[OpenLayers-Commits] r12099 - in trunk/openlayers: examples lib lib/OpenLayers/Layer tests tests/Layer
commits-20090109 at openlayers.org commits-20090109 at openlayers.org
Fri Jun 17 14:18:41 EDT 2011
Author: tschaub
Date: 2011-06-17 11:18:40 -0700 (Fri, 17 Jun 2011)
New Revision: 12099
Added:
   trunk/openlayers/examples/point-grid.html
   trunk/openlayers/examples/point-grid.js
   trunk/openlayers/examples/snap-grid.html
   trunk/openlayers/examples/snap-grid.js
   trunk/openlayers/lib/OpenLayers/Layer/PointGrid.js
   trunk/openlayers/tests/Layer/PointGrid.html
   trunk/openlayers/lib/OpenLayers.js
   trunk/openlayers/tests/list-tests.html
Adding layer for generating dynamic point grids. r=bartvde (closes #3344)
Added: trunk/openlayers/examples/point-grid.html
--- trunk/openlayers/examples/point-grid.html	                        (rev 0)
+++ trunk/openlayers/examples/point-grid.html	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,75 @@
+<!DOCTYPE html>
+<html>
+  <head>
+    <meta name="viewport" content="width=device-width; initial-scale=1.0; maximum-scale=1.0; user-scalable=0;">
+    <meta name="apple-mobile-web-app-capable" content="yes">
+    <title>OpenLayers Point Grid Example</title>
+    <link rel="stylesheet" href="../theme/default/style.css" type="text/css">
+    <link rel="stylesheet" href="style.css" type="text/css">
+    <style type="text/css">
+        .olControlAttribution {
+            left: 5px;
+            bottom: 5px;
+    </style>
+  </head>
+  <body>
+    <h1 id="title">Point Grid Example</h1>
+    <div id="tags">
+        point grid
+    </div>
+    <div id="shortdesc">Use a PointGrid layer to display a grid of regularly spaced points</div>
+    <div id="map" class="smallmap"></div>
+    Grid rotation:
+    <select name="rotation" id="rotation">
+        <option value="-45">-45</option>
+        <option value="-30">-30</option>
+        <option value="-15">-15</option>
+        <option value="0">0</option>
+        <option value="15">15</option>
+        <option value="30">30</option>
+        <option value="45">45</option>
+    </select>
+    &nbsp;
+    Grid spacing:
+    <select name="dx" id="dx">
+        <option value="10">10</option>
+        <option value="20">20</option>
+        <option value="25">25</option>
+    </select> x
+    <select name="dy" id="dy">
+    </select>
+    &nbsp;
+    Max points:
+    <select name="max" id="max">
+        <option value="150">150</option>
+        <option value="250">250</option>
+        <option value="350">350</option>
+    </select>
+    <div class="docs">
+        <p>
+            This example demonstrates a <code>OpenLayers.Layer.PointGrid</code>
+            layer to render a regularly spaced grid of point features.
+        </p><p>
+            See the <a href="point-grid.js" target="_blank">
+            point-grid.js source</a> to see how this is done.
