[OpenLayers-Commits] r11557 - in sandbox/ahocevar/3072:
lib/OpenLayers/Handler tests/Control tests/Handler
commits-20090109 at openlayers.org
Sun Feb 27 08:06:37 EST 2011
Author: ahocevar
Date: 2011-02-27 05:06:36 -0800 (Sun, 27 Feb 2011)
New Revision: 11557
sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js
sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js
sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js
sandbox/ahocevar/3072/tests/Control/Measure.html
sandbox/ahocevar/3072/tests/Handler/Path.html
sandbox/ahocevar/3072/tests/Handler/Point.html
sandbox/ahocevar/3072/tests/Handler/Polygon.html
applying Stephane's patch, but without the Handler.Click changes"
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Path.js 2011-02-27 13:06:36 UTC (rev 11557)
@@ -223,12 +223,12 @@
* Returns:
* {Boolean} Allow event propagation
- mousedown: function(evt) {
+ down: function(evt) {
var stopDown = this.stopDown;
if(this.freehandMode(evt)) {
stopDown = true;
- if(!this.lastDown || !this.lastDown.equals(evt.xy)) {
+ if (!this.touch && (!this.lastDown || !this.passesTolerance(this.lastDown, evt.xy, this.pixelTolerance))) {
this.modifyFeature(evt.xy, !!this.lastUp);
this.mouseDown = true;
@@ -248,7 +248,7 @@
* Returns:
- mousemove: function (evt) {
+ move: function (evt) {
if(this.stoppedDown && this.freehandMode(evt)) {
if(this.persist) {
this.destroyPersistedFeature();
@@ -256,7 +256,7 @@
this.addPoint(evt.xy);
return false;
- if(!this.mouseDown || this.stoppedDown) {
+ if (!this.touch && (!this.mouseDown || this.stoppedDown)) {
return true;
@@ -273,13 +273,17 @@
* Returns:
- mouseup: function (evt) {
- if(this.mouseDown && (!this.lastUp || !this.lastUp.equals(evt.xy))) {
+ up: function (evt) {
+ if (this.mouseDown && (!this.lastUp || !this.passesTolerance(
+ this.lastUp, evt.xy, this.dblclickPixelTolerance))) {
this.removePoint();
this.finalize();
} else {
- if(this.lastDown.equals(evt.xy)) {
+ if (this.passesTolerance(this.lastDown, evt.xy, this.pixelTolerance)) {
+ if (this.touch) {
+ this.modifyFeature(evt.xy);
if(this.lastUp == null && this.persist) {
@@ -290,13 +294,21 @@
this.stoppedDown = this.stopDown;
this.mouseDown = false;
- return !this.stopUp;
+ return !this.stopUp && !this.isDblclick;
* APIMethod: finishGeometry
* Finish the geometry and send it back to the control.
+ finishTouchGeometry: function() {
+ this.finishGeometry();
+ * APIMethod: finishGeometry
+ * Finish the geometry and send it back to the control.
finishGeometry: function() {
var index = this.line.geometry.components.length - 1;
this.line.geometry.removeComponent(this.line.geometry.components[index]);
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Point.js 2011-02-27 13:06:36 UTC (rev 11557)
@@ -95,8 +95,51 @@
* {Object} Any optional properties to be set on the sketch layer.
layerOptions: null,
+ * APIProperty: pixelTolerance
+ * {Number} Maximum number of pixels between mouseup and mousedown for an
+ * event to be considered a click. Default is 5. If set to an
+ * integer value, clicks with a drag greater than the value will be
+ * ignored. This property can only be set when the handler is
+ * constructed.
+ pixelTolerance: 5,
+ * APIProperty: dblclickPixelTolerance
+ * {Number} Maximum number of pixels between two touchend for an
+ * event to be considered a dblclick. Default is 20.
+ dblclickPixelTolerance: 20,
+ * Property: touch
+ * {Boolean} Privat, that indcate the support of touch events.
+ touch: false,
+ * Property: timerId
+ * {Integer} Privat, the timer used to test the double touch.
