[OpenLayers-Commits] r11507 - in trunk/openlayers: lib/OpenLayers/Handler tests/Handler
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Feb 25 09:53:00 EST 2011
Author: tschaub
Date: 2011-02-25 06:52:56 -0800 (Fri, 25 Feb 2011)
New Revision: 11507
   trunk/openlayers/lib/OpenLayers/Handler/Click.js
   trunk/openlayers/tests/Handler/Click.html
Don't store touch events.  The same event is used between touchstart, touchmove, and touchend.  Instead, we store event details on the handler and use those when needed.  p=bbinet, r=me (closes #3120)
Modified: trunk/openlayers/lib/OpenLayers/Handler/Click.js
--- trunk/openlayers/lib/OpenLayers/Handler/Click.js	2011-02-25 14:35:43 UTC (rev 11506)
+++ trunk/openlayers/lib/OpenLayers/Handler/Click.js	2011-02-25 14:52:56 UTC (rev 11507)
@@ -85,24 +85,23 @@
      * Property: down
-     * {<OpenLayers.Pixel>} The pixel location of the last mousedown.
+     * {Object} Object that store relevant information about the last
+     *     mousedown or touchstart. Its 'xy' OpenLayers.Pixel property gives
+     *     the average location of the mouse/touch event. Its 'touches'
+     *     property records clientX/clientY of each touches.
     down: null,
      * Property: last
-     * {<OpenLayers.Pixel>} The pixel for the last touchmove. This is
-     * used to
+     *     touchmove. Its 'xy' OpenLayers.Pixel property gives
     last: null,
-     * Property: touch
-     * {Boolean} Are we on a touch enabled device? Default is false.
-    touch: false,
      * Property: rightclickTimerId
      * {Number} The id of the right mouse timeout waiting to clear the
      *     <delayedEvent>.
@@ -130,7 +129,7 @@
         // optionally register for mouseup and mousedown
         if(this.pixelTolerance != null) {
             this.mousedown = function(evt) {
-                this.down = evt;
+                this.down = this.getEventInfo(evt);
                 return true;
@@ -154,8 +153,7 @@
      * {Boolean} Continue propagating this event.
     touchstart: function(evt) {
-        this.touch = true;
-        this.down = evt;
         this.last = null;
         return true;
@@ -244,8 +242,9 @@
     dblclick: function(evt) {
         // for touch devices trigger dblclick only for
         // "one finger" touch
-        if(this.passesTolerance(evt) &&
-           (!evt.lastTouches || evt.lastTouches.length == 1)) {
+        var last = this.down || this.last;
+        if (this.passesTolerance(evt) &&
+            (!last || !last.touches || last.touches.length == 1)) {
             if(this["double"]) {
                 this.callback('dblclick', [evt]);
@@ -260,7 +259,7 @@
      *    an empty "touches" property.
     touchmove: function(evt) {
-        this.last = evt;
+        this.last = this.getEventInfo(evt);
@@ -287,13 +286,14 @@
         // Sencha Touch emulates click events, see ticket 3079 for more info
-        if (this.touch === true && evt.type === "click") {
+        if (this.down && this.down.touches && evt.type === "click") {
             return !this.stopSingle;
         if(this.passesTolerance(evt)) {
             if(this.timerId != null) {
                 // already received a click
-                if(evt.lastTouches) {
+                if (last && last.touches && last.touches.length > 0) {
                     // touch device - we may trigger dblclick
                     this.dblclick(evt);
                 } else {
@@ -367,6 +367,35 @@
+     * Method: getEventInfo
+     * This method allows us to store event information without storing the
+     *     actual event.  In touch devices (at least), the same event is
+     *     modified between touchstart, touchmove, and touchend.
+     * Returns:
+     * {Object} An object with event related info.
+    getEventInfo: function(evt) {
+        var touches;
+        if (evt.touches) {
+            var len = evt.touches.length;
+            touches = new Array(len);
+            var touch;
+            for (var i=0; i<len; i++) {
+                touch = evt.touches[i];
+                touches[i] = {
+                    clientX: touch.clientX,
+                    clientY: touch.clientY
+        return {
+            xy: evt.xy,
+            touches: touches
      * APIMethod: deactivate
      * Deactivate the handler.
Modified: trunk/openlayers/tests/Handler/Click.html
--- trunk/openlayers/tests/Handler/Click.html	2011-02-25 14:35:43 UTC (rev 11506)
+++ trunk/openlayers/tests/Handler/Click.html	2011-02-25 14:52:56 UTC (rev 11507)
@@ -316,14 +316,14 @@
         log = null;
         handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
-        handler.touchend({});
+        handler.touchend({touches: ["foo"]});
         t.delay_call(1, function() {
             t.ok(log != null, "click callback called");
             if(log != null) {
                 t.eq(log.x, 1, "evt.xy.x as expected");
                 t.eq(log.y, 1, "evt.xy.y as expected");
-                t.eq(log.lastTouches, ["foo"], "evt.lastTouches as expected");
+                t.ok(log.lastTouches, "evt.lastTouches as expected");
             // tear down
             map.destroy();
@@ -359,7 +359,7 @@
         handler.touchend({type: "click"});
-        t.eq(handler.touch, true, "Touch property should be true");
+        t.eq(!!handler.down.touches, true, "Handler down touches property should be truthy");
         t.ok(log.dblclick == undefined, "dblclick callback not called with simulated click");
@@ -395,9 +395,9 @@
         // test
         log = {};
-        handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
+        handler.touchstart({xy: {x: 1, y: 1}, touches: [{clientX:0, clientY:10}]});
         t.eq(log.click, undefined, "click callback not called");
@@ -405,7 +405,7 @@
         if(log.dblclick != undefined) {
             t.eq(log.dblclick.x, 1, "evt.xy.x as expected");
             t.eq(log.dblclick.y, 1, "evt.xy.y as expected");
-            t.eq(log.dblclick.lastTouches, ["foo"], "evt.lastTouches as expected");
+            t.ok(log.dblclick.lastTouches, "evt.lastTouches on evt");
         // tear down
More information about the Commits mailing list
