[OpenLayers-Commits] r12136 - trunk/openlayers/lib/OpenLayers
commits-20090109 at openlayers.org
Thu Jun 30 01:31:42 EDT 2011
Author: tschaub
Date: 2011-06-29 22:31:41 -0700 (Wed, 29 Jun 2011)
New Revision: 12136
trunk/openlayers/lib/OpenLayers/Map.js
Correct formatting issues with map example (doc change).
Modified: trunk/openlayers/lib/OpenLayers/Map.js
--- trunk/openlayers/lib/OpenLayers/Map.js 2011-06-30 05:22:39 UTC (rev 12135)
+++ trunk/openlayers/lib/OpenLayers/Map.js 2011-06-30 05:31:41 UTC (rev 12136)
@@ -443,7 +443,7 @@
* provided or if you intend to call the <render> method later.
* options - {Object} Optional object with properties to tag onto the map.
- * Examples (method one):
+ * Examples:
* (code)
* // create a map with default options in an element with the id "map1"
* var map = new OpenLayers.Map("map1");
@@ -456,11 +456,8 @@
* projection: "EPSG:41001"
* var map = new OpenLayers.Map("map2", options);
- * (end)
- * Examples (method two - single argument):
- * (code)
- * // create a map with non-default options
+ * // map with non-default options - same as above but with a single argument
* var map = new OpenLayers.Map({
* div: "map_id",
* maxExtent: new OpenLayers.Bounds(-200000, -200000, 200000, 200000),
@@ -476,6 +473,7 @@
* units: 'm',
+ * (end)
initialize: function (div, options) {
More information about the Commits