+        </p>
+    </div>
+    <script src="../lib/OpenLayers.js"></script>
+    <script src="point-grid.js"></script>
+  </body>
+</html>
Added: trunk/openlayers/examples/point-grid.js
--- trunk/openlayers/examples/point-grid.js	                        (rev 0)
+++ trunk/openlayers/examples/point-grid.js	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,33 @@
+var points = new OpenLayers.Layer.PointGrid({
+    isBaseLayer: true, dx: 15, dy: 15
+var map = new OpenLayers.Map({
+    div: "map",
+    layers: [points],
+    center: new OpenLayers.LonLat(0, 0),
+    zoom: 2
+var rotation = document.getElementById("rotation");
+rotation.value = String(points.rotation);
+rotation.onchange = function() {
+    points.setRotation(Number(rotation.value));
+var dx = document.getElementById("dx");
+var dy = document.getElementById("dy");
+dx.value = String(points.dx);
+dy.value = String(points.dy);
+dx.onchange = function() {
+    points.setSpacing(Number(dx.value), Number(dy.value));
+dy.onchange = function() {
+var max = document.getElementById("max");
+max.value = String(points.maxFeatures);
+max.onchange = function() {
+    points.setMaxFeatures(Number(max.value));
Added: trunk/openlayers/examples/snap-grid.html
--- trunk/openlayers/examples/snap-grid.html	                        (rev 0)
+++ trunk/openlayers/examples/snap-grid.html	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,78 @@
+<!DOCTYPE html>
+<html>
+  <head>
+    <title>OpenLayers Snap Grid Example</title>
+            left: 5px;
+            bottom: 5px;
+        .olControlEditingToolbar .olControlModifyFeatureItemInactive {
+            background-position: -1px -1px;
+        .olControlEditingToolbar .olControlModifyFeatureItemActive {
+            background-position: -1px -24px;
+    </style>
+  </head>
+  <body>
+    <h1 id="title">Snap Grid Example</h1>
+    <div id="tags">
+        snap grid
+    </div>
+    <div id="shortdesc">Use a PointGrid layer and a Snapping control to snap to a grid of regularly spaced points</div>
+    Grid rotation:
+    </select>
+    &nbsp;
+    Grid spacing:
+    <select name="spacing" id="spacing">
+        <option value="300">300</option>
+        <option value="600">600</option>
+        <option value="1200">1200</option>
+        <option value="2400">2400</option>
+    </select>
+    &nbsp;
+    Max points:
+    </select>
+        <p>
+            This example demonstrates feature editing with snapping to a regular
+            grid.  The map is configured with a <code>OpenLayers.Layer.PointGrid</code>
+            layer and a <code>OpenLayers.Control.Snapping</code> agent.  For the
+            best performance, the point grid layer should not made visible.
+            Snapping still works with layers that are not visible.
+        </p><p>
+            See the <a href="snap-grid.js" target="_blank">
+            snap-grid.js source</a> to see how this is done.
+        </p>
+    </div>
+    <script src="snap-grid.js"></script>
+  </body>
+</html>
Added: trunk/openlayers/examples/snap-grid.js
--- trunk/openlayers/examples/snap-grid.js	                        (rev 0)
+++ trunk/openlayers/examples/snap-grid.js	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,81 @@
+    name: "Snap Grid",
+    dx: 600, dy: 600,
+    styleMap: new OpenLayers.StyleMap({
+        pointRadius: 1,
+        strokeColor: "#3333ff",
+        strokeWidth: 1,
+        fillOpacity: 1,
+        fillColor: "#ffffff",
+        graphicName: "square"
+var lines = new OpenLayers.Layer.Vector("Lines", {
+        pointRadius: 3,
+        strokeColor: "#ff3300",
+        strokeWidth: 3,
+        fillOpacity: 0
+    div: "map",
+    layers: [new OpenLayers.Layer.OSM(), points, lines],
+    controls: [
+        new OpenLayers.Control.Navigation(),
+        new OpenLayers.Control.LayerSwitcher(),
+        new OpenLayers.Control.Attribution()
+    restrictedExtent: new OpenLayers.Bounds(
+        1035374, 7448940, 1074510, 7468508
+    center: new OpenLayers.LonLat(1054942, 7458724),
+    zoom: 13
+// configure the snapping agent
+var snap = new OpenLayers.Control.Snapping({
+    layer: lines,
+    targets: [{
+        layer: points,
+        tolerance: 15
+snap.activate();
+// add some editing tools to a panel
+var panel = new OpenLayers.Control.Panel({
+    displayClass: "olControlEditingToolbar"
+var draw = new OpenLayers.Control.DrawFeature(
+    lines, OpenLayers.Handler.Path,
+    {displayClass: "olControlDrawFeaturePath", title: "Draw Features"}
+modify = new OpenLayers.Control.ModifyFeature(
+    lines, {displayClass: "olControlModifyFeature", title: "Modify Features"}
+panel.addControls([
+    new OpenLayers.Control.Navigation({title: "Navigate"}),
+    modify, draw
+map.addControl(panel);
+var spacing = document.getElementById("spacing");
+spacing.value = String(points.dx);
+spacing.onchange = function() {
+    points.setSpacing(Number(spacing.value));
Added: trunk/openlayers/lib/OpenLayers/Layer/PointGrid.js
--- trunk/openlayers/lib/OpenLayers/Layer/PointGrid.js	                        (rev 0)
+++ trunk/openlayers/lib/OpenLayers/Layer/PointGrid.js	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,299 @@
+/* Copyright (c) 2006-2011 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the Clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Layer/Vector.js
+ * @requires OpenLayers/Geometry/Polygon.js
+ * Class: OpenLayers.Layer.PointGrid
+ * A point grid layer dynamically generates a regularly spaced grid of point
+ *     features.  This is a specialty layer for cases where an application needs
+ *     a regular grid of points.  It can be used, for example, in an editing
+ *     environment to snap to a grid.
