[OpenLayers-Commits] r11003 - in trunk/openlayers/lib/OpenLayers: . BaseTypes
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Wed Jan 5 12:24:33 EST 2011
Author: tschaub
Date: 2011-01-05 09:24:32 -0800 (Wed, 05 Jan 2011)
New Revision: 11003
   trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
   trunk/openlayers/lib/OpenLayers/Util.js
Removing the OpenLayers.Util.extend method to the Class.js file to avoid a circular dependency that cannot be resolved with an arbitrary sort order. r=elemoine (closes #2992)
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js	2011-01-05 17:21:58 UTC (rev 11002)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js	2011-01-05 17:24:32 UTC (rev 11003)
@@ -106,3 +106,50 @@
        OpenLayers.Util.extend(C.prototype, o);
+ * APIFunction: extend
+ * Copy all properties of a source object to a destination object.  Modifies
+ *     the passed in destination object.  Any properties on the source object
+ *     that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+OpenLayers.Util = OpenLayers.Util || {};
+OpenLayers.Util.extend = function(destination, source) {
+    destination = destination || {};
+    if (source) {
+        for (var property in source) {
+            var value = source[property];
+            if (value !== undefined) {
+                destination[property] = value;
+         * IE doesn't include the toString property when iterating over an object's
+         * properties with the for(property in object) syntax.  Explicitly check if
+         * the source has its own toString property.
+         * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
+         * prototype object" when calling hawOwnProperty if the source object
+         * is an instance of window.Event.
+        var sourceIsEvt = typeof window.Event == "function"
+                          && source instanceof window.Event;
+        if (!sourceIsEvt
+           && source.hasOwnProperty && source.hasOwnProperty("toString")) {
+            destination.toString = source.toString;
+    return destination;
Modified: trunk/openlayers/lib/OpenLayers/Util.js
--- trunk/openlayers/lib/OpenLayers/Util.js	2011-01-05 17:21:58 UTC (rev 11002)
+++ trunk/openlayers/lib/OpenLayers/Util.js	2011-01-05 17:24:32 UTC (rev 11003)
@@ -11,7 +11,7 @@
  * Namespace: Util
-OpenLayers.Util = {};
  * Function: getElement
@@ -54,53 +54,6 @@
     window.$ = OpenLayers.Util.getElement;
- * APIFunction: extend
- * Copy all properties of a source object to a destination object.  Modifies
- *     the passed in destination object.  Any properties on the source object
- *     that are set to undefined will not be (re)set on the destination object.
- * Parameters:
- * destination - {Object} The object that will be modified
- * source - {Object} The object with properties to be set on the destination
- * Returns:
- * {Object} The destination object.
-OpenLayers.Util.extend = function(destination, source) {
-    destination = destination || {};
-    if(source) {
-        for(var property in source) {
-            var value = source[property];
-            if(value !== undefined) {
-                destination[property] = value;
-         * IE doesn't include the toString property when iterating over an object's
-         * properties with the for(property in object) syntax.  Explicitly check if
-         * the source has its own toString property.
-         * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
-         * prototype object" when calling hawOwnProperty if the source object
-         * is an instance of window.Event.
-        var sourceIsEvt = typeof window.Event == "function"
-                          && source instanceof window.Event;
-        if(!sourceIsEvt
-           && source.hasOwnProperty && source.hasOwnProperty('toString')) {
-            destination.toString = source.toString;
-    return destination;
  * Function: removeItem
  * Remove an object from an array. Iterates through the array
More information about the Commits mailing list
