter.Logical.AND){for(var i=0,len=filter.filters.length;i<len;i++){params=this.filterToParams(filter.filters[i],params);}}else{OpenLayers.Console.warn("Unsupported logical filter type "+filter.type);}
-break;default:OpenLayers.Console.warn("Unknown filter type "+filterType);}
-return params;},regex2value:function(value){value=value.replace(/%/g,"\\%");value=value.replace(/\\\\\.(\*)?/g,function($0,$1){return $1?$0:"\\\\_";});value=value.replace(/\\\\\.\*/g,"\\\\%");value=value.replace(/(\\)?\.(\*)?/g,function($0,$1,$2){return $1||$2?$0:"_";});value=value.replace(/(\\)?\.\*/g,function($0,$1){return $1?$0:"%";});value=value.replace(/\\\./g,".");value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"*";});return value;},create:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:features,requestType:"create"});resp.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleCreate,resp,options),headers:options.headers,data:this.format.write(features)});return resp;},handleCreate:function(resp,options){this.handleResponse(resp,options);},update:function(feature,options){options=options||{};var url=options.url||feature.url||this.op
tions.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"update"});resp.priv=OpenLayers.Request.PUT({url:url,callback:this.createCallback(this.handleUpdate,resp,options),headers:options.headers,data:this.format.write(feature)});return resp;},handleUpdate:function(resp,options){this.handleResponse(resp,options);},"delete":function(feature,options){options=options||{};var url=options.url||feature.url||this.options.url+"/"+feature.fid;options=OpenLayers.Util.applyDefaults(options,this.options);var resp=new OpenLayers.Protocol.Response({reqFeatures:feature,requestType:"delete"});resp.priv=OpenLayers.Request.DELETE({url:url,callback:this.createCallback(this.handleDelete,resp,options),headers:options.headers});return resp;},handleDelete:function(resp,options){this.handleResponse(resp,options);},handleResponse:function(resp,options){var request=resp.priv;if(options.callback){if(
request.status>=200&&request.status<300){if(resp.requestType!="delete"){resp.features=this.parseFeatures(request);}
-resp.code=OpenLayers.Protocol.Response.SUCCESS;}else{resp.code=OpenLayers.Protocol.Response.FAILURE;}
-options.callback.call(options.scope,resp);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(!doc||doc.length<=0){return null;}
-return this.format.read(doc);},commit:function(features,options){options=OpenLayers.Util.applyDefaults(options,this.options);var resp=[],nResponses=0;var types={};types[OpenLayers.State.INSERT]=[];types[OpenLayers.State.UPDATE]=[];types[OpenLayers.State.DELETE]=[];var feature,list,requestFeatures=[];for(var i=0,len=features.length;i<len;++i){feature=features[i];list=types[feature.state];if(list){list.push(feature);requestFeatures.push(feature);}}
-var nRequests=(types[OpenLayers.State.INSERT].length>0?1:0)+
-types[OpenLayers.State.UPDATE].length+
-types[OpenLayers.State.DELETE].length;var success=true;var finalResponse=new OpenLayers.Protocol.Response({reqFeatures:requestFeatures});function insertCallback(response){var len=response.features?response.features.length:0;var fids=new Array(len);for(var i=0;i<len;++i){fids[i]=response.features[i].fid;}
-finalResponse.insertIds=fids;callback.apply(this,[response]);}
-function callback(response){this.callUserCallback(response,options);success=success&&response.success();nResponses++;if(nResponses>=nRequests){if(options.callback){finalResponse.code=success?OpenLayers.Protocol.Response.SUCCESS:OpenLayers.Protocol.Response.FAILURE;options.callback.apply(options.scope,[finalResponse]);}}}
-var queue=types[OpenLayers.State.INSERT];if(queue.length>0){resp.push(this.create(queue,OpenLayers.Util.applyDefaults({callback:insertCallback,scope:this},options.create)));}
-queue=types[OpenLayers.State.UPDATE];for(var i=queue.length-1;i>=0;--i){resp.push(this.update(queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options.update)));}
-queue=types[OpenLayers.State.DELETE];for(var i=queue.length-1;i>=0;--i){resp.push(this["delete"](queue[i],OpenLayers.Util.applyDefaults({callback:callback,scope:this},options["delete"])));}
-return resp;},abort:function(response){if(response){response.priv.abort();}},callUserCallback:function(resp,options){var opt=options[resp.requestType];if(opt&&opt.callback){opt.callback.call(opt.scope,resp);}},CLASS_NAME:"OpenLayers.Protocol.HTTP"});(function(){var o=OpenLayers.Protocol.HTTP.COMP_TYPE_TO_OP_STR={};o[OpenLayers.Filter.Comparison.EQUAL_TO]="eq";o[OpenLayers.Filter.Comparison.NOT_EQUAL_TO]="ne";o[OpenLayers.Filter.Comparison.LESS_THAN]="lt";o[OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO]="lte";o[OpenLayers.Filter.Comparison.GREATER_THAN]="gt";o[OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO]="gte";o[OpenLayers.Filter.Comparison.LIKE]="ilike";})();OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Strategy.Cluster=OpenLayers.Class(OpenLayers.Strategy,{distance:20,threshold:null,features:null,clusters:null,clustering:false,resoluti
on:null,initialize:function(options){OpenLayers.Strategy.prototype.initialize.apply(this,[options]);},activate:function(){var activated=OpenLayers.Strategy.prototype.activate.call(this);if(activated){this.layer.events.on({"beforefeaturesadded":this.cacheFeatures,"moveend":this.cluster,scope:this});}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Strategy.prototype.deactivate.call(this);if(deactivated){this.clearCache();this.layer.events.un({"beforefeaturesadded":this.cacheFeatures,"moveend":this.cluster,scope:this});}
-return deactivated;},cacheFeatures:function(event){var propagate=true;if(!this.clustering){this.clearCache();this.features=event.features;this.cluster();propagate=false;}
-return propagate;},clearCache:function(){this.features=null;},cluster:function(event){if((!event||event.zoomChanged)&&this.features){var resolution=this.layer.map.getResolution();if(resolution!=this.resolution||!this.clustersExist()){this.resolution=resolution;var clusters=[];var feature,clustered,cluster;for(var i=0;i<this.features.length;++i){feature=this.features[i];if(feature.geometry){clustered=false;for(var j=clusters.length-1;j>=0;--j){cluster=clusters[j];if(this.shouldCluster(cluster,feature)){this.addToCluster(cluster,feature);clustered=true;break;}}
-if(!clustered){clusters.push(this.createCluster(this.features[i]));}}}
-this.layer.removeAllFeatures();if(clusters.length>0){if(this.threshold>1){var clone=clusters.slice();clusters=[];var candidate;for(var i=0,len=clone.length;i<len;++i){candidate=clone[i];if(candidate.attributes.count<this.threshold){Array.prototype.push.apply(clusters,candidate.cluster);}else{clusters.push(candidate);}}}
-this.clustering=true;this.layer.addFeatures(clusters);this.clustering=false;}
-this.clusters=clusters;}}},clustersExist:function(){var exist=false;if(this.clusters&&this.clusters.length>0&&this.clusters.length==this.layer.features.length){exist=true;for(var i=0;i<this.clusters.length;++i){if(this.clusters[i]!=this.layer.features[i]){exist=false;break;}}}
-return exist;},shouldCluster:function(cluster,feature){var cc=cluster.geometry.getBounds().getCenterLonLat();var fc=feature.geometry.getBounds().getCenterLonLat();var distance=(Math.sqrt(Math.pow((cc.lon-fc.lon),2)+Math.pow((cc.lat-fc.lat),2))/this.resolution);return(distance<=this.distance);},addToCluster:function(cluster,feature){cluster.cluster.push(feature);cluster.attributes.count+=1;},createCluster:function(feature){var center=feature.geometry.getBounds().getCenterLonLat();var cluster=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(center.lon,center.lat),{count:1});cluster.cluster=[feature];return cluster;},CLASS_NAME:"OpenLayers.Strategy.Cluster"});OpenLayers.Protocol.SOS=function(options){options=OpenLayers.Util.applyDefaults(options,OpenLayers.Protocol.SOS.DEFAULTS);var cls=OpenLayers.Protocol.SOS["v"+options.version.replace(/\./g,"_")];if(!cls){throw"Unsupported SOS version: "+options.version;}
-return new cls(options);};OpenLayers.Protocol.SOS.DEFAULTS={"version":"1.0.0"};OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");var box=this.getElementsByTagNameNS(item,this.georssns,"box")
;if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
-var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(line[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(this.concatChildValues(polygon[0])).split(/\s+/);var components=[];var point;for(var i=0,len=coords.length;i<len;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
-var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}else if(box.length>0){var coords=OpenLayers.String.trim(box[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;if(coords.length>3){point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[2]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[3]),parseFloat(coords[0]));components.push(point);point=new OpenLayers.Geometry.Point(parseFloat(coords[1]),parseFloat(coords[0]));components.push(point);}
-if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.getChildValue(item,"*","summary",this.featureDescription)));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
-var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;var eles=this.getElementsByTagNameNS(node,nsuri,name);if(eles&&eles[0]&&eles[0].firstChild&&eles[0].firstChild.nodeValue){value=eles[0].firstChild.nodeValue;}else{value=(def==undefined)?"":def;}
-return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
-var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0,len=features.length;i<len;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
-for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
-var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
-featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
-return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
-var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
-path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.TouchNavigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,pinchZoom:null,pinchZoomOptions:null,documentDrag:false,autoActivate:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
this.dragPan=null;if(this.pinchZoom){this.pinchZoom.destroy();delete this.pinchZoom;}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.pinchZoom.activate();this.handlers.click.activate();return true;}
-return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.pinchZoom.deactivate();this.handlers.click.deactivate();return true;}
-return false;},draw:function(){var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});OpenLayers.Style2=OpenLayers.Class({id:null,name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,initialize:function(config){OpenLayers.Util.extend(this,config);this.id=Ope
nLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){for(var i=0,len=this.rules.length;i<len;i++){this.rules[i].destroy();}
-delete this.rules;},clone:function(){var config=OpenLayers.Util.extend({},this);if(this.rules){config.rules=[];for(var i=0,len=this.rules.length;i<len;++i){config.rules.push(this.rules[i].clone());}}
-return new OpenLayers.Style2(config);},CLASS_NAME:"OpenLayers.Style2"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
-if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
-if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));}
-var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);updateNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
-valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
-var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){OpenLayers.Console.userError(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.featurePrefix+':'+this.featureName);deleteNode.setAttribute("xmlns:"+this.featurePrefix,this.featureNS);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker
.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Format.WFSCapabilities.v1_0_0=OpenLayers.Class(OpenLayers.Format.WFSCapabilities.v1,{initialize:function(options){OpenLayers.Format.WFSCapabilities.v1.prototype.initialize.apply(this,[options]);},read_cap_Service:function(capabilities,node){var service={};this.runChildNodes(service,node);capabilities.service=service;},read_cap_Fees:function(service,node){var fees=this.getChildValue(node);if(fees&&fees.toLowerCase()!="none"){service.fees=fees;}},read_cap_AccessConstraints:function(service,node){var constraints=this.getChildValue(node);if
(constraints&&constraints.toLowerCase()!="none"){service.accessConstraints=constraints;}},read_cap_OnlineResource:function(service,node){var onlineResource=this.getChildValue(node);if(onlineResource&&onlineResource.toLowerCase()!="none"){service.onlineResource=onlineResource;}},read_cap_Keywords:function(service,node){var keywords=this.getChildValue(node);if(keywords&&keywords.toLowerCase()!="none"){service.keywords=keywords.split(', ');}},read_cap_Capability:function(capabilities,node){var capability={};this.runChildNodes(capability,node);capabilities.capability=capability;},read_cap_Request:function(obj,node){var request={};this.runChildNodes(request,node);obj.request=request;},read_cap_GetFeature:function(request,node){var getfeature={href:{},formats:[]};this.runChildNodes(getfeature,node);request.getfeature=getfeature;},read_cap_ResultFormat:function(obj,node){var children=node.childNodes;var childNode;for(var i=0;i<children.length;i++){childNode=children[i];if(childNode
