[OpenLayers-Commits] r11051 - in sandbox/sonxurxo/sos: examples lib lib/OpenLayers/Layer lib/OpenLayers/Protocol/SOS
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Jan 21 08:33:59 EST 2011
Author: sonxurxo
Date: 2011-01-21 05:33:59 -0800 (Fri, 21 Jan 2011)
New Revision: 11051
Added:
   sandbox/sonxurxo/sos/examples/sosClass.html
   sandbox/sonxurxo/sos/lib/OpenLayers/Layer/SOS2.js
   sandbox/sonxurxo/sos/lib/OpenLayers.js
   sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js
Added a SOS convenience class
Added: sandbox/sonxurxo/sos/examples/sosClass.html
--- sandbox/sonxurxo/sos/examples/sosClass.html	                        (rev 0)
+++ sandbox/sonxurxo/sos/examples/sosClass.html	2011-01-21 13:33:59 UTC (rev 11051)
@@ -0,0 +1,60 @@
+<html xmlns="http://www.w3.org/1999/xhtml">
+  <head>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css" />
+    <style type="text/css">
+    .sosmap {
+        width: 768px;
+        height: 512px;
+    </style>
+    <script src="../lib/OpenLayers.js"></script>
+    <script type="text/javascript">
+        var map;
+        OpenLayers.ProxyHost = "proxy.cgi?url=";
+        OpenLayers.Util.extend(OpenLayers.Lang.en,
+                'SOSClientType': "Type",
+                'SOSClientTime': "Date/time",
+                'SOSClientLastvalue': "Last value"
+        function init(){
+            map = new OpenLayers.Map( 'map' );
+            var url  = 'http://v-swe.uni-muenster.de:8080/WeatherSOS/sos?';
+            var sosLayer = new OpenLayers.Layer.SOS2("Stations", url, {
+                offering: "RAIN_GAUGE",
+                observedProperties: ["urn:ogc:def:property:OGC::Precipitation1Hour"],
+                responseFormat: 'text/xml;subtype="om/1.0.0"',
+                resultModel: "om:Measurement",
+                eventTime: "latest"
+            var baseLayer = new OpenLayers.Layer.WMS("Test Layer", "http://vmap0.tiles.osgeo.org/wms/vmap0?", {
+                layers: "basic"}, {singleTile: true});
+            map.addLayers([baseLayer, sosLayer]);
+            map.setCenter(new OpenLayers.LonLat(5, 45), 4);
+            map.addControl( new OpenLayers.Control.LayerSwitcher() );
+            map.addControl( new OpenLayers.Control.MousePosition() );
+    </script>
+  </head>
+  <body onload="init()">
+    <h1 id="title">SOS client example</h1>
+    <div id="tags">
+        sos, sensor, observation, popup, advanced
+    </div>
+        <p id="shortdesc">
+            Shows how to connect OpenLayers to a Sensor Observation Service (SOS)
+        </p>
+    <div id="map" class="sosmap"></div>
+        <div id="docs">
+        <p>This example uses a vector layer with a Protocol.SOS and a fixed Strategy.
+        </p><p>When clicking on a point feature (the weather stations offered by the SOS), the
+        latest values for all offerings are displayed in a popup.</p>
+        </div>
+  </body>
+</html>
Added: sandbox/sonxurxo/sos/lib/OpenLayers/Layer/SOS2.js
--- sandbox/sonxurxo/sos/lib/OpenLayers/Layer/SOS2.js	                        (rev 0)
+++ sandbox/sonxurxo/sos/lib/OpenLayers/Layer/SOS2.js	2011-01-21 13:33:59 UTC (rev 11051)
@@ -0,0 +1,134 @@
+/* Copyright (c) 2006-2010 MetaCarta, Inc., published under the Clear BSD
+ * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/Vector.js
+ * @requires OpenLayers/Strategy/Fixed.js
+ * @requires OpenLayers/Protocol/SOS.js
+ * @requires OpenLayers/Format/SOSCapabilities.js
+ * Class: OpenLayers.Layer.SOS
+ * Convenience layer for accessing Sensor Observation Services (SOS).
+ * Inherits from:
+ *  - <OpenLayers.Layer.Vector>
+OpenLayers.Layer.SOS2 = OpenLayers.Class(OpenLayers.Layer.Vector, {
+     * APIProperty: url
+     * {String} The url of the Sensor Observation Service (SOS)
+    url: null,
+    offering: null,
+    observedProperties: [],
+    resultModel: null,
+    responseFormat: null,
+    eventTime: 'latest',
+     * APIProperty: sosCache
+     * {Object} Cache to use for storing parsed results from
+     *     <OpenLayers.Format.SOSCapabilities.read>. If not provided,
+     *     these will be cached on the prototype.
