[OpenLayers-Commits] r12122 -
trunk/openlayers/lib/OpenLayers/Control
commits-20090109 at openlayers.org
Wed Jun 22 02:30:46 EDT 2011
Author: tschaub
Date: 2011-06-21 23:30:45 -0700 (Tue, 21 Jun 2011)
New Revision: 12122
trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js
Clarifying that the TouchNavigation control can be used without a standard Navigation control (closes #3350).
Modified: trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js
--- trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js 2011-06-22 06:04:10 UTC (rev 12121)
+++ trunk/openlayers/lib/OpenLayers/Control/TouchNavigation.js 2011-06-22 06:30:45 UTC (rev 12122)
@@ -15,6 +15,12 @@
* double-tapping, tap with two fingers, and pinch zoom). Create a new
* control with the <OpenLayers.Control.TouchNavigation> constructor.
+ * If you’re only targeting touch enabled devices with your mapping application,
+ * you can create a map with only a TouchNavigation control. The
+ * <OpenLayers.Control.Navigation> control is mobile ready by default, but
+ * you can generate a smaller build of the library by only including this
+ * touch navigation control if you aren't concerned about mouse interaction.
* Inherits:
* - <OpenLayers.Control>
More information about the Commits