+ * Create a new vector layer with the <OpenLayers.Layer.PointGrid> constructor.
+ * (code)
+ * // create a grid with points spaced at 10 map units
+ * var points = new OpenLayers.Layer.PointGrid({dx: 10, dy: 10});
+ * // create a grid with different x/y spacing rotated 15 degrees clockwise.
+ * var points = new OpenLayers.Layer.PointGrid({dx: 5, dy: 10, rotation: 15});
+ * (end)
+ * Inherits from:
+ *  - <OpenLayers.Layer.Vector>
+OpenLayers.Layer.PointGrid = OpenLayers.Class(OpenLayers.Layer.Vector, {
+     * APIProperty: dx
+     * {Number} Point grid spacing in the x-axis direction (map units).
+     * Read-only.  Use the <setSpacing> method to modify this value.
+    dx: null,
+     * APIProperty: dy
+     * {Number} Point grid spacing in the y-axis direction (map units).
+    dy: null,
+     * APIProperty: ratio
+     * {Number} Ratio of the desired grid size to the map viewport size.
+     * Default is 1.5.  Larger ratios mean the grid is recalculated less often
+     * while panning.  The <maxFeatures> setting has precedence when determining
+     * grid size.  Read-only.  Use the <setRatio> method to modify this value.
+    ratio: 1.5,
+     * APIProperty: maxFeatures
+     * {Number} The maximum number of points to generate in the grid.  Default
+     * is 250.  Read-only.  Use the <setMaxFeatures> method to modify this value.
+    maxFeatures: 250,
+     * APIProperty: rotation
+     * {Number} Grid rotation (in degrees clockwise from the positive x-axis).
+     * Default is 0.  Read-only.  Use the <setRotation> method to modify this
+     * value.
+    rotation: 0,
+     * APIProperty: origin
+     * {OpenLayers.LonLat} Grid origin.  The grid lattice will be aligned with
+     * the origin.  If not set at construction, the center of the map's maximum
+     * extent is used.  Read-only.  Use the <setOrigin> method to modify this
+     * value.
+    origin: null,
+     * Property: gridBounds
+     * {<OpenLayers.Bounds>}  Internally cached grid bounds (with optional
+     * rotation applied).
+    gridBounds: null,
+     * Constructor: OpenLayers.Layer.PointGrid
+     * Creates a new point grid layer.
+     * Parameters:
+     * config - {Object} An object containing all configuration properties for
+     *     the layer.  The <dx> and <dy> properties are required to be set at
+     *     construction.  Any other layer properties may be set in this object.
+    initialize: function(config) {
+        config = config || {};
+        OpenLayers.Layer.Vector.prototype.initialize.apply(this, [config.name, config]);
+     * Method: setMap
+     * The layer has been added to the map.
+     * Parameters:
+     * map - {<OpenLayers.Map>}
+    setMap: function(map) {
+        OpenLayers.Layer.Vector.prototype.setMap.apply(this, arguments);
+        map.events.register("moveend", this, this.onMoveEnd);
+     * Method: removeMap
+     * The layer has been removed from the map.
+     * Parameters:
+    removeMap: function(map) {
+        map.events.unregister("moveend", this, this.onMoveEnd);
+        OpenLayers.Layer.Vector.prototype.removeMap.apply(this, arguments);
+     * APIMethod: setRatio
+     * Set the grid <ratio> property and update the grid.  Can only be called
+     *     after the layer has been added to a map with a center/extent.
