[OpenLayers-Commits] r11454 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org
Fri Feb 25 02:25:03 EST 2011
Author: crschmidt
Date: 2011-02-24 23:25:03 -0800 (Thu, 24 Feb 2011)
New Revision: 11454
trunk/openlayers/lib/OpenLayers/Map.js
Extending Map.js documentation to include comment regarding destroy from
#2277.
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-02-25 00:47:14 UTC (rev 11453)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-02-25 07:25:03 UTC (rev 11454)
@@ -643,7 +643,15 @@
* APIMethod: destroy
- * Destroy this map
+ * Destroy this map.
+ * Note that if you are using an application which removes a container
+ * of the map from the DOM, you need to ensure that you destroy the
+ * map *before* this happens; otherwise, the page unload handler
+ * will fail because the DOM elements that map.destroy() wants
+ * to clean up will be gone. (See
+ * http://trac.osgeo.org/openlayers/ticket/2277 for more information).
+ * This will apply to GeoExt and also to other applications which
+ * modify the DOM of the container of the OpenLayers Map.
destroy:function() {
// if unloadDestroy is null, we've already been destroyed
More information about the Commits
