[OpenLayers-Commits] r12042 - in sandbox/tschaub/editing: examples
lib/OpenLayers/Handler
commits-20090109 at openlayers.org
Sun Jun 5 19:17:10 EDT 2011
Author: tschaub
Date: 2011-06-05 16:17:09 -0700 (Sun, 05 Jun 2011)
New Revision: 12042
Added:
sandbox/tschaub/editing/examples/editing-methods.html
sandbox/tschaub/editing/examples/editing-methods.js
sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
Adding editing methods example.
Added: sandbox/tschaub/editing/examples/editing-methods.html
--- sandbox/tschaub/editing/examples/editing-methods.html (rev 0)
+++ sandbox/tschaub/editing/examples/editing-methods.html 2011-06-05 23:17:09 UTC (rev 12042)
@@ -0,0 +1,64 @@
+<!DOCTYPE html>
+<html>
+ <head>
+ <title>OpenLayers Editing Methods</title>
+ <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+ <meta name="viewport" content="width=device-width, user-scalable=no, initial-scale=1.0, maximum-scale=1.0;">
+ <meta name="apple-mobile-web-app-capable" content="yes">
+ <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="style.css" type="text/css">
+ <script src="../lib/OpenLayers.js"></script>
+ <style>
+ .olControlAttribution {
+ font-size: 9px;
+ bottom: 5px;
+ </style>
+ </head>
+ <body>
+ <h1 id="title">Editing Methods</h1>
+ <p id="shortdesc">
+ Demonstrates the use of editing methods for manipulating geometries
+ while drawing.
+ </p>
+ <div id="map" class="smallmap"></div>
+ <ul id="methods">
+ <li><a href="#" id="insertXY">insert x,y</a></li>
+ <li><a href="#" id="insertDeltaXY">insert dx,dy</a></li>
+ <li><a href="#" id="insertDirectionLength">insert direction/length</a></li>
+ <li><a href="#" id="insertDeflectionLength">insert deflection/length</a></li>
+ <li><a href="#" id="finishSketch">finish sketch</a></li>
+ </ul>
+ <div id="docs">
+ <p>
+ The <code>control.insertXY</code> method inserts a point at the given
+ map coordinates (x, y) immediately prior to the most recent point
+ (under the mouse).
+ The <code>control.insertDeltaXY</code> method inserts a point at
+ the given offset values (dx, dy) from the previously added point.
+ The <code>control.insertDirectionLength</code> method inserts a
+ point at offset direction and length from the previously added point.
+ Direction is measured counter-clockwise from the positive x-axis.
+ The <code>control.insertDeflectionLength</code> method inserts a
+ point at offset deflection and length from the previously added point.
+ Deflection is measured counter-clockwise from the previous line
+ segment.
+ The <code>control.finishSketch</code> method completes the current
+ sketch without adding the point under the user's mouse. This
+ allows a sketch to be finished without a double-click.
+ The <code>control.insertXY</code> method may be called before
+ any points are digitized manually. The other methods have no
+ effect until at least one point has been added to the sketch.
+ </p><p>
+ View the <a href="editing-methods.js" target="_blank">editing-methods.js</a>
+ source to see how this is done.
+ </p>
+ </div>
+ <script src="editing-methods.js"></script>
+ </body>
+</html>
Added: sandbox/tschaub/editing/examples/editing-methods.js
--- sandbox/tschaub/editing/examples/editing-methods.js (rev 0)
+++ sandbox/tschaub/editing/examples/editing-methods.js 2011-06-05 23:17:09 UTC (rev 12042)
@@ -0,0 +1,80 @@
+var map = new OpenLayers.Map({
+ div: "map",
+ layers: [
+ new OpenLayers.Layer.WMS(
+ "Global Imagery",
+ "http://maps.opengeo.org/geowebcache/service/wms",
+ {layers: "bluemarble"},
+ {tileOrigin: new OpenLayers.LonLat(-180, -90)}
+ new OpenLayers.Layer.Vector()
+ center: new OpenLayers.LonLat(0, 0),
+ zoom: 1
+var draw = new OpenLayers.Control.DrawFeature(
+ map.layers[1], OpenLayers.Handler.Path
+map.addControl(draw);
+draw.activate();
+// handle clicks on method links
+$("insertXY").onclick = function() {
+ var values = parseInput(
+ window.prompt(
+ "Enter map coordinates for new point (e.g. '-111, 46')", "x, y"
+ if (values != null) {
+ draw.insertXY(values[0], values[1]);
+$("insertDeltaXY").onclick = function() {
+ window.prompt(
+ "Enter offset values for new point (e.g. '15, -10')", "dx, dy"
+ draw.insertDeltaXY(values[0], values[1]);
+$("insertDirectionLength").onclick = function() {
+ window.prompt(
+ "Enter direction and length offset values for new point (e.g. '-45, 10')", "direction, length"
+ draw.insertDirectionLength(values[0], values[1]);
+$("insertDeflectionLength").onclick = function() {
+ window.prompt(
+ "Enter deflection and length offset values for new point (e.g. '15, 20')", "deflection, length"
+ draw.insertDeflectionLength(values[0], values[1]);
+$("finishSketch").onclick = function() {
+ draw.finishSketch();
+function parseInput(text) {
+ var values = text.split(",");
+ if (values.length !== 2) {
+ values = null;
+ } else {
+ values[0] = parseFloat(values[0]);
+ values[1] = parseFloat(values[1]);
+ if (isNaN(values[0]) || isNaN(values[1])) {
+ window.alert("The two values must be numeric.");
+ values = null;
+ return values;
\ No newline at end of file
Modified: sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js
--- sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-06-05 22:09:02 UTC (rev 12041)
+++ sandbox/tschaub/editing/lib/OpenLayers/Handler/Path.js 2011-06-05 23:17:09 UTC (rev 12042)
@@ -207,7 +207,9 @@
insertDeltaXY: function(dx, dy) {
var previousIndex = this.getCurrentPointIndex() - 1;
var p0 = this.line.geometry.components[previousIndex];
- this.insertXY(p0.x + dx, p0.y + dy);
+ if (p0 && !isNaN(p0.x) && !isNaN(p0.y)) {
+ this.insertXY(p0.x + dx, p0.y + dy);
More information about the Commits
