[OpenLayers-Commits] r11479 - in sandbox/ahocevar/layercontainer:
lib/OpenLayers tests
commits-20090109 at openlayers.org
Fri Feb 25 06:01:38 EST 2011
Author: erilem
Date: 2011-02-25 03:01:37 -0800 (Fri, 25 Feb 2011)
New Revision: 11479
sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
sandbox/ahocevar/layercontainer/tests/Map.html
moveByPx now verifies that the new extent is within the restricted extent
Modified: sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js
--- sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-25 10:28:52 UTC (rev 11478)
+++ sandbox/ahocevar/layercontainer/lib/OpenLayers/Map.js 2011-02-25 11:01:37 UTC (rev 11479)
@@ -1516,7 +1516,7 @@
getCachedCenter: function() {
if (!this.center) {
this.center = this.getLonLatFromViewPortPx(
- new OpenLayers.Pixel(map.size.w / 2, map.size.h / 2)
+ new OpenLayers.Pixel(this.size.w / 2, this.size.h / 2)
return this.center;
@@ -1663,13 +1663,21 @@
moveByPx: function(dx, dy) {
dx = Math.round(dx);
dy = Math.round(dy);
- var x = this.size.w / 2 + dx;
- var y = this.size.h / 2 + dy;
+ var hw = this.size.w / 2;
+ var hh = this.size.h / 2;
+ var x = hw + dx;
+ var y = hh + dy;
var valid = x <= this.maxPx.x &&
x >= this.minPx.x &&
y <= this.maxPx.y &&
y >= this.minPx.y;
- if (valid === true) {
+ if (this.restrictedExtent && valid) {
+ valid = !(this.maxPx.x - x < hw ||
+ x - this.minPx.x < hw ||
+ this.maxPx.y - y < hh ||
+ y - this.minPx.y < hh);
+ if (valid) {
this.center = null;
if (dx) {
this.layerContainerDiv.style.left =
@@ -1792,7 +1800,7 @@
this.layerContainerOrigin = this.getCachedCenter();
this.layerContainerDiv.style.left = "0px";
this.layerContainerDiv.style.top = "0px";
- var maxExtent = this.getMaxExtent();
+ var maxExtent = this.getMaxExtent({restricted: true});
var maxExtentCenter = maxExtent.getCenterLonLat();
var lonDelta = this.center.lon - maxExtentCenter.lon;
var latDelta = maxExtentCenter.lat - this.center.lat;
Modified: sandbox/ahocevar/layercontainer/tests/Map.html
--- sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-25 10:28:52 UTC (rev 11478)
+++ sandbox/ahocevar/layercontainer/tests/Map.html 2011-02-25 11:01:37 UTC (rev 11479)
@@ -1319,7 +1319,7 @@
var m = {
'baseLayer': { 'units': {} },
'getSize': function() { return {'w': 10, 'h': 15}; },
- 'getCenter': function() { return {'lon': -5, 'lat': -25}; },
+ 'getCachedCenter': function() { return {'lon': -5, 'lat': -25}; },
'zoomToExtent': function(extent, closest) {
t.ok(extent.equals(g_ExpectedExtent), "extent correctly calculated for zoomToExtent()");
t.ok(closest == g_Closest, "closest correctly passed on to zoomToExtent()");
@@ -1687,6 +1687,41 @@
map.destroy();
+ function test_moveByPx(t) {
+ t.plan(8);
+ var map = new OpenLayers.Map({
+ div: 'map',
+ maxExtent: new OpenLayers.Bounds(-50, -50, 50, 50),
+ restrictedExtent: new OpenLayers.Bounds(-10, -10, 10, 10),
+ layers: [
+ new OpenLayers.Layer('name', {isBaseLayer: true})
+ map.zoomToExtent(new OpenLayers.Bounds(-1, -1, 1, 1));
+ // check initial state
+ t.eq(map.layerContainerDiv.style.left, '0px', 'layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '0px', 'layer container top correct');
+ // move to a valid position
+ map.moveByPx(-455, 455);
+ t.eq(map.layerContainerDiv.style.left, '455px', 'layer container left correct');
+ t.eq(map.layerContainerDiv.style.top, '-455px', 'layer container top correct');
+ // move outside the max extent
+ map.moveByPx(-4500, 4500);
+ // move outside the restricted extent
+ map.moveByPx(-500, 500);
+ map.destroy();
</script>
</head>
<body>
More information about the Commits