+ timerId: null,
+ * Property: last
+ * {Pixel} Privat, the last pixel used to know the distance betweene
+ * two touch (for double touch).
+ last: null,
+ * Property: dblclick
+ * {Pixel} Privat, the current event is a dblclick.
+ isDblclick: false,
* Constructor: OpenLayers.Handler.Point
* Create a new point handler.
@@ -214,6 +257,14 @@
+ this.finalize();
* Method: finalize
* Finish the geometry and call the "done" callback.
@@ -333,6 +384,125 @@
var geom = this.getGeometry();
return geom && geom.clone();
+ * Method: mousedown
+ * Handle mousedown.
+ * Parameters:
+ * evt - {Event} The browser event
+ * Returns:
+ * {Boolean} Allow event propagation
+ mousedown: function(evt) {
+ if (this.touch) {
+ return;
+ return this.down(evt);
+ * Method: touchstart
+ * Handle touchstart.
+ * Parameters:
+ * Returns:
+ touchstart: function(evt) {
+ this.touch = true;
+ var last = this.last;
+ this.last = evt.xy;
+ if (this.timerId &&
+ this.passesTolerance(last, evt.xy, this.dblclickPixelTolerance)) {
+ this.isDblclick = true;
+ this.finishTouchGeometry();
+ window.clearTimeout(this.timerId);
+ this.timerId = null;
+ return false;
+ else {
+ if (this.timerId) {
+ this.isDblclick = false;
+ this.timerId = window.setTimeout(
+ OpenLayers.Function.bind(function() {
+ }, this), 300);
+ * Method: mousemove
+ * Handle mousemove.
+ * Parameters:
+ * Returns:
+ mousemove: function(evt) {
+ if (this.touch) {
+ return;
+ return this.move(evt);
+ * Method: touchmove
+ * Handle touchmove.
+ * Parameters:
+ * Returns:
+ touchmove: function(evt) {
+ * Method: mouseup
+ * Handle mouseup.
+ * Parameters:
+ * Returns:
+ mouseup: function(evt) {
+ if (this.touch) {
+ return;
+ return this.up(evt);
+ * Method: touchend
+ * Handle touchend.
+ * Parameters:
+ * Returns:
+ touchend: function(evt) {
+ evt.xy = this.last;
* Method: mousedown
@@ -345,10 +515,12 @@
* Returns:
this.lastDown = evt.xy;
- this.modifyFeature(evt.xy);
+ if (!this.touch) {
return !this.stopDown;
@@ -364,8 +536,8 @@
* Returns:
+ if(!this.touch && (!this.mouseDown || this.stoppedDown)) {
return true;
@@ -382,18 +554,22 @@
* Returns:
// check keyboard modifiers
if(!this.checkModifiers(evt)) {
return true;
// ignore double-clicks
- if(this.lastUp && this.lastUp.equals(evt.xy)) {
+ if (this.lastUp && this.passesTolerance(this.lastUp, evt.xy, this.dblclickPixelTolerance)) {
return true;
- if(this.lastDown && this.lastDown.equals(evt.xy)) {
+ if (this.lastDown && this.passesTolerance(this.lastDown, evt.xy, this.pixelTolerance)) {
+ if (this.touch) {
if(this.persist) {
@@ -420,5 +596,39 @@
+ * Method: passesTolerance
+ * Determine whether the event is within the optional pixel tolerance. Note
+ * that the pixel tolerance check only works if mousedown events get to
+ * the listeners registered here. If they are stopped by other elements,
+ * the <clickPixelTolerance> will have no effect here (this method will always
+ * return true).
+ * Returns:
+ * {Boolean} The click is within the pixel tolerance (if specified).
