[OpenLayers-Commits] r11541 - in sandbox/pinch/tests: . Control
commits-20090109 at openlayers.org
Fri Feb 25 15:23:45 EST 2011
Author: tschaub
Date: 2011-02-25 12:23:45 -0800 (Fri, 25 Feb 2011)
New Revision: 11541
Added:
sandbox/pinch/tests/Control/PinchZoom.html
sandbox/pinch/tests/list-tests.html
Tests.
Added: sandbox/pinch/tests/Control/PinchZoom.html
--- sandbox/pinch/tests/Control/PinchZoom.html (rev 0)
+++ sandbox/pinch/tests/Control/PinchZoom.html 2011-02-25 20:23:45 UTC (rev 11541)
@@ -0,0 +1,87 @@
+<html>
+<head>
+ <script src="../OLLoader.js"></script>
+ <script type="text/javascript">
+ function test_constructor(t) {
+ t.plan(2);
+ var control = new OpenLayers.Control.PinchZoom();
+ t.ok(control instanceof OpenLayers.Control.PinchZoom, "got an instance");
+ t.ok(control.handler instanceof OpenLayers.Handler.Pinch, "control has pinch handler");
+ control.destroy();
+ function test_destroy(t) {
+ t.plan(1);
+ t.ok(!control.handler, "handler destroyed");
+ function test_activate(t) {
+ t.plan(3);
+ t.ok(!control.active, "control not activated after construction");
+ var map = new OpenLayers.Map({
+ div: "map",
+ controls: [control]
+ t.ok(control.active, "control activated after being added to the map");
+ control.deactivate();
+ t.ok(!control.active, "control deactivated");
+ map.destroy();
+ function test_pinchMove(t) {
+ div: "map",
+ var log = [];
+ control.applyTransform = function(transform) {
+ log.push(transform);
+ control.containerOrigin = {
+ x: 0, y: 0
+ control.pinchOrigin = {
+ x: 100, y: 50
+ var cases = [
+ {x: 100, y: 60, scale: 1, transform: "translate(0px, 10px) scale(1)"},
+ {x: 150, y: 60, scale: 1, transform: "translate(50px, 10px) scale(1)"},
+ {x: 150, y: 60, scale: 2, transform: "translate(-50px, -40px) scale(2)"},
+ {x: 50, y: 20, scale: 2.5, transform: "translate(-200px, -105px) scale(2.5)"},
+ {x: 50, y: 20, scale: 0.25, transform: "translate(25px, 8px) scale(0.25)"}
+ var len = cases.length;
+ t.plan(len*2);
+ var c;
+ for (var i=0; i<len; ++i) {
+ c = cases[i];
+ control.pinchMove({xy: {x: c.x, y: c.y}}, {scale: c.scale});
+ t.eq(log.length, i+1, i + " called once");
+ t.eq(log[i], c.transform, i + " correct transform");
+ </script>
+</head>
+<body>
+ <div id="map" style="width: 256px; height: 256px;"></div>
+</body>
+</html>
Modified: sandbox/pinch/tests/list-tests.html
--- sandbox/pinch/tests/list-tests.html 2011-02-25 20:23:22 UTC (rev 11540)
+++ sandbox/pinch/tests/list-tests.html 2011-02-25 20:23:45 UTC (rev 11541)
@@ -32,6 +32,7 @@
<li>Control/PanZoom.html</li>
<li>Control/PanZoomBar.html</li>
<li>Control/Permalink.html</li>
+ <li>Control/PinchZoom.html</li>
<li>Control/Scale.html</li>
<li>Control/ScaleLine.html</li>
<li>Control/SelectFeature.html</li>
More information about the Commits