.nodeType==1){obj.formats.push(childNode.nodeName);}}},read_cap_DCPType:function(obj,node){this.runChildNodes(obj,node);},read_cap_HTTP:function(obj,node){this.runChildNodes(obj.href,node);},read_cap_Get:function(obj,node){obj.get=node.getAttribute("onlineResource");},read_cap_Post:function(obj,node){obj.post=node.getAttribute("onlineResource");},CLASS_NAME:"OpenLayers.Format.WFSCapabilities.v1_0_0"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031],type:null,wrapDateLine:true,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(
this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.par
entNode.removeChild(yahooEventPane);}
-this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
-return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lon
lat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Layer.Zoomify=OpenLayers.Class(OpenLayers.Layer.Grid,{url:null,size:null,isBaseLayer:true,standardTileSize:256,numberOfTiers:0,tileCountUpToTier:new Array(),tierSizeInTiles:new Array(),tierImageSize:new Array(),initialize:function(name,url,size,options){this.initializeZoomify(size);var newArguments=[];newArguments.push(name,url,size,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},initializeZoomify:function(size){var imageSize=size.clone();var tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.pu
sh(imageSize);while(imageSize.w>this.standardTileSize||imageSize.h>this.standardTileSize){imageSize=new OpenLayers.Size(Math.floor(imageSize.w/2),Math.floor(imageSize.h/2));tiles=new OpenLayers.Size(Math.ceil(imageSize.w/this.standardTileSize),Math.ceil(imageSize.h/this.standardTileSize));this.tierSizeInTiles.push(tiles);this.tierImageSize.push(imageSize);}
-this.tierSizeInTiles.reverse();this.tierImageSize.reverse();this.numberOfTiers=this.tierSizeInTiles.length;this.tileCountUpToTier[0]=0;for(var i=1;i<this.numberOfTiers;i++){this.tileCountUpToTier.push(this.tierSizeInTiles[i-1].w*this.tierSizeInTiles[i-1].h+
-this.tileCountUpToTier[i-1]);}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);this.tileCountUpToTier.length=0;this.tierSizeInTiles.length=0;this.tierImageSize.length=0;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Zoomify(this.name,this.url,this.size,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var tileIndex=x+y*this.tierSizeInTiles[z].w+this.tileCountUpToTier[z];var path="TileGroup"+Math.floor((tileIndex)/256)+"/"+z+"-"+x+"-"+y+".jpg";var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-return url+path;},getImageSize:function(){if(arguments.length>0){var bounds=this.adjustBounds(arguments[0]);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((this.tileOrigin.lat-bounds.top)/(res*this.tileSize.h));var z=this.map.getZoom();var w=this.standardTileSize;var h=this.standardTileSize;if(x==this.tierSizeInTiles[z].w-1){var w=this.tierImageSize[z].w%this.standardTileSize;};if(y==this.tierSizeInTiles[z].h-1){var h=this.tierImageSize[z].h%this.standardTileSize;};return(new OpenLayers.Size(w,h));}else{return this.tileSize;}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.top);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var t
ilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.Zoomify"});OpenLayers.Layer.WMTS=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,version:"1.0.0",requestEncoding:"KVP",url:null,layer:null,matrixSet:null,style:null,format:"image/jpeg",tileOrigin:null,tileFullExtent:null,formatSuffix:null,matrixIds:null,dimensions:null,params:null,zoomOffset:0,formatSuffixMa
p:{"image/png":"png","image/png8":"png","image/png24":"png","image/png32":"png","png":"png","image/jpeg":"jpg","image/jpg":"jpg","jpeg":"jpg","jpg":"jpg"},matrix:null,initialize:function(config){var required={url:true,layer:true,style:true,matrixSet:true};for(var prop in required){if(!(prop in config)){throw new Error("Missing property '"+prop+"' in layer configuration.");}}
-config.params=OpenLayers.Util.upperCaseObject(config.params);var args=[config.name,config.url,config.params,config];OpenLayers.Layer.Grid.prototype.initialize.apply(this,args);if(!this.formatSuffix){this.formatSuffix=this.formatSuffixMap[this.format]||this.format.split("/").pop();}
-if(this.matrixIds){var len=this.matrixIds.length;if(len&&typeof this.matrixIds[0]==="string"){var ids=this.matrixIds;this.matrixIds=new Array(len);for(var i=0;i<len;++i){this.matrixIds[i]={identifier:ids[i]};}}}},setMap:function(){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);this.updateMatrixProperties();},updateMatrixProperties:function(){this.matrix=this.getMatrix();if(this.matrix){if(this.matrix.topLeftCorner){this.tileOrigin=this.matrix.topLeftCorner;}
-if(this.matrix.tileWidth&&this.matrix.tileHeight){this.tileSize=new OpenLayers.Size(this.matrix.tileWidth,this.matrix.tileHeight);}
-if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.maxExtent.left,this.maxExtent.top);}
-if(!this.tileFullExtent){this.tileFullExtent=this.maxExtent;}}},moveTo:function(bounds,zoomChanged,dragging){if(zoomChanged||!this.matrix){this.updateMatrixProperties();}
-return OpenLayers.Layer.Grid.prototype.moveTo.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMTS(this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getMatrix:function(){var matrix;if(!this.matrixIds||this.matrixIds.length===0){matrix={identifier:this.map.getZoom()+this.zoomOffset};}else{if("scaleDenominator"in this.matrixIds[0]){var denom=OpenLayers.METERS_PER_INCH*OpenLayers.INCHES_PER_UNIT[this.units]*this.map.getResolution()/0.28E-3;var diff=Number.POSITIVE_INFINITY;var delta;for(var i=0,ii=this.matrixIds.length;i<ii;++i){delta=Math.abs(1-(this.matrixIds[i].scaleDenominator/denom));if(delta<diff){diff=delta;matrix=this.matrixIds[i];}}}else{matrix=this.matrixIds[this.map.getZoom()+this.zoomOffset];}}
-return matrix;},getTileInfo:function(loc){var res=this.map.getResolution();var fx=(loc.lon-this.tileOrigin.lon)/(res*this.tileSize.w);var fy=(this.tileOrigin.lat-loc.lat)/(res*this.tileSize.h);var col=Math.floor(fx);var row=Math.floor(fy);return{col:col,row:row,i:Math.floor((fx-col)*this.tileSize.w),j:Math.floor((fy-row)*this.tileSize.h)};},getURL:function(bounds){bounds=this.adjustBounds(bounds);var url="";if(!this.tileFullExtent||this.tileFullExtent.intersectsBounds(bounds)){var center=bounds.getCenterLonLat();var info=this.getTileInfo(center);var matrixId=this.matrix.identifier;if(this.requestEncoding.toUpperCase()==="REST"){var path=this.version+"/"+this.layer+"/"+this.style+"/";if(this.dimensions){for(var i=0;i<this.dimensions.length;i++){if(this.params[this.dimensions[i]]){path=path+this.params[this.dimensions[i]]+"/";}}}
-path=path+this.matrixSet+"/"+this.matrix.identifier+"/"+info.row+"/"+info.col+"."+this.formatSuffix;if(this.url instanceof Array){url=this.selectUrl(path,this.url);}else{url=this.url;}
-if(!url.match(/\/$/)){url=url+"/";}
-url=url+path;}else if(this.requestEncoding.toUpperCase()==="KVP"){var params={SERVICE:"WMTS",REQUEST:"GetTile",VERSION:this.version,LAYER:this.layer,STYLE:this.style,TILEMATRIXSET:this.matrixSet,TILEMATRIX:this.matrix.identifier,TILEROW:info.row,TILECOL:info.col,FORMAT:this.format};url=OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,[params]);}}
-return url;},mergeNewParams:function(newParams){if(this.requestEncoding.toUpperCase()==="KVP"){return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,[OpenLayers.Util.upperCaseObject(newParams)]);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.WMTS"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",symbolCache:{},offset:null,initialize:function(containerID){if(!this.supported()){return;}
-if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();var shapes=['shape','rect','oval','fill','stroke','imagedata','group','textbox'];for(var i=0,len=shapes.length;i<len;i++){style.addRule('olv\\:'+shapes[i],"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent,resolutionChanged){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var left=(extent.left/resolution)|0;var top=(extent.top/resolution-this.size.h)|0;if(resolutionChanged||!this.offset){this.offset={x:left,y:top};left=0;top=0;}else{left=left-this.offset.x;top=top-this.offset.y;}
-var org=left+" "+top;this.root.coordorigin=org;var roots=[this.root,this.vectorRoot,this.textRoot];var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];var size=this.size.w+" "+this.size.h;root.coordsize=size;}
-this.root.style.flip="y";return true;},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);var roots=[this.rendererRoot,this.root,this.vectorRoot,this.textRoot];var w=this.size.w+"px";var h=this.size.h+"px";var root;for(var i=0,len=roots.length;i<len;++i){root=roots[i];root.style.width=w;root.style.height=h;}},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":if(style.externalGraphic){nodeType="olv:rect";}else if(this.isComplexSymbol(style.graphicName)){nodeType="olv:shape";}else{nodeType="olv:oval";}
-break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
-return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;var fillColor=style.fillColor;if(node._geometryClass==="OpenLayers.Geometry.Point"){if(style.externalGraphic){options.isFilled=true;if(style.graphicTitle){node.title=style.graphicTitle;}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=(((geometry.x/resolution-this.offset.x)+xOffset)|0)+"px";node.style.top=(((geometry.y/resolution-this.offset.y)-(yOffset+height))|0)+"px";node.style.width=width+"px";node.style.height=height+"px";node.style.flip="y";fillColor="none";options.isStroked=false;}else if(this.isComplexSymbol(style.graphicName)){var cache=this.importSymbol(style.graphicName);node.path=cache.path;node.coordorigin=cache.left+","+cache.bottom;var size=cache.size;node.coordsize=size+","+size;this.drawCircle(node,geometry,style.pointRadius);node.style.flip="y";}else{this.drawCircle(node,geometry,style.pointRadius);}}
-if(options.isFilled){node.fillcolor=fillColor;}else{node.filled="false";}
-var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
-fill.opacity=style.fillOpacity;if(node._geometryClass==="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.opacity=style.graphicOpacity;}
-fill.src=style.externalGraphic;fill.type="frame";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
-if(fill.parentNode!=node){node.appendChild(fill);}}
-var rotation=style.rotation;if((rotation!==undefined||node._rotation!==undefined)){node._rotation=rotation;if(style.externalGraphic){this.graphicRotate(node,xOffset,yOffset,style);fill.opacity=0;}else if(node._geometryClass==="OpenLayers.Geometry.Point"){node.style.rotation=rotation||0;}}
-var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){node.stroked=false;if(stroke){stroke.on=false;}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
-stroke.on=true;stroke.color=style.strokeColor;stroke.weight=style.strokeWidth+"px";stroke.opacity=style.strokeOpacity;stroke.endcap=style.strokeLinecap=='butt'?'flat':(style.strokeLinecap||'round');if(style.strokeDashstyle){stroke.dashstyle=this.dashStyle(style);}}
-if(style.cursor!="inherit"&&style.cursor!=null){node.style.cursor=style.cursor;}
-return node;},graphicRotate:function(node,xOffset,yOffset,style){var style=style||node._style;var rotation=style.rotation||0;var aspectRatio,size;if(!(style.graphicWidth&&style.graphicHeight)){var img=new Image();img.onreadystatechange=OpenLayers.Function.bind(function(){if(img.readyState=="complete"||img.readyState=="interactive"){aspectRatio=img.width/img.height;size=Math.max(style.pointRadius*2,style.graphicWidth||0,style.graphicHeight||0);xOffset=xOffset*aspectRatio;style.graphicWidth=size*aspectRatio;style.graphicHeight=size;this.graphicRotate(node,xOffset,yOffset,style);}},this);img.src=style.externalGraphic;return;}else{size=Math.max(style.graphicWidth,style.graphicHeight);aspectRatio=style.graphicWidth/style.graphicHeight;}
-var width=Math.round(style.graphicWidth||size*aspectRatio);var height=Math.round(style.graphicHeight||size);node.style.width=width+"px";node.style.height=height+"px";var image=document.getElementById(node.id+"_image");if(!image){image=this.createNode("olv:imagedata",node.id+"_image");node.appendChild(image);}
-image.style.width=width+"px";image.style.height=height+"px";image.src=style.externalGraphic;image.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader("+"src='', sizingMethod='scale')";var rot=rotation*Math.PI/180;var sintheta=Math.sin(rot);var costheta=Math.cos(rot);var filter="progid:DXImageTransform.Microsoft.Matrix(M11="+costheta+",M12="+(-sintheta)+",M21="+sintheta+",M22="+costheta+",SizingMethod='auto expand')\n";var opacity=style.graphicOpacity||style.fillOpacity;if(opacity&&opacity!=1){filter+="progid:DXImageTransform.Microsoft.BasicImage(opacity="+
-opacity+")\n";}
