[OpenLayers-Commits] r11482 - in trunk/openlayers: lib/OpenLayers/Layer tests tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 07:02:33 EST 2011
Author: erilem
Date: 2011-02-25 04:02:29 -0800 (Fri, 25 Feb 2011)
New Revision: 11482
   trunk/openlayers/lib/OpenLayers/Layer/Grid.js
   trunk/openlayers/tests/Layer/Grid.html
   trunk/openlayers/tests/Map.html
the grid layer needs to clear its tile loading timeout when it's removed from the map, or moveGriddedTiles can be called with this.map set to null, r=crschmidt (closes #3110)
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-25 11:50:30 UTC (rev 11481)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-25 12:02:29 UTC (rev 11482)
@@ -132,6 +132,20 @@
+     * Method: removeMap
+     * Called when the layer is removed from the map.
+     * Parameters:
+     * map - {<OpenLayers.Map>} The map.
+    removeMap: function(map) {
+        if(this.timerId != null) {
+            window.clearTimeout(this.timerId);
+            this.timerId = null;
      * APIMethod: destroy
      * Deconstruct the layer and clear the grid.
Modified: trunk/openlayers/tests/Layer/Grid.html
--- trunk/openlayers/tests/Layer/Grid.html	2011-02-25 11:50:30 UTC (rev 11481)
+++ trunk/openlayers/tests/Layer/Grid.html	2011-02-25 12:02:29 UTC (rev 11482)
@@ -593,7 +593,7 @@
     function test_Layer_Grid_destroy (t) {
-        t.plan( 7 );
+        t.plan( 8 );
         var map = new OpenLayers.Map('map');
         layer = new OpenLayers.Layer.Grid(name, url, params);
@@ -608,6 +608,7 @@
         map.addLayer(layer);
         map.setCenter(new OpenLayers.LonLat(0,0), 10);
+        map.setCenter(new OpenLayers.LonLat(1,1));
         //grab a reference to one of the tiles
@@ -616,6 +617,7 @@
         layer.destroy();
         t.eq( tile.imgDiv, null, "Tile destroyed" );
+        t.eq( layer.timerId, null, "Tile loading timeout cleared");
         t.ok( layer.grid == null, "tiles appropriately destroyed")
Modified: trunk/openlayers/tests/Map.html
--- trunk/openlayers/tests/Map.html	2011-02-25 11:50:30 UTC (rev 11481)
+++ trunk/openlayers/tests/Map.html	2011-02-25 12:02:29 UTC (rev 11482)
@@ -352,6 +352,8 @@
         valid = OpenLayers.Map.prototype.isValidZoomLevel.apply(map, [19]);
         t.eq(valid, false, "19 is not a valid zoomLevel when baseLayer has restrictedMinZoom of 1");
+        map.destroy();
     function test_Map_isValidLonLat(t) {
@@ -977,6 +979,8 @@
         map.addControls(controls2, pixels2);
         t.eq(map.controls.length, 5, "three additional controls were added by map.addControls with a px-array");
         t.eq(map.controls[3].position.toString(), pixels2[1].toString(), "control 'fourthctrl' has position set to given px");
+        map.destroy();
     function test_Map_getControl(t) {
@@ -1598,6 +1602,8 @@
         t.eq(map.layers.length, 2, "multiple layers added from options");
         t.ok(map.baseLayer, "map has a base layer");
+        map.destroy();
More information about the Commits mailing list
