[OpenLayers-Commits] r11576 - in trunk/openlayers/lib/OpenLayers: . BaseTypes Control Format Geometry Layer Protocol/WFS Renderer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Mon Feb 28 03:19:19 EST 2011
Author: fredj
Date: 2011-02-28 00:19:18 -0800 (Mon, 28 Feb 2011)
New Revision: 11576
   trunk/openlayers/lib/OpenLayers/BaseTypes.js
   trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
   trunk/openlayers/lib/OpenLayers/Console.js
   trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
   trunk/openlayers/lib/OpenLayers/Control/Snapping.js
   trunk/openlayers/lib/OpenLayers/Control/Split.js
   trunk/openlayers/lib/OpenLayers/Events.js
   trunk/openlayers/lib/OpenLayers/Format/GML.js
   trunk/openlayers/lib/OpenLayers/Format/GPX.js
   trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js
   trunk/openlayers/lib/OpenLayers/Format/KML.js
   trunk/openlayers/lib/OpenLayers/Geometry/Rectangle.js
   trunk/openlayers/lib/OpenLayers/Layer.js
   trunk/openlayers/lib/OpenLayers/Layer/Grid.js
   trunk/openlayers/lib/OpenLayers/Map.js
   trunk/openlayers/lib/OpenLayers/Projection.js
   trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
   trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
   trunk/openlayers/lib/OpenLayers/Util.js
fix Natural Docs comments, no functional change. p=jorix, r=me (closes #2989)
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -260,7 +260,7 @@
      *          Default is center.
      * Returns:
-     * {<OpenLayers.Bound>} A new bounds that is scaled by ratio
+     * {<OpenLayers.Bounds>} A new bounds that is scaled by ratio
      *                      from origin.
@@ -560,6 +560,8 @@
      * Parameters:
      * maxExtent - {<OpenLayers.Bounds>}
      * options - {Object} Some possible options are:
+     * Allowed Options:
      *                    leftTolerance - {float} Allow for a margin of error
      *                                            with the 'left' value of this
      *                                            bound.
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -25,7 +25,7 @@
      * Parameters:
      * str - {String} The string to test.
-     * sub - {Sring} The substring to look for.
+     * sub - {String} The substring to look for.
      * Returns:
      * {Boolean} The first string starts with the second.
@@ -204,7 +204,7 @@
      * *Deprecated*. Whether or not a string starts with another string.
      * Parameters:
-     * sStart - {Sring} The string we're testing for.
+     * sStart - {String} The string we're testing for.
      * Returns:
      * {Boolean} Whether or not this string starts with the string passed in.
Modified: trunk/openlayers/lib/OpenLayers/Console.js
--- trunk/openlayers/lib/OpenLayers/Console.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Console.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -101,7 +101,7 @@
      * Expects a single error message
      * Parameters:
-     * object - {Object}
+     * error - {Object}
     userError: function(error) {
         alert(error);
Modified: trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js
--- trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Control/SelectFeature.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -132,7 +132,7 @@
      * Property: layers
-     * {Array(<OpenLayers.Layer.Vector>} The layers this control will work on,
+     * {Array(<OpenLayers.Layer.Vector>)} The layers this control will work on,
      * or null if the control was configured with a single layer
     layers: null,
Modified: trunk/openlayers/lib/OpenLayers/Control/Snapping.js
--- trunk/openlayers/lib/OpenLayers/Control/Snapping.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Control/Snapping.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -372,7 +372,7 @@
      * Method: considerSnapping
      * Parameters:
-     * point - {<OpenLayers.Geometry.Point}} The vertex to be snapped (or
+     * point - {<OpenLayers.Geometry.Point>} The vertex to be snapped (or
      *     unsnapped).
      * loc - {<OpenLayers.Geometry.Point>} The location of the mouse in map
      *     coords.
Modified: trunk/openlayers/lib/OpenLayers/Control/Split.js
--- trunk/openlayers/lib/OpenLayers/Control/Split.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Control/Split.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -297,7 +297,7 @@
      * Remove a feature from a list based on the given geometry.
      * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>} A list of features.
+     * features - {Array(<OpenLayers.Feature.Vector>)} A list of features.
      * geometry - {<OpenLayers.Geometry>} A geometry.
     removeByGeometry: function(features, geometry) {
@@ -340,7 +340,7 @@
      *     will be split if eligible.
      * Parameters:
-     * feature - {<OpenLayers.Feature.Vector}} The newly created or modified
+     * feature - {<OpenLayers.Feature.Vector>} The newly created or modified
      *     feature.