-node.style.filter=filter;var centerPoint=new OpenLayers.Geometry.Point(-xOffset,-yOffset);var imgBox=new OpenLayers.Bounds(0,0,width,height).toGeometry();imgBox.rotate(style.rotation,centerPoint);var imgBounds=imgBox.getBounds();node.style.left=Math.round(parseInt(node.style.left)+imgBounds.left)+"px";node.style.top=Math.round(parseInt(node.style.top)-imgBounds.bottom)+"px";},postDraw:function(node){node.style.visibility="visible";var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.fillcolor!=fillColor){node.fillcolor=fillColor;}
-if(strokeColor=="none"&&node.strokecolor!=strokeColor){node.strokecolor=strokeColor;}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution-this.offset.x)|0,(bbox.bottom/resolution-this.offset.y)|0,(bbox.right/resolution-this.offset.x)|0,(bbox.top/resolution-this.offset.y)|0);node.style.left=scaledBox.left+"px";node.style.top=scaledBox.top+"px";node.style.width=scaledBox.getWidth()+"px";node.style.height=scaledBox.getHeight()+"px";node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},dashStyle:function(style){var dash=style.strokeDashstyle;switch(dash){case'solid':case'dot':case'dash':case'dashdot':case'longdash':case'longdashdot':return dash;default:var parts=dash.split(/[ ,]/);if(parts.length==2){if(1*parts[0]>=2*parts[1]){return"longdash";}
-return(parts[0]==1||parts[1]==1)?"dot":"dash";}else if(parts.length==4){return(1*parts[0]>=2*parts[1])?"longdashdot":"dashdot";}
-return"solid";}},createNode:function(type,id){var node=document.createElement(type);if(id){node.id=id;}
-node.unselectable='on';node.onselectstart=OpenLayers.Function.False;return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
-var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
-return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(suffix){return this.nodeFactory(this.container.id+suffix,"olv:group");},drawPoint:function(node,geometry){return this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(((geometry.x/resolution-this.offset.x)|0)-radius)+"px";node.style.top=(((geometry.y/resolution-this.offset.y)|0)-radius)+"px";var diameter=radius*2;node.style.width=diameter+"px";node.style.height=diameter+"px";return node;}
-return false;},drawLineString:function(node,geometry){return this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){return this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;parts[i]=" "+x+","+y+" l ";}
-var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;return node;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var j,jj,points,area,first,second,i,ii,comp,pathComp,x,y;for(j=0,jj=geometry.components.length;j<jj;j++){path.push("m");points=geometry.components[j].components;area=(j===0);first=null;second=null;for(i=0,ii=points.length;i<ii;i++){comp=points[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;pathComp=" "+x+","+y;path.push(pathComp);if(i==0){path.push(" l");}
-if(!area){if(!first){first=pathComp;}else if(first!=pathComp){if(!second){second=pathComp;}else if(second!=pathComp){area=true;}}}}
-path.push(area?" x ":" ");}
-path.push("e");node.path=path.join("");return node;},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=((geometry.x/resolution-this.offset.x)|0)+"px";node.style.top=((geometry.y/resolution-this.offset.y)|0)+"px";node.style.width=((geometry.width/resolution)|0)+"px";node.style.height=((geometry.height/resolution)|0)+"px";return node;},drawText:function(featureId,style,location){var label=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX,"olv:rect");var textbox=this.nodeFactory(featureId+this.LABEL_ID_SUFFIX+"_textbox","olv:textbox");var resolution=this.getResolution();label.style.left=((location.x/resolution-this.offset.x)|0)+"px";label.style.top=((location.y/resolution-this.offset.y)|0)+"px";label.style.flip="y";textbox.innerText=style.label;if(style.fontColor){textbox.style.color=style.fontColor;}
-if(style.fontOpacity){textbox.style.filter='alpha(opacity='+(style.fontOpacity*100)+')';}
-if(style.fontFamily){textbox.style.fontFamily=style.fontFamily;}
-if(style.fontSize){textbox.style.fontSize=style.fontSize;}
-if(style.fontWeight){textbox.style.fontWeight=style.fontWeight;}
-if(style.labelSelect===true){label._featureId=featureId;textbox._featureId=featureId;textbox._geometry=location;textbox._geometryClass=location.CLASS_NAME;}
-textbox.style.whiteSpace="nowrap";textbox.inset="1px,0px,0px,0px";if(!label.parentNode){label.appendChild(textbox);this.textRoot.appendChild(label);}
-var align=style.labelAlign||"cm";if(align.length==1){align+="m";}
-var xshift=textbox.clientWidth*(OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(0,1)]);var yshift=textbox.clientHeight*(OpenLayers.Renderer.VML.LABEL_SHIFT[align.substr(1,1)]);label.style.left=parseInt(label.style.left)-xshift-1+"px";label.style.top=parseInt(label.style.top)+yshift+"px";},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0,len=geometry.components.length;i<len;i++){comp=geometry.components[i];x=(comp.x/resolution-this.offset.x)|0;y=(comp.y/resolution-this.offset.y)|0;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
-path.push(" "+x+","+y);}
-path.push(" x e");node.path=path.join("");return node;},moveRoot:function(renderer){var layer=this.map.getLayer(renderer.container.id);if(layer instanceof OpenLayers.Layer.Vector.RootContainer){layer=this.map.getLayer(this.container.id);}
-layer&&layer.renderer.clear();OpenLayers.Renderer.Elements.prototype.moveRoot.apply(this,arguments);layer&&layer.redraw();},importSymbol:function(graphicName){var id=this.container.id+"-"+graphicName;var cache=this.symbolCache[id];if(cache){return cache;}
-var symbol=OpenLayers.Renderer.symbol[graphicName];if(!symbol){throw new Error(graphicName+' is not a valid symbol name');}
-var symbolExtent=new OpenLayers.Bounds(Number.MAX_VALUE,Number.MAX_VALUE,0,0);var pathitems=["m"];for(var i=0;i<symbol.length;i=i+2){var x=symbol[i];var y=symbol[i+1];symbolExtent.left=Math.min(symbolExtent.left,x);symbolExtent.bottom=Math.min(symbolExtent.bottom,y);symbolExtent.right=Math.max(symbolExtent.right,x);symbolExtent.top=Math.max(symbolExtent.top,y);pathitems.push(x);pathitems.push(y);if(i==0){pathitems.push("l");}}
-pathitems.push("x e");var path=pathitems.join(" ");var diff=(symbolExtent.getWidth()-symbolExtent.getHeight())/2;if(diff>0){symbolExtent.bottom=symbolExtent.bottom-diff;symbolExtent.top=symbolExtent.top+diff;}else{symbolExtent.left=symbolExtent.left+diff;symbolExtent.right=symbolExtent.right-diff;}
-cache={path:path,size:symbolExtent.getWidth(),left:symbolExtent.left,bottom:symbolExtent.bottom};this.symbolCache[id]=cache;return cache;},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Renderer.VML.LABEL_SHIFT={"l":0,"c":.5,"r":1,"t":0,"m":.5,"b":1};OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unsh
ift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMerca
tor(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
-return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Protocol.WFS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol.WFS.v1,{version:"1.0.0",CLASS_NAME:"OpenLayers.Protocol.WFS.v1_0_0"});OpenLayers.Control.WMTSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,requestEncoding:"KVP",drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:true,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","getfeatureinfo","exception"],pending:0,initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMTSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOption
s||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
-if(this.drillDown===true){this.hover=false;}
-if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{move:this.cancelHover,pause:this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{delay:250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},getInfoForClick:function(evt){this.request(evt.xy,{});},getInfoForHover:function(evt){this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
-this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer;for(var i=candidates.length-1;i>=0;--i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMTS&&layer.requestEncoding===this.requestEncoding&&(!this.queryVisible||layer.getVisibility())){layers.push(layer);if(!this.drillDown||this.hover){break;}}}
-return layers;},buildRequestOptions:function(layer,xy){var loc=this.map.getLonLatFromPixel(xy);var getTileUrl=layer.getURL(new OpenLayers.Bounds(loc.lon,loc.lat,loc.lon,loc.lat));var params=OpenLayers.Util.getParameters(getTileUrl);var tileInfo=layer.getTileInfo(loc);OpenLayers.Util.extend(params,{service:"WMTS",version:layer.version,request:"GetFeatureInfo",infoFormat:this.infoFormat,i:tileInfo.i,j:tileInfo.j});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:layer.url instanceof Array?layer.url[0]:layer.url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(xy,request,layer);},scope:this};},request:function(xy,options){options=options||{};var layers=this.findLayers();if(layers.length>0){var issue,layer;for(var i=0,len=layers.length;i<len;i++){layer=layers[i];issue=this.events.triggerEvent("beforegetfeatureinfo",{xy:xy,layer:layer});if(issue!==false){++this.pending;var requestOptions=this.buildRequestOptions(layer
,xy);var request=OpenLayers.Request.GET(requestOptions);if(options.hover===true){this.hoverRequest=request;}}}
-if(this.pending>0){OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");}}},handleResponse:function(xy,request,layer){--this.pending;if(this.pending<=0){OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");this.pending=0;}
-if(request.status&&(request.status<200||request.status>=300)){this.events.triggerEvent("exception",{xy:xy,request:request,layer:layer});}else{var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var features,except;try{features=this.format.read(doc);}catch(error){except=true;this.events.triggerEvent("exception",{xy:xy,request:request,error:error,layer:layer});}
-if(!except){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy,layer:layer});}}},CLASS_NAME:"OpenLayers.Control.WMTSGetFeatureInfo"});OpenLayers.Control.Graticule=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,intervals:[45,30,20,10,5,2,1,0.5,0.2,0.1,0.05,0.01,0.005,0.002,0.001],displayInLayerSwitcher:true,visible:true,numPoints:50,targetSize:200,layerName:null,labelled:true,labelFormat:'dm',lineSymbolizer:{strokeColor:"#333",strokeWidth:1,strokeOpacity:0.5},labelSymbolizer:{},gratLayer:null,initialize:function(options){options=options||{};options.layerName=options.layerName||OpenLayers.i18n("graticule");OpenLayers.Control.prototype.initialize.apply(this,[options]);this.labelSymbolizer.stroke=false;this.labelSymbolizer.fill=false;this.labelSymbolizer.label="${label}";this.labelSymbolizer.labelAlign="${labelAlign}";this.labelSymbolizer.labelXOffset="${xOffset}";this.labelSymbolizer.labelYOffset="${yOffset}";},d
estroy:function(){this.deactivate();OpenLayers.Control.prototype.destroy.apply(this,arguments);if(this.gratLayer){this.gratLayer.destroy();this.gratLayer=null;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.gratLayer){var gratStyle=new OpenLayers.Style({},{rules:[new OpenLayers.Rule({'symbolizer':{"Point":this.labelSymbolizer,"Line":this.lineSymbolizer}})]});this.gratLayer=new OpenLayers.Layer.Vector(this.layerName,{styleMap:new OpenLayers.StyleMap({'default':gratStyle}),visibility:this.visible,displayInLayerSwitcher:this.displayInLayerSwitcher});}
-return this.div;},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.map.addLayer(this.gratLayer);this.map.events.register('moveend',this,this.update);this.update();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.map.events.unregister('moveend',this,this.update);this.map.removeLayer(this.gratLayer);return true;}else{return false;}},update:function(){var mapBounds=this.map.getExtent();if(!mapBounds){return;}
-this.gratLayer.destroyFeatures();var llProj=new OpenLayers.Projection("EPSG:4326");var mapProj=this.map.getProjectionObject();var mapRes=this.map.getResolution();if(mapProj.proj&&mapProj.proj.projName=="longlat"){this.numPoints=1;}
-var mapCenter=this.map.getCenter();var mapCenterLL=new OpenLayers.Pixel(mapCenter.lon,mapCenter.lat);OpenLayers.Projection.transform(mapCenterLL,mapProj,llProj);var testSq=this.targetSize*mapRes;testSq*=testSq;var llInterval;for(var i=0;i<this.intervals.length;++i){llInterval=this.intervals[i];var delta=llInterval/2;var p1=mapCenterLL.offset(new OpenLayers.Pixel(-delta,-delta));var p2=mapCenterLL.offset(new OpenLayers.Pixel(delta,delta));OpenLayers.Projection.transform(p1,llProj,mapProj);OpenLayers.Projection.transform(p2,llProj,mapProj);var distSq=(p1.x-p2.x)*(p1.x-p2.x)+(p1.y-p2.y)*(p1.y-p2.y);if(distSq<=testSq){break;}}
-mapCenterLL.x=Math.floor(mapCenterLL.x/llInterval)*llInterval;mapCenterLL.y=Math.floor(mapCenterLL.y/llInterval)*llInterval;var iter=0;var centerLonPoints=[mapCenterLL.clone()];var newPoint=mapCenterLL.clone();var mapXY;do{newPoint=newPoint.offset(new OpenLayers.Pixel(0,llInterval));mapXY=OpenLayers.Projection.transform(newPoint.clone(),llProj,mapProj);centerLonPoints.unshift(newPoint);}while(mapBounds.containsPixel(mapXY)&&++iter<1000);newPoint=mapCenterLL.clone();do{newPoint=newPoint.offset(new OpenLayers.Pixel(0,-llInterval));mapXY=OpenLayers.Projection.transform(newPoint.clone(),llProj,mapProj);centerLonPoints.push(newPoint);}while(mapBounds.containsPixel(mapXY)&&++iter<1000);iter=0;var centerLatPoints=[mapCenterLL.clone()];newPoint=mapCenterLL.clone();do{newPoint=newPoint.offset(new OpenLayers.Pixel(-llInterval,0));mapXY=OpenLayers.Projection.transform(newPoint.clone(),llProj,mapProj);centerLatPoints.unshift(newPoint);}while(mapBounds.containsPixel(mapXY)&&++iter<1000);
