[OpenLayers-Commits] r10999 - sandbox/camptocamp/ifremer/openlayers/build
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Tue Jan 4 03:30:07 EST 2011
Author: fvanderbiest
Date: 2011-01-04 00:30:07 -0800 (Tue, 04 Jan 2011)
New Revision: 10999
   sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
   sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg
camptocamp/ifremer sandbox: new build profile
Modified: sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js
--- sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js	2011-01-04 07:43:54 UTC (rev 10998)
+++ sandbox/camptocamp/ifremer/openlayers/build/OpenLayers.cc.js	2011-01-04 08:30:07 UTC (rev 10999)
@@ -299,11 +299,6 @@
 "");c=c.replace(this.regExes.trimComma,",");c=c.split(this.regExes.splitSpace);b.left=c[0];b.bottom=c[1]},UpperCorner:function(a,b){var c=this.getChildValue(a).replace(this.regExes.trimSpace,"");c=c.replace(this.regExes.trimComma,",");c=c.split(this.regExes.splitSpace);b.right=c[0];b.top=c[1];b.bounds=new OpenLayers.Bounds(b.left,b.bottom,b.right,b.top);delete b.left;delete b.bottom;delete b.right;delete b.top}}},writers:{ows:{BoundingBox:function(a){var b=this.createElementNSPlus("ows:BoundingBox",
 {attributes:{crs:a.projection}});this.writeNode("ows:LowerCorner",a,b);this.writeNode("ows:UpperCorner",a,b);return b},LowerCorner:function(a){return this.createElementNSPlus("ows:LowerCorner",{value:a.bounds.left+" "+a.bounds.bottom})},UpperCorner:function(a){return this.createElementNSPlus("ows:UpperCorner",{value:a.bounds.right+" "+a.bounds.top})},Title:function(a){return this.createElementNSPlus("ows:Title",{value:a})},OutputFormat:function(a){return this.createElementNSPlus("ows:OutputFormat",
 {value:a})}}},CLASS_NAME:"OpenLayers.Format.OWSCommon.v1"});
-OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,"double":false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,rightclickTimerId:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null)this.mousedown=function(a){this.down=a.xy;return true}},mousedown:null,mouseup:function(a){var b=true;if(this.checkModifiers(a)&&this.control.handleRightClicks&&OpenLayers.Event.isRightClick(a))b=
-this.rightclick(a);return b},rightclick:function(a){if(this.passesTolerance(a))if(this.rightclickTimerId!=null){this.clearTimer();this.callback("dblrightclick",[a]);return!this.stopDouble}else{a=this["double"]?OpenLayers.Util.extend({},a):this.callback("rightclick",[a]);a=OpenLayers.Function.bind(this.delayedRightCall,this,a);this.rightclickTimerId=window.setTimeout(a,this.delay)}return!this.stopSingle},delayedRightCall:function(a){this.rightclickTimerId=null;a&&this.callback("rightclick",[a]);return!this.stopSingle},
-dblclick:function(a){if(this.passesTolerance(a)){this["double"]&&this.callback("dblclick",[a]);this.clearTimer()}return!this.stopDouble},click:function(a){if(this.passesTolerance(a))if(this.timerId!=null)this.clearTimer();else{a=this.single?OpenLayers.Util.extend({},a):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,a),this.delay)}return!this.stopSingle},passesTolerance:function(a){var b=true;if(this.pixelTolerance!=null&&this.down)if(Math.sqrt(Math.pow(this.down.x-
-a.xy.x,2)+Math.pow(this.down.y-a.xy.y,2))>this.pixelTolerance)b=false;return b},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null}if(this.rightclickTimerId!=null){window.clearTimeout(this.rightclickTimerId);this.rightclickTimerId=null}},delayedCall:function(a){this.timerId=null;a&&this.callback("click",[a])},deactivate:function(){var a=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;a=true}return a},
-CLASS_NAME:"OpenLayers.Handler.Click"});
 OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,interval:0,timeoutId:null,documentDrag:false,documentEvents:null,initialize:function(){OpenLayers.Handler.prototype.initialize.apply(this,arguments)},down:function(){},move:function(){},up:function(){},out:function(){},mousedown:function(a){var b=true;this.dragging=false;if(this.checkModifiers(a)&&OpenLayers.Event.isLeftClick(a)){this.started=true;this.last=
 this.start=a.xy;OpenLayers.Element.addClass(this.map.viewPortDiv,"olDragDown");this.down(a);this.callback("down",[a.xy]);OpenLayers.Event.stop(a);if(!this.oldOnselectstart)this.oldOnselectstart=document.onselectstart?document.onselectstart:OpenLayers.Function.True;document.onselectstart=OpenLayers.Function.False;b=!this.stopDown}else{this.started=false;this.last=this.start=null}return b},mousemove:function(a){if(this.started&&!this.timeoutId&&(a.xy.x!=this.last.x||a.xy.y!=this.last.y)){if(this.documentDrag===
 true&&this.documentEvents)if(a.element===document){this.adjustXY(a);this.setEvent(a)}else this.destroyDocumentEvents();if(this.interval>0)this.timeoutId=setTimeout(OpenLayers.Function.bind(this.removeTimeout,this),this.interval);this.dragging=true;this.move(a);this.callback("move",[a.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=OpenLayers.Function.False}this.last=this.evt.xy}return true},removeTimeout:function(){this.timeoutId=null},mouseup:function(a){if(this.started){if(this.documentDrag===
@@ -420,13 +415,7 @@
 a),c)},createLiterals:function(a,b){var c=OpenLayers.Util.extend({},b.attributes||b.data);OpenLayers.Util.extend(c,this.context);for(var d in this.propertyStyles)a[d]=OpenLayers.Style.createLiteral(a[d],c,b,d);return a},findPropertyStyles:function(){var a={};this.addPropertyStyles(a,this.defaultStyle);for(var b=this.rules,c,d,e=0,f=b.length;e<f;e++){c=b[e].symbolizer;for(var g in c){d=c[g];if(typeof d=="object")this.addPropertyStyles(a,d);else{this.addPropertyStyles(a,c);break}}}return a},addPropertyStyles:function(a,
 b){var c,d;for(d in b){c=b[d];if(typeof c=="string"&&c.match(/\$\{\w+\}/))a[d]=true}return a},addRules:function(a){Array.prototype.push.apply(this.rules,a);this.propertyStyles=this.findPropertyStyles()},setDefaultStyle:function(a){this.defaultStyle=a;this.propertyStyles=this.findPropertyStyles()},getSymbolizerPrefix:function(a){for(var b=OpenLayers.Style.SYMBOLIZER_PREFIXES,c=0,d=b.length;c<d;c++)if(a.CLASS_NAME.indexOf(b[c])!=-1)return b[c]},clone:function(){var a=OpenLayers.Util.extend({},this);
 if(this.rules){a.rules=[];for(var b=0,c=this.rules.length;b<c;++b)a.rules.push(this.rules[b].clone())}a.context=this.context&&OpenLayers.Util.extend({},this.context);b=OpenLayers.Util.extend({},this.defaultStyle);return new OpenLayers.Style(b,a)},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(a,b,c,d){if(typeof a=="string"&&a.indexOf("${")!=-1){a=OpenLayers.String.format(a,b,[c,d]);a=isNaN(a)||!a?a:parseFloat(a)}return a};
-OpenLayers.Style.SYMBOLIZER_PREFIXES=["Point","Line","Polygon","Text","Raster"];
-OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,dragPanOptions:null,documentDrag:false,zoomBox:null,zoomBoxEnabled:true,zoomWheelEnabled:true,mouseWheelOptions:null,handleRightClicks:false,zoomBoxKeyMask:OpenLayers.Handler.MOD_SHIFT,autoActivate:true,initialize:function(){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments)},destroy:function(){this.deactivate();this.dragPan&&this.dragPan.destroy();this.dragPan=null;this.zoomBox&&this.zoomBox.destroy();
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments)},activate:function(){this.dragPan.activate();this.zoomWheelEnabled&&this.handlers.wheel.activate();this.handlers.click.activate();this.zoomBoxEnabled&&this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments)},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,