+ passesTolerance: function(pixel1, pixel2, tollerate) {
+ var passes = true;
+ // convert event into pixel
+ if (pixel1 != null && pixel1.xy) {
+ pixel1 = pixel1.xy;
+ if (pixel2 != null && pixel2.xy) {
+ pixel2 = pixel2.xy;
+ if (tollerate != null && pixel1 && pixel2) {
+ var dist = Math.sqrt(
+ Math.pow(pixel1.x - pixel2.x, 2) +
+ Math.pow(pixel1.y - pixel2.y, 2)
+ if (dist > tollerate) {
+ passes = false;
+ return passes;
CLASS_NAME: "OpenLayers.Handler.Point"
Modified: sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js
--- sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/lib/OpenLayers/Handler/Polygon.js 2011-02-27 13:06:36 UTC (rev 11557)
@@ -148,8 +148,19 @@
point.y = last.y;
+ var index = this.line.geometry.components.length - 2;
+ this.line.geometry.removeComponent(this.line.geometry.components[index]);
+ this.removePoint();
+ this.finalize();
* Method: finalizeInteriorRing
* Enforces that new ring has some area and doesn't contain vertices of any
* other rings.
Modified: sandbox/ahocevar/3072/tests/Control/Measure.html
--- sandbox/ahocevar/3072/tests/Control/Measure.html 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/tests/Control/Measure.html 2011-02-27 13:06:36 UTC (rev 11557)
@@ -96,6 +96,10 @@
measure: function(evt){
log.push(evt);
+ handlerOptions: {
+ pixelTolerance: 0,
+ dblclickPixelTolerance: 0
@@ -131,8 +135,8 @@
// wait for delay then confirm event was logged
delay, function() {
t.eq(log.length, 1, "a) event logged")
- t.ok(log[0] && log[0].type == "measurepartial", "a) event logged");
- t.ok(log[0] && log[0].measure == 10, "a) correct measure");
+ t.eq(log[0] && log[0].type, "measurepartial", "a) event logged");
+ t.eq(log[0] && log[0].measure, 10, "a) correct measure");
// b) move 10 pixels and click
trigger("mousemove", 0, 20);
@@ -145,8 +149,8 @@
delay, function() {
t.eq(log.length, 2, "b) event logged");
- t.ok(log[1] && log[1].type == "measurepartial", "b) correct type");
- t.ok(log[1] && log[1].measure == 20, "b) correct measure");
+ t.eq(log[1] && log[1].type, "measurepartial", "b) correct type");
+ t.eq(log[1] && log[1].measure, 20, "b) correct measure");
// c) move 10 pixels and click
trigger("mousemove", 0, 30);
@@ -161,8 +165,8 @@
// wait for rest of delay and confirm event logged
delay / 2, function() {
t.eq(log.length, 3, "c) event logged");
- t.ok(log[2] && log[2].type == "measurepartial", "c) correct type");
- t.ok(log[2] && log[2].measure == 30, "c) correct measure");
+ t.eq(log[2] && log[2].type, "measurepartial", "c) correct type");
+ t.eq(log[2] && log[2].measure, 30, "c) correct measure");
// d) move 10 pixels and click
trigger("mousemove", 0, 40);
@@ -176,8 +180,8 @@
trigger("dblclick", 0, 40);
t.eq(log.length, 4, "e) event logged");
- t.ok(log[3] && log[3].type == "measure", "e) correct type");
- t.ok(log[3] && log[3].measure == 40, "e) correct measure");
+ t.eq(log[3] && log[3].type, "measure", "e) correct type");
+ t.eq(log[3] && log[3].measure, 40, "e) correct measure");
// wait for rest of delay and confirm no measurepartial logged
delay, function() {
@@ -198,22 +202,22 @@
trigger("mousemove", 10, 0);
t.eq(log.length, 1, "g) event logged");
- t.ok(log[0] && log[0].type == "measurepartial", "g) correct type");
- t.ok(log[0] && log[0].measure == 10, "g) correct measure");
+ t.eq(log[0] && log[0].type, "measurepartial", "g) correct type");
+ t.eq(log[0] && log[0].measure, 10, "g) correct measure");
// h) move 10 pixels
trigger("mousemove", 20, 0);
