[OpenLayers-Commits] r10980 - sandbox/tschaub/uncircular/tools
commits-20090109 at openlayers.org
Sat Jan 1 15:29:26 EST 2011
Author: tschaub
Date: 2011-01-01 12:29:26 -0800 (Sat, 01 Jan 2011)
New Revision: 10980
sandbox/tschaub/uncircular/tools/mergejs.py
Using the simpler toposort.
Modified: sandbox/tschaub/uncircular/tools/mergejs.py
--- sandbox/tschaub/uncircular/tools/mergejs.py 2011-01-01 20:28:19 UTC (rev 10979)
+++ sandbox/tschaub/uncircular/tools/mergejs.py 2011-01-01 20:29:26 UTC (rev 10980)
@@ -44,6 +44,10 @@
SUFFIX_JAVASCRIPT = ".js"
RE_REQUIRE = "@requires:? (.*)\n" # TODO: Ensure in comment?
+class MissingImport(Exception):
+ """Exception raised when a listed import is not found in the lib."""
class SourceFile:
Represents a Javascript source code file.
@@ -161,8 +165,6 @@
files = {}
- order = [] # List of filepaths to output, in a dependency satisfying order
## Import file source code
## TODO: Do import when we walk the directories above?
for filepath in allFiles:
@@ -179,41 +181,31 @@
resolution_pass = 1
while not complete:
- nodes = []
- routes = []
+ complete = True
## Resolve the dependencies
print "Resolution pass %s... " % resolution_pass
resolution_pass += 1
for filepath, info in files.items():
- nodes.append(filepath)
- for neededFilePath in info.requires:
- routes.append((neededFilePath, filepath))
- for dependencyLevel in toposort(nodes, routes):
- for filepath in dependencyLevel:
- order.append(filepath)
- if not files.has_key(filepath):
- print "Importing: %s" % filepath
- fullpath = os.path.join(sourceDirectory, filepath).strip()
- content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
- files[filepath] = SourceFile(filepath, content) # TODO: Chop path?
- # Double check all dependencies have been met
- complete = True
- try:
- for fp in order:
- if max([order.index(rfp) for rfp in files[fp].requires] +
- [order.index(fp)]) != order.index(fp):
+ for path in info.requires:
+ if not files.has_key(path):
complete = False
- except:
- complete = False
+ fullpath = os.path.join(sourceDirectory, path).strip()
+ if os.path.exists(fullpath):
+ print "Importing: %s" % path
+ content = open(fullpath, "U").read() # TODO: Ensure end of line @ EOF?
+ files[path] = SourceFile(path, content) # TODO: Chop path?
+ else:
+ raise MissingImport("File '%s' not found (required by '%s')." % (path, filepath))
- print
+ # create dictionary of dependencies
+ dependencies = {}
+ for filepath, info in files.items():
+ dependencies[filepath] = info.requires
+ print "Sorting..."
+ order = toposort(dependencies) #[x for x in toposort(dependencies)]
## Move forced first and last files to the required position
if cfg:
More information about the Commits
