[OpenLayers-Commits] r11561 - in sandbox/ahocevar/3072: . tests
tests/Handler
commits-20090109 at openlayers.org
Sun Feb 27 08:59:10 EST 2011
Author: ahocevar
Date: 2011-02-27 05:59:09 -0800 (Sun, 27 Feb 2011)
New Revision: 11561
sandbox/ahocevar/3072/
sandbox/ahocevar/3072/tests/Events.html
sandbox/ahocevar/3072/tests/Handler/Click.html
merging from trunk
Property changes on: sandbox/ahocevar/3072
___________________________________________________________________
Modified: svn:mergeinfo
- /sandbox/roberthl/openlayers:9745-9748
+ /sandbox/roberthl/openlayers:9745-9748
/trunk/openlayers:11557-11560
Modified: sandbox/ahocevar/3072/tests/Events.html
--- sandbox/ahocevar/3072/tests/Events.html 2011-02-27 13:57:33 UTC (rev 11560)
+++ sandbox/ahocevar/3072/tests/Events.html 2011-02-27 13:59:09 UTC (rev 11561)
@@ -318,8 +318,8 @@
touches: [{clientX: 1, clientY: 1}, {clientX: 2, clientY: 2}]
events.handleBrowserEvent(evt);
- t.eq(evt.clientX, 1, "evt.clientX value is correct");
- t.eq(evt.clientY, 1, "evt.clientY value is correct");
+ t.eq(evt.clientX, 1.5, "evt.clientX value is correct");
+ t.eq(evt.clientY, 1.5, "evt.clientY value is correct");
function test_Events_destroy (t) {
Modified: sandbox/ahocevar/3072/tests/Handler/Click.html
--- sandbox/ahocevar/3072/tests/Handler/Click.html 2011-02-27 13:57:33 UTC (rev 11560)
+++ sandbox/ahocevar/3072/tests/Handler/Click.html 2011-02-27 13:59:09 UTC (rev 11561)
@@ -2,6 +2,11 @@
<head>
<script src="../OLLoader.js"></script>
<script type="text/javascript">
+ function px(x, y) {
+ return new OpenLayers.Pixel(x, y);
function test_Handler_Click_constructor(t) {
t.plan(3);
var control = new OpenLayers.Control();
@@ -155,7 +160,7 @@
map.events.triggerEvent("dblclick", testEvt);
// set up for double click with double true - one test here
- handler.double = true;
+ handler["double"] = true;
handler.callbacks = {
"click": function(evt) {
t.fail("(dblclick w/ double true) click should not be called here");
@@ -169,7 +174,7 @@
// set up for two clicks with double true - 6 tests here (with timeout ones from above)
t.ok(evt != null, "(two clicks w/ double true) click will not be called here if next three tests pass");
@@ -195,11 +200,11 @@
handler.activate();
var downEvt = {
- xy: new OpenLayers.Pixel(0, 0)
+ xy: px(0, 0)
map.events.triggerEvent("mousedown", downEvt);
var clickEvt = {
- xy: new OpenLayers.Pixel(0, 1)
+ xy: px(0, 1)
// mouse moves one pixel, click should be called
@@ -213,7 +218,7 @@
// mouse moves 3x3 pixels, click should not be called
var clickEvt = {
- xy: new OpenLayers.Pixel(3, 3)
+ xy: px(3, 3)
@@ -315,7 +320,7 @@
// test
log = null;
- handler.touchstart({xy: {x: 1, y: 1}, touches: ["foo"]});
+ handler.touchstart({xy: px(1, 1), touches: ["foo"]});
handler.touchend({touches: ["foo"]});
t.delay_call(1, function() {
@@ -354,9 +359,9 @@
// test
log = {};
handler.touchend({});
handler.touchend({type: "click"});
t.eq(!!handler.down.touches, true, "Handler down touches property should be truthy");
@@ -395,9 +400,9 @@
// test
log = {};
- handler.touchstart({xy: {x: 1, y: 1}, touches: [{clientX:0, clientY:10}]});
+ handler.touchstart({xy: px(1, 1), touches: [{clientX:0, clientY:10}]});
t.eq(log.click, undefined, "click callback not called");
More information about the Commits