newPoint=mapCenterLL.clone();do{newPoint=newPoint.offset(new OpenLayers.Pixel(llInterval,0));mapXY=OpenLayers.Projection.transform(newPoint.clone(),llProj,mapProj);centerLatPoints.push(newPoint);}while(mapBounds.containsPixel(mapXY)&&++iter<1000);var lines=[];for(var i=0;i<centerLatPoints.length;++i){var lon=centerLatPoints[i].x;var pointList=[];var labelPoint=null;var latEnd=Math.min(centerLonPoints[0].y,90);var latStart=Math.max(centerLonPoints[centerLonPoints.length-1].y,-90);var latDelta=(latEnd-latStart)/this.numPoints;var lat=latStart;for(var j=0;j<=this.numPoints;++j){var gridPoint=new OpenLayers.Geometry.Point(lon,lat);gridPoint.transform(llProj,mapProj);pointList.push(gridPoint);lat+=latDelta;if(gridPoint.y>=mapBounds.bottom&&!labelPoint){labelPoint=gridPoint;}}
-if(this.labelled){var labelPos=new OpenLayers.Geometry.Point(labelPoint.x,mapBounds.bottom);var labelAttrs={value:lon,label:this.labelled?OpenLayers.Util.getFormattedLonLat(lon,"lon",this.labelFormat):"",labelAlign:"cb",xOffset:0,yOffset:2};this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(labelPos,labelAttrs));}
-var geom=new OpenLayers.Geometry.LineString(pointList);lines.push(new OpenLayers.Feature.Vector(geom));}
-for(var j=0;j<centerLonPoints.length;++j){lat=centerLonPoints[j].y;if(lat<-90||lat>90){continue;}
-var pointList=[];var lonStart=centerLatPoints[0].x;var lonEnd=centerLatPoints[centerLatPoints.length-1].x;var lonDelta=(lonEnd-lonStart)/this.numPoints;var lon=lonStart;var labelPoint=null;for(var i=0;i<=this.numPoints;++i){var gridPoint=new OpenLayers.Geometry.Point(lon,lat);gridPoint.transform(llProj,mapProj);pointList.push(gridPoint);lon+=lonDelta;if(gridPoint.x<mapBounds.right){labelPoint=gridPoint;}}
-if(this.labelled){var labelPos=new OpenLayers.Geometry.Point(mapBounds.right,labelPoint.y);var labelAttrs={value:lat,label:this.labelled?OpenLayers.Util.getFormattedLonLat(lat,"lat",this.labelFormat):"",labelAlign:"rb",xOffset:-2,yOffset:2};this.gratLayer.addFeatures(new OpenLayers.Feature.Vector(labelPos,labelAttrs));}
-this.gratLayer.addFeatures(lines);},CLASS_NAME:"OpenLayers.Control.Graticule"});OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,autoActivate:true,clearOnDeactivate:false,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.registry=OpenLayers.Util.extend({"moveend":this.getState},this.registry);var previousOptions={trigger:OpenLayers.Function.bind(this.previousTrigger,this),displayClass:this.displayClass+" "+this.displayClass+"Previous"};OpenLayers.Util.extend(previousOptions,this.previousOptions);this.previous=new OpenLayers.Control.Button(previousOptions);var nextOptions={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+" "+this.displayClass+"Next"};OpenLayers.Util.extend(nextOptions,t
his.nextOptions);this.next=new OpenLayers.Control.Button(nextOptions);this.clear();},onPreviousChange:function(state,length){if(state&&!this.previous.active){this.previous.activate();}else if(!state&&this.previous.active){this.previous.deactivate();}},onNextChange:function(state,length){if(state&&!this.next.active){this.next.activate();}else if(!state&&this.next.active){this.next.deactivate();}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var prop in this){this[prop]=null;}},setMap:function(map){this.map=map;this.next.setMap(map);this.previous.setMap(map);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw();},previousTrigger:function(){var current=this.previousStack.shift();var state=this.previousStack.shift();if(state!=undefined){this.nextStack.unshift(current);this.previousStack.unshift(state);this.restoring=true;this.restore(
state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}else{this.previousStack.unshift(current);}
-return state;},nextTrigger:function(){var state=this.nextStack.shift();if(state!=undefined){this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-return state;},clear:function(){this.previousStack=[];this.previous.deactivate();this.nextStack=[];this.next.deactivate();},getState:function(){return{center:this.map.getCenter(),resolution:this.map.getResolution(),projection:this.map.getProjectionObject(),units:this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units};},restore:function(state){var center,zoom;if(this.map.getProjectionObject()==state.projection){zoom=this.map.getZoomForResolution(state.resolution);center=state.center;}else{center=state.center.clone();center.transform(state.projection,this.map.getProjectionObject());var sourceUnits=state.units;var targetUnits=this.map.getProjectionObject().getUnits()||this.map.units||this.map.baseLayer.units;var resolutionFactor=sourceUnits&&targetUnits?OpenLayers.INCHES_PER_UNIT[sourceUnits]/OpenLayers.INCHES_PER_UNIT[targetUnits]:1;zoom=this.map.getZoomForResolution(resolutionFactor*state.resolution);}
-this.map.setCenter(center,zoom);},setListeners:function(){this.listeners={};for(var type in this.registry){this.listeners[type]=OpenLayers.Function.bind(function(){if(!this.restoring){var state=this.registry[type].apply(this,arguments);this.previousStack.unshift(state);if(this.previousStack.length>1){this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-if(this.previousStack.length>(this.limit+1)){this.previousStack.pop();}
-if(this.nextStack.length>0){this.nextStack=[];this.onNextChange(null,0);}}
-return true;},this);}},activate:function(){var activated=false;if(this.map){if(OpenLayers.Control.prototype.activate.apply(this)){if(this.listeners==null){this.setListeners();}
-for(var type in this.listeners){this.map.events.register(type,this,this.listeners[type]);}
-activated=true;if(this.previousStack.length==0){this.initStack();}}}
-return activated;},initStack:function(){if(this.map.getCenter()){this.listeners.moveend();}},deactivate:function(){var deactivated=false;if(this.map){if(OpenLayers.Control.prototype.deactivate.apply(this)){for(var type in this.listeners){this.map.events.unregister(type,this,this.listeners[type]);}
-if(this.clearOnDeactivate){this.clear();}
-deactivated=true;}}
-return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Layer.WMS.Post=OpenLayers.Class(OpenLayers.Layer.WMS,{unsupportedBrowsers:["mozilla","firefox","opera"],SUPPORTED_TRANSITIONS:[],usePost:null,initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.WMS.prototype.initialize.apply(this,newArguments);this.usePost=OpenLayers.Util.indexOf(this.unsupportedBrowsers,OpenLayers.BROWSER_NAME)==-1;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize,{maxGetUrlLength:this.usePost?0:null});},CLASS_NAME:'OpenLayers.Layer.WMS.Post'});OpenLayers.Control.TransformFeature=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesetfeature","setfeature","beforetransform","transform","transformcomplete"],geometryTypes:null,layer:null,preserveAspectRatio:false,rotate:true,feature:null,renderIntent:"temporary",rotationHandleSymbolizer:null,b
ox:null,center:null,scale:1,ratio:1,rotation:0,handles:null,rotationHandles:null,dragControl:null,initialize:function(layer,options){this.EVENT_TYPES=OpenLayers.Control.TransformFeature.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;if(!this.rotationHandleSymbolizer){this.rotationHandleSymbolizer={stroke:false,pointRadius:10,fillOpacity:0,cursor:"pointer"};}
-this.createBox();this.createControl();},activate:function(){var activated=false;if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragControl.activate();this.layer.addFeatures([this.box]);this.rotate&&this.layer.addFeatures(this.rotationHandles);this.layer.addFeatures(this.handles);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.handles);this.rotate&&this.layer.removeFeatures(this.rotationHandles);this.layer.removeFeatures([this.box]);this.dragControl.deactivate();deactivated=true;}
-return deactivated;},setMap:function(map){this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},setFeature:function(feature,initialParams){initialParams=OpenLayers.Util.applyDefaults(initialParams,{rotation:0,scale:1,ratio:1});var evt={feature:feature};var oldRotation=this.rotation;var oldCenter=this.center;OpenLayers.Util.extend(this,initialParams);if(this.events.triggerEvent("beforesetfeature",evt)===false){return;}
-this.feature=feature;this.activate();this._setfeature=true;var featureBounds=this.feature.geometry.getBounds();this.box.move(featureBounds.getCenterLonLat());this.box.geometry.rotate(-oldRotation,oldCenter);this._angle=0;var ll;if(this.rotation){var geom=feature.geometry.clone();geom.rotate(-this.rotation,this.center);var box=new OpenLayers.Feature.Vector(geom.getBounds().toGeometry());box.geometry.rotate(this.rotation,this.center);this.box.geometry.rotate(this.rotation,this.center);this.box.move(box.geometry.getBounds().getCenterLonLat());var llGeom=box.geometry.components[0].components[0];ll=llGeom.getBounds().getCenterLonLat();}else{ll=new OpenLayers.LonLat(featureBounds.left,featureBounds.bottom);}
-this.handles[0].move(ll);delete this._setfeature;this.events.triggerEvent("setfeature",evt);},createBox:function(){var control=this;this.center=new OpenLayers.Geometry.Point(0,0);var box=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([new OpenLayers.Geometry.Point(-1,-1),new OpenLayers.Geometry.Point(0,-1),new OpenLayers.Geometry.Point(1,-1),new OpenLayers.Geometry.Point(1,0),new OpenLayers.Geometry.Point(1,1),new OpenLayers.Geometry.Point(0,1),new OpenLayers.Geometry.Point(-1,1),new OpenLayers.Geometry.Point(-1,0),new OpenLayers.Geometry.Point(-1,-1)]),null,typeof this.renderIntent=="string"?null:this.renderIntent);box.geometry.move=function(x,y){control._moving=true;OpenLayers.Geometry.LineString.prototype.move.apply(this,arguments);control.center.move(x,y);delete control._moving;};var vertexMoveFn=function(x,y){OpenLayers.Geometry.Point.prototype.move.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.move(x,y);this._handle.geometr
y.move(x,y);};var vertexResizeFn=function(scale,center,ratio){OpenLayers.Geometry.Point.prototype.resize.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.resize(scale,center,ratio);this._handle.geometry.resize(scale,center,ratio);};var vertexRotateFn=function(angle,center){OpenLayers.Geometry.Point.prototype.rotate.apply(this,arguments);this._rotationHandle&&this._rotationHandle.geometry.rotate(angle,center);this._handle.geometry.rotate(angle,center);};var handleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
-var evt=control.dragControl.handlers.drag.evt;var preserveAspectRatio=!control._setfeature&&control.preserveAspectRatio;var reshape=!preserveAspectRatio&&!(evt&&evt.shiftKey);var oldGeom=new OpenLayers.Geometry.Point(oldX,oldY);var centerGeometry=control.center;this.rotate(-control.rotation,centerGeometry);oldGeom.rotate(-control.rotation,centerGeometry);var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-(this.x-oldGeom.x);var dy0=dy1-(this.y-oldGeom.y);this.x=oldX;this.y=oldY;var scale,ratio=1;if(reshape){scale=Math.abs(dy0)<0.00001?1:dy1/dy0;ratio=(Math.abs(dx0)<0.00001?1:(dx1/dx0))/scale;}else{var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));scale=l1/l0;}
-control._moving=true;control.box.geometry.rotate(-control.rotation,centerGeometry);delete control._moving;control.box.geometry.resize(scale,centerGeometry,ratio);control.box.geometry.rotate(control.rotation,centerGeometry);control.transformFeature({scale:scale,ratio:ratio});};var rotationHandleMoveFn=function(x,y){var oldX=this.x,oldY=this.y;OpenLayers.Geometry.Point.prototype.move.call(this,x,y);if(control._moving){return;}
-var evt=control.dragControl.handlers.drag.evt;var constrain=(evt&&evt.shiftKey)?45:1;var centerGeometry=control.center;var dx1=this.x-centerGeometry.x;var dy1=this.y-centerGeometry.y;var dx0=dx1-x;var dy0=dy1-y;this.x=oldX;this.y=oldY;var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;control._angle=(control._angle+angle)%360;var diff=control.rotation%constrain;if(Math.abs(control._angle)>=constrain||diff!==0){angle=Math.round(control._angle/constrain)*constrain-
-diff;control._angle=0;control.box.geometry.rotate(angle,centerGeometry);control.transformFeature({rotation:angle});}};var handles=new Array(8);var rotationHandles=new Array(4);var geom,handle,rotationHandle;for(var i=0;i<8;++i){geom=box.geometry.components[i];handle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.renderIntent=="string"?null:this.renderIntent);if(i%2==0){rotationHandle=new OpenLayers.Feature.Vector(geom.clone(),null,typeof this.rotationHandleSymbolizer=="string"?null:this.rotationHandleSymbolizer);rotationHandle.geometry.move=rotationHandleMoveFn;geom._rotationHandle=rotationHandle;rotationHandles[i/2]=rotationHandle;}
-geom.move=vertexMoveFn;geom.resize=vertexResizeFn;geom.rotate=vertexRotateFn;handle.geometry.move=handleMoveFn;geom._handle=handle;handles[i]=handle;}
-this.box=box;this.rotationHandles=rotationHandles;this.handles=handles;},createControl:function(){var control=this;this.dragControl=new OpenLayers.Control.DragFeature(this.layer,{documentDrag:true,moveFeature:function(pixel){if(this.feature===control.feature){this.feature=control.box;}