+     * Parameters:
+     * ratio - {Number}
+    setRatio: function(ratio) {
+        this.ratio = ratio;
+        this.updateGrid(true);
+     * APIMethod: setMaxFeatures
+     * Set the grid <maxFeatures> property and update the grid.  Can only be
+     *     called after the layer has been added to a map with a center/extent.
+     * Parameters:
+     * maxFeatures - {Number}
+    setMaxFeatures: function(maxFeatures) {
+        this.maxFeatures = maxFeatures;
+     * APIMethod: setSpacing
+     * Set the grid <dx> and <dy> properties and update the grid.  If only one
+     *     argument is provided, it will be set as <dx> and <dy>.  Can only be
+     * Parameters:
+     * dx - {Number}
+     * dy - {Number}
+    setSpacing: function(dx, dy) {
+        this.dx = dx;
+        this.dy = dy || dx;
+     * APIMethod: setOrigin
+     * Set the grid <origin> property and update the grid.  Can only be called
+     * Parameters:
+     * origin - {<OpenLayers.LonLat>}
+    setOrigin: function(origin) {
+        this.origin = origin;
+     * APIMethod: getOrigin
+     * Get the grid <origin> property.
+     * Returns:
+     * {<OpenLayers.LonLat>} The grid origin.
+    getOrigin: function() {
+        if (!this.origin) {
+            this.origin = this.map.getExtent().getCenterLonLat();
+        return this.origin;
+     * APIMethod: setRotation
+     * Set the grid <rotation> property and update the grid.  Rotation values
+     *     are in degrees clockwise from the positive x-axis (negative values
+     *     for counter-clockwise rotation).  Can only be called after the layer
+     *     has been added to a map with a center/extent.
+     * Parameters:
+     * rotation - {Number} Degrees clockwise from the positive x-axis.
+    setRotation: function(rotation) {
+        this.rotation = rotation;
+     * Method: onMoveEnd
+     * Listener for map "moveend" events.
+    onMoveEnd: function() {
+        this.updateGrid();
+     * Method: getViewBounds
+     * Gets the (potentially rotated) view bounds for grid calculations.
+     * Returns:
+    getViewBounds: function() {
+        var bounds = this.map.getExtent();
+        if (this.rotation) {
+            var origin = this.getOrigin();
+            var rotationOrigin = new OpenLayers.Geometry.Point(origin.lon, origin.lat);
+            var rect = bounds.toGeometry();
+            rect.rotate(-this.rotation, rotationOrigin);
+            bounds = rect.getBounds();
+        return bounds;
+     * Method: updateGrid
+     * Update the grid.
+     * Parameters:
+     * force - {Boolean} Update the grid even if the previous bounds are still
+     *     valid.
+    updateGrid: function(force) {
+        if (force || this.invalidBounds()) {
+            var viewBounds = this.getViewBounds();
+            var viewBoundsWidth = viewBounds.getWidth();
+            var viewBoundsHeight = viewBounds.getHeight();
+            var aspectRatio = viewBoundsWidth / viewBoundsHeight;
+            var maxHeight = Math.sqrt(this.dx * this.dy * this.maxFeatures / aspectRatio);
+            var maxWidth = maxHeight * aspectRatio;
+            var gridWidth = Math.min(viewBoundsWidth * this.ratio, maxWidth);
+            var gridHeight = Math.min(viewBoundsHeight * this.ratio, maxHeight);
+            var center = viewBounds.getCenterLonLat();
+            this.gridBounds = new OpenLayers.Bounds(
+                center.lon - (gridWidth / 2),
+                center.lat - (gridHeight / 2),
+                center.lon + (gridWidth / 2),
+                center.lat + (gridHeight / 2)
+            var rows = Math.floor(gridHeight / this.dy);
+            var cols = Math.floor(gridWidth / this.dx);
+            var gridLeft = origin.lon + (this.dx * Math.ceil((this.gridBounds.left - origin.lon) / this.dx));
+            var gridBottom = origin.lat + (this.dy * Math.ceil((this.gridBounds.bottom - origin.lat) / this.dy));
+            var features = new Array(rows * cols);
+            var x, y, point;
+            for (var i=0; i<cols; ++i) {
+                x = gridLeft + (i * this.dx);
+                for (var j=0; j<rows; ++j) {
+                    y = gridBottom + (j * this.dy);
+                    point = new OpenLayers.Geometry.Point(x, y);
+                        point.rotate(this.rotation, rotationOrigin);
+                    features[(i*rows)+j] = new OpenLayers.Feature.Vector(point);
+            this.destroyFeatures(this.features, {silent: true});
+            this.addFeatures(features, {silent: true});
+     * Method: invalidBounds
+     * Determine whether the previously generated point grid is invalid.