-arguments)},draw:function(){if(this.handleRightClicks)this.map.viewPortDiv.oncontextmenu=OpenLayers.Function.False;this.handlers.click=new OpenLayers.Handler.Click(this,{dblclick:this.defaultDblClick,dblrightclick:this.defaultDblRightClick},{"double":true,stopDouble:true});this.dragPan=new OpenLayers.Control.DragPan(OpenLayers.Util.extend({map:this.map,documentDrag:this.documentDrag},this.dragPanOptions));this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:this.zoomBoxKeyMask});this.dragPan.draw();
-this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{up:this.wheelUp,down:this.wheelDown},this.mouseWheelOptions)},defaultDblClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom+1)},defaultDblRightClick:function(a){this.map.setCenter(this.map.getLonLatFromViewPortPx(a.xy),this.map.zoom-1)},wheelChange:function(a,b){var c=this.map.getZoom(),d=this.map.getZoom()+Math.round(b);d=Math.max(d,0);d=Math.min(d,this.map.getNumZoomLevels());if(d!==
-c){var e=this.map.getSize();c=e.w/2-a.xy.x;e=a.xy.y-e.h/2;var f=this.map.baseLayer.getResolutionForZoom(d),g=this.map.getLonLatFromPixel(a.xy);this.map.setCenter(new OpenLayers.LonLat(g.lon+c*f,g.lat+e*f),d)}},wheelUp:function(a,b){this.wheelChange(a,b||1)},wheelDown:function(a,b){this.wheelChange(a,b||-1)},disableZoomBox:function(){this.zoomBoxEnabled=false;this.zoomBox.deactivate()},enableZoomBox:function(){this.zoomBoxEnabled=true;this.active&&this.zoomBox.activate()},disableZoomWheel:function(){this.zoomWheelEnabled=
-false;this.handlers.wheel.deactivate()},enableZoomWheel:function(){this.zoomWheelEnabled=true;this.active&&this.handlers.wheel.activate()},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Filter=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},destroy:function(){},evaluate:function(){return true},clone:function(){return null},CLASS_NAME:"OpenLayers.Filter"});
+OpenLayers.Style.SYMBOLIZER_PREFIXES=["Point","Line","Polygon","Text","Raster"];OpenLayers.Filter=OpenLayers.Class({initialize:function(a){OpenLayers.Util.extend(this,a)},destroy:function(){},evaluate:function(){return true},clone:function(){return null},CLASS_NAME:"OpenLayers.Filter"});
 OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_")},destroy:function(){this.bounds=this.id=null},clone:function(){return new OpenLayers.Geometry},setBounds:function(a){if(a)this.bounds=a.clone()},clearBounds:function(){this.bounds=null;this.parent&&this.parent.clearBounds()},extendBounds:function(a){this.getBounds()?this.bounds.extend(a):this.setBounds(a)},getBounds:function(){this.bounds==null&&this.calculateBounds();
 return this.bounds},calculateBounds:function(){},distanceTo:function(){},getVertices:function(){},atPoint:function(a,b,c){var d=false;if(this.getBounds()!=null&&a!=null){b=b!=null?b:0;c=c!=null?c:0;d=(new OpenLayers.Bounds(this.bounds.left-b,this.bounds.bottom-c,this.bounds.right+b,this.bounds.top+c)).containsLonLat(a)}return d},getLength:function(){return 0},getArea:function(){return 0},getCentroid:function(){return null},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this))},
 CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.fromWKT=function(a){var b=arguments.callee.format;if(!b){b=new OpenLayers.Format.WKT;arguments.callee.format=b}var c;b=b.read(a);if(b instanceof OpenLayers.Feature.Vector)c=b.geometry;else if(b instanceof Array){c=b.length;for(var d=Array(c),e=0;e<c;++e)d[e]=b[e].geometry;c=new OpenLayers.Geometry.Collection(d)}return c};
Modified: sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg
--- sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg	2011-01-04 07:43:54 UTC (rev 10998)
+++ sandbox/camptocamp/ifremer/openlayers/build/ifremer.cfg	2011-01-04 08:30:07 UTC (rev 10999)
@@ -17,7 +17,8 @@
 OpenLayers/Layer/XYZ.js
 OpenLayers/Layer/SphericalMercator.js
 OpenLayers/Filter/Spatial.js
-OpenLayers/Control/Navigation.js
+OpenLayers/Control/DragPan.js
+OpenLayers/Handler/MouseWheel.js
 OpenLayers/Control/ZoomBox.js
 OpenLayers/Control/Attribution.js
 OpenLayers/Layer/Vector.js
More information about the Commits mailing list
