[OpenLayers-Commits] r12067 -
sandbox/bartvde/exception/openlayers/tests/Format/WMSCapabilities
commits-20090109 at openlayers.org
Tue Jun 7 17:31:26 EDT 2011
Author: bartvde
Date: 2011-06-07 14:31:25 -0700 (Tue, 07 Jun 2011)
New Revision: 12067
sandbox/bartvde/exception/openlayers/tests/Format/WMSCapabilities/v1_3_0.html
add test for 1.3.0 WMS error handling
Modified: sandbox/bartvde/exception/openlayers/tests/Format/WMSCapabilities/v1_3_0.html
--- sandbox/bartvde/exception/openlayers/tests/Format/WMSCapabilities/v1_3_0.html 2011-06-07 21:27:29 UTC (rev 12066)
+++ sandbox/bartvde/exception/openlayers/tests/Format/WMSCapabilities/v1_3_0.html 2011-06-07 21:31:25 UTC (rev 12067)
@@ -3,6 +3,15 @@
<script src="../../OLLoader.js"></script>
<script type="text/javascript">
+ function test_read_exception(t) {
+ t.plan(1);
+ var xml = document.getElementById("exceptionsample").firstChild.nodeValue;
+ var doc = new OpenLayers.Format.XML().read(xml);
+ var format = new OpenLayers.Format.WMSCapabilities();
+ var obj = format.read(doc);
+ t.ok(!!obj.error, "Error reported correctly");
function test_layers(t) {
t.plan(22);
@@ -280,6 +289,26 @@
</head>
<body>
+<div id="exceptionsample"><!--
+<?xml version='1.0' encoding="UTF-8"?>
+<ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc"
+ xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
+ xsi:schemaLocation="http://www.opengis.net/ogc
+ http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
+ <ServiceException> Plain text message about an error. </ServiceException>
+ <ServiceException code="InvalidUpdateSequence"> Another error message, this one with a service
+ exception code supplied. </ServiceException>
+ <![CDATA[ Error in module <foo.c>, line 42
+A message that includes angle brackets in text must be enclosed in a Character Data Section as in this example. All XML-like markup is ignored except for this sequence of three closing characters:
+ </ServiceException>
+ <![CDATA[ <Module>foo.c</Module> <Error>An error occurred</Error> <Explanation>Similarly, actual XML can be enclosed in a CDATA section. A generic parser will ignore that XML, but application-specific software may choose to process it.</Explanation> ]]>
+</ServiceExceptionReport>
+--></div>
OGC example below taken from
http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xml
More information about the Commits