+    sosCache: {},
+     * Constructor: OpenLayers.Layer.SOS
+     * Create a new SOS layer object
+     * Example:
+     * (code)
+     * var sos = new OpenLayers.Layer.SOS("Weather stations",
+     *     'http://myhost/sos?');
+     * (end)
+     * Parameters:
+     * name - {String} A name for the layer
+     * url - {String} Base url for the Sensor Observation Service
+     * options - {Ojbect} Hashtable of extra options to tag onto the layer
+    initialize: function(name, url, options) {
+        this.url = url;
+        OpenLayers.Util.extend(options, {
+            styleMap: new OpenLayers.StyleMap({
+                        'default':{
+                            strokeColor: "#e8e8e8",
+                            strokeOpacity: 1,
+                            strokeWidth: 3,
+                            fillColor: "#FF5500",
+                            fillOpacity: 0.5,
+                            pointRadius: 6,
+                            pointerEvents: "visiblePainted",
+                            label : "${value} ${uom}",
+                            fontSize: "11px",
+                            fontFamily: "Courier New, monospace",
+                            fontWeight: "normal",
+                            labelAlign: "cm",
+                            labelXOffset: "0",
+                            labelYOffset: "15"
+                        'select':{
+                            strokeColor: "#a8a8a8",
+                            strokeOpacity: 1,
+                            strokeWidth: 3,
+                            fillColor: "#aa5500",
+                            fillOpacity: 0.8,
+                            pointRadius: 4,
+                            label : "${value} ${uom} (${time})",
+                            fontSize: "12px",
+                            fontWeight: "bold",
+                            labelAlign: "cm",
+        OpenLayers.Layer.Vector.prototype.initialize.apply(this,
+            [name, options]);
+     * Method: afterAdd
+     * Called at the end of the map.addLayer sequence.
+    afterAdd: function() {
+        var strategy = new OpenLayers.Strategy.Fixed();
+        this.strategies = [strategy];
+        OpenLayers.Util.extend(this.options, {url: this.url});
+        this.protocol = new OpenLayers.Protocol.SOS.v1_0_0_2(this.options);
+        strategy.setLayer(this);
+        strategy.activate();
+        this.selectFeature = new OpenLayers.Control.SelectFeature(this, {
+            hover: true
+        this.map.addControls([this.selectFeature]);
+        this.selectFeature.activate();
+     * APIMethod: destroy
+     * Take care of things that are not handled in the superclass.
+    destroy: function() {
+        delete this.sosCache[this.id];
+        OpenLayers.Layer.Vector.prototype.destroy.apply(this, arguments);
+    CLASS_NAME: "OpenLayers.Layer.SOS2"
Modified: sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js
--- sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js	2011-01-21 12:37:47 UTC (rev 11050)
+++ sandbox/sonxurxo/sos/lib/OpenLayers/Protocol/SOS/v1_0_0_2.js	2011-01-21 13:33:59 UTC (rev 11051)
@@ -136,8 +136,8 @@
         var oAM = this.format.read(doc);
         var features = [];
         for (var m in oAM.measurements) {
-            var foi = oAM.measurements[m].fois[0].features[0];
-            var geometry = new OpenLayers.Geometry.Point(foi.geometry.x, foi.geometry.y);
+            var foi = oAM.measurements[m].fois[0].components[0];
+            var geometry = new OpenLayers.Geometry.Point(foi.x, foi.y);
             var feature = new OpenLayers.Feature.Vector(geometry, {
                 value: oAM.measurements[m].result.value,
                 uom: oAM.measurements[m].result.uom,
Modified: sandbox/sonxurxo/sos/lib/OpenLayers.js
--- sandbox/sonxurxo/sos/lib/OpenLayers.js	2011-01-21 12:37:47 UTC (rev 11050)
+++ sandbox/sonxurxo/sos/lib/OpenLayers.js	2011-01-21 13:33:59 UTC (rev 11051)
@@ -202,6 +202,7 @@
             "OpenLayers/Layer/Vector.js",
             "OpenLayers/Layer/Vector/RootContainer.js",
             "OpenLayers/Layer/SOS.js",
+            "OpenLayers/Layer/SOS2.js",
             "OpenLayers/Strategy.js",
             "OpenLayers/Strategy/Filter.js",
             "OpenLayers/Strategy/Fixed.js",
More information about the Commits mailing list
