[OpenLayers-Commits] r11448 - in trunk/openlayers: build tools
commits-20090109 at openlayers.org
Thu Feb 24 18:19:53 EST 2011
Author: crschmidt
Date: 2011-02-24 15:19:53 -0800 (Thu, 24 Feb 2011)
New Revision: 11448
Added:
trunk/openlayers/tools/closure.py
trunk/openlayers/build/README.txt
trunk/openlayers/build/build.py
trunk/openlayers/tools/closure_ws.py
Adding support for closure compiler and some documentation
in the README about how to use it.
Modified: trunk/openlayers/build/README.txt
--- trunk/openlayers/build/README.txt 2011-02-24 23:14:21 UTC (rev 11447)
+++ trunk/openlayers/build/README.txt 2011-02-24 23:19:53 UTC (rev 11448)
@@ -1,14 +1,43 @@
+The OpenLayers build tool supports several different
+forms of compressing your javascript code, and a method
+of describing build profiles to create customized
+OpenLayers builds with only the components you need.
-## HowTo: Build & deploy "Shrunk" Single File Library version of OpenLayers ##
+When building a file, you can choose to build with several
+different compression options to the Python-based build.py
+script. The following is an example script:
- * Build:
+python build.py -c closure full OpenLayers-closure.js
- cd build
- ./build.py
- cd ..
+This script selects the 'closure' compression mechanism,
+uses a config file called 'full.cfg', and writes the output
+to OpenLayers-closure.js.
- * Upload the result to the server: e.g.
+The options available for compression are:
- scp build/OpenLayers.js openlayers at openlayers.org:openlayers.org/htdocs/code/
+ * closure
+ This requires you to have a closure-compiler.jar in your
+ tools directory. You can do this by fetching the compiler
+ from:
+ http://closure-compiler.googlecode.com/files/compiler-latest.zip
+ Then unzipping that file, and placing compiler.jar into tools
+ and renaming it closure-compiler.jar.
+ * closure_ws
+ This uses the closure compiler webservice. This will only work
+ for files source Javascript files which are under 1MB. (Note that
+ the default OpenLayers full build is not under 1MB.)
+ * jsmin
+ jsmin is the default compiler, and uses the Python-based
+ jsmin script to compress the Javascript.
+ * minimize
+ This is a simple whitespace removing Python script, designed
+ to fill in when other tools are unavailable.
+ * none
+ None will leave the Javascript uncompressed.
Modified: trunk/openlayers/build/build.py
--- trunk/openlayers/build/build.py 2011-02-24 23:14:21 UTC (rev 11447)
+++ trunk/openlayers/build/build.py 2011-02-24 23:19:53 UTC (rev 11448)
@@ -13,6 +13,11 @@
except ImportError:
print "No jsmin"
try:
+ import closure
+ have_compressor.append("closure")
+ except ImportError, E:
+ print "No closure (%s) % E"
+ try:
import closure_ws
have_compressor.append("closure_ws")
except ImportError:
@@ -51,6 +56,8 @@
minimized = minimize.minimize(merged)
elif use_compressor == "closure_ws":
minimized = closure_ws.minimize(merged)
+ elif use_compressor == "closure":
+ minimized = closure.minimize(merged)
else: # fallback
minimized = merged
print "Adding license file."
Added: trunk/openlayers/tools/closure.py
--- trunk/openlayers/tools/closure.py (rev 0)
+++ trunk/openlayers/tools/closure.py 2011-02-24 23:19:53 UTC (rev 11448)
@@ -0,0 +1,21 @@
+import sys
+import os
+import tempfile
+path = os.path.join(os.path.dirname(__file__), "closure-compiler.jar")
+if not os.path.exists(path):
+ raise Exception("No closure-compiler.jar at %s; read README.txt!" % path)
+def minimize(code):
+ ntf = tempfile.NamedTemporaryFile()
+ ntf.write(code)
+ ntf.flush()
+ ntf2 = tempfile.NamedTemporaryFile()
+ os.system("java -jar %s --js %s --js_output_file %s" % (path, ntf.name, ntf2.name))
+ ntf2.seek(0)
+ data = ntf2.read()
+ ntf.close()
+ ntf2.close()
+ return data
Modified: trunk/openlayers/tools/closure_ws.py
--- trunk/openlayers/tools/closure_ws.py 2011-02-24 23:14:21 UTC (rev 11447)
+++ trunk/openlayers/tools/closure_ws.py 2011-02-24 23:19:53 UTC (rev 11448)
@@ -22,5 +22,7 @@
response = conn.getresponse()
data = response.read()
conn.close()
- print "%.3f seconds to compile", time.time() - t
+ if data.startswith("Error"):
+ raise Exception(data)
+ print "%.3f seconds to compile" % (time.time() - t)
return data
More information about the Commits
