[OpenLayers-Commits] r10982 - in
sandbox/tschaub/uncircular/lib/OpenLayers: . BaseTypes
commits-20090109 at openlayers.org
Sat Jan 1 15:31:33 EST 2011
Author: tschaub
Date: 2011-01-01 12:31:33 -0800 (Sat, 01 Jan 2011)
New Revision: 10982
sandbox/tschaub/uncircular/lib/OpenLayers/BaseTypes/Class.js
sandbox/tschaub/uncircular/lib/OpenLayers/Util.js
Removing hard circular dependency.
Modified: sandbox/tschaub/uncircular/lib/OpenLayers/BaseTypes/Class.js
--- sandbox/tschaub/uncircular/lib/OpenLayers/BaseTypes/Class.js 2011-01-01 20:30:19 UTC (rev 10981)
+++ sandbox/tschaub/uncircular/lib/OpenLayers/BaseTypes/Class.js 2011-01-01 20:31:33 UTC (rev 10982)
@@ -106,3 +106,50 @@
OpenLayers.Util.extend(C.prototype, o);
+ * APIFunction: extend
+ * Copy all properties of a source object to a destination object. Modifies
+ * the passed in destination object. Any properties on the source object
+ * that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+OpenLayers.Util = OpenLayers.Util || {};
+OpenLayers.Util.extend = function(destination, source) {
+ destination = destination || {};
+ if (source) {
+ for (var property in source) {
+ var value = source[property];
+ if (value !== undefined) {
+ destination[property] = value;
+ * IE doesn't include the toString property when iterating over an object's
+ * properties with the for(property in object) syntax. Explicitly check if
+ * the source has its own toString property.
+ * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
+ * prototype object" when calling hawOwnProperty if the source object
+ * is an instance of window.Event.
+ var sourceIsEvt = typeof window.Event == "function"
+ && source instanceof window.Event;
+ if (!sourceIsEvt
+ && source.hasOwnProperty && source.hasOwnProperty("toString")) {
+ destination.toString = source.toString;
+ return destination;
Modified: sandbox/tschaub/uncircular/lib/OpenLayers/Util.js
--- sandbox/tschaub/uncircular/lib/OpenLayers/Util.js 2011-01-01 20:30:19 UTC (rev 10981)
+++ sandbox/tschaub/uncircular/lib/OpenLayers/Util.js 2011-01-01 20:31:33 UTC (rev 10982)
@@ -4,6 +4,10 @@
* full text of the license. */
+ * @requires OpenLayers/BaseTypes.js
+ * @requires OpenLayers/BaseTypes/Element.js
+ * @requires OpenLayers/BaseTypes/LonLat.js
+ * @requires OpenLayers/BaseTypes/Size.js
* @requires OpenLayers/Console.js
* @requires OpenLayers/Lang.js
@@ -11,7 +15,7 @@
* Namespace: Util
-OpenLayers.Util = {};
* Function: getElement
@@ -54,53 +58,6 @@
window.$ = OpenLayers.Util.getElement;
- * APIFunction: extend
- * Copy all properties of a source object to a destination object. Modifies
- * the passed in destination object. Any properties on the source object
- * that are set to undefined will not be (re)set on the destination object.
- * Parameters:
- * destination - {Object} The object that will be modified
- * source - {Object} The object with properties to be set on the destination
- * Returns:
- * {Object} The destination object.
-OpenLayers.Util.extend = function(destination, source) {
- destination = destination || {};
- if(source) {
- for(var property in source) {
- var value = source[property];
- if(value !== undefined) {
- destination[property] = value;
- * IE doesn't include the toString property when iterating over an object's
- * properties with the for(property in object) syntax. Explicitly check if
- * the source has its own toString property.
- * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
- * prototype object" when calling hawOwnProperty if the source object
- * is an instance of window.Event.
- var sourceIsEvt = typeof window.Event == "function"
- && source instanceof window.Event;
- if(!sourceIsEvt
- && source.hasOwnProperty && source.hasOwnProperty('toString')) {
- destination.toString = source.toString;
- return destination;
* Function: removeItem
* Remove an object from an array. Iterates through the array
More information about the Commits