+     *     This occurs when the map bounds extends beyond the previously
+     *     generated grid bounds.
+     * Returns:
+     * {Boolean}
+    invalidBounds: function() {
+        return !this.gridBounds || !this.gridBounds.containsBounds(this.getViewBounds());
+    CLASS_NAME: "OpenLayers.Layer.PointGrid"
Modified: trunk/openlayers/lib/OpenLayers.js
--- trunk/openlayers/lib/OpenLayers.js	2011-06-17 17:12:01 UTC (rev 12098)
+++ trunk/openlayers/lib/OpenLayers.js	2011-06-17 18:18:40 UTC (rev 12099)
@@ -232,6 +232,7 @@
                 "OpenLayers/Renderer/Canvas.js",
                 "OpenLayers/Renderer/VML.js",
                 "OpenLayers/Layer/Vector.js",
+                "OpenLayers/Layer/PointGrid.js",
                 "OpenLayers/Layer/Vector/RootContainer.js",
                 "OpenLayers/Strategy.js",
                 "OpenLayers/Strategy/Filter.js",
Added: trunk/openlayers/tests/Layer/PointGrid.html
--- trunk/openlayers/tests/Layer/PointGrid.html	                        (rev 0)
+++ trunk/openlayers/tests/Layer/PointGrid.html	2011-06-17 18:18:40 UTC (rev 12099)
@@ -0,0 +1,231 @@
+<!DOCTYPE html>
+<html>
+<head>
+<script src="../OLLoader.js"></script>
+<script type="text/javascript">
+    function test_initialize(t) {
+        t.plan(1);
+        var layer = new OpenLayers.Layer.PointGrid();
+        t.ok(layer instanceof OpenLayers.Layer.PointGrid, "instance created");
+        layer.destroy();
+    function test_name(t) {
+        t.plan(1);
+        var layer = new OpenLayers.Layer.PointGrid({name: "foo"});
+        t.eq(layer.name, "foo", "name set like every other property");
+        layer.destroy();
+    function test_spacing(t) {
+        t.plan(7);
+            resolutions: [1],
+            maxExtent: new OpenLayers.Bounds(-100, -50, 100, 50),
+            dx: 10,
+            dy: 10,
+            ratio: 1
+        var map = new OpenLayers.Map({
+            div: "map",
+            layers: [layer],
+            zoom: 0
+        t.eq(layer.features.length, 200, "200 features");
+        // set dx/dy together
+        layer.setSpacing(20);
+        t.eq(layer.dx, 20, "dx 20");
+        t.eq(layer.dy, 20, "dy 20");
+        t.eq(layer.features.length, 50, "50 features");
+        // set dx/dy independently
+        layer.setSpacing(50, 25);
+        t.eq(layer.dx, 50, "dx 50");
+        t.eq(layer.dy, 25, "dy 25");
+        t.eq(layer.features.length, 16, "16 features");
+        map.destroy();
+    function test_ratio(t) {
+        t.plan(3);
+            resolutions: [1],
+            dx: 25,
+            dy: 25,
+            ratio: 1
+            div: "map",
+            layers: [layer],
+            zoom: 0
+        t.eq(layer.features.length, 32, "32 features");
+        // increase ratio (1.5 -> 300 x 150)
+        layer.setRatio(1.5);
+        t.eq(layer.ratio, 1.5, "ratio 1.5");
+        t.eq(layer.features.length, 72, "72 features");
+        map.destroy();
+    function test_maxFeatures(t) {
+        t.plan(3);
+            resolutions: [1],
+            dx: 10,
+            dy: 10,
+            ratio: 1
+            div: "map",
+            layers: [layer],
+            zoom: 0
+        // limit maxFeatures
+        layer.setMaxFeatures(150);
+        t.eq(layer.maxFeatures, 150, "maxFeatures 150");