      * Returns:
Modified: trunk/openlayers/lib/OpenLayers/Events.js
--- trunk/openlayers/lib/OpenLayers/Events.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Events.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -604,6 +604,9 @@
      * events.register("loadstart", object, loadStartListener);
      * events.register("loadstart", object, loadEndListener);
      * (end)
+     * Parameters:
+     *  object - {Object}
     on: function(object) {
         for(var type in object) {
Modified: trunk/openlayers/lib/OpenLayers/Format/GML.js
--- trunk/openlayers/lib/OpenLayers/Format/GML.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Format/GML.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -582,7 +582,7 @@
      * Method: parseAttributes
      * Parameters:
-     * node - {<DOMElement>}
+     * node - {DOMElement}
      * Returns:
      * {Object} An attributes object.
Modified: trunk/openlayers/lib/OpenLayers/Format/GPX.js
--- trunk/openlayers/lib/OpenLayers/Format/GPX.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Format/GPX.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -134,7 +134,7 @@
     * Method: extractSegment
     * Parameters:
-    * segment - {<DOMElement>} a trkseg or rte node to parse
+    * segment - {DOMElement} a trkseg or rte node to parse
     * segmentType - {String} nodeName of waypoints that form the line
     * Returns:
Modified: trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js
--- trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Format/GeoRSS.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -263,12 +263,12 @@
      * APIMethod: read
      * Return a list of features from a GeoRSS doc
      * Parameters:
-     * data - {Element}
+     * doc - {Element}
      * Returns:
-     * An Array of <OpenLayers.Feature.Vector>s
+     * {Array(<OpenLayers.Feature.Vector>)}
     read: function(doc) {
         if (typeof doc == "string") {
Modified: trunk/openlayers/lib/OpenLayers/Format/KML.js
--- trunk/openlayers/lib/OpenLayers/Format/KML.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Format/KML.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -1125,7 +1125,7 @@
      * Accept Feature Collection, and return a string.
      * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>} An array of features.
+     * features - {Array(<OpenLayers.Feature.Vector>)} An array of features.
      * Returns:
      * {String} A KML string.
Modified: trunk/openlayers/lib/OpenLayers/Geometry/Rectangle.js
--- trunk/openlayers/lib/OpenLayers/Geometry/Rectangle.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Geometry/Rectangle.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -50,7 +50,7 @@
      * Constructor: OpenLayers.Geometry.Rectangle
      * Parameters:
-     * points - {Array(<OpenLayers.Geometry.Point>}
+     * points - {Array(<OpenLayers.Geometry.Point>)}
     initialize: function(x, y, width, height) {
         OpenLayers.Geometry.prototype.initialize.apply(this, arguments);
Modified: trunk/openlayers/lib/OpenLayers/Layer/Grid.js
--- trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Layer/Grid.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -798,7 +798,7 @@
      * Parameters:
      * rows - {Integer} Maximum number of rows we want our grid to have.
-     * colums - {Integer} Maximum number of columns we want our grid to have.
+     * columns - {Integer} Maximum number of columns we want our grid to have.
     removeExcessTiles: function(rows, columns) {
Modified: trunk/openlayers/lib/OpenLayers/Layer.js
--- trunk/openlayers/lib/OpenLayers/Layer.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Layer.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -556,7 +556,7 @@
      * Method: moveTo
      * Parameters:
-     * bound - {<OpenLayers.Bounds>}
+     * bounds - {<OpenLayers.Bounds>}
      * zoomChanged - {Boolean} Tells when zoom has changed, as layers have to
      *     do some init work in that case.
      * dragging - {Boolean}
@@ -715,7 +715,7 @@
      *     subverted.
      * Parameters:
-     * visible - {Boolean} Whether or not to display the layer (if in range)
+     * visibility - {Boolean} Whether or not to display the layer (if in range)
     setVisibility: function(visibility) {
         if (visibility != this.visibility) {
@@ -1079,7 +1079,7 @@
      * APIMethod: getZoomForExtent
      * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
+     * extent - {<OpenLayers.Bounds>}
      * closest - {Boolean} Find the zoom level that most closely fits the
      *     specified bounds. Note that this may result in a zoom that does
      *     not exactly contain the entire extent.