t.eq(log.length, 2, "h) event logged");
- t.ok(log[1] && log[1].type == "measurepartial", "h) correct type");
- t.ok(log[1] && log[1].measure == 20, "h) correct measure");
+ t.eq(log[1] && log[1].type, "measurepartial", "h) correct type");
+ t.eq(log[1] && log[1].measure, 20, "h) correct measure");
// i) mouse up to finish
trigger("mouseup", 20, 0);
t.eq(log.length, 3, "i) event logged");
- t.ok(log[2] && log[2].type == "measure", "i) correct type");
- t.ok(log[2] && log[2].measure == 20, "i) correct measure");
+ t.eq(log[2] && log[2].type, "measure", "i) correct type");
+ t.eq(log[2] && log[2].measure, 20, "i) correct measure");
// j) clean up
log = [];
@@ -254,6 +258,10 @@
log.push(evt);
+ handlerOptions: {
@@ -296,10 +304,10 @@
// confirm measurepartial is fired 2 times
t.eq(log.length, 3, "b) event logged");
// d) switch immediate measurement off
control.setImmediate(false);
@@ -346,23 +354,23 @@
t.eq(log.length, 7, "i) no event fired yet");
delay, function() {
- t.eq(log.length, 8, "i) event logged");
- t.eq(log[7] && log[7].type, "measurepartial", "i) correct type");
- t.eq(log[7] && log[7].measure, 60, "i) correct measure");
+ t.eq(log.length, 8, "j) event logged");
+ t.eq(log[7] && log[7].type, "measurepartial", "j) correct type");
+ t.eq(log[7] && log[7].measure, 60, "j) correct measure");
trigger("dblclick", 0, 60);
- t.eq(log.length, 9, "i) event logged");
- t.eq(log[8] && log[8].type, "measure", "i) correct type");
- t.eq(log[8] && log[8].measure, 60, "i) correct measure");
+ t.eq(log.length, 9, "k) event logged");
+ t.eq(log[8] && log[8].type, "measure", "k) correct type");
+ t.eq(log[8] && log[8].measure, 60, "k) correct measure");
// clear log
log = [];
- // j) clean up
+ // l) clean up
map.destroy();
// wait for delay and confirm event not logged
delay, function() {
- t.eq(log.length, 0, "j) no event fired after destroy");
+ t.eq(log.length, 0, "l) no event fired after destroy");
Modified: sandbox/ahocevar/3072/tests/Handler/Path.html
--- sandbox/ahocevar/3072/tests/Handler/Path.html 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/tests/Handler/Path.html 2011-02-27 13:06:36 UTC (rev 11557)
@@ -145,6 +145,10 @@
cancel: function() {
logs.push({type: "cancel", args: arguments});
control.handler = handler;
map.addControl(control);
@@ -642,7 +646,11 @@
map.addLayer(layer);
var control = new OpenLayers.Control({});
- var handler = new OpenLayers.Handler.Path(control, {});
+ var handler = new OpenLayers.Handler.Path(control, {},
map.setCenter(new OpenLayers.LonLat(0, 0), 0);
@@ -741,6 +749,97 @@
]), "geometry is correct after mousemove");
+ function test_sequence_touch_1(t) {
+ t.plan(19);
+ log = [];
+ var map = new OpenLayers.Map("map", { // 300 x 150
+ resolutions: [1]
+ var layer = new OpenLayers.Layer.Vector("foo", {
+ maxExtent: new OpenLayers.Bounds(-100, -100, 100, 100),
+ isBaseLayer: true
+ map.addLayer(layer);
+ var control = new OpenLayers.Control({});
+ "done": function(g, f) {
+ log.push({geometry: g, feature: f});
+ control.handler = handler;
+ map.addControl(control);
+ map.setCenter(new OpenLayers.LonLat(0, 0), 5);
+ handler.activate();
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(49, 75)});
+ t.eq(log.length, 0, "touch start 1");
+ handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(50, 75)});
+ t.eq(log.length, 0, "touch move");
+ handler.touchend({type: "touchend"});
+ t.eq(log.length, 0, "touch end");
+ t.geom_eq(handler.line.geometry,
+ new OpenLayers.Geometry.LineString([
