[OpenLayers-Commits] r11570 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Sun Feb 27 19:56:21 EST 2011
Author: crschmidt
Date: 2011-02-27 16:56:20 -0800 (Sun, 27 Feb 2011)
New Revision: 11570
   trunk/openlayers/lib/OpenLayers/Control.js
Moving some properties (title, div, type, events, activate, deactivate) to
API Properties. (Closes #2827)
Modified: trunk/openlayers/lib/OpenLayers/Control.js
--- trunk/openlayers/lib/OpenLayers/Control.js	2011-02-28 00:46:52 UTC (rev 11569)
+++ trunk/openlayers/lib/OpenLayers/Control.js	2011-02-28 00:56:20 UTC (rev 11570)
@@ -71,13 +71,14 @@
     map: null,
-     * Property: div
-     * {DOMElement}
+     * APIProperty: div
+     * {DOMElement} The element that contains the control, if not present the
+     *     control is placed inside the map.
     div: null,
-     * Property: type
+     * APIProperty: type
      * {Number} Controls can have a 'type'. The type determines the type of
      * interactions which are possible with them when they are placed in an
      * <OpenLayers.Control.Panel>.
@@ -101,7 +102,7 @@
     displayClass: "",
-    * Property: title
+    * APIProperty: title
     * {string}  This property is used for showing a tooltip over the
     * Control.
@@ -136,9 +137,9 @@
     eventListeners: null,
-     * Property: events
-     * {<OpenLayers.Events>} Events instance for triggering control specific
-     *     events.
+     * APIProperty: events
+     * {<OpenLayers.Events>} Events instance for listeners and triggering
+     *     control specific events.
     events: null,
@@ -296,7 +297,7 @@
-     * Method: activate
+     * APIMethod: activate
      * Explicitly activates a control and it's associated
      * handler if one has been set.  Controls can be
      * deactivated by calling the deactivate() method.
@@ -324,7 +325,7 @@
-     * Method: deactivate
+     * APIMethod: deactivate
      * Deactivates a control and it's associated handler if any.  The exact
      * effect of this depends on the control itself.
More information about the Commits mailing list
