[OpenLayers-Commits] r11034 - in trunk/openlayers:
lib/OpenLayers/Format/WFST tests/Format/WFST
commits-20090109 at openlayers.org
Fri Jan 14 11:13:10 EST 2011
Author: tschaub
Date: 2011-01-14 08:13:10 -0800 (Fri, 14 Jan 2011)
New Revision: 11034
trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
trunk/openlayers/tests/Format/WFST/v1.html
In r11031 support was added for writing null geometries in an update transaction. This change corrects the syntax for null geometries, omitting the wfs:Value element altogether. r=ahocevar (closes #3010).
Modified: trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js
--- trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js 2011-01-14 15:56:07 UTC (rev 11033)
+++ trunk/openlayers/lib/OpenLayers/Format/WFST/v1.js 2011-01-14 16:13:10 UTC (rev 11034)
@@ -253,8 +253,9 @@
// add in geometry
if (this.geometryName !== null) {
+ this.srsName = this.getSrsName(feature);
this.writeNode(
- "Property", {name: this.geometryName, value: feature}, node
+ "Property", {name: this.geometryName, value: feature.geometry}, node
@@ -287,13 +288,10 @@
"Value": function(obj) {
var node;
- if(obj instanceof OpenLayers.Feature.Vector) {
+ if(obj instanceof OpenLayers.Geometry) {
node = this.createElementNSPlus("wfs:Value");
- if (obj.geometry) {
- this.srsName = this.getSrsName(obj);
- var geom = this.writeNode("feature:_geometry", obj.geometry).firstChild;
- node.appendChild(geom);
+ var geom = this.writeNode("feature:_geometry", obj).firstChild;
+ node.appendChild(geom);
} else {
node = this.createElementNSPlus("wfs:Value", {value: obj});
Modified: trunk/openlayers/tests/Format/WFST/v1.html
--- trunk/openlayers/tests/Format/WFST/v1.html 2011-01-14 15:56:07 UTC (rev 11033)
+++ trunk/openlayers/tests/Format/WFST/v1.html 2011-01-14 16:13:10 UTC (rev 11034)
@@ -262,7 +262,6 @@
<wfs:Update xmlns:wfs="http://www.opengis.net/wfs" typeName="topp:states" xmlns:topp="http://www.openplans.org/topp">
<wfs:Property>
<wfs:Name>the_geom</wfs:Name>
- <wfs:Value></wfs:Value>
</wfs:Property>
<wfs:Property>
<wfs:Name>foo</wfs:Name>
More information about the Commits