-OpenLayers.Control.DragFeature.prototype.moveFeature.apply(this,arguments);},onDrag:function(feature,pixel){if(feature===control.box){control.transformFeature({center:control.center});control.drawHandles();}},onStart:function(feature,pixel){var eligible=!control.geometryTypes||OpenLayers.Util.indexOf(control.geometryTypes,feature.geometry.CLASS_NAME)!==-1;var i=OpenLayers.Util.indexOf(control.handles,feature);i+=OpenLayers.Util.indexOf(control.rotationHandles,feature);if(feature!==control.feature&&feature!==control.box&&i==-2&&eligible){control.setFeature(feature);}},onComplete:function(feature,pixel){control.events.triggerEvent("transformcomplete",{feature:control.feature});}});},drawHandles:function(){var layer=this.layer;for(var i=0;i<8;++i){if(this.rotate&&i%2===0){layer.drawFeature(this.rotationHandles[i/2],this.rotationHandleSymbolizer);}
-layer.drawFeature(this.handles[i],this.renderIntent);}},transformFeature:function(mods){if(!this._setfeature){this.scale*=(mods.scale||1);this.ratio*=(mods.ratio||1);var oldRotation=this.rotation;this.rotation=(this.rotation+(mods.rotation||0))%360;if(this.events.triggerEvent("beforetransform",mods)!==false){var feature=this.feature;var geom=feature.geometry;var center=this.center;geom.rotate(-oldRotation,center);if(mods.scale||mods.ratio){geom.resize(mods.scale,center,mods.ratio);}else if(mods.center){feature.move(mods.center.getBounds().getCenterLonLat());}
-geom.rotate(this.rotation,center);this.layer.drawFeature(feature);feature.toState(OpenLayers.State.UPDATE);this.events.triggerEvent("transform",mods);}}
-this.layer.drawFeature(this.box,this.renderIntent);this.drawHandles();},destroy:function(){var geom;for(var i=0;i<8;++i){geom=this.box.geometry.components[i];geom._handle.destroy();geom._handle=null;geom._rotationHandle&&geom._rotationHandle.destroy();geom._rotationHandle=null;}
-this.box.destroy();this.box=null;this.layer=null;this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.TransformFeature"});OpenLayers.Control.WMSGetFeatureInfo=OpenLayers.Class(OpenLayers.Control,{hover:false,drillDown:false,maxFeatures:10,clickCallback:"click",layers:null,queryVisible:false,url:null,layerUrls:null,infoFormat:'text/html',vendorParams:{},format:null,formatOptions:null,handlerOptions:null,handler:null,hoverRequest:null,EVENT_TYPES:["beforegetfeatureinfo","nogetfeatureinfo","getfeatureinfo"],initialize:function(options){this.EVENT_TYPES=OpenLayers.Control.WMSGetFeatureInfo.prototype.EVENT_TYPES.concat(OpenLayers.Control.prototype.EVENT_TYPES);options=options||{};options.handlerOptions=options.handlerOptions||{};OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!this.format){this.format=new OpenLayers.Format.WMSGetFeatureInfo(options.formatOptions);}
-if(this.hover){this.handler=new OpenLayers.Handler.Hover(this,{'move':this.cancelHover,'pause':this.getInfoForHover},OpenLayers.Util.extend(this.handlerOptions.hover||{},{'delay':250}));}else{var callbacks={};callbacks[this.clickCallback]=this.getInfoForClick;this.handler=new OpenLayers.Handler.Click(this,callbacks,this.handlerOptions.click||{});}},activate:function(){if(!this.active){this.handler.activate();}
-return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},getInfoForClick:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});OpenLayers.Element.addClass(this.map.viewPortDiv,"olCursorWait");this.request(evt.xy,{});},getInfoForHover:function(evt){this.events.triggerEvent("beforegetfeatureinfo",{xy:evt.xy});this.request(evt.xy,{hover:true});},cancelHover:function(){if(this.hoverRequest){this.hoverRequest.abort();this.hoverRequest=null;}},findLayers:function(){var candidates=this.layers||this.map.layers;var layers=[];var layer,url;for(var i=0,len=candidates.length;i<len;++i){layer=candidates[i];if(layer instanceof OpenLayers.Layer.WMS&&(!this.queryVisible||layer.getVisibility())){url=layer.url instanceof Array?layer.url[0]:layer.url;if(this.drillDown===false&&!this.url){this.url=url;}
-if(this.drillDown===true||this.urlMatches(url)){layers.push(layer);}}}
-return layers;},urlMatches:function(url){var matches=OpenLayers.Util.isEquivalentUrl(this.url,url);if(!matches&&this.layerUrls){for(var i=0,len=this.layerUrls.length;i<len;++i){if(OpenLayers.Util.isEquivalentUrl(this.layerUrls[i],url)){matches=true;break;}}}
-return matches;},buildWMSOptions:function(url,layers,clickPosition,format){var layerNames=[],styleNames=[];for(var i=0,len=layers.length;i<len;i++){layerNames=layerNames.concat(layers[i].params.LAYERS);styleNames=styleNames.concat(this.getStyleNames(layers[i]));}
-var firstLayer=layers[0];var projection=this.map.getProjection();var layerProj=firstLayer.projection;if(layerProj&&layerProj.equals(this.map.getProjectionObject())){projection=layerProj.getCode();}
-var params=OpenLayers.Util.extend({service:"WMS",version:firstLayer.params.VERSION,request:"GetFeatureInfo",layers:layerNames,query_layers:layerNames,styles:styleNames,bbox:this.map.getExtent().toBBOX(null,firstLayer.reverseAxisOrder()),feature_count:this.maxFeatures,height:this.map.getSize().h,width:this.map.getSize().w,format:format,info_format:this.infoFormat},(parseFloat(firstLayer.params.VERSION)>=1.3)?{crs:projection,i:parseInt(clickPosition.x),j:parseInt(clickPosition.y)}:{srs:projection,x:parseInt(clickPosition.x),y:parseInt(clickPosition.y)});OpenLayers.Util.applyDefaults(params,this.vendorParams);return{url:url,params:OpenLayers.Util.upperCaseObject(params),callback:function(request){this.handleResponse(clickPosition,request);},scope:this};},getStyleNames:function(layer){var styleNames;if(layer.params.STYLES){styleNames=layer.params.STYLES;}else{if(layer.params.LAYERS instanceof Array){styleNames=new Array(layer.params.LAYERS.length);}else{styleNames=layer.params.L
AYERS.replace(/[^,]/g,"");}}
-return styleNames;},request:function(clickPosition,options){var layers=this.findLayers();if(layers.length==0){this.events.triggerEvent("nogetfeatureinfo");OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");return;}
-options=options||{};if(this.drillDown===false){var wmsOptions=this.buildWMSOptions(this.url,layers,clickPosition,layers[0].params.FORMAT);var request=OpenLayers.Request.GET(wmsOptions);if(options.hover===true){this.hoverRequest=request;}}else{this._requestCount=0;this._numRequests=0;this.features=[];var services={},url;for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];var service,found=false;url=layer.url instanceof Array?layer.url[0]:layer.url;if(url in services){services[url].push(layer);}else{this._numRequests++;services[url]=[layer];}}
-var layers;for(var url in services){layers=services[url];var wmsOptions=this.buildWMSOptions(url,layers,clickPosition,layers[0].params.FORMAT);OpenLayers.Request.GET(wmsOptions);}}},triggerGetFeatureInfo:function(request,xy,features){this.events.triggerEvent("getfeatureinfo",{text:request.responseText,features:features,request:request,xy:xy});OpenLayers.Element.removeClass(this.map.viewPortDiv,"olCursorWait");},handleResponse:function(xy,request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var features=this.format.read(doc);if(this.drillDown===false){this.triggerGetFeatureInfo(request,xy,features);}else{this._requestCount++;this._features=(this._features||[]).concat(features);if(this._requestCount===this._numRequests){this.triggerGetFeatureInfo(request,xy,this._features.concat());delete this._features;delete this._requestCount;delete this._numRequests;}}},CLASS_NAME:"OpenLayers.Control.WMSGetFeatureInfo"});OpenLayers.Format.WMSCapabilities.v1_3=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1,{readers:{"wms":OpenLayers.Util.applyDefaults({"WMS_Capabilities":function(node,obj){this.readChildNodes(node,obj);},"LayerLimit":function(node,obj){obj.layerLimit=parseInt(this.getChildValue(node));},"MaxWidth":function(node,obj){obj.maxWidth=parseInt(this.getChildValue(node));},"MaxHeight":function(node,obj){obj.maxHeight=parseInt(this.getChildValue(node));},"BoundingBox":function(node,obj){var bbox=OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"].Boun
dingBox.apply(this,[node,obj]);bbox.srs=node.getAttribute("CRS");obj.bbox[bbox.srs]=bbox;},"CRS":function(node,obj){this.readers.wms.SRS.apply(this,[node,obj]);},"EX_GeographicBoundingBox":function(node,obj){obj.llbbox=[];this.readChildNodes(node,obj.llbbox);},"westBoundLongitude":function(node,obj){obj[0]=this.getChildValue(node);},"eastBoundLongitude":function(node,obj){obj[2]=this.getChildValue(node);},"southBoundLatitude":function(node,obj){obj[1]=this.getChildValue(node);},"northBoundLatitude":function(node,obj){obj[3]=this.getChildValue(node);},"MinScaleDenominator":function(node,obj){obj.maxScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"MaxScaleDenominator":function(node,obj){obj.minScale=parseFloat(this.getChildValue(node)).toPrecision(16);},"Dimension":function(node,obj){var name=node.getAttribute("name").toLowerCase();var dim={name:name,units:node.getAttribute("units"),unitsymbol:node.getAttribute("unitSymbol"),nearestVal:node.getAttribute("nearestVa
lue")==="1",multipleVal:node.getAttribute("multipleValues")==="1","default":node.getAttribute("default")||"",current:node.getAttribute("current")==="1",values:this.getChildValue(node).split(",")};obj.dimensions[dim.name]=dim;},"Keyword":function(node,obj){var keyword={value:this.getChildValue(node),vocabulary:node.getAttribute("vocabulary")};if(obj.keywords){obj.keywords.push(keyword);}}},OpenLayers.Format.WMSCapabilities.v1.prototype.readers["wms"]),"sld":{"UserDefinedSymbolization":function(node,obj){this.readers.wms.UserDefinedSymbolization.apply(this,[node,obj]);obj.userSymbols.inlineFeature=parseInt(node.getAttribute("InlineFeature"))==1;obj.userSymbols.remoteWCS=parseInt(node.getAttribute("RemoteWCS"))==1;},"DescribeLayer":function(node,obj){this.readers.wms.DescribeLayer.apply(this,[node,obj]);},"GetLegendGraphic":function(node,obj){this.readers.wms.GetLegendGraphic.apply(this,[node,obj]);}}},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3"});OpenLayers.Format.WMSC
apabilities.v1_3_0=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_3,{version:"1.3.0",CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_3_0"});OpenLayers.Format.CQL=(function(){var tokens=["PROPERTY","COMPARISON","VALUE","LOGICAL"],patterns={PROPERTY:/^[_a-zA-Z]\w*/,COMPARISON:/^(=|<>|<=|<|>=|>|LIKE)/i,COMMA:/^,/,LOGICAL:/^(AND|OR)/i,VALUE:/^('\w+'|\d+(\.\d*)?|\.\d+)/,LPAREN:/^\(/,RPAREN:/^\)/,SPATIAL:/^(BBOX|INTERSECTS|DWITHIN|WITHIN|CONTAINS)/i,NOT:/^NOT/i,BETWEEN:/^BETWEEN/i,GEOMETRY:function(text){var type=/^(POINT|LINESTRING|POLYGON|MULTIPOINT|MULTILINESTRING|MULTIPOLYGON|GEOMETRYCOLLECTION)/.exec(text);if(type){var len=text.length;var idx=text.indexOf("(",type[0].length);if(idx>-1){var depth=1;while(idx<len&&depth>0){idx++;switch(text.charAt(idx)){case'(':depth++;break;case')':depth--;break;default:}}}
-return[text.substr(0,idx+1)];}},END:/^$/},follows={LPAREN:['GEOMETRY','SPATIAL','PROPERTY','VALUE','LPAREN'],RPAREN:['NOT','LOGICAL','END','RPAREN'],PROPERTY:['COMPARISON','BETWEEN','COMMA'],BETWEEN:['VALUE'],COMPARISON:['VALUE'],COMMA:['GEOMETRY','VALUE','PROPERTY'],VALUE:['LOGICAL','COMMA','RPAREN','END'],SPATIAL:['LPAREN'],LOGICAL:['NOT','VALUE','SPATIAL','PROPERTY','LPAREN'],NOT:['PROPERTY','LPAREN'],GEOMETRY:['COMMA','RPAREN']},operators={'=':OpenLayers.Filter.Comparison.EQUAL_TO,'<>':OpenLayers.Filter.Comparison.NOT_EQUAL_TO,'<':OpenLayers.Filter.Comparison.LESS_THAN,'<=':OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO,'>':OpenLayers.Filter.Comparison.GREATER_THAN,'>=':OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO,'LIKE':OpenLayers.Filter.Comparison.LIKE,'BETWEEN':OpenLayers.Filter.Comparison.BETWEEN},operatorReverse={},logicals={'AND':OpenLayers.Filter.Logical.AND,'OR':OpenLayers.Filter.Logical.OR},logicalReverse={},precedence={'RPAREN':3,'LOGICAL':2,'COMPA
RISON':1};var i;for(i in operators){if(operators.hasOwnProperty(i)){operatorReverse[operators[i]]=i;}}
-for(i in logicals){if(logicals.hasOwnProperty(i)){logicalReverse[logicals[i]]=i;}}
-function tryToken(text,pattern){if(pattern instanceof RegExp){return pattern.exec(text);}else{return pattern(text);}}
-function nextToken(text,tokens){var i,token,len=tokens.length;for(i=0;i<len;i++){token=tokens[i];var pat=patterns[token];var matches=tryToken(text,pat);if(matches){var match=matches[0];var remainder=text.substr(match.length).replace(/^\s*/,"");return{type:token,text:match,remainder:remainder};}}
-var msg="ERROR: In parsing: ["+text+"], expected one of: ";for(i=0;i<len;i++){token=tokens[i];msg+="\n "+token+": "+patterns[token];}
-throw new Error(msg);}
-function tokenize(text){var results=[];var token,expect=["NOT","GEOMETRY","SPATIAL","PROPERTY","LPAREN"];do{token=nextToken(text,expect);text=token.remainder;expect=follows[token.type];if(token.type!="END"&&!expect){throw new Error("No follows list for "+token.type);}
-results.push(token);}while(token.type!="END");return results;}
