[OpenLayers-Commits] r11018 - in trunk/openlayers: examples
lib/OpenLayers/Layer/Google lib/OpenLayers/Renderer theme/default
commits-20090109 at openlayers.org
Fri Jan 7 13:50:24 EST 2011
Author: ahocevar
Date: 2011-01-07 10:50:23 -0800 (Fri, 07 Jan 2011)
New Revision: 11018
trunk/openlayers/examples/google-v3.html
trunk/openlayers/examples/osm-google.html
trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
trunk/openlayers/theme/default/google.css
trunk/openlayers/theme/default/style.css
Reverted a part of r10976 which removed code that is still needed. Thanks cmoullet for spotting this. r=me (closes #2985)
Modified: trunk/openlayers/examples/google-v3.html
--- trunk/openlayers/examples/google-v3.html 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/examples/google-v3.html 2011-01-07 18:50:23 UTC (rev 11018)
@@ -5,7 +5,7 @@
<link rel="stylesheet" href="../theme/default/style.css" type="text/css">
<link rel="stylesheet" href="../theme/default/google.css" type="text/css">
<link rel="stylesheet" href="style.css" type="text/css">
- <script src="http://maps.google.com/maps/api/js?v=3.2&sensor=false"></script>
+ <script src="http://maps.google.com/maps/api/js?sensor=false"></script>
<script src="../lib/OpenLayers.js"></script>
<script src="google-v3.js"></script>
</head>
Modified: trunk/openlayers/examples/osm-google.html
--- trunk/openlayers/examples/osm-google.html 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/examples/osm-google.html 2011-01-07 18:50:23 UTC (rev 11018)
@@ -5,7 +5,7 @@
<script src="osm-google.js"></script>
</head>
Modified: trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js
--- trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/lib/OpenLayers/Layer/Google/v3.js 2011-01-07 18:50:23 UTC (rev 11018)
@@ -134,6 +134,11 @@
var cache = OpenLayers.Layer.Google.cache[this.map.id];
var container = this.map.viewPortDiv;
+ // move the Map Data popup to the container, if any
+ while (div.lastChild.style.display == "none") {
+ container.appendChild(div.lastChild);
// move the ToS and branding stuff up to the container div
var termsOfUse = div.lastChild;
Modified: trunk/openlayers/lib/OpenLayers/Renderer/SVG.js
--- trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/lib/OpenLayers/Renderer/SVG.js 2011-01-07 18:50:23 UTC (rev 11018)
@@ -329,11 +329,17 @@
if ((rotation !== undefined || node._rotation !== undefined) && pos) {
node._rotation = rotation;
rotation |= 0;
- var metrics = this.symbolMetrics[id];
- node.firstChild.setAttributeNS(null, "transform", "rotate("
- + rotation + " "
- + metrics[1] + " "
- + metrics[2] + ")");
+ if (node.nodeName !== "svg") {
+ node.setAttributeNS(null, "transform",
+ "rotate(" + rotation + " " + pos.x + " " +
+ pos.y + ")");
+ } else {
+ var metrics = this.symbolMetrics[id];
+ node.firstChild.setAttributeNS(null, "transform", "rotate("
+ + rotation + " "
+ + metrics[1] + " "
+ + metrics[2] + ")");
Modified: trunk/openlayers/theme/default/google.css
--- trunk/openlayers/theme/default/google.css 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/theme/default/google.css 2011-01-07 18:50:23 UTC (rev 11018)
@@ -3,8 +3,15 @@
bottom: 2px;
left: auto;
+.olLayerGoogleV3.olLayerGoogleCopyright {
+ bottom: 0px;
+ right: 0px !important;
.olLayerGooglePoweredBy {
left: 2px;
bottom: 2px;
+.olLayerGoogleV3.olLayerGooglePoweredBy {
+ bottom: 0px !important;
Modified: trunk/openlayers/theme/default/style.css
--- trunk/openlayers/theme/default/style.css 2011-01-07 00:13:46 UTC (rev 11017)
+++ trunk/openlayers/theme/default/style.css 2011-01-07 18:50:23 UTC (rev 11018)
@@ -16,12 +16,18 @@
left: 2px;
- bottom: 2px;
+ bottom: 2px;
+ right: auto !important;
left: 2px;
bottom: 15px;
+ bottom: 15px !important;
.olControlAttribution {
font-size: smaller;
right: 3px;
More information about the Commits