+        t.ok(layer.features.length <= 150, "<= 150 features");
+        map.destroy();
+    function test_rotation(t) {
+        t.plan(6);
+            resolutions: [1],
+            dx: 10,
+            dy: 10,
+            ratio: 1
+            div: "map",
+            layers: [layer],
+            zoom: 0
+        function getRotation(layer) {
+            // grid starts at bottom left and goes up
+            var g0 = layer.features[0].geometry;
+            var g1 = layer.features[1].geometry;
+            // subtract 90 to get rotation of grid
+            return Math.atan2(g1.y - g0.y, g1.x - g0.x) * (180 / Math.PI) - 90;
+        t.eq(layer.rotation, 0, "0 rotation");
+        t.eq(getRotation(layer).toFixed(3), (0).toFixed(3), "0 grid")
+        // rotate grid 25 degrees counter-clockwise
+        layer.setRotation(25);
+        t.eq(layer.rotation, 25, "25 rotation");
+        t.eq(getRotation(layer).toFixed(3), (25).toFixed(3), "25 grid");
+        // rotate grid 45 degrees clockwise
+        layer.setRotation(-45);
+        t.eq(layer.rotation, -45, "-45 rotation");
+        t.eq(getRotation(layer).toFixed(3), (-45).toFixed(3), "-45 grid");
+        map.destroy();
+    function test_origin(t) {
+        t.plan(7);
+            resolutions: [1],
+            dx: 10,
+            dy: 10,
+            ratio: 1
+            div: "map",
+            layers: [layer],
+            zoom: 0
+        var origin = layer.getOrigin();
+        t.ok(map.getExtent().getCenterLonLat().equals(origin), "default is center of map extent");
+        t.eq((g0.x - origin.lon) % layer.dx, 0, "a) lattice aligned with origin x");
+        t.eq((g0.y - origin.lat) % layer.dy, 0, "a) lattice aligned with origin y");
+        // set origin
+        layer.setOrigin(new OpenLayers.LonLat(-5, 12));
+        origin = layer.getOrigin();
+        t.eq(origin.lon, -5, "-5 origin x");
+        t.eq(origin.lat, 12, "12 origin y");
+        g0 = layer.features[0].geometry;
+        t.eq((g0.x - origin.lon) % layer.dx, 0, "b) lattice aligned with origin x");
+        t.eq((g0.y - origin.lat) % layer.dy, 0, "b) lattice aligned with origin y");
+        map.destroy();
+    function test_zoom(t) {
+        t.plan(2);
+            resolutions: [2, 1],
+            maxExtent: new OpenLayers.Bounds(-200, -100, 200, 100),
+            dx: 20,
+            dy: 20,
+            ratio: 1
+            div: "map",
+            layers: [layer],
+            zoom: 1
+        t.eq(layer.features.length, 50, "50 features at zoom 1");
+        map.zoomTo(0);
+        t.eq(layer.features.length, 200, "200 features at zoom 0")
+        map.destroy();
+</script>
+</head>
+<body>
+<div id="map" style="width:200px;height:100px"></div>
+</body>
+</html>
Modified: trunk/openlayers/tests/list-tests.html
--- trunk/openlayers/tests/list-tests.html	2011-06-17 17:12:01 UTC (rev 12098)
+++ trunk/openlayers/tests/list-tests.html	2011-06-17 18:18:40 UTC (rev 12099)
@@ -156,6 +156,7 @@
     <li>Layer/MapServer.html</li>
     <li>Layer/Markers.html</li>
     <li>Layer/MultiMap.html</li>
+    <li>Layer/PointGrid.html</li>
     <li>Layer/PointTrack.html</li>
     <li>Layer/SphericalMercator.html</li>
     <li>Layer/Text.html</li>
More information about the Commits mailing list