+ new OpenLayers.Geometry.Point(-100, 0),
+ ]), "geometry is correct");
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(100, 75)});
+ t.eq(log.length, 0, "touch start 2");
+ handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 75)});
+ t.eq(log.length, 0, "touch start 3");
+ handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(100, 75)});
+ new OpenLayers.Geometry.Point(-50, 0),
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(252, 100)});
+ t.eq(log.length, 0, "touch start 4");
+ handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(252, 100)});
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(250, 100)});
+ t.eq(log.length, 1, "touch start");
+ handler.touchmove({type: "touchmove", xy: new OpenLayers.Pixel(250, 100)});
+ t.eq(log.length, 1, "touch move");
+ t.eq(log.length, 1, "touch end");
+ t.geom_eq(log[0].geometry,
+ new OpenLayers.Geometry.Point(102, -25)
</script>
</head>
<body>
Modified: sandbox/ahocevar/3072/tests/Handler/Point.html
--- sandbox/ahocevar/3072/tests/Handler/Point.html 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/tests/Handler/Point.html 2011-02-27 13:06:36 UTC (rev 11557)
@@ -75,7 +75,7 @@
function test_Handler_Point_events(t) {
- t.plan(34);
+ t.plan(49);
var log = [];
resolutions: [1]
@@ -97,7 +97,7 @@
// list below events that should be handled (events) and those
// that should not be handled (nonevents) by the handler
- var events = ["click", "dblclick", "mousedown", "mouseup", "mousemove", "mouseout"];
+ var events = ["click", "dblclick", "mousedown", "mouseup", "mousemove", "mouseout", "touchstart", "touchmove", "touchend"];
var nonevents = ["resize", "focus", "blur"];
map.events.registerPriority = function(type, obj, func) {
var r = func();
@@ -166,6 +166,10 @@
@@ -379,8 +383,49 @@
"handler.point is null after destroy");
+ t.plan(7);
+ log = [];
+ resolutions: [1]
+ isBaseLayer: true
+ var control = new OpenLayers.Control();
+ var handler = new OpenLayers.Handler.Point(control, {
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(50, 75)});
+ handler.touchstart({type: "touchstart", xy: new OpenLayers.Pixel(99, 75)});
+ t.geom_eq(log[0].geometry, new OpenLayers.Geometry.Point(-50, 0), "geometry is correct");
</script>
</head>
<body>
Modified: sandbox/ahocevar/3072/tests/Handler/Polygon.html
--- sandbox/ahocevar/3072/tests/Handler/Polygon.html 2011-02-27 13:02:23 UTC (rev 11556)
+++ sandbox/ahocevar/3072/tests/Handler/Polygon.html 2011-02-27 13:06:36 UTC (rev 11557)
@@ -142,6 +142,10 @@
@@ -531,7 +535,11 @@
var draw = new OpenLayers.Control.DrawFeature(
map.layers[0],
OpenLayers.Handler.Polygon,
- {handlerOptions: {holeModifier: "altKey"}}
+ {handlerOptions: {
+ holeModifier: "altKey",
map.addControl(draw);
draw.activate();
@@ -745,7 +753,8 @@
var handler = new OpenLayers.Handler.Polygon(control,
{done: function(g) { log.geometry = g; }},
- {stopDown: true, stopUp: true}
+ {stopDown: true, stopUp: true,
+ pixelTolerance: 0, dblclickPixelTolerance: 0}
@@ -816,7 +825,8 @@
- {stopDown: false, stopUp: false}
+ {stopDown: false, stopUp: false,
@@ -868,6 +878,103 @@
+ t.plan(17);
+ log = [];
+ resolutions: [1]
+ isBaseLayer: true
+ var handler = new OpenLayers.Handler.Polygon(control, {
+ control.layer = layer;
+ /*t.geom_eq(handler.polygon.geometry,
+ new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([
+ ])]), "geometry is correct");*/
+ t.geom_eq(handler.polygon.geometry,
+ new OpenLayers.Geometry.Point(102, -25),
</script>
</head>
<body>
More information about the Commits
