[OpenLayers-Commits] r12134 -
trunk/openlayers/lib/OpenLayers/BaseTypes
commits-20090109 at openlayers.org
Thu Jun 30 01:18:01 EDT 2011
Author: tschaub
Date: 2011-06-29 22:18:00 -0700 (Wed, 29 Jun 2011)
New Revision: 12134
trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
Syntax highlighting with (code)blocks(end).
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js 2011-06-30 05:15:02 UTC (rev 12133)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Bounds.js 2011-06-30 05:18:00 UTC (rev 12134)
@@ -16,10 +16,12 @@
* you should make sure you set them before using the bounds for anything.
* Possible use case:
- * > bounds = new OpenLayers.Bounds();
- * > bounds.extend(new OpenLayers.LonLat(4,5));
- * > bounds.extend(new OpenLayers.LonLat(5,6));
- * > bounds.toBBOX(); // returns 4,5,5,6
+ * (code)
+ * bounds = new OpenLayers.Bounds();
+ * bounds.extend(new OpenLayers.LonLat(4,5));
+ * bounds.extend(new OpenLayers.LonLat(5,6));
+ * bounds.toBBOX(); // returns 4,5,5,6
+ * (end)
OpenLayers.Bounds = OpenLayers.Class({
Modified: trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js
--- trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js 2011-06-30 05:15:02 UTC (rev 12133)
+++ trunk/openlayers/lib/OpenLayers/BaseTypes/Class.js 2011-06-30 05:18:00 UTC (rev 12134)
@@ -17,13 +17,17 @@
* will be removed.
* To create a new OpenLayers-style class, use the following syntax:
- * > var MyClass = OpenLayers.Class(prototype);
+ * (code)
+ * var MyClass = OpenLayers.Class(prototype);
+ * (end)
* To create a new OpenLayers-style class with multiple inheritance, use the
* following syntax:
- * > var MyClass = OpenLayers.Class(Class1, Class2, prototype);
- * Note that instanceof reflection will only reveil Class1 as superclass.
- * Class2 ff are mixins.
+ * (code)
+ * var MyClass = OpenLayers.Class(Class1, Class2, prototype);
+ * (end)
+ * Note that instanceof reflection will only reveal Class1 as superclass.
OpenLayers.Class = function() {
More information about the Commits