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Map.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -1591,7 +1591,7 @@
      * If the new lonlat is in the current extent the map will slide smoothly
      * Parameters:
-     * lonlat - {<OpenLayers.Lonlat>}
+     * lonlat - {<OpenLayers.LonLat>}
     panTo: function(lonlat) {
         if (this.panMethod && this.getExtent().scale(this.panRatio).containsLonLat(lonlat)) {
@@ -2250,8 +2250,6 @@
      * APIMethod: zoomIn
-     * Parameters:
-     * zoom - {int}
     zoomIn: function() {
         this.zoomTo(this.getZoom() + 1);
@@ -2260,8 +2258,6 @@
      * APIMethod: zoomOut
-     * Parameters:
-     * zoom - {int}
     zoomOut: function() {
         this.zoomTo(this.getZoom() - 1);
Modified: trunk/openlayers/lib/OpenLayers/Projection.js
--- trunk/openlayers/lib/OpenLayers/Projection.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Projection.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -30,7 +30,7 @@
      * Property: titleRegEx
-     * {RegEx} regular expression to strip the title from a proj4js definition
+     * {RegExp} regular expression to strip the title from a proj4js definition
     titleRegEx: /\+title=[^\+]*/,
@@ -174,10 +174,10 @@
  *     the input point is transformed in place.
  * Parameters:
- * point - {{OpenLayers.Geometry.Point> | Object} An object with x and y
+ * point - {<OpenLayers.Geometry.Point> | Object} An object with x and y
  *     properties representing coordinates in those dimensions.
- * sourceProj - {OpenLayers.Projection} Source map coordinate system
- * destProj - {OpenLayers.Projection} Destination map coordinate system
+ * source - {OpenLayers.Projection} Source map coordinate system
+ * dest - {OpenLayers.Projection} Destination map coordinate system
  * Returns:
  * point - {object} A transformed coordinate.  The original point is modified.
Modified: trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js
--- trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Protocol/WFS/v1.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -250,7 +250,7 @@
      *     is used.
      * Parameters:
      * Returns:
      * {<OpenLayers.Protocol.Response>} A response object with a features
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -799,9 +799,9 @@
      * inside the valid range.
      * Parameters:
-     * badComponent - {<OpenLayers.Geometry.Point>)} original geometry of the
+     * badComponent - {<OpenLayers.Geometry.Point>} original geometry of the
      *     invalid point
-     * goodComponent - {<OpenLayers.Geometry.Point>)} original geometry of the
+     * goodComponent - {<OpenLayers.Geometry.Point>} original geometry of the
      *     valid point
      * Returns
      * {String} the SVG coordinate pair of the clipped point (like
Modified: trunk/openlayers/lib/OpenLayers/Util.js
--- trunk/openlayers/lib/OpenLayers/Util.js	2011-02-28 08:12:05 UTC (rev 11575)
+++ trunk/openlayers/lib/OpenLayers/Util.js	2011-02-28 08:19:18 UTC (rev 11576)
@@ -22,6 +22,11 @@
  * Function: getElement
  * This is the old $() from prototype
+ * Parameters:
+ * e - {String or DOMElement or Window}
+ * Return:
+ * {Array(DOMElement)}
 OpenLayers.Util.getElement = function() {
     var elements = [];
@@ -105,7 +110,7 @@
  * Parameters:
  * array - {Array}
- * obj - {Object}
+ * obj - {*}
  * Returns:
  * {Integer} The index at, which the first object was found in the array.
@@ -134,6 +139,7 @@
  * null to an individual parameter will avoid setting the attribute.
  * Parameters:
+ * element - {DOMElement} DOM element to modify.
  * id - {String} The element id attribute to set.
  * px - {<OpenLayers.Pixel>} The left and top style position.
  * sz - {<OpenLayers.Size>}  The width and height style attributes.
@@ -404,6 +410,7 @@
  * Function: modifyAlphaImageDiv
+ * Parameters:
  * div - {DOMElement} Div containing Alpha-adjusted Image
  * id - {String}
@@ -411,7 +418,7 @@
  * imgURL - {String}
  * position - {String}
  * border - {String}
- * sizing {String} 'crop', 'scale', or 'image'. Default is "scale"
+ * sizing - {String} 'crop', 'scale', or 'image'. Default is "scale"
  * opacity - {Float} Fractional value (0.0 - 1.0)
 OpenLayers.Util.modifyAlphaImageDiv = function(div, id, px, sz, imgURL,
@@ -452,6 +459,7 @@
  * Function: createAlphaImageDiv
+ * Parameters:
  * id - {String}
@@ -938,7 +946,7 @@
  * lonlat  - {<OpenLayers.LonLat>} (or any object with both .lat, .lon
  *     properties) The start point.
  * brng     - {Float} The bearing (degrees).
- * distance - {Float} The ground distance (meters).
+ * dist     - {Float} The ground distance (meters).
  * Returns:
  * {<OpenLayers.LonLat>} The destination point.
@@ -1663,6 +1671,8 @@
  *     useful in the case where we have a limit in one dimension and must
  *     therefore meaure the flow in the other dimension.
  *     displayClass - {String} Optional parameter.  A CSS class name(s) string
  *         to provide the CSS context of the rendered content.
  *     containerElement - {DOMElement} Optional parameter. Insert the HTML to
More information about the Commits mailing list