-function buildAst(tokens){var operatorStack=[],postfix=[];while(tokens.length){var tok=tokens.shift();switch(tok.type){case"PROPERTY":case"GEOMETRY":case"VALUE":postfix.push(tok);break;case"COMPARISON":case"BETWEEN":case"LOGICAL":var p=precedence[tok.type];while(operatorStack.length>0&&(precedence[operatorStack[operatorStack.length-1].type]<=p)){postfix.push(operatorStack.pop());}
-operatorStack.push(tok);break;case"SPATIAL":case"NOT":case"LPAREN":operatorStack.push(tok);break;case"RPAREN":while(operatorStack.length>0&&(operatorStack[operatorStack.length-1].type!="LPAREN")){postfix.push(operatorStack.pop());}
-operatorStack.pop();if(operatorStack.length>0&&operatorStack[operatorStack.length-1].type=="SPATIAL"){postfix.push(operatorStack.pop());}
-case"COMMA":case"END":break;default:throw new Error("Unknown token type "+tok.type);}}
-while(operatorStack.length>0){postfix.push(operatorStack.pop());}
-function buildTree(){var tok=postfix.pop();switch(tok.type){case"LOGICAL":var rhs=buildTree(),lhs=buildTree();return new OpenLayers.Filter.Logical({filters:[lhs,rhs],type:logicals[tok.text.toUpperCase()]});case"NOT":var operand=buildTree();return new OpenLayers.Filter.Logical({filters:[operand],type:OpenLayers.Filter.Logical.NOT});case"BETWEEN":var min,max,property;postfix.pop();max=buildTree();min=buildTree();property=buildTree();return new OpenLayers.Filter.Comparison({property:property,lowerBoundary:min,upperBoundary:max,type:OpenLayers.Filter.Comparison.BETWEEN});case"COMPARISON":var value=buildTree(),property=buildTree();return new OpenLayers.Filter.Comparison({property:property,value:value,type:operators[tok.text.toUpperCase()]});case"VALUE":if((/^'.*'$/).test(tok.text)){return tok.text.substr(1,tok.text.length-2);}else{return Number(tok.text);}
-case"SPATIAL":switch(tok.text.toUpperCase()){case"BBOX":var maxy=buildTree(),maxx=buildTree(),miny=buildTree(),minx=buildTree(),prop=buildTree();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.BBOX,property:prop,value:OpenLayers.Bounds.fromArray([minx,miny,maxx,maxy])});case"INTERSECTS":var value=buildTree(),property=buildTree();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.INTERSECTS,property:property,value:value});case"WITHIN":var value=buildTree(),property=buildTree();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.WITHIN,property:property,value:value});case"CONTAINS":var value=buildTree(),property=buildTree();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.CONTAINS,property:property,value:value});case"DWITHIN":var distance=buildTree(),value=buildTree(),property=buildTree();return new OpenLayers.Filter.Spatial({type:OpenLayers.Filter.Spatial.DWITHIN,value:value,property:property,distance
:Number(distance)});}
-case"GEOMETRY":return OpenLayers.Geometry.fromWKT(tok.text);default:return tok.text;}}
-var result=buildTree();if(postfix.length>0){var msg="Remaining tokens after building AST: \n";for(var i=postfix.length-1;i>=0;i--){msg+=postfix[i].type+": "+postfix[i].text+"\n";}
-return result;}
-return OpenLayers.Class(OpenLayers.Format,{read:function(text){var result=buildAst(tokenize(text));if(this.keepData){this.data=result;};return result;},write:function(filter){if(filter instanceof OpenLayers.Geometry){return filter.toString();}
-switch(filter.CLASS_NAME){case"OpenLayers.Filter.Spatial":switch(filter.type){case OpenLayers.Filter.Spatial.BBOX:return"BBOX("+
-filter.property+","+
-filter.value.toBBOX()+")";case OpenLayers.Filter.Spatial.DWITHIN:return"DWITHIN("+
-filter.property+", "+
-this.write(filter.value)+", "+
-filter.distance+")";case OpenLayers.Filter.Spatial.WITHIN:return"WITHIN("+
-this.write(filter.value)+")";case OpenLayers.Filter.Spatial.INTERSECTS:return"INTERSECTS("+
-this.write(filter.value)+")";case OpenLayers.Filter.Spatial.CONTAINS:return"CONTAINS("+
-this.write(filter.value)+")";default:throw new Error("Unknown spatial filter type: "+filter.type);}
-case"OpenLayers.Filter.Logical":if(filter.type==OpenLayers.Filter.Logical.NOT){return"NOT ("+this.write(filter.filters[0])+")";}else{var res="(";var first=true;for(var i=0;i<filter.filters.length;i++){if(first){first=false;}else{res+=") "+logicalReverse[filter.type]+" (";}
-res+=this.write(filter.filters[i]);}
-return res+")";}
-case"OpenLayers.Filter.Comparison":if(filter.type==OpenLayers.Filter.Comparison.BETWEEN){return filter.property+" BETWEEN "+
-this.write(filter.lowerBoundary)+" AND "+
-this.write(filter.upperBoundary);}else{return filter.property+" "+operatorReverse[filter.type]+" "+
-this.write(filter.value);}
-case undefined:if(typeof filter==="string"){return"'"+filter+"'";}else if(typeof filter==="number"){return String(filter);}
-default:throw new Error("Can't encode: "+filter.CLASS_NAME+" "+filter);}},CLASS_NAME:"OpenLayers.Format.CQL"});})();OpenLayers.Control.Split=OpenLayers.Class(OpenLayers.Control,{EVENT_TYPES:["beforesplit","split","aftersplit"],layer:null,source:null,sourceOptions:null,tolerance:null,edge:true,deferDelete:false,mutual:true,targetFilter:null,sourceFilter:null,handler:null,initialize:function(options){Array.prototype.push.apply(this.EVENT_TYPES,OpenLayers.Control.prototype.EVENT_TYPES);OpenLayers.Control.prototype.initialize.apply(this,[options]);this.options=options||{};if(this.options.source){this.setSource(this.options.source);}},setSource:function(layer){if(this.active){this.deactivate();if(this.handler){this.handler.destroy();delete this.handler;}
-this.source=layer;this.activate();}else{this.source=layer;}},activate:function(){var activated=OpenLayers.Control.prototype.activate.call(this);if(activated){if(!this.source){if(!this.handler){this.handler=new OpenLayers.Handler.Path(this,{done:function(geometry){this.onSketchComplete({feature:new OpenLayers.Feature.Vector(geometry)});}},{layerOptions:this.sourceOptions});}
-this.handler.activate();}else if(this.source.events){this.source.events.on({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});}}
-return activated;},deactivate:function(){var deactivated=OpenLayers.Control.prototype.deactivate.call(this);if(deactivated){if(this.source&&this.source.events){this.layer.events.un({sketchcomplete:this.onSketchComplete,afterfeaturemodified:this.afterFeatureModified,scope:this});}}
-return deactivated;},onSketchComplete:function(event){this.feature=null;return!this.considerSplit(event.feature);},afterFeatureModified:function(event){if(event.modified){var feature=event.feature;if(feature.geometry instanceof OpenLayers.Geometry.LineString||feature.geometry instanceof OpenLayers.Geometry.MultiLineString){this.feature=event.feature;this.considerSplit(event.feature);}}},removeByGeometry:function(features,geometry){for(var i=0,len=features.length;i<len;++i){if(features[i].geometry===geometry){features.splice(i,1);break;}}},isEligible:function(target){return(target.state!==OpenLayers.State.DELETE)&&(target.geometry instanceof OpenLayers.Geometry.LineString||target.geometry instanceof OpenLayers.Geometry.MultiLineString)&&(this.feature!==target)&&(!this.targetFilter||this.targetFilter.evaluate(target.attributes));},considerSplit:function(feature){var sourceSplit=false;var targetSplit=false;if(!this.sourceFilter||this.sourceFilter.evaluate(feature.attributes)){v
ar features=this.layer&&this.layer.features||[];var target,results,proceed;var additions=[],removals=[];var mutual=(this.layer===this.source)&&this.mutual;var options={edge:this.edge,tolerance:this.tolerance,mutual:mutual};var sourceParts=[feature.geometry];var targetFeature,targetParts;var source,parts;for(var i=0,len=features.length;i<len;++i){targetFeature=features[i];if(this.isEligible(targetFeature)){targetParts=[targetFeature.geometry];for(var j=0;j<sourceParts.length;++j){source=sourceParts[j];for(var k=0;k<targetParts.length;++k){target=targetParts[k];if(source.getBounds().intersectsBounds(target.getBounds())){results=source.split(target,options);if(results){proceed=this.events.triggerEvent("beforesplit",{source:feature,target:targetFeature});if(proceed!==false){if(mutual){parts=results[0];if(parts.length>1){parts.unshift(j,1);Array.prototype.splice.apply(sourceParts,parts);j+=parts.length-3;}
-results=results[1];}
-if(results.length>1){results.unshift(k,1);Array.prototype.splice.apply(targetParts,results);k+=results.length-3;}}}}}}
-if(targetParts&&targetParts.length>1){this.geomsToFeatures(targetFeature,targetParts);this.events.triggerEvent("split",{original:targetFeature,features:targetParts});Array.prototype.push.apply(additions,targetParts);removals.push(targetFeature);targetSplit=true;}}}
-if(sourceParts&&sourceParts.length>1){this.geomsToFeatures(feature,sourceParts);this.events.triggerEvent("split",{original:feature,features:sourceParts});Array.prototype.push.apply(additions,sourceParts);removals.push(feature);sourceSplit=true;}
-if(sourceSplit||targetSplit){if(this.deferDelete){var feat,destroys=[];for(var i=0,len=removals.length;i<len;++i){feat=removals[i];if(feat.state===OpenLayers.State.INSERT){destroys.push(feat);}else{feat.state=OpenLayers.State.DELETE;this.layer.drawFeature(feat);}}
-this.layer.destroyFeatures(destroys,{silent:true});for(var i=0,len=additions.length;i<len;++i){additions[i].state=OpenLayers.State.INSERT;}}else{this.layer.destroyFeatures(removals,{silent:true});}
-this.layer.addFeatures(additions,{silent:true});this.events.triggerEvent("aftersplit",{source:feature,features:additions});}}
-return sourceSplit;},geomsToFeatures:function(feature,geoms){var clone=feature.clone();delete clone.geometry;var newFeature;for(var i=0,len=geoms.length;i<len;++i){newFeature=clone.clone();newFeature.geometry=geoms[i];newFeature.state=OpenLayers.State.INSERT;geoms[i]=newFeature;}},destroy:function(){if(this.active){this.deactivate();}
-OpenLayers.Control.prototype.destroy.call(this);},CLASS_NAME:"OpenLayers.Control.Split"});OpenLayers.Protocol.SOS.v1_0_0=OpenLayers.Class(OpenLayers.Protocol,{fois:null,formatOptions:null,initialize:function(options){OpenLayers.Protocol.prototype.initialize.apply(this,[options]);if(!options.format){this.format=new OpenLayers.Format.SOSGetFeatureOfInterest(this.formatOptions);}},destroy:function(){if(this.options&&!this.options.format){this.format.destroy();}
-this.format=null;OpenLayers.Protocol.prototype.destroy.apply(this);},read:function(options){options=OpenLayers.Util.extend({},options);OpenLayers.Util.applyDefaults(options,this.options||{});var response=new OpenLayers.Protocol.Response({requestType:"read"});var format=this.format;var data=OpenLayers.Format.XML.prototype.write.apply(format,[format.writeNode("sos:GetFeatureOfInterest",{fois:this.fois})]);response.priv=OpenLayers.Request.POST({url:options.url,callback:this.createCallback(this.handleRead,response,options),data:data});return response;},handleRead:function(response,options){if(options.callback){var request=response.priv;if(request.status>=200&&request.status<300){response.features=this.parseFeatures(request);response.code=OpenLayers.Protocol.Response.SUCCESS;}else{response.code=OpenLayers.Protocol.Response.FAILURE;}
-options.callback.call(options.scope,response);}},parseFeatures:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-if(!doc||doc.length<=0){return null;}
-return this.format.read(doc);},CLASS_NAME:"OpenLayers.Protocol.SOS.v1_0_0"});OpenLayers.Layer.KaMapCache=OpenLayers.Class(OpenLayers.Layer.KaMap,{IMAGE_EXTENSIONS:{'jpeg':'jpg','gif':'gif','png':'png','png8':'png','png24':'png','dithered':'png'},DEFAULT_FORMAT:'jpeg',initialize:function(name,url,params,options){OpenLayers.Layer.KaMap.prototype.initialize.apply(this,arguments);this.extension=this.IMAGE_EXTENSIONS[this.params.i.toLowerCase()||DEFAULT_FORMAT];},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);var metaX=Math.floor(pX/this.tileSize.w/this.params.metaTileSize.w)*this.tileSize.w*this.params.metaTileSize.w;var metaY=Math.floor(pY/this.tileSize.h/this.params.metaTileSize.h)*this.tileSize.h*this.params.metaTileSize.h;var url=this.url;if(url instanceof Array){url=this.selectUrl(paramsString,url);
-var components=[url,"/",this.params.map,"/",scale,"/",this.params.g.replace(/\s/g,'_'),"/def/t",metaY,"/l",metaX,"/t",pY,"l",pX,".",this.extension];return components.join("");},CLASS_NAME:"OpenLayers.Layer.KaMapCache"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,format:'image/png',serverResolutions:null,initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.getOptions());}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.serverResolutions!=null?OpenLayers.Util.indexOf(this.serverResolutions,res):this.map.getZoom();function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
-return zeros.join('').substring(0,length-number.length)+number;}
-var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Format.WMSCapabilities.v1_1_1=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1,{version:"1.1.1",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.applyDefaults({"SRS":function(node,obj){obj.srs[this.getChildValue(node)]=true;}},OpenLayers.Format.WMSCapabilities.v1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1"});OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC=OpenLayers.Class(OpenLayers.Format.WMSCapabilities.v1_1_1,{version:"1.1.1",profile:"WMSC",initialize:function(options){OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.initialize.apply(this,[options]);},readers:{"wms":OpenLayers.Util.
applyDefaults({"VendorSpecificCapabilities":function(node,obj){obj.vendorSpecific={tileSets:[]};this.readChildNodes(node,obj.vendorSpecific);},"TileSet":function(node,vendorSpecific){var tileset={srs:{},bbox:{},resolutions:[]};this.readChildNodes(node,tileset);vendorSpecific.tileSets.push(tileset);},"Resolutions":function(node,tileset){var res=this.getChildValue(node).split(" ");for(var i=0,len=res.length;i<len;i++){if(res[i]!=""){tileset.resolutions.push(parseFloat(res[i]));}}},"Width":function(node,tileset){tileset.width=parseInt(this.getChildValue(node));},"Height":function(node,tileset){tileset.height=parseInt(this.getChildValue(node));},"Layers":function(node,tileset){tileset.layers=this.getChildValue(node);},"Styles":function(node,tileset){tileset.styles=this.getChildValue(node);}},OpenLayers.Format.WMSCapabilities.v1_1_1.prototype.readers["wms"])},CLASS_NAME:"OpenLayers.Format.WMSCapabilities.v1_1_1_WMSC"});OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector
,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
-if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
-params=OpenLayers.Util.upperCaseObject(params);OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
-OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
-if(this.params&&this.params.typename&&!this.options.typename){this.options.typename=this.params.typename;}
-if(!this.options.geometry_column){this.options.geometry_column="the_geom";}
-this.params=OpenLayers.Util.applyDefaults(params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.url=url;},destroy:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);}
-if(this.tile){this.tile.destroy();}
-this.tile=null;this.ratio=null;this.featureClass=null;this.format=null;if(this.formatObject&&this.formatObject.destroy){this.formatObject.destroy();}
-this.formatObject=null;this.formatOptions=null;this.vectorMode=null;this.encodeBBOX=null;this.extractAttributes=null;},setMap:function(map){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);var options={'extractAttributes':this.extractAttributes};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.formatObject=this.format?new this.format(options):new OpenLayers.Format.GML(options);}else{OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments);}},moveTo:function(bounds,zoomChanged,dragging){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);}
-if(dragging){return false;}
-if(zoomChanged){if(this.vectorMode){this.renderer.clear();}}
-if(this.options.minZoomLevel){OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));if(this.map.getZoom()<this.options.minZoomLevel){return null;}}
-if(bounds==null){bounds=this.map.getExtent();}
-var firstRendering=(this.tile==null);var outOfBounds=(!firstRendering&&!this.tile.bounds.containsBounds(bounds));if(zoomChanged||firstRendering||(!dragging&&outOfBounds)){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var tileSize=this.map.getSize();tileSize.w=tileSize.w*this.ratio;tileSize.h=tileSize.h*this.ratio;var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var pos=this.map.getLayerPxFromLonLat(ul);var url=this.getFullRequestString();var params=null;var filter=this.params.filter||this.params.FILTER;if(filter){params={FILTER:filter};}
-else{params={BBOX:this.encodeBBOX?tileBounds.toBBOX():tileBounds.toArray()};}
-if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var projectedBounds=tileBounds.clone();projectedBounds.transform(this.map.getProjectionObject(),this.projection);if(!filter){params.BBOX=this.encodeBBOX?projectedBounds.toBBOX():projectedBounds.toArray();}}
-url+="&"+OpenLayers.Util.getParameterString(params);if(!this.tile){this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}else{if(this.vectorMode){this.destroyFeatures();this.renderer.clear();}else{this.clearMarkers();}
-this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}}},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("loadstart");}};tile.events.register("loadstart",tile,tile.onLoadStart);tile.onLoadEnd=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("tileloaded");this.layer.events.triggerEvent("loadend");}};tile.events.register("loadend",tile,tile.onLoadEnd);tile.events.register("unload",tile,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:tile});},onMapResize:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,arg
uments);}},display:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.display.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.display.apply(this,arguments);}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.getOptions());}
-if(this.vectorMode){obj=OpenLayers.Layer.Vector.prototype.clone.apply(this,[obj]);}else{obj=OpenLayers.Layer.Markers.prototype.clone.apply(this,[obj]);}
-return obj;},getFullRequestString:function(newParams,altUrl){var projectionCode=this.projection.getCode()||this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},commit:function(){if(!this.writer){var options={};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.writer=new OpenLayers.Format.WFS(options,this);}
-var data=this.writer.write(this.features);OpenLayers.Request.POST({url:this.url,data:data,success:this.commitSuccess,failure:this.commitFailure,scope:this});},commitSuccess:function(request){var response=request.responseText;if(response.indexOf('SUCCESS')!=-1){this.commitReport(OpenLayers.i18n("commitSuccess",{'response':response}));for(var i=0;i<this.features.length;i++){this.features[i].state=null;}}else if(response.indexOf('FAILED')!=-1||response.indexOf('Exception')!=-1){this.commitReport(OpenLayers.i18n("commitFailed",{'response':response}));}},commitFailure:function(request){},commitReport:function(string,response){OpenLayers.Console.userError(string);},refresh:function(){if(this.tile){if(this.vectorMode){this.renderer.clear();this.features.length=0;}else{this.clearMarkers();this.markers.length=0;}
-this.tile.draw();}},getDataExtent:function(){var extent;if(this.vectorMode){extent=OpenLayers.Layer.Vector.prototype.getDataExtent.apply(this);}else{extent=OpenLayers.Layer.Markers.prototype.getDataExtent.apply(this);}
-return extent;},setOpacity:function(opacity){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setOpacity.apply(this,[opacity]);}else{OpenLayers.Layer.Markers.prototype.setOpacity.apply(this,[opacity]);}},CLASS_NAME:"OpenLayers.Layer.WFS"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{roundedCorner:true,roundedCornerColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[];},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselay
er":this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();if(!this.outsideViewport){this.minimizeControl();}
-this.redraw();return this.div;},clearLayersArray:function(layersType){var layers=this[layersType+"Layers"];if(layers){for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];OpenLayers.Event.stopObservingElement(layer.inputElem);OpenLayers.Event.stopObservingElement(layer.labelSpan);}}
-this[layersType+"LayersDiv"].innerHTML="";this[layersType+"Layers"]=[];},checkRedraw:function(){var redraw=false;if(!this.layerStates.length||(this.map.layers.length!=this.layerStates.length)){redraw=true;}else{for(var i=0,len=this.layerStates.length;i<len;i++){var layerState=this.layerStates[i];var layer=this.map.layers[i];if((layerState.name!=layer.name)||(layerState.inRange!=layer.inRange)||(layerState.id!=layer.id)||(layerState.visibility!=layer.visibility)){redraw=true;break;}}}
-return redraw;},redraw:function(){if(!this.checkRedraw()){return this.div;}
-this.clearLayersArray("base");this.clearLayersArray("data");var containsOverlays=false;var containsBaseLayers=false;var len=this.map.layers.length;this.layerStates=new Array(len);for(var i=0;i<len;i++){var layer=this.map.layers[i];this.layerStates[i]={'name':layer.name,'visibility':layer.visibility,'inRange':layer.inRange,'id':layer.id};}
-var layers=this.map.layers.slice();if(!this.ascending){layers.reverse();}
-for(var i=0,len=layers.length;i<len;i++){var layer=layers[i];var baseLayer=layer.isBaseLayer;if(layer.displayInLayerSwitcher){if(baseLayer){containsBaseLayers=true;}else{containsOverlays=true;}
-var checked=(baseLayer)?(layer==this.map.baseLayer):layer.getVisibility();var inputElem=document.createElement("input");inputElem.id=this.id+"_input_"+layer.name;inputElem.name=(baseLayer)?this.id+"_baseLayers":layer.name;inputElem.type=(baseLayer)?"radio":"checkbox";inputElem.value=layer.name;inputElem.checked=checked;inputElem.defaultChecked=checked;if(!baseLayer&&!layer.inRange){inputElem.disabled=true;}
-var context={'inputElem':inputElem,'layer':layer,'layerSwitcher':this};OpenLayers.Event.observe(inputElem,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var labelSpan=document.createElement("span");OpenLayers.Element.addClass(labelSpan,"labelSpan");if(!baseLayer&&!layer.inRange){labelSpan.style.color="gray";}
-labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
-this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
-OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0,len=this.baseLayers.length;i<len;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
-for(var i=0,len=this.dataLayers.length;i<len;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layers
Div=document.createElement("div");this.layersDiv.id=this.id+"_layersDiv";OpenLayers.Element.addClass(this.layersDiv,"layersDiv");this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");OpenLayers.Element.addClass(this.baseLbl,"baseLbl");this.baseLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.baseLayersDiv,"baseLayersDiv");this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");OpenLayers.Element.addClass(this.dataLbl,"dataLbl");this.dataLayersDiv=document.createElement("div");OpenLayers.Element.addClass(this.dataLayersDiv,"dataLayersDiv");if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layers
Div.appendChild(this.baseLayersDiv);}
-this.div.appendChild(this.layersDiv);if(this.roundedCorner){OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.roundedCornerColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);}
-var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.maximizeDiv,"maximizeDiv");this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");OpenLayers.Element.addClass(this.minimizeDiv,"minimizeDiv");this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.
Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Format.Atom=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{atom:"http://www.w3.org/2005/Atom",georss:"http://www.georss.org/georss"},feedTitle:"untitled",defaultEntryTitle:"untitled",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-return this.parseFeatures(doc);},write:function(features){var doc;if(features instanceof Array){doc=this.createElementNSPlus("atom:feed");doc.appendChild(this.createElementNSPlus("atom:title",{value:this.feedTitle}));for(var i=0,ii=features.length;i<ii;i++){doc.appendChild(this.buildEntryNode(features[i]));}}
-else{doc=this.buildEntryNode(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[doc]);},buildContentNode:function(content){var node=this.createElementNSPlus("atom:content",{attributes:{type:content.type||null}});if(content.src){node.setAttribute("src",content.src);}else{if(content.type=="text"||content.type==null){node.appendChild(this.createTextNode(content.value));}else if(content.type=="html"){if(typeof content.value!="string"){throw"HTML content must be in form of an escaped string";}
-node.appendChild(this.createTextNode(content.value));}else if(content.type=="xhtml"){node.appendChild(content.value);}else if(content.type=="xhtml"||content.type.match(/(\+|\/)xml$/)){node.appendChild(content.value);}
-else{node.appendChild(this.createTextNode(content.value));}}
-return node;},buildEntryNode:function(feature){var attrib=feature.attributes;var atomAttrib=attrib.atom||{};var entryNode=this.createElementNSPlus("atom:entry");if(atomAttrib.authors){var authors=atomAttrib.authors instanceof Array?atomAttrib.authors:[atomAttrib.authors];for(var i=0,ii=authors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("author",authors[i]));}}
-if(atomAttrib.categories){var categories=atomAttrib.categories instanceof Array?atomAttrib.categories:[atomAttrib.categories];var category;for(var i=0,ii=categories.length;i<ii;i++){category=categories[i];entryNode.appendChild(this.createElementNSPlus("atom:category",{attributes:{term:category.term,scheme:category.scheme||null,label:category.label||null}}));}}
-if(atomAttrib.content){entryNode.appendChild(this.buildContentNode(atomAttrib.content));}
-if(atomAttrib.contributors){var contributors=atomAttrib.contributors instanceof Array?atomAttrib.contributors:[atomAttrib.contributors];for(var i=0,ii=contributors.length;i<ii;i++){entryNode.appendChild(this.buildPersonConstructNode("contributor",contributors[i]));}}
-if(feature.fid){entryNode.appendChild(this.createElementNSPlus("atom:id",{value:feature.fid}));}
-if(atomAttrib.links){var links=atomAttrib.links instanceof Array?atomAttrib.links:[atomAttrib.links];var link;for(var i=0,ii=links.length;i<ii;i++){link=links[i];entryNode.appendChild(this.createElementNSPlus("atom:link",{attributes:{href:link.href,rel:link.rel||null,type:link.type||null,hreflang:link.hreflang||null,title:link.title||null,length:link.length||null}}));}}
-if(atomAttrib.published){entryNode.appendChild(this.createElementNSPlus("atom:published",{value:atomAttrib.published}));}
-if(atomAttrib.rights){entryNode.appendChild(this.createElementNSPlus("atom:rights",{value:atomAttrib.rights}));}
-if(atomAttrib.summary||attrib.description){entryNode.appendChild(this.createElementNSPlus("atom:summary",{value:atomAttrib.summary||attrib.description}));}
-entryNode.appendChild(this.createElementNSPlus("atom:title",{value:atomAttrib.title||attrib.title||this.defaultEntryTitle}));if(atomAttrib.updated){entryNode.appendChild(this.createElementNSPlus("atom:updated",{value:atomAttrib.updated}));}
-if(feature.geometry){var whereNode=this.createElementNSPlus("georss:where");whereNode.appendChild(this.buildGeometryNode(feature.geometry));entryNode.appendChild(whereNode);}
-return entryNode;},initGmlParser:function(){this.gmlParser=new OpenLayers.Format.GML.v3({xy:this.xy,featureNS:"http://example.com#feature",internalProjection:this.internalProjection,externalProjection:this.externalProjection});},buildGeometryNode:function(geometry){if(!this.gmlParser){this.initGmlParser();}
-var node=this.gmlParser.writeNode("feature:_geometry",geometry);return node.firstChild;},buildPersonConstructNode:function(name,value){var oNames=["uri","email"];var personNode=this.createElementNSPlus("atom:"+name);personNode.appendChild(this.createElementNSPlus("atom:name",{value:value.name}));for(var i=0,ii=oNames.length;i<ii;i++){if(value[oNames[i]]){personNode.appendChild(this.createElementNSPlus("atom:"+oNames[i],{value:value[oNames[i]]}));}}
-return personNode;},getFirstChildValue:function(node,nsuri,name,def){var value;var nodes=this.getElementsByTagNameNS(node,nsuri,name);if(nodes&&nodes.length>0){value=this.getChildValue(nodes[0],def);}else{value=def;}
-return value;},parseFeature:function(node){var atomAttrib={};var value=null;var nodes=null;var attval=null;var atomns=this.namespaces.atom;this.parsePersonConstructs(node,"author",atomAttrib);nodes=this.getElementsByTagNameNS(node,atomns,"category");if(nodes.length>0){atomAttrib.categories=[];}
-for(var i=0,ii=nodes.length;i<ii;i++){value={};value.term=nodes[i].getAttribute("term");attval=nodes[i].getAttribute("scheme");if(attval){value.scheme=attval;}
-attval=nodes[i].getAttribute("label");if(attval){value.label=attval;}
-atomAttrib.categories.push(value);}
-nodes=this.getElementsByTagNameNS(node,atomns,"content");if(nodes.length>0){value={};attval=nodes[0].getAttribute("type");if(attval){value.type=attval;}
-attval=nodes[0].getAttribute("src");if(attval){value.src=attval;}else{if(value.type=="text"||value.type=="html"||value.type==null){value.value=this.getFirstChildValue(node,atomns,"content",null);}else if(value.type=="xhtml"||value.type.match(/(\+|\/)xml$/)){value.value=this.getChildEl(nodes[0]);}else{value.value=this.getFirstChildValue(node,atomns,"content",null);}
-atomAttrib.content=value;}}
-this.parsePersonConstructs(node,"contributor",atomAttrib);atomAttrib.id=this.getFirstChildValue(node,atomns,"id",null);nodes=this.getElementsByTagNameNS(node,atomns,"link");if(nodes.length>0){atomAttrib.links=new Array(nodes.length);}
-var oAtts=["rel","type","hreflang","title","length"];for(var i=0,ii=nodes.length;i<ii;i++){value={};value.href=nodes[i].getAttribute("href");for(var j=0,jj=oAtts.length;j<jj;j++){attval=nodes[i].getAttribute(oAtts[j]);if(attval){value[oAtts[j]]=attval;}}
-atomAttrib.links[i]=value;}
-value=this.getFirstChildValue(node,atomns,"published",null);if(value){atomAttrib.published=value;}
-value=this.getFirstChildValue(node,atomns,"rights",null);if(value){atomAttrib.rights=value;}
-value=this.getFirstChildValue(node,atomns,"summary",null);if(value){atomAttrib.summary=value;}
-atomAttrib.title=this.getFirstChildValue(node,atomns,"title",null);atomAttrib.updated=this.getFirstChildValue(node,atomns,"updated",null);var featureAttrib={title:atomAttrib.title,description:atomAttrib.summary,atom:atomAttrib};var geometry=this.parseLocations(node)[0];var feature=new OpenLayers.Feature.Vector(geometry,featureAttrib);feature.fid=atomAttrib.id;return feature;},parseFeatures:function(node){var features=[];var entries=this.getElementsByTagNameNS(node,this.namespaces.atom,"entry");if(entries.length==0){entries=[node];}
-for(var i=0,ii=entries.length;i<ii;i++){features.push(this.parseFeature(entries[i]));}
-return features;},parseLocations:function(node){var georssns=this.namespaces.georss;var locations={components:[]};var where=this.getElementsByTagNameNS(node,georssns,"where");if(where&&where.length>0){if(!this.gmlParser){this.initGmlParser();}
-for(var i=0,ii=where.length;i<ii;i++){this.gmlParser.readChildNodes(where[i],locations);}}
-var components=locations.components;var point=this.getElementsByTagNameNS(node,georssns,"point");if(point&&point.length>0){for(var i=0,ii=point.length;i<ii;i++){var xy=OpenLayers.String.trim(point[i].firstChild.nodeValue).split(/\s+/);if(xy.length!=2){xy=OpenLayers.String.trim(point[i].firstChild.nodeValue).split(/\s*,\s*/);}
-components.push(new OpenLayers.Geometry.Point(parseFloat(xy[1]),parseFloat(xy[0])));}}
-var line=this.getElementsByTagNameNS(node,georssns,"line");if(line&&line.length>0){var coords;var p;var points;for(var i=0,ii=line.length;i<ii;i++){coords=OpenLayers.String.trim(line[i].firstChild.nodeValue).split(/\s+/);points=[];for(var j=0,jj=coords.length;j<jj;j+=2){p=new OpenLayers.Geometry.Point(parseFloat(coords[j+1]),parseFloat(coords[j]));points.push(p);}
-components.push(new OpenLayers.Geometry.LineString(points));}}
-var polygon=this.getElementsByTagNameNS(node,georssns,"polygon");if(polygon&&polygon.length>0){var coords;var p;var points;for(var i=0,ii=polygon.length;i<ii;i++){coords=OpenLayers.String.trim(polygon[i].firstChild.nodeValue).split(/\s+/);points=[];for(var j=0,jj=coords.length;j<jj;j+=2){p=new OpenLayers.Geometry.Point(parseFloat(coords[j+1]),parseFloat(coords[j]));points.push(p);}
-components.push(new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]));}}
-if(this.internalProjection&&this.externalProjection){for(var i=0,ii=components.length;i<ii;i++){if(components[i]){components[i].transform(this.externalProjection,this.internalProjection);}}}
-return components;},parsePersonConstructs:function(node,name,data){var persons=[];var atomns=this.namespaces.atom;var nodes=this.getElementsByTagNameNS(node,atomns,name);var oAtts=["uri","email"];for(var i=0,ii=nodes.length;i<ii;i++){var value={};value.name=this.getFirstChildValue(nodes[i],atomns,"name",null);for(var j=0,jj=oAtts.length;j<jj;j++){var attval=this.getFirstChildValue(nodes[i],atomns,oAtts[j],null);if(attval){value[oAtts[j]]=attval;}}
-persons.push(value);}
-if(persons.length>0){data[name+"s"]=persons;}},CLASS_NAME:"OpenLayers.Format.Atom"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{autoActivate:true,slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keydown":this.defaultKeyPress});},defaultKeyPress:function(evt){switch(evt.keyCode){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:case 61:case 187:case 107:this.map.zoomIn();break;case 45:case 109:case 189:case 95:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.Feature.WFS=O
penLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
-OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});
\ No newline at end of file
+OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){this.dragPan.activate();this.handlers.click.activate();this.pinchZoom.activate();return true;}
+return false;},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.dragPan.deactivate();this.handlers.click.deactivate();this.pinchZoom.deactivate();return true;}
+return false;},draw:function(){var clickCallbacks={'click':this.defaultClick,'dblclick':this.defaultDblClick};var clickOptions={'double':true,'stopDouble':true};this.handlers.click=new OpenLayers.Handler.Click(this,clickCallbacks,clickOptions);this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.dragPan.draw();this.pinchZoom=new OpenLayers.Control.PinchZoom(OpenLayers.Util.extend({map:this.map},this.pinchZoomOptions));},defaultClick:function(evt){if(evt.lastTouches&&evt.lastTouches.length==2){this.map.zoomOut();}},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},CLASS_NAME:"OpenLayers.Control.TouchNavigation"});
Modified: sandbox/pinch/examples/mobile-navigation.html
--- sandbox/pinch/examples/mobile-navigation.html 2011-02-24 17:22:52 UTC (rev 11440)
+++ sandbox/pinch/examples/mobile-navigation.html 2011-02-24 17:26:04 UTC (rev 11441)
@@ -11,9 +11,8 @@
<script>
OpenLayers.ImgPath = "../img/";
</script>
- <script type="text/javascript" src="mobile-navigation.js"></script>
</head>
- <body onload="init()">
+ <body>
<h1 id="title">Mobile Navigation</h1>
<div id="tags">
@@ -50,5 +49,6 @@
source</a> to see how this is done.
</p>
</div>
+ <script type="text/javascript" src="mobile-navigation.js"></script>
</body>
</html>
Modified: sandbox/pinch/examples/mobile-navigation.js
--- sandbox/pinch/examples/mobile-navigation.js 2011-02-24 17:22:52 UTC (rev 11440)
+++ sandbox/pinch/examples/mobile-navigation.js 2011-02-24 17:26:04 UTC (rev 11441)
@@ -1,6 +1,13 @@
-var map, layer;
-function init() {
- map = new OpenLayers.Map('map', { controls: [
+var map = new OpenLayers.Map({
+ div: "map",
+ projection: new OpenLayers.Projection("EPSG:90913"),
+ units: "m",
+ numZoomLevels: 18,
+ maxResolution: 156543.0339,
+ maxExtent: new OpenLayers.Bounds(
+ -20037508.34, -20037508.34, 20037508.34, 20037508.34
+ controls: [
new OpenLayers.Control.TouchNavigation({
dragPanOptions: {
interval: 0, // non-zero kills performance on some mobile phones
@@ -8,10 +15,8 @@
new OpenLayers.Control.ZoomPanel()
- layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
- "http://vmap0.tiles.osgeo.org/wms/vmap0",
- {layers: 'basic'} );
- map.addLayer(layer);
- map.setCenter(new OpenLayers.LonLat(5, 40), 2);
+ layers: [new OpenLayers.Layer.OSM()],
+ center: new OpenLayers.LonLat(737977, 5860365),
+ zoom: 9
More information about the Commits
